20th November 2008, 09:11 | #1001 | Link |
likes to tinker
Thanks. The SetMTMode I'd thought just changed the mode back and forth (and I tended to have them at the start of each block of code, mostly snipped out of that sample)... and I was quite taken with the concept of MT, using it wherever I could since it was supposed to retain temporal position. Will give it a try. Still unsure why a scene change should cause the shudder.
Oh, and it used to be quite a speedy script too, by comparison Pity it didn't work as I'd hoped. Code:
Source Frames: 4355 original (borked) MT script best profile,fox1 matrix, encoding time: 0:02:56 (176.41 s) fps: 24.7 non-MT script best profile,fox1 matrix, encoding time: 0:03:56 (236.00 s) fps: 18.5 merlin7777 script best profile,fox1 matrix, encoding time: 0:03:24 (204.48 s) fps: 21.3 Last edited by halsboss; 20th November 2008 at 09:40. |
20th November 2008, 11:05 | #1003 | Link |
likes to tinker
Yes, thanks Merlin777, it did appear to fix it.
Here's an example of the issue showing out of order frames by a scene change, for that possible bug in MT/HCenc (it's possible it is the script, though... anyone spot the script error?) 3 images with MT http://rapidshare.com/files/165589313/mt2420.jpg http://rapidshare.com/files/165589314/mt2421.jpg http://rapidshare.com/files/165589315/mt2422.jpg and 3 images with NO MT http://rapidshare.com/files/165589316/nomt2420.jpg http://rapidshare.com/files/165589317/nomt2421.jpg http://rapidshare.com/files/165589318/nomt2422.jpg Last edited by halsboss; 20th November 2008 at 11:56. |
26th November 2008, 22:30 | #1004 | Link | ||
Interested Newbie
Hello guys. I'm trying to figure out this MT thingy.
Could this be the reason, why I experience absolutely no speedup when encoding to XviD (using VirtualDubMod)? |
26th November 2008, 23:07 | #1005 | Link |
x264aholic
If your filter chain is just mt("blur(1)",threads=2), you shouldn't expect any realistic speedup. It runs so fast on its own that MT'ing it provides no practical benefit.
You can't call your encoding speed slow until you start measuring in seconds per frame. |
26th November 2008, 23:22 | #1007 | Link | ||||
Interested Newbie
# Number of threads for multithreaded encoding mt_count = 4 # PLUGINS LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\MaskTools.dll") LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\Repair.dll") LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\RemoveGrain.dll") LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\FFT3DFilter.dll") LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\mvtools\mvtools.dll") LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\ChromaShift.dll") LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\VInverse.dll") LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\gradfun2db.dll") LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\mt_masktools-25.dll") LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\TTempSmooth.dll") LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\AddGrainC.dll") LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\Cnr2.dll") LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\TIVTC.dll") #LoadPlugin("E:\MyProgies\Ripping\GordianKnot\AviSynthPlugins\VScope.dll") # IMPORT Import("E:\MyProgies\Ripping\GordianKnot\AviSynthIncludes\MCTemporalDenoise.v1.0beta2.avsi") Import("E:\MyProgies\Ripping\GordianKnot\AviSynthIncludes\LimitedSharpenFaster.avsi") Import("E:\MyProgies\Ripping\GordianKnot\AviSynthIncludes\GrainFactory3.avsi") Import("E:\MyProgies\Ripping\GordianKnot\AviSynthIncludes\FixChromaBleeding.avsi") # Load AVI source clip AviSource("J:\Ripping\MasqueOfTheRedDeath-1989\capture.avi", true, "RGB24", fourCC="HFYU") # IVTC