1st March 2007, 21:36 | #41 | Link | |
Curious BetaTester
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=27067 regarding gcc 4.3 did you update to the latest binutils - with patched winres? hope devs include the patch in 4.2 & 4.3 has they did not with gcc 4.1.2 i'll dig a bit further to see whats up, cheers
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC |
1st March 2007, 21:39 | #42 | Link | |
Curious BetaTester
cheers
2nd March 2007, 02:39 | #43 | Link |
i did not do any patches at all. i compiled 4.2 successfully from yesterdays svn with:
../gcc-4.2.0/configure -v --enable-optimize --enable-languages=c,c++ --prefix=/mingw \ --enable-threads --oldincludedir=/mingw/include --disable-shared \ --with-cpu=prescott --with-arch=prescott --with-tune=prescott \ --with-ld=/mingw/bin/ld.exe --with-as=/mingw/bin/as.exe --disable-checking \ --without-x --disable-win32-registry --disable-nls --disable-werror --disable-libssp make "CFLAGS=-O3 -march=prescott -mtune=prescott -msse -msse2 -msse3 -mmmx" "LDFLAGS=-s" as for 4.3, the snapshot from back in december works with out any problems. the current svn doesnt work. i think the reason why is because they moved things around and created a libgcc folder which is whats causing my problem (atleast one of them). i think something is screwed up with the way they do the dependancys for it creating the .dep files and not deleting them. what im probably going to do is see the exact point they did that move and then try to get an svn of the version right before it (maybe ill go back a few from that just to be safe) and see if it works. wish me luck, ill let ya know how it goes. |
2nd March 2007, 02:56 | #44 | Link |
sorry missed your point bout binutils...i pulled an svn down like 3 days ago and successfully built and installed that so i believe that should be good (unless the patch is something i have to add on top of that). afaik binutils has things like ar and ld, so below are my version info on those. im rebuilding/installing them from the most current svn now just incase althoguh i doubt it will do anything for me.
GNU ld version 2.17.50 20070228 GNU ar 2.17.50 20070228 |
2nd March 2007, 03:49 | #45 | Link | |
Curious BetaTester
the gcc 4.2 patch i was talking about fixes a problem about 'thunk alias's' - it was working in gcc 4.0 branch put they broke or changed something in gcc 4.2 and gcc 4.3 - so you might have problems compiling somethings looking at your config sames like you can't it any faster, maybe if you use profiledbootstrap (but thats a different ball game - should be docs floating around about it) you could re-compile gcc 4.2 with 'make bootstrap' just to check for errors cheers
2nd March 2007, 09:00 | #47 | Link |
its officially 3am but i just thought id post this up for now...ill explain tomorrow morning when I am consious
$ gcc --version gcc.exe (GCC) 4.3.0 20070301 (experimental) |
2nd March 2007, 19:22 | #48 | Link |
so interesting quirk. mplayer wont compile at -O0 or -O4 but does on -O1
i get an "'asm' operand has impossible constraint" error with libavcodec/i386/dsputil_mmx.c on line 636 (that matches the first asm volatile call in static inline void transpose4x4). my quick searching on google shows that this could be a gcc 4.2/4.3 error however i also found something on the gcc buglist about a similar file/problem from oct 2006 (h264.c http://gcc.gnu.org/bugzilla/show_bug.cgi?id=29440) and this is exhibiting identical signs. any advice? EDIT: so yea...seems that it works...sometimes. its kinda weird...ive run it now twice at -O4 with no changes to the system at all and it worked once and failed once...im doing more runs with different options on the gcc line to see what caused the failure... EDIT2: ok ignore the whole thing bout -O what ever...it was crashing only when using "-march=core2 -mtune=core2" however i tested it on prescott and that worked...im looking more into it. im thinking the way i built/optimized 4.3 may have had something to do with it so im making another build now that is completely unoptimized to double check. Last edited by morph166955; 2nd March 2007 at 20:12. |
3rd March 2007, 01:16 | #49 | Link | |
Curious BetaTester
also there's 'make check' but you need some others files, i think dejagnu i've just trying to do a cross-compile with linux - not had much look yet cheers
3rd March 2007, 01:56 | #50 | Link |
ive run make bootstrap and it works also. im attempting a cygwin cross-compile now (im still at the stage that im compiling/loading gmp,bison, etc). i can get 4.3 to compile and work when its in "prescott mode" its just agrivating that i cant get libavcodec to compile with core2 set.
the other issue im still having (and i loaded the binutils from sf.net already as well as my own) is that when gcc is run with -MM i still get output that has C:/msys... in it. the colon is whats causing my problem cause for some reason it isnt converting that to /c/msys and im not sure how to force that to do it. im kinda stumped on that one and i think if i fixed that then things would be much easier in this build for me. |
3rd March 2007, 02:51 | #51 | Link | |
Curious BetaTester
3rd March 2007, 03:02 | #52 | Link |
Curious BetaTester
just found that compiling gmp & mfpr using gcc-4.1.2, fail the 'make check' so the libs can't be trusted - they are fine using gcc-4.0.4
3rd March 2007, 20:12 | #53 | Link |
i havent patched it yet no...i was waiting to get a vanilla version working before going any further with patches and such. My cygwin cross-compile failed but I think its cause my cygwin isnt setup properly (ive never used it before and I just installed it).
I have a freebsd 6.1 box that im going to try to compile it on today to see if that works. assuming I can get it working I'll be happy although I have a feeling that I'm going to have a similar problem that I have now. I'm probably going to end up upgrading that box to have 4.3 locally so that it can create my core2 optimized version of 4.3 for mingw after that works. |
4th March 2007, 03:45 | #54 | Link |
Curious BetaTester
i've successfully cross-compiled gcc 4.0.4 using linux, i'll post a guide soon - more testing first
then i'll try doing a cross-compiled 4.2 & 4.3 cheers
4th March 2007, 03:55 | #55 | Link |
can you by chance give me a cliff notes of what you did or at least your configure line to use as a base? i JUST finished upgrading gcc natively on my bsd box and im getting ready to do the cross compile in the next half hour.
4th March 2007, 04:16 | #56 | Link | ||||
Curious BetaTester
cross-compile
it's tricky -- tuck about 2days of re-learning
you will need bison,flex libtool, and maybe others first you compile binutils with Quote:
then PATH=$PATH:/mingw/bin (so it knows where the new mingw32-cross is) then you need mingw32-includes & libs in the correct folder eg. /mingw/i686-pc-mingw32/ then compile gcc with Quote:
then CC=/usr/bin/gcc and re-compile with Quote:
4th March 2007, 04:58 | #58 | Link |
Curious BetaTester
build=is always the systems-compiler
host=is what system its going to run on target=create code for the desired system cross-compile is the target=mingw and build=system(as it needs to run the code it makes) and target=mingw so the last step is a cross-compiler that can on run on its own system and produce=mingw too there's plenty of docs on the net but hard to follow, as there scripts what never work for me cheers
4th March 2007, 05:06 | #59 | Link |
well thats my point...none of the docs i have read online including whats on the mingw site have said anythingabout that last step that i was asking about...atleast not anything to do with changing build...i think one showed doing something to host.
4th March 2007, 05:15 | #60 | Link |
king.dev
good,I will try to compile
http://quiclive.com |
