3rd September 2012, 21:52 | #15641 | Link |
Ya, 116 seems to be buggered up. It's also only 79 kb's.
I made a mistake earlier..it is in the playlist. I didn't scroll far enough down in the BDR window. If I knew how I could remove it from the playlist, that would be worth a try. Last edited by greslogo; 3rd September 2012 at 21:57. |
3rd September 2012, 21:53 | #15642 | Link |
I've had bad rips due to my Lite-on drive iHES108. They made it through the encode, but there were problems with the output. E.g. the audio would be non existent in certain segments. Although the rip itself appeared fine. Apparently the audio encoder simply isn't noticing a problem. I only use that drive for quality scanning now. My LG WH10LS30 is also non trustworthy. It reads perfectly, but every burn is a coaster now. Thankfully, I put a 3yr warranty on the successor (WH12LS39). If this one quits prematurely, I may be done with LG drives. Which would suck, since I love the living room player BD640.
Ok. Now I see what's going on. Movie only mode causes the title to change :S I see Adbear has also discovered this
Only one rooster, need be in the hen house... |
3rd September 2012, 22:12 | #15644 | Link |
If it's really BDRB that's doing that playlist thing then i owe you an apology. Sorry, it just looked too much like an illegitimate disc with that source name. That being said it does look like a corrupt rip, AFAIK BD's don't use MPEG1 codec but either MPEG2, AVC or VC-1.
3rd September 2012, 22:39 | #15645 | Link |
Accepted.
Unfortunately I do not have the disc anymore. The other 2 movies, I rented at the same, ripped and ran through BDR fine, though. I've also had issues with Blue Ray burners in the past, but never read problems. Usually write issues where they won't play in stand alone players. Solution, replace the reader/burner. |
3rd September 2012, 22:46 | #15646 | Link | |
3rd September 2012, 23:29 | #15647 | Link |
Yup. BDRB is definitely appending the playlist number to the disc label. I didn't notice before, but I just looked at the log history and this started happening with the latest BDRB release. Not sure if it only affects "movie only" backups; all my backups are movie-only.
3rd September 2012, 23:57 | #15648 | Link |
i did 5 rebuild so far in the past 2 days and it doesnt affect full disc backups nor movie+menu (with blanking) option. It's logical though, apart from blanking some shit out you keep the full disc structure so BDRB doesnt need a specific playlist to use
4th September 2012, 00:26 | #15649 | Link | |
- Added the MPLS (playlist) number to the title section of the stream list when MOVIE-ONLY mode is selected. This is to avoid confusion as to which playlist is active at any point in time. The playlist number is also now displayed as a part of the batch list. Last edited by jdobbs; 4th September 2012 at 00:34. |
4th September 2012, 01:48 | #15650 | Link | |
(I suppose I should read the change log more often. I usually just upgrade and go. With never a complaint). |
4th September 2012, 21:41 | #15651 | Link |
I know that BD-RB can't re encode 3D discs at the moment but should it be able to rebuild the file structure? I have a 35gb disc but when I untick all the foreign streams it comes in at less than 25gb. Should it be able to do this? Trie the disc but just gets past the language selection and then does nothing.
4th September 2012, 22:42 | #15652 | Link |
Braveheart (Sapphire Series)
After AnyDVD (7.0.8.0) rips the movie, I've set BD-RB to blank the last 3 segments using:
[Options] VERSION=0.41.0.1 MODE=0 ENCODE_QUALITY=0 MULTIPROCESS=0 FORCE_NOENCODE=1 MIN_M2TS_SIZE=10 MKV_MUXSUPS=1 ENABLE_TEST=1 ONEPASS_ENCODING=0 AUTO_QUALITY=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=1 AC3_REENCODE=0 AC3_640=0 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=10200 MOVIEONLY_TYPE=10 ALTCRF=20 ALT_TARGET=8200 ALTMETHOD=2 ALTAUTOCROP=0 VERBOSE_STATUS=1 TARGET_SIZE=23500 AUTO_BURN=0 ENABLE_BLANKING=1 QUICK_EXTRAS=0 [Paths] SOURCE_PATH=J:\!BLU-RAY RIPS\BRAVEHEART_D1_AC\ WORKING_PATH=E:\BLU-RAY\REBUILDER\ Code:
