Old 24th June 2009, 09:38   #1  |  Link
Sidi
H.264 scaled decoding?
Does anybody know if is it possible to improve H.264 decoding performance in simmilar manner than JPEG? I mean scaling during decode (for example to 1/8), which speeds up at least two times on IJL. Is there any decoder that supports anything like this?
Or is there any other mean of making this process faster (other than I-Frame decoding only), even with lower quality? Lets say it is Baseline H.264.
Sidi is offline   Reply With Quote
Old 25th June 2009, 21:09   #2  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
One way that I know of is to turn in-loop deblocking off.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 25th June 2009, 21:21   #3  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
It should be noted that turning off in-loop deblocking for a H.264 stream that was encoded with in-loop deblocking enabled, will not only cause more visible blocks. It will cause corrupted output! That's because deblocking is part of H.264 encoding process. P-Frames and B-Frames reference deblocked frames. Skipping the deblocking causes "wrong" references frames, so the error sums up from frame to frame...
Old 30th June 2009, 15:06   #4  |  Link
Shevach
Video compressionist
More idea.
You can discard pictures which are not used for reference (provided that an input stream contains non-reference pictures).
Shevach is offline   Reply With Quote
Old 30th June 2009, 15:46   #5  |  Link
LoRd_MuldeR
Software Developer
Why should a stream contain pictures that are neither referenced nor displayed?
I think any picture, referenced or not, will be displayed at least. So you can't simply "discard" any pictures.
That would result in missing pictures and produce jumpy output!
What you can do: Skip the deblocking part on non-referenced pictures (all b-frames, unless b-pyramid is used).
Old 1st July 2009, 07:40   #6  |  Link
Shevach
Perhaps I was mis-understood.
I suggested to discard pictures which are not used for reference despite these pictures are displayed. Thus the decoding process can be accelerated.
I think this is a popular action implemented in many decoders to cope with performance peaks.
Frankly speaking a stream can contain dangling fields which some decoders do not display.
Old 1st July 2009, 15:18   #7  |  Link
LoRd_MuldeR
Software Developer
So you want to "discard" pictures that are not used for reference. But you still want to display these pictures
How do you want to display a picture that has been discarded ???
As said in my previous post: I believe the only the thing you can do is skipping the deblocking on non-referenced frames, but not discard those frames entirely!
Furthermore I think skipping the deblocking on non-referenced frames won't give that much speed-up. The only frames that aren't referenced are b-frames.
And even that is only the case with b-pyramid disabled. With b-pyramid b-frames may be referenced by other b-frames as well.
Last but not least deblocking is not the most compute-intensive task. CABAC decoding is, given that CABAC is used...
Old 1st July 2009, 15:42   #8  |  Link
nm
No, he suggested skipping those frames completely, i.e. dropping them within the decoder. As you said, this causes jumpiness, but one could argue that it's still "improved decoding performance at lower quality".
Edit: By the way, libavcodec already does have this option. Try -lavdopts skipframe=nonref with MPlayer.
The relative time required for these tasks depends a lot on the frame resolution and bitrate though. I'd guess that at low bitrates deblocking would be harder than CABAC with current software implementations.
Old 1st July 2009, 15:59   #9  |  Link
LoRd_MuldeR
Software Developer
That's true. Some dropped frame here and there may still be better than a complete desync.
Yeah, but I think decoding performance hardly becomes a problem for SD content. More for HD content (720p or 1080p).
And then the bitrate probably is high enough to make CABAC the performance bottleneck...
Old 2nd July 2009, 11:03   #10  |  Link
Shevach
Nm is right. I suggested to discard non-reference pictures and consequently don't display them.
Before discarding of pictures a decoder should care the very particular case when in a single complementary field pair one field is used for reference while another not. Indeed, in such case how the frame can be displayed if one of the two fields is absent.
As usual a removal of non-reference frames causes jerkiness artifacts. Although in case of significant motion or a scene cut the removal several frames is not noticeable.
decoding, scaling, speed
