Old 4th June 2016, 15:57   #1  |  Link
ar
libavcodec 54 vs. 57: rate controller regression?
Preamble
A few years ago i encoded sequence from Elephant's Dream (see source) with different MPEG-2 encoding libraries. I downloaded all pngs, and then made AVI with lossless FFV1 (bgr0 pixel format). It helped to reduce size from 21 to 12,4 GiB. Avisynth script:
InputRGB = ImageReader("%05d.png", \
                       start=00001, \
                       end=15691, \
                       fps=24, pixel_type="rgb24").\
           AssumeFPS(24000, 1001)
return InputRGB ++ \
       InputRGB.Trim(15690, 15690)
Then i converted film 1080p RGB to PAL YV12 and encoded to AVI with lossless FFVH. Avisynth script:
InputVideo_RGB = AVISource("ed-film-1080p-ffv1.avi", \
                           audio=false, \
                           pixel_type="RGB32", \
                           fourCC="FFV1")
InputVideo_YUV = InputVideo_RGB.\
                 BilinearResize(720, 576).\
                 ConvertToYV12(matrix="Rec601", interlaced=false).\
                 AssumeFPS(25, 1)
return InputVideo_YUV
So, i passed data to MPEG-encoders through Avisynth (see script ed-pal.avs):
original = AVISource("ed-pal-i420-ffvh.avi", \
                     audio=false, \
                     pixel_type="YV12", \
                     fourCC="FFVH")
return original
Command for the first pass:
intra="8,16,19,22,26,27,29,34,\
       16,16,22,24,27,29,34,37,\
       19,22,26,27,29,34,34,38,\
       22,22,26,27,29,34,37,40,\
       22,26,27,29,32,35,40,48,\
       26,27,29,32,35,40,48,58,\
       26,27,29,34,38,46,56,69,\
       27,29,35,38,46,56,69,83"
inter="16,16,16,16,16,16,16,16,\
       16,16,16,16,16,16,16,16"
intra=$(echo $intra | sed -e "s/[^0-9,]//g;")
inter=$(echo $inter | sed -e "s/[^0-9,]//g;")
wine avs2yuv -raw ed-pal.avs - | \
  mencoder -demuxer rawvideo -rawvideo fps=25:pal=yes:i420=yes \
           -of mpeg=yes -mpegopts format=dvd:tsaf=yes -ofps 25 -noskip -ovc lavc=yes \
           -lavcopts vcodec=mpeg2video:vstrict=1 \
           -lavcopts vbitrate=4800:vrc_maxrate=8700:vpass=1:vqblur=0.5:vb_strategy=2 \
           -lavcopts vqmin=1:vqmax=31:vqdiff=3:dc=10 \
           -lavcopts vb_qfactor=1.25:vi_qfactor=0.8:vb_qoffset=1.25:vi_qoffset=0 \
           -lavcopts vlelim=0:vcelim=0 \
           -lavcopts lmin=0.5:lmax=20:mblmin=0.5:mblmax=20:vqsquish=1 \
           -lavcopts vrc_minrate=0:vrc_strategy=0:vrc_buf_size=1835 \
           -lavcopts vqcomp=0.5 \
           -lavcopts keyint=15:cgop=yes \
           -lavcopts vmax_b_frames=2 \
           -lavcopts sc_threshold=1000000000 \
           -lavcopts vme=4:me_range=0:preme=2:bidir_refine=4 \
           -lavcopts predia=-1:dia=-1 \
           -lavcopts mbd=0:mbcmp=6:precmp=6:cmp=6:subcmp=6:skipcmp=6 \
           -lavcopts mv0_threshold=256 \
           -lavcopts subq=8 \
           -lavcopts intra_matrix=${intra} \
           -lavcopts inter_matrix=${inter} \
           -lavcopts nr=0 \
           -lavcopts aspect=16/9:threads=4 \
           -passlogfile pass_ed-pal_menc50mpeg-nlqs.log \
           -o /dev/null -
and the second pass:
           -lavcopts vbitrate=4800:vrc_maxrate=8700:vpass=2:vqblur=1.0 \
           -lavcopts subq=8 \
           -lavcopts nr=0 \
           -o ed-pal_menc50mpeg-nlqs.vob -
I got ed-pal_menc50mpeg-nlqs.vob with very nice picture quality (compared to CCE and HCenc) and averange bitrate 4797 kbps.
The matter
Today i have tried to reproduce results with actual versions of libavcodec (encoders: ffmpeg 2.8.7, mencoder 1.1.1 and mencoder 1.3.0). For mencoder 1.1.1 command was the same, for others see commands bellow.
