Old 11th May 2008, 22:30   #21  |  Link
Chainmax
Huh?
Chainmax's Avatar
I second that request, I'd like to try this filter out on some digicam footage and compare it to HDRAGC.
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it.
Chainmax is offline   Reply With Quote
Old 12th May 2008, 01:10   #22  |  Link
NormanBates
NormanBates's Avatar
I found Autolevels v0.3 on my hdd and uploaded it for you.
Here is the link:
http://www.sendspace.com/file/7i6yx0
NormanBates is offline   Reply With Quote
Old 12th May 2008, 01:26   #23  |  Link
unskinnyboy
unskinnyboy's Avatar
Here is the link:
This does seem the latest version!
unskinnyboy is offline   Reply With Quote
Old 12th May 2008, 03:49   #24  |  Link
AlanHK
Originally Posted by unskinnyboy View Post
Does anyone have a working version of the latest version of Autolevels? If so, can they upload it somewhere, please? The previous URL is dead, and this don't seem to be hosted anywhere else.
Attached.
But as you see above, I didn't have much luck with it.
AlanHK is offline   Reply With Quote
Old 12th May 2008, 04:09   #25  |  Link
unskinnyboy
AlanHK, Try the version NormanBates linked above. It works fine for me. Maybe yours is a corrupted version?
Old 12th May 2008, 04:23   #26  |  Link
AlanHK
They're identical.
Old 12th May 2008, 04:52   #27  |  Link
unskinnyboy
Originally Posted by AlanHK View Post
They're identical.
OK. Your attachment was unapproved (still is) when I posted my earlier reply, so I wasn't sure if it was. Not sure what your issue is then, sorry. Sure is specific to just you though. Works for me on my current Vista machine, and it used to work on my previous XP machine too (before it crashed a few months ago, that is).
Old 7th August 2008, 00:13   #28  |  Link
chriszxl
Little red-cap
chriszxl's Avatar
links did not work............
chriszxl is offline   Reply With Quote
Old 9th August 2008, 07:30   #29  |  Link
NormanBates
Again:-)
Here two links:
http://www.sendspace.com/file/z16kmr
http://rapidshare.com/files/13597845...ls0.3.zip.html
Old 19th August 2008, 01:58   #30  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
direct download: http://www.webalice.it/f.corriga/misc/autolevels0.3.zip
Old 13th September 2008, 01:14   #31  |  Link
dreamy83
URL is dead can some1 upload autolevels again
thanks
dreamy83 is offline   Reply With Quote
Old 13th September 2008, 02:04   #32  |  Link
Nightshiver
Quality Freak
No it's not. Use the direct download link from Sharky, it still works.
Nightshiver is offline   Reply With Quote
Old 13th September 2008, 03:01   #33  |  Link
AlanHK
The file attached to my post above is okay.
Old 14th September 2008, 23:13   #34  |  Link
IYG
What is this filter's advantage?
IYG is offline   Reply With Quote
Old 19th May 2009, 21:48   #35  |  Link
carlmart
Carlos Martinez
I would like to know what are the parameters to load on autolevels. The link is dead.
Any suggestions?
carlmart is offline   Reply With Quote
Old 19th May 2009, 22:09   #36  |  Link
sidewinder711
near the waterfront
sidewinder711's Avatar
Here you go:
http://www.mediafire.com/?ywjkgzmclgy
Cheers!
sidewinder711 is offline   Reply With Quote
Old 3rd August 2009, 21:03   #37  |  Link
EugenSU
Something wrong occurs to colours after the filter. The picture is constantly painted in any colour. Has submitted on an input a black-and-white picture. On an exit has received floating displacement of colours. U and V components constantly float. I work with normal YUY2.
EugenSU is offline   Reply With Quote
Old 29th October 2010, 22:52   #38  |  Link
frustum
The wiki
http://avisynth.org/mediawiki/External_filters
says that autolevels works on YV12, YUY2, RGB32, RGB24 format pixels.
Certainly it works on YV12. If I convertToRGB24() before autolevels, it still works, but the effect is small. If I convertToRGB32() first I don't see any difference from the unprocessed video.
But my biggest problem is that ConvertToYUY2().autolevels() produces a very saturated purple video (it might be different on different clips, but this is what I'm seeing).
Is the wiki simply wrong?
I've worked around it with this:
(orig is in YUY2 format)
tmp = orig.convertToYV12().autolevels().convertToYUY2()
orig = MergeLuma(orig,tmp)
but if there is a more direct way to operate on YUY2() without the two conversions, I'd like to know.
frustum is offline   Reply With Quote
Old 30th October 2010, 06:27   #39  |  Link
IanB
Avisynth Developer
Ouch! Yes this filter really only has a code path for YV12, although it should give correct results for RGB24 and near correct results for RGB32. It will be using the min(a, r, g, b) and the max(a, r, g, b) for its determinations, so the contents of the A channel can upset things. Unfortunately it will just make a mess of YUY2 chroma.
Given the filter just ploughs through RowSize bytes of data per line, you might get away with this :-
tmp = orig.GreyScale().autolevels() # make all chroma bytes 128
orig = MergeLuma(orig, tmp) # Overlay new luma bytes
IanB is offline   Reply With Quote
Old 30th October 2010, 08:37   #40  |  Link
frustum
Ian, your suggestion works well enough for the one scene I've tried it on. Thanks for the tip. Also thanks for the work you are doing on avisynth!
I've just had a look at the source for the autolevels plugin. I know nothing about avisynth data structures and internals, but it assumes the pixel data is planar. Won't it just treat y,u,v as three luma values? So if the image is very dark, it will think there are a bunch of y=128 pixels after performing the GrayScale() conversion, won't it?
Overall, it seems wrong to say autolevels() supports anything but YV12 (except in special cases) right now.
