Old 30th April 2014, 10:28   #2181  |  Link
xkinn123
Selur, i've had a problem
on linux64, i can't extract subtitle attachment from mkv...
please fix that..
xkinn123 is offline   Reply With Quote
Old 30th April 2014, 10:30   #2182  |  Link
Selur
Selur's Avatar
debug output?
Old 30th April 2014, 14:20   #2183  |  Link
xkinn123
Originally Posted by Selur View Post
debug output?
here it go...
Old 30th April 2014, 15:20   #2184  |  Link
Selur
Selur's Avatar
a. re-read on how to create the debutoutput, the debut output you posted is too short.
b. use the latest version
c. for subtitle problem please create a debut output with level 5
Old 30th April 2014, 18:27   #2185  |  Link
xkinn123
a. because it's level 4(?)
b. it is.
c. here it goes...
Old 30th April 2014, 18:33   #2186  |  Link
Selur
Selur's Avatar
No because it doesn't include the analysis&co.
b. it is.
Current version is "2014.04.28.1" according to the log you used "2014.04.23.1"
c. here it goes...
will look at it once a moderator approves it (and I'm aware of that approval)
Old 30th April 2014, 18:38   #2187  |  Link
@all
No help to be given to xkinn123 on his issue, as he is discussing rule 6 material.
Old 30th April 2014, 18:40   #2188  |  Link
Selur
Selur's Avatar
Sorry, xkinn123.
Old 11th May 2014, 15:40   #2189  |  Link
VoxMix
hi
hybrid dont start in my system and show this error:
kvazaar.exe - Application Error
The application was unable to start correctly (0xc000007b). Click OK to close the application.
OK
How I fix this
VoxMix is offline   Reply With Quote
Old 11th May 2014, 16:44   #2190  |  Link
Selur
Selur's Avatar
a good start would be to provide at least some basic infos about your system,....
uploaded MinGW build binaries to: http://www.embedupload.com/?d=6RM0BMGZEB
Old 12th May 2014, 08:27   #2191  |  Link
VoxMix
Thank you so much Selur!
my problem fix
hybrid is wonderful GUI , i love it
Old 21st May 2014, 06:09   #2192  |  Link
MichaelRow
MichaelRow's Avatar
Hi, Selur.
It seems that the zone editor doesn't work, or is my setting wrong?
type:constant rate fator
Mod/quant:16
MichaelRow is offline   Reply With Quote
Old 21st May 2014, 06:34   #2193  |  Link
Selur
Selur's Avatar
will look into it (haven't used the zones for ages )
-> found the bug (a missing not), if you tell me what OS you are using I can build and send you a link to a dev version which should fix the problem
Old 21st May 2014, 12:39   #2194  |  Link
DJ-1
Hi, just a quick one. In the resize section of Hybrid is the Lanzsos option a certain version of it or is the Lanzsos 2, 3, 3 optimised, 4 etc... Or are theses just 'playback types(realtime iterations of Lanszos?)
Cheers.
Sent from my HTC One using tapatalk
DJ-1 is offline   Reply With Quote
Old 21st May 2014, 12:44   #2195  |  Link
Selur
Selur's Avatar
when Avisynth is used: lanczos <> LanczosResize(...)
when mencoder is used: lanczos <> -sws 9
when ffmpeg is used: lanczos <> -sws_flags lanczos
no clue if they all use the same or different lanczos implementations
Old 21st May 2014, 15:23   #2196  |  Link
DJ-1
Ok ta... When is the nnedi3 used, I don't remember seeing it in hybrid.... I may be wrong but think it's a resizer used when Qtgmc is active?... Forgot now..
Cheers.
Sent from my HTC One M8 using tapatalk
Old 22nd May 2014, 06:09   #2197  |  Link
MichaelRow
MichaelRow's Avatar
OS X 10.9.3
Thanks
Old 23rd May 2014, 09:24   #2198  |  Link
DJ-1
Hi, if I wanna try out other deinterlacing options, mcbob for instance, can I just drop the plug in & its dependencies into the avisynth plug in folder & go. Or hybrid not like that?
Cheers.
Old 8th June 2014, 19:44   #2199  |  Link
Selur
Selur's Avatar
Hybrid rev 2014.06.08.1:
*added*
  • avisynth: support for aWarpSharp sharpening
  • avisynth: tivtc now also allows QTGMC 'slow' and 'Very Slow' as deinterlacer
  • avisynth: 'add custom content', allows to add content to Hybrids avisynths scripts;
    WARNING: Hybrid does not check/verify the content of the entry, so if you mess up, you are on your own!
  • Kvazaar: support for RDO quantization
  • x265: support for 4:2:2 color space
  • x265: support for '--[no-]repeat-headers'
  • x265: support for '--psy-rdo X';
  • x265: adjusted to new preset&tune values -> It's recommend to reset the x265Model
    WARNING: This option is known to produce artifacts in some cases!
*changed*
  • avisynth: set MTMode to 5 before LibAVVideoSource
  • avisynth: enable "Disable distributor()' for Windows 8 & 8.1, by default, for all others disable it by default
  • avisynth: fixed links which linked to avisynth.org
  • avisynth: allow distributor() even for avisynth preview
  • input: improve mpls handling
  • jobs: make sure there will be no job creation if .m4v is used as output extension while 'Audio handling' isn't set to ignore. Added awarning about it and how to avoid it and still create .m4v output.
  • DivX265: use DivX265 'resolution profiles' internally and enforce them
*fixed*
  • audio: mp4 audio extraction name problem (on Windows)
  • avisynth: force deinterlace + Avisynth-Deinterlacer sometimes didn't force deinterlacing
  • avisynth: RGBColorAdjust Filter-Preview
  • avisynth: ColorMatrix Avisynth/Filter-Preview
  • avisynth: bug could cause distributor() to be added, even when 'Disable distributor()' was enabled
  • avisynth: reset 'need avisynth'-checks
  • avisynth: fixed HQDering call
  • decode: mencoder 422 output and color space mixup using mencoder
  • DivX265: use constant quantizer '-qp' instead of '--cq'
  • filtering: mcdeint -> framestep didn't update the gui
  • input: monitoring folder support
  • jobs: check whether FRAPS is installed on the system or not
  • x265: 12bit encoding
  • mux: mp4box didn't always use short file names on Windows which could cause problems with unicode names&paths
  • mux: tsMuxeR set disklabel for isos
-> downloads: http://www.selur.de/downloads
Cu Selur
Old 9th June 2014, 22:50   #2200  |  Link
digitall.h
Great!, good news!
Already downloaded, I will try and test ASAP.
...I was missing your releases.
I suppose that real life take a lot of our time.
digitall.h is offline   Reply With Quote