For mencoder 1.3.0:
           -lavcopts o=luma_elim_threshold=0:o=chroma_elim_threshold=0 \
           -lavcopts lmin=0.5:lmax=31:mblmin=0.5:mblmax=31 \
           -lavcopts subq=8 \
           -msglevel global=0 \
           -o /dev/null -
           -lavcopts subq=8 \
           -lavcopts nr=0 \
           -o ed-pal_men50mpeg-nlqs-lavc57.vob -
For ffmpeg 2.8.7:
ffmpeg -i ed-pal-i420-ffvh.avi \
       -vcodec mpeg2video -strict strict \
       -pass 1 \
       -b:v 4800k -maxrate 8700k -minrate 0 -bufsize 1835k -rc_strategy 0 \
       -g 15 -bf 2 -b_strategy 2 -flags cgop \
       -qcomp 0.1 -qblur 0.5 \
       -qmin 1 -qmax 28 -qdiff 3 -dc 10 -non_linear_quant 1 \
       -lmin 0 -lmax 767 -mblmin 1 -mblmax 31 \
       -i_qfactor 0.8 -i_qoffset 0 -b_qfactor 1.25 -b_qoffset 1.25 -ibias 96 -pbias 0 \
       -luma_elim_threshold 0 -chroma_elim_threshold 0 \
       -sc_threshold 1000000000 \
       -me_method epzs -me_range 0 -dia_size -1 -pre_dia_size -1 -preme 2 -bidir_refine 4 -mv0_threshold 256 \
       -mbd simple -cmp rd -subcmp rd -mbcmp rd -precmp rd -skipcmp rd -subq 8 -brd_scale 0 \
       -intra_matrix ${intra} \
       -inter_matrix ${inter} \
       -nr 0 \
       -aspect 16/9 -threads 4 \
       -f dvd \
       /dev/null -y
       -pass 2 \
       -g 15 -bf 2 -flags cgop \
       -qcomp 0.1 -qblur 1.0 \
       -nr 0 \
       -f dvd \
       ed-pal_men50mpeg-nlqs-lavc56.vob -y
The results
encoder     library       version      max       min       avg.        ssim 0.24
                                       bitrate,  bitrate,  bitrate,
                                       kbps      kbps      kbps
cce sp3     cceserver2    1.0.1.4      9434      159       4779        92,65
hcenc       hcenc         0.25         9181      118       4788        92,55
mencoder    libavcodec    52.72.2      9048      118       4797        92,97
mencoder    libavcodec    54.23.100    9390      118       4796        92,98
ffmpeg      libavcodec    56.60.100    9018      167       4792        92,67
mencoder    libavcodec    57.25.100    9472      167       3516        91,83
As you can see, rate controller of libavcodec 57.25.100 lowers bitrate and accepts too high quantizers, thus encoded sequence looks blocky; the result of encoding with libavcodec 56.60.100 looks ugly too (so i had to reduce qmax to 28).
The question
How to make it good again? How to make libavcodec 56/57 to reduce quantizers for low motion scenes? Which keys for ffmpeg/mencoder?
Any ideas?
Last edited by ar; 5th June 2016 at 10:19. Reason: fixed command for ffmpeg (-lmax 767) and results.
ar is offline   Reply With Quote
Old 4th June 2016, 19:59   #2  |  Link
manolito
manolito's Avatar
Just a shot from the hip (as I am no ffmpeg specialist at all...):
Could it be that you still use Q units for lmin, lmax, mblmin and mblmax while newer ffmpeg versions use lambda units?
See this post:
http://forum.doom9.org/showthread.ph...26#post1662726
Whatever, for my AVStoDVD plugin I use the parameters supplied by Fishman from this post:
http://forum.doom9.org/showthread.ph...63#post1663063
And with these parameters dark and static scenes do look very good...
Cheers
manolito
Old 5th June 2016, 16:18   #3  |  Link
ar
Thank you!
I have just tested parameters supplied by Fishman.
ffmpeg commands:
inter="16,17,18,19,20,21,22,23,\
       17,18,19,20,21,22,23,24,\
       18,19,20,21,22,23,24,25,\
       19,20,21,22,23,24,26,27,\
       20,21,22,23,25,26,27,28,\
       21,22,23,24,26,27,28,30,\
       22,23,24,26,27,28,30,31,\
       23,24,25,27,28,30,31,33"
       -profile:v 4 \
       -pass 1 \
       -q:v 2 -maxrate 8700k \
       -g 12 -bf 2 -b_strategy 2 \
       -dc 10 \
       -brd_scale 2 \
       -an \
       -f mpeg2video \
       /dev/null -y
       -profile:v 4 \
       -pass 2 \
       -b:v 4800k -maxrate 8700k \
       -g 12 -bf 2 \
       -qcomp 0.7 -qblur 0 \
       -qmin 1 -qmax 31 -dc 10 \
       -lmin 0.75 -mblmin 50 \
       -sc_threshold 0 -sc_factor 4 \
       -me_method dia -dia_size 5 -pre_dia_size 5 -preme 2 -bidir_refine 4 \
       -mbd rd -cmp satd -subcmp satd -mbcmp satd -precmp satd -skipcmp satd \
       -an \
       -f mpeg2video \
       ed-pal_ffm50mpeg-lqs-fishman.m2v -y
Result:
                                       kbps      kbps      kbps
ffmpeg      libavcodec    56.60.100    9252      167       4786        93,59 (fishman config)
SSIM value is so promising. I will try visual test a bit later.
cce, ffmpeg, hcenc, libavcodec, rate control
