26th March 2015, 09:53 | #7821 | Link | |
Thanks. |
26th March 2015, 10:01 | #7822 | Link |
I wonder if that warning can be circumvented by explicitly adding "--profile high[10]" to the 1st pass call when these parameters with maximum VBV values are added too.
__ P.S.: Just discussed briefly in IRC, turbo 1st pass always assumes Main Profile because 8x8dtc is disabled. This warning has a minor relevance, VBV values don't matter much during a 1st pass. Last edited by LigH; 26th March 2015 at 10:09. |
26th March 2015, 21:36 | #7824 | Link | |
my megui suddenly stopped working. upon program start megui says that "Fatal Error. megui encountered a fatal errorr and may not be able to proceed. reason:index was outside the boundaries of the array". if i click ok, program closes immetiately.
26th March 2015, 22:10 | #7825 | Link | |
Thanks. |
27th March 2015, 20:02 | #7826 | Link |
Maybe this is a stupid question, but I have to ask it to learn: if I add, say, 8 GB of RAM, will encoding wth MeGUI be any faster? I already have a good CPU (4.0 GHz) and 8 GB of RAM.
Would the improvement from 8 GB of RAM be trivial as maybe MeGUI only uses the CPU? Or would it help a lot and I could grasp a good number of FPS? Thank you. |
29th March 2015, 13:13 | #7829 | Link | |
http://megui.org/auto/megui-core_2525.zip Does it fix the problem? |
30th March 2015, 11:46 | #7830 | Link | |
30th March 2015, 23:42 | #7831 | Link |
Hi everyone,
I get this frustrating mkvmerge error occasionally after encoding videos (without adding their audio tracks) using x264 Encoder (which I need) then muxing the result with the audio from the file source. "video.720p.mkv: Error in the Matroska file structure at position 4010858. Resyncing to the next level 1 element. The last timecode processed before the error was encountered was 00:00:19.978000000. Resyncing successful at position 4782373. The first cluster timecode after the resync is 00:00:25.025000000." Now when the video reaches the defective minutes, the picture freezes with continuous audio until the point of the first cluster timecode arrives! If the error doesn't show up in mkvmerge, the muxed file will probably get the same issue! I tried the old versions of mkvmerge to be sure but got the same error, so it must has something to do with MeGUI encoding process. I'm using v2525 of MeGUI with updated components and even tried reinstalling it along with K-Lite Mega Codec Pack but sadly that didn't help either! Any tip would be greatly appreciated. Thanks a bunch! Cheers, Salaam |
31st March 2015, 05:59 | #7832 | Link |
Hello and thanks in advance for any help, and an Extra Big thanks for MeGUI . I have a simple question: is there a built in feature--or can anyone think of a way--to make MeGUI "pause" or "rest" for a selectable amount of time between queued jobs? I ask because often I'm away from home for weeks at a time and I'd love to have MeGUI chug away at my collection of sources to be encoded, but with MT AviSynth I'm able to achieve 100% CPU usage and I figure that it's not necessarily a good idea to have my CPU running at 100% for 10+ straight days. I've been queuing enough jobs to keep my computer busy for around 3 days straight without apparent issue, but if I could queue, for example, 2 days worth of jobs, then queue a 12 hour break, then repeat I'd be very pleased. I searched for an answer without success, but probably because I'm using the wrong terms. Any relevant input is much appreciated, thanks for your time.
31st March 2015, 06:11 | #7833 | Link | |
In the past I've occasionally experienced a similar problem, without an error message, and after much effort I've decided that it was some combination of fragmented files (my storage drive's an HDD) and poor mkv muxing. Since then I've kept my storage drive defragmented (defragmenting the sources before muxing) and checked the mkv files (sampling the audio-video sync at the beginning, middle, and end of the mkv) after muxing and before encoding, and I've not experienced this problem since. |
31st March 2015, 08:47 | #7834 | Link | |
A Man Eating Duck |
31st March 2015, 09:36 | #7835 | Link |
Thanks for your reply, AMED, I appreciate it, and my computer is already obsolete, ha ha, but it's the only one I have. Define "ok"? It's a laptop, elevated on an open aluminum pad. with a small fan blowing down on it from above. I live in the tropics and can't leave the A/C running when I'm not home. I understand where you're coming from, but I'd still prefer to give it a rest every two or three days. Any thought on how to do that with MeGUI? Some kind of dummy file? Anything?
1st April 2015, 01:36 | #7837 | Link | |
Thanks for the input. |
1st April 2015, 02:19 | #7838 | Link |
AMED: I understand that, but it's not possible. The point of my original post was that I'm not home to queue smaller batches so I'm looking for a way to add a "dummy" encode, or some such, to rest the CPU for half a day every couple days in a one to three week queue. I wouldn't have the question if I was home to tend the queue .
salam2009: sorry that didn't help, I wish I knew more. Last edited by LouieChuckyMerry; 1st April 2015 at 02:21. |
1st April 2015, 09:18 | #7839 | Link |
l-smash
Guys I am using following profile in avisynth script creator for files I indexed using l-smash with Megui File Indexer.
<input> AudioDub(last, LWLibavAudioSource("source location", av_sync=true)) AssumeTFF() Trim(111,222) ++ Trim(333,444) Audio=KillVideo() AudioDub(last,Audio) Load_Stdcall_Plugin("C:\Program Files\MeGUI\tools\yadi\yadif.dll") Yadif(order=-1) crop(2, 2, -2, -2) Spline36Resize(720,400) # Spline36 (Neutral) Import("C:\Program Files\MeGUI\tools\avisynth_extra\_load\degrain.avs") Code:
LoadPlugin("C:\Program Files\MeGUI\tools\avisynth_extra\TTempSmooth\TTempSmooth.dll") ttempsmooth() LoadPlugin("C:\Program Files\MeGUI\tools\avisynth_extra\RemoveGrain\RemoveGrainSSE3.dll") RemoveGrain(mode=1) Where is this lag coming from? I have never experienced it with with files indexed with DGIndex* tools. Megui version - 2525 L-smash version - r784 |
1st April 2015, 10:20 | #7840 | Link |
Some source formats are easier to index than others, especially when they already contain a keyframe index which can be read separately (e.g. AVI, MKV); for more broadcast oriented containers without such index chunks (especially TS), an indexer application has to follow the whole file, trying to demultiplex the streams and looking for starts of decodable blocks in each stream, which is a lot more elaborate.
Indexers supporting only a small range of input formats (few containers, one video stream only) may be faster (ignoring unsupported streams) than more generic indexers supporting a wider range (more containers, several audio streams too, maybe even subtitles). |
megui |