---------------------- [09/04/12] BD Rebuilder v0.41.01 (beta) [13:42:46] Source: BRAVEHEART_D1_AC - Input BD size: 45.34 GB - Approximate total content: [03:38:54.154] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Quality: Good (Very Fast), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [13:42:48] PHASE ONE, Encoding - [13:42:48] Processing: VID_00003 (1 of 26) - [13:42:48] Extracting A/V streams [VID_00003] - [13:42:52] Reencoding video [VID_00003] - [13:42:52] Keeping original video (no reencode) - [13:42:52] Processing audio tracks - Track 4352 (eng): Keeping original audio - [13:42:52] Multiplexing M2TS - [13:42:58] Processing: VID_00006 (2 of 26) - [13:42:58] Extracting A/V streams [VID_00006] - [13:55:35] Reencoding video [VID_00006] - [13:55:35] Keeping original video (no reencode) - [13:55:35] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4355 (eng): Keeping original audio - [13:55:35] Multiplexing M2TS - [14:16:46] Processing: VID_00011 (3 of 26) - [14:16:46] Extracting A/V streams [VID_00011] - [14:16:54] Reencoding video [VID_00011] - [14:16:54] Keeping original video (no reencode) - [14:16:54] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:16:54] Multiplexing M2TS - [14:16:59] Processing: VID_00012 (4 of 26) - [14:16:59] Extracting A/V streams [VID_00012] - [14:17:06] Reencoding video [VID_00012] - [14:17:06] Keeping original video (no reencode) - [14:17:06] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:17:06] Multiplexing M2TS - [14:17:12] Processing: VID_00013 (5 of 26) - [14:17:12] Extracting A/V streams [VID_00013] - [14:17:19] Reencoding video [VID_00013] - [14:17:19] Keeping original video (no reencode) - [14:17:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:17:19] Multiplexing M2TS - [14:17:24] Processing: VID_00014 (6 of 26) - [14:17:24] Extracting A/V streams [VID_00014] - [14:17:31] Reencoding video [VID_00014] - [14:17:31] Keeping original video (no reencode) - [14:17:31] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:17:31] Multiplexing M2TS - [14:17:36] Processing: VID_00015 (7 of 26) - [14:17:36] Extracting A/V streams [VID_00015] - [14:17:44] Reencoding video [VID_00015] - [14:17:44] Keeping original video (no reencode) - [14:17:44] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:17:44] Multiplexing M2TS - [14:17:49] Processing: VID_00016 (8 of 26) - [14:17:49] Extracting A/V streams [VID_00016] - [14:17:56] Reencoding video [VID_00016] - [14:17:56] Keeping original video (no reencode) - [14:17:56] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:17:56] Multiplexing M2TS - [14:18:01] Processing: VID_00017 (9 of 26) - [14:18:01] Extracting A/V streams [VID_00017] - [14:18:07] Reencoding video [VID_00017] - [14:18:07] Keeping original video (no reencode) - [14:18:07] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:18:07] Multiplexing M2TS - [14:18:12] Processing: VID_00018 (10 of 26) - [14:18:12] Extracting A/V streams [VID_00018] - [14:18:19] Reencoding video [VID_00018] - [14:18:19] Keeping original video (no reencode) - [14:18:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:18:19] Multiplexing M2TS - [14:18:24] Processing: VID_00019 (11 of 26) - [14:18:24] Extracting A/V streams [VID_00019] - [14:18:31] Reencoding video [VID_00019] - [14:18:31] Keeping original video (no reencode) - [14:18:31] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:18:31] Multiplexing M2TS - [14:18:36] Processing: VID_00020 (12 of 26) - [14:18:36] Extracting A/V streams [VID_00020] - [14:18:43] Reencoding video [VID_00020] - [14:18:43] Keeping original video (no reencode) - [14:18:43] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:18:43] Multiplexing M2TS - [14:18:48] Processing: VID_00021 (13 of 26) - [14:18:48] Extracting A/V streams [VID_00021] - [14:18:55] Reencoding video [VID_00021] - [14:18:55] Keeping original video (no reencode) - [14:18:55] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:18:55] Multiplexing M2TS - [14:19:01] Processing: VID_00022 (14 of 26) - [14:19:01] Extracting A/V streams [VID_00022] - [14:19:07] Reencoding video [VID_00022] - [14:19:07] Keeping original video (no reencode) - [14:19:07] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:19:07] Multiplexing M2TS - [14:19:11] Processing: VID_00023 (15 of 26) - [14:19:11] Extracting A/V streams [VID_00023] - [14:19:17] Reencoding video [VID_00023] - [14:19:17] Keeping original video (no reencode) - [14:19:17] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:19:17] Multiplexing M2TS - [14:19:21] Processing: