Old 1st March 2008, 02:08   #21  |  Link
Fugdefino
Tried converting mkv file with the following info. Resultant file doesn't play on PC or Xbox:
General #0
Format                       : Matroska
File size                    : 67.1 MiB
PlayTime                     : 1mn 1s
Bit rate                     : 9132 Kbps
Encoded date                 : UTC 2008-02-26 16:51:12
Writing application          : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library              : libebml v0.7.7 + libmatroska v0.8.1
Video #0
Codec                        : AVC
Codec/Family                 : AVC
Codec/Info                   : Advanced Video Codec
Codec profile                : High@L4.1
Codec settings, CABAC        : Yes
PlayTime                     : 1mn 1s
Bit rate                     : 8122 Kbps
Width                        : 1920 pixels
Height                       : 816 pixels
Display Aspect ratio         : 2.35
Frame rate                   : 23.976 fps
Chroma                       : 4:2:0
Interlacement                : Progressive
Audio #0
Codec                        : AC3
Bit rate mode                : CBR
Bit rate                     : 640 Kbps
Channel(s)                   : 6 channels
Channel positions            : Front: L C R, Rear: L R, LFE
Sampling rate                : 48 KHz
Language                     : English
Fugdefino is offline   Reply With Quote
Old 2nd March 2008, 19:53   #22  |  Link
miklg21
I'm running Vista and got a error with you new build.
this is the file I'm trying to convert.
General #0
Complete name : C:\Users\mike\Desktop\test\75 percent.mkv
Format : Matroska
File size : 1.52 GiB
PlayTime : 1h 56mn
Bit rate : 1863 Kbps
Movie name : Done with AutoMKV 0.95 http://forum.doom9.org/showthread.php?p=854221
Encoded date : UTC 2008-02-28 12:54:40
Video #0
Codec : AVC
Codec/Family : AVC
PlayTime : 1h 56mn
Bit rate : 1332 Kbps
Width : 720 pixels
Height : 480 pixels
Display Aspect ratio : 1.500
Standard : NTSC
Chroma : 4:2:0
Title : VTS_01_1
Writing library : x264 - core 58 svn-736M
Encoding settings : cabac=1 / ref=6 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=5 / me-prepass=0 / brdo=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=crf / crf=21.3 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.5:13.0
Audio #0
Codec : AC3
Bit rate mode : CBR
Bit rate : 448 Kbps
Channel positions : Front: L C R, Rear: L R, Subwoofer
miklg21 is offline   Reply With Quote
Old 2nd March 2008, 20:21   #23  |  Link
ZeroColl
Click details and send me that screen!
ZeroColl is offline   Reply With Quote
Old 2nd March 2008, 20:36   #24  |  Link
ZeroColl
Oh, and in most cases you should run this app as Admin.. didn't care to check why this is the case, but for me it works.
And for now the app almost always worked for me, the only problems were with some prison break episodes, no clue why.
Old 3rd March 2008, 06:49   #25  |  Link
miklg21
From the details
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.BadImageFormatException: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
at MediaInfoLib.MediaInfo.MediaInfo_New()
at MKVBoxer.MianBoxerForm.btnInfo_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
MKVBoxer
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/mike/Desktop/MKVboxer/MKVBoxer.exe
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Old 4th March 2008, 13:20   #26  |  Link
ZeroColl
Jep.. its the same problem someone else had.. you probably use the 32bit vista version?
In the buntle there is a 64bit MediaInfo.dll.. please download the 32bit mediainfo.dll and replace th eone provided in my package.
The link is somewhere in this topic.
Old 5th March 2008, 03:44   #27  |  Link
MachThree
It tells me I'm using the wrong audio or video codec, even though I'm using a Matroska file with x264 and AC3 streams. What's going on?
MachThree is offline   Reply With Quote
Old 5th March 2008, 09:20   #28  |  Link
Amir
Originally Posted by ZeroColl View Post
I'll look into the problem. The movie is spilt if the original is larger than 4GB since according to my info the XBOX 360 has problems playing non wmv files larger than that, it has nothing to do with the drive stored on.
An option to not split would be most welcome!... I've played 8GB files without issue myself, played via twonkymedia server btw.
Amir is offline   Reply With Quote
Old 5th March 2008, 09:38   #29  |  Link
ZeroColl
My problem is that I don't have your file to test it and determine what the problem is. Until now I never encountered such a problem if the file was in correct format. (You could tell me on PM what file so I can test it)
OK, I will ad that in the next release, after I sort out some other problems that people occasionally have.
Old 14th March 2008, 03:21   #30  |  Link
andyd2k
Thanks for this! I do have issues that hopefully can be addressed...
I was able to convert a file but it won't actually stream to my 360. I can see the file in the folder but all I get is a black screen when trying to play the file.
Now the problem here is that I know this was a issue when I was messing with mkv to mp4 a couple of months back - the level needs to be changed from 5.1 to 4.1.
I see that this is supposedly addressed but is this a definite? I can't actually run the file through h264 since the output file is avi
andyd2k is offline   Reply With Quote
Old 24th March 2008, 02:13   #31  |  Link
ZeroColl
the actual output file is an MP4 file, but for some (stupid) reason my system was set up so that WM didn't recognize the .mp4 files, but worked correctly with an avi extension.. so you can change this to .mp4 if you want to.
the 5.1 to 4.1 conversion is done (no actual conversion there only a change in the h264 file header) but i had also experienced some files (prison break) that wouldn't play.. try some other file, if the problem is still there I will try to find a solution.
But remember this is by no means a perfect solution, but for some weird reason it almost always works for me
Old 12th May 2008, 05:02   #32  |  Link
bradtn
Cant even click convert as soon as i do i get error
mscorlib
Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100)
MKVBoxer
CodeBase: file:///C:/Users/Brad/Desktop/MKVboxer/MKVBoxer.exe
System
System.Drawing
enabled.
For example:
<configuration>
</configuration>
any idea why? im on vista 32 bit
bradtn is offline   Reply With Quote
