Old 19th January 2006, 10:38   #1021  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Check or Copy ? What do you prefer ?
Here is my point of view for a future release :
1/ BeLight checks in Windows/system32 dir whether mfc71.dll is there. If "true" then exit else then 2/.
2/ BeLight checks in Common Files/Ahead/Lib then copies mfc71.dll in Windows/System32 dir.
Copy the dll in Windows/System32 dir is more safer I think. because some other apps could be dependent of this...
Old 19th January 2006, 10:52   #1022  |  Link
tedgo
Your "point of view" sounds good
And i also think it is better to copy the dll to WINDOWS\system32 instead of the belight-folder.
tedgo is offline   Reply With Quote
Old 19th January 2006, 19:34   #1023  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
If you copy the MFC71.DLL that comes with Nero to the System32 dir, all applications will use it. I'm not sure if that's a good idea. Maybe there're different builds of that DLL and some applications don't "like" the one that comes with Nero. Don't know, but possible problems should be avoided...
Old 19th January 2006, 22:36   #1024  |  Link
tedgo
Version 7.10.3077.0 shipped with nero is the latest "official" MFC71.DLL from March 2003.
I don't think that some applications won't like it.
Btw. the program "VH Screen Capture Driver" http://www.hmelyoff.com/index.php?section=1 also depends on this dll and works good with the nero-shipped version.
Old 20th January 2006, 01:19   #1025  |  Link
thana
thana's Avatar
a small cosmetical bug in beta9: when processing multiple files in a queue, the total% bar works only for the first file, after that it displays always 0.00%
thana is offline   Reply With Quote
Old 20th January 2006, 09:29   #1026  |  Link
Kolich
Kurtnoise13,
I tried to create MP4 with HEAAC. As it mentioned it a ISO_IEC_14496-3_2001_Amd_1_2003_PDF_version_(en)_038148_CPDF.pdf ,
The High Efficiency AAC Profile contains the audio object types 5 (SBR) and 2(AAC LC). So first 5 bits in AudioSpecificConfig should te 5 for HEAAC for right handling of extensions (ext ObjType, ext Freq & Freq Index). And BeLight writes 2 to this field.
Kolich is offline   Reply With Quote
Old 20th January 2006, 10:08   #1027  |  Link
Kurtnoise
Kurtnoise's Avatar
@Kolich: don't blame me for that...I'm not an AAC dev. What kind of Encoder engine did you use ?
@thana: if i remember (yeah, I sleep...), this is fixed in the last daily build.
Old 20th January 2006, 10:37   #1028  |  Link
Kolich
Kurtnoise13,
i used NeroDigital.
FAAC places files to unknown destination
3gp and WinAmp do not produces HEAAC, as i see.
Old 22nd January 2006, 16:44   #1029  |  Link
Kurtnoise
Kurtnoise's Avatar
winamp is able to produce heaac stream...
@All: a new build for testing.
+ Added mfc71.dll detection.
+ Some tweakings & tunings. I hope you like them...
Old 22nd January 2006, 19:27   #1030  |  Link
LoRd_MuldeR
Software Developer
Just tested the new build and I got the following problem:
Tried to convert a list of PCM Wave Files to OGG Vorbis. Within seconds BeLight showed all files as beeing converted successfully and also showed the final "Transcoding finished" messages. Only now BeLight startet to convert the first file. For this file the progressbar was correct. But after the first file no other files were converted! Nevertheless for each Wave file a .ogg file had been created. But all .ogg files, except the first one, were unplayable 3 KB files...
Old 22nd January 2006, 20:24   #1031  |  Link
Kurtnoise
Kurtnoise's Avatar
Strange...how many input files exactly ?
Old 22nd January 2006, 20:30   #1032  |  Link
LoRd_MuldeR
Software Developer
14 files
Just tried to convert those files to MP3. Now I got 14 .mp3 files, but each file, except the last one, only contains the first ~12 secondes of the track...
Old 22nd January 2006, 20:35   #1033  |  Link
Kurtnoise
Kurtnoise's Avatar
I'll check why...but this is stange coz I haven't changed something in this part.
Could you test with 3-4 files with the beta 9, please ?
Old 22nd January 2006, 21:00   #1034  |  Link
LoRd_MuldeR
Software Developer
Okay. I've now tested in Beta-9 without any daily builds.
14 files: Does *not* work (only one files was converted correctly, some converted files are "empty" and some files were not converted at all)
3 files: All three files converted successfully (but total progressbar didn't work)
Old 22nd January 2006, 21:03   #1035  |  Link
LoRd_MuldeR
Software Developer
And I just noticed: When I add more than one file via Drag&Drop I get an "List out of Bounds" error
Old 23rd January 2006, 01:05   #1036  |  Link
Kurtnoise
Kurtnoise's Avatar
ok...thanks for your tests.
Old 23rd January 2006, 01:25   #1037  |  Link
Tima
If I want to convert audio '25000 -> 23976', should it be done via OTA or via SOUNDTOUCH settings?
Tima is offline   Reply With Quote
Old 23rd January 2006, 01:58   #1038  |  Link
Kurtnoise
Kurtnoise's Avatar
soundtouch...
Old 23rd January 2006, 02:19   #1039  |  Link
Tima
soundtouch...
I think so too. But BeLight generates this commandline:
"C:\Bin\BeLight\BeSweet.exe" -core( -input "E:\DVD\Pr_Island\project T01 3_2ch 384Kbps DELAY -24ms.ac3" -output "E:\DVD\Pr_Island\project T01 3_2ch 384Kbps DELAY -24ms.ogg" -logfile "E:\DVD\Pr_Island\project T01 3_2ch 384Kbps DELAY -24ms.log" ) -azid( -n1 -s stereo -c normal -L -3db ) -ota( -d -24 -hybridgain -r 25000 23976 ) -ogg( -q 0.600 )
When I additionaly check 'Tempo' checkbox and set it to 0, I get this:
"C:\Bin\BeLight\BeSweet.exe" -core( -input "E:\DVD\Pr_Island\project T03 3_2ch 384Kbps DELAY -24ms.ac3" -output "E:\DVD\Pr_Island\project T03 3_2ch 384Kbps DELAY -24ms.ogg" -logfile "E:\DVD\Pr_Island\project T03 3_2ch 384Kbps DELAY -24ms.log" ) -azid( -n1 -s stereo -c normal -L -3db ) -ota( -d -24 -hybridgain -r 25000 23976 ) -ogg( -q 0.600 ) -soundtouch( -r 25000 23976 -tempo 0 )
Old 23rd January 2006, 15:09   #1040  |  Link
Kurtnoise
Kurtnoise's Avatar
fixed...
@Lord_Mulder: could you try with the last daily build ? thanks...