ConvertToYV12() tfm(pp=7, cthresh=8, chroma=true).tdecimate() Vinverse() # Shift chroma info left by 2 pixels MT("ChromaShift(C=-2)", mt_count, 2) # DENOISING MT("FFT3DFilter(sigma=3,plane=3,bt=5)", mt_count, 24) MCTemporalDenoise(settings="medium",chroma=true,stabilize=true,GPU=false) MT("""Cnr2("xxx", 4, 5, 255)""", mt_count, 24) # Remove chroma noise # Trimming & Cropping crop(0, 6, -4, -0) MT("Spline36Resize(512, last.height)", mt_count) MT("Spline36Resize(last.width, 384)", mt_count, splitvertical=true) # Correct Basic Video settings MT("""ColorYUV(off_y=-15, gain_y=+22, cont_v=-12.8, cont_u=-51.2, opt="coring")""", mt_count) MT("Tweak(bright=0, cont=1, hue=+4.5, sat=0.95, coring=false)", mt_count) # Add grain MT("GrainFactory3(g1str=4, g2str=5, g3str=16, g1shrp=30, g2shrp=40, g3shrp=50)", mt_count, 24) MT("FadeIO2(180)", mt_count) Quote:
That's why I am confused. |
27th November 2008, 10:00 | #1009 | Link | |
Interested Newbie
I'm still thinking that MT does not do anything. It calls SetMTMode(5) which is the slowest solution, even slower than not using MT. What sense does this make? Here are some encoding times for the above script: VirutalDubMod/Xvid using no MT at all: 18 hours VirutalDubMod/Xvid using MT() only (= above script): 18 hours VirutalDubMod/Xvid using SetMTMode(2) only: 16 hours Can you verify my following thoughts? AviSynth multithreading has basically nothing to do with multithreading XviD or x264. You can do one of the following 4: 1.) NO Avisynth MT + NO XviD MT (standard encoding) 2.) Avisynth MT + NO XviD MT 3.) NO Avisynth MT + XviD MT 4.) Avisynth MT + XviD MT NO Avisynth MT + XviD MT is basically the same as using Avisynth MT + NO XviD MT with SetMTMode() in AviSynth, because they both result in temporal multithreading. AviSynth MT + XviD MT is quite nonsense, because it uses multiple threads for creating XviD frames whereas every XviD thread in addition is split up into another threads at the level of AviSynth. Last edited by seggitek; 27th November 2008 at 11:45. |
29th November 2008, 14:45 | #1010 | Link | |
Interested Newbie
Now it looks like this: VirutalDubMod/Xvid using no MT at all: 18 hours VirutalDubMod/Xvid using MT() only (= above script): 16 hours VirutalDubMod/Xvid using SetMTMode(2) only: 16 hours Speedup is about 10%. Quite dissapointing. Maybe something is still wrong. |
29th November 2008, 18:04 | #1013 | Link |
x264aholic
It's possible. You have some really slow filters running though (FFT3DFilter, MCTemporalDenoise, GrainFactory). There's also a lot of temporal dependenices for the first two, so MT'ing them efficiently is difficult.
2nd December 2008, 14:18 | #1015 | Link | |
likes to tinker
Help ! MTi giving me unexpected results
When I use this script and alternate between the MTi line and the one under it, I get different results with what HCEnc thinks is the vertical size !.
SetMTmode(mode=5,threads=1) # start with mode=5 forAVIsource http://forum.doom9.org/showthread.php?p=1067216#post1067216 SetMemoryMax(256) AviSource("G:\HDTV\capt\capt-type1.08-11-30_20-39.00.avi", audio=false) AssumeFPS(25) AssumeBFF() original=LAST # snipped processing , just for testing # for MTi info refer http://avisynth.org/mediawiki/MT#Technical_info MTi("original").AssumeBFF() #HC tells me this is 720x1152 #original.AssumeBFF() #HC tells me this is 720x576 Converttoyv12(interlaced=true) SetPlanarLegacyAlignment(True) Distributor() # use this when using HC and SetMTmode, per http://forum.doom9.org/showthread.php?p=1063622#post1063622 Quote:
What am I doing wrong ? |
2nd December 2008, 15:03 | #1017 | Link |
likes to tinker
Oh. Thanks. Swapping between the two L1 lines confirmed I get different size results for each.
original=LAST L1 = MTi("original.MVDegrain1i2_insideMTi(doAGC=FALSE)") #L1 = MTi("last.MVDegrain1i2_insideMTi(doAGC=FALSE)") L1 function AGCiEmbedded(clip srcclp) { inpclp = srcclp #inpclp=inpclp.HDRAGC(coef_gain=1.0, coef_sat=1.0) # default. +coef_gain=brighter decrease to limit. +coef_sat=more saturation #inpclp=inpclp.HDRAGC(coef_gain=0.1, coef_sat=1.0) # default. +coef_gain=brighter decrease to limit. +coef_sat=more saturation #inpclp=inpclp.HDRAGC(coef_gain=0.2, coef_sat=1.0, corrector=0.8, reducer=2.0) # default. +coef_gain=brighter decrease to limit. +coef_sat=more saturation #inpclp=inpclp.HDRAGC(coef_gain=0.2, min_gain=0.1, max_gain=1.0, coef_sat=1.0, corrector=0.8, reducer=2.0) # default. +coef_gain=brighter decrease to limit. +coef_sat=more saturation #inpclp=inpclp.HDRAGC(coef_gain=0.2, min_gain=0.1, max_gain=1.0, coef_sat=1.0, corrector=0.8, reducer=2.0, black_clip=0.5) # default. +coef_gain=brighter decrease to limit. +coef_sat=more saturation inpclp=inpclp.HDRAGC(coef_gain=0.1, min_gain=0.1, max_gain=0.5, coef_sat=0.75, corrector=0.8, reducer=2.0, black_clip=1.0) #inpclp=inpclp.HDRAGC(coef_gain=0.1, min_gain=0.1, max_gain=0.5, coef_sat=1.0, corrector=0.8, reducer=2.0, black_clip=1.0) #inpclp=inpclp.HDRAGC(coef_gain=0.1, min_gain=0.2, max_gain=1.0, coef_sat=1.0, corrector=0.8, reducer=2.0, black_clip=1.0) return inpclp } function MVDegrain1i2_insideMTi(clip srcclp, int "blksize", int "overlap", int "dct", bool "doAGC") { doAGC=default(doAGC,TRUE) # AssumexFF() must have been done prior to calling this function blksize=default(blksize,8) # # 4, 8 or 16 ( default is 8 ). Larger blocks are less sensitive to noise, are faster, but also less accurate. overlap=default(overlap,2) # overlap value (0 to 4 for blksize=8) Must be even and less than block size dct=default(dct,0) # use dct=1 for clip with light flicker fields=srcclp # FIELDS ALREADY SEPARATED BY MTi SO DON'T DO HERE super = fields.MVSuper(pel=2, chroma=true, sharp=2) # half-pixel accuracy of the motion estimation backward_vec2 = super.MVAnalyse(isb = true, delta = 1, blksize=blksize, overlap=overlap, dct=dct, chroma=true) forward_vec2 = super.MVAnalyse(isb = false, delta = 1, blksize=blksize, overlap=overlap, dct=dct, chroma=true) fields=fields.MVDegrain1(super, backward_vec2,forward_vec2,thSAD=400,plane=4) doAGC ? fields.AGCiEmbedded() : fields # FIELDS WILL BE RE-WEAVED by MTi SO DON'T DO IT HERE } |
2nd December 2008, 15:33 | #1018 | Link | |
Avisynth language lover
Both your L1 lines are wrong, the second one works by accident because "last" is not the value at the point of calling MTi, but the value inside MTi when the string is evaluated. What you actually want is Code:
L1 = original.MTi("MVDegrain1i2_insideMTi(doAGC=FALSE)") |
3rd December 2008, 12:58 | #1019 | Link | |
likes to tinker
Yes, thankyou, that seems to clear that up. Now for a strange one...
In the script below, the L1, L2, L3 items work fine (un-commenting out , re-commenting-out) but L4 doesn't and throws the error message Quote:
original=LAST #L1 = original.SeparateFields().HDRAGC(coef_gain=0.1, min_gain=0.1, max_gain=0.5, coef_sat=0.75, corrector=0.8, reducer=2.0, black_clip=1.0).Weave() #L2 = original.MTi("HDRAGC(coef_gain=0.1, min_gain=0.1, max_gain=0.5, coef_sat=0.75, corrector=0.8, reducer=2.0, black_clip=1.0)") #L3 = original.SeparateFields() #L3e = L3.SelectEven().AGCiEmbedded() #L3o = L3.SelectOdd().AGCiEmbedded() #L3 = Interleave(L3e,L3o).Weave() L4 = original.MTi("AGCiEmbedded()") #L1 #L2 #L3 L4 function AGCiEmbedded(clip srcclp) { inpclp = srcclp # other processing inpclp=inpclp.HDRAGC(coef_gain=0.1, min_gain=0.1, max_gain=0.5, coef_sat=0.75, corrector=0.8, reducer=2.0, black_clip=1.0) return inpclp } Last edited by halsboss; 3rd December 2008 at 13:21. |
3rd December 2008, 15:09 | #1020 | Link |
Very odd. I too would have expected it to work.
What happens if you change the function to Code:
function AGCiEmbedded(clip srcclp) { return srcclp.HDRAGC(coef_gain=0.1, min_gain=0.1, max_gain=0.5, coef_sat=0.75, corrector=0.8, reducer=2.0, black_clip=1.0) } |