VID_00024 (16 of 26) - [14:19:21] Extracting A/V streams [VID_00024] - [14:19:28] Reencoding video [VID_00024] - [14:19:28] Keeping original video (no reencode) - [14:19:28] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:19:29] Multiplexing M2TS - [14:19:34] Processing: VID_00025 (17 of 26) - [14:19:34] Extracting A/V streams [VID_00025] - [14:19:40] Reencoding video [VID_00025] - [14:19:40] Keeping original video (no reencode) - [14:19:40] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:19:40] Multiplexing M2TS - [14:19:45] Processing: VID_00026 (18 of 26) - [14:19:45] Extracting A/V streams [VID_00026] - [14:19:53] Reencoding video [VID_00026] - [14:19:53] Keeping original video (no reencode) - [14:19:53] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:19:53] Multiplexing M2TS - [14:19:58] Processing: VID_00027 (19 of 26) - [14:19:58] Extracting A/V streams [VID_00027] - [14:20:04] Reencoding video [VID_00027] - [14:20:04] Keeping original video (no reencode) - [14:20:04] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:20:04] Multiplexing M2TS - [14:20:08] Processing: VID_00028 (20 of 26) - [14:20:08] Extracting A/V streams [VID_00028] - [14:20:14] Reencoding video [VID_00028] - [14:20:14] Keeping original video (no reencode) - [14:20:14] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:20:14] Multiplexing M2TS - [14:20:19] Processing: VID_00029 (21 of 26) - [14:20:19] Extracting A/V streams [VID_00029] - [14:20:25] Reencoding video [VID_00029] - [14:20:25] Keeping original video (no reencode) - [14:20:25] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:20:25] Multiplexing M2TS - [14:20:30] Processing: VID_00030 (22 of 26) - [14:20:30] Extracting A/V streams [VID_00030] - [14:20:38] Reencoding video [VID_00030] - [14:20:38] Keeping original video (no reencode) - [14:20:38] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:20:38] Multiplexing M2TS - [14:20:43] Processing: VID_00031 (23 of 26) - [14:20:43] Extracting A/V streams [VID_00031] - [14:20:49] Reencoding video [VID_00031] - [14:20:49] Keeping original video (no reencode) - [14:20:49] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:20:49] Multiplexing M2TS - [14:20:53] Processing: VID_00032 (24 of 26) - [14:20:53] Extracting A/V streams [VID_00032] - [14:20:57] Reencoding video [VID_00032] - [14:20:57] Keeping original video (no reencode) - [14:20:57] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4355 (eng): Keeping original audio - [14:20:57] Multiplexing M2TS - [14:21:00] Processing: VID_01002 (25 of 26) - [14:21:00] Extracting A/V streams [VID_01002] - [14:21:05] Reencoding video [VID_01002] - [14:21:05] Keeping original video (no reencode) - [14:21:05] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:21:05] Multiplexing M2TS - [14:21:10] Processing: VID_01003 (26 of 26) - [14:21:10] Extracting A/V streams [VID_01003] - [14:21:14] Reencoding video [VID_01003] - [14:21:15] Keeping original video (no reencode) - [14:21:15] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:21:15] Multiplexing M2TS [14:21:20]PHASE ONE complete [14:21:20]PHASE TWO - Rebuild Started - [14:21:20] Rebuilding BD file Structure [14:21:32] - Encode and Rebuild complete [14:21:32] JOB: BRAVEHEART_D1_AC finished. BD-RB is processing... Process finished. Final size is 2.51GB. Seems that blanking that segment (stream) breaks something...or bug with BD-RB?
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 4th September 2012 at 22:50. |
5th September 2012, 12:49 | #15653 | Link |
jdobbs, thanks for the newest version. I recently tried to back up a bluray but somehow the audio from the menu is tied to the trailer audio which I kept but I don't know why the audio is not there after I encoded. Unless it is tied to the second audio track which I have removed, but that couldn't have make sense because the trailer is the same as the menu's scene motion. The bluray is an asian bluray called The Four.
[Status] LABEL=The Four VERSION=v0.41.01 (beta) SOURCE_SIZE=24700286445 SOURCE_VIDEO_SIZE=24688551936 TARGET_SIZE=8422162432 REDUCTION=.340661045848388 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=-1 INSTANCES=1 DGDECNV=0 QUICK=0 ENCODE_STEP=0 COMPLETED=3 REBUILD_COMPLETE=1 [00000] AUDIO=11 PGS=11 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=31317880 RATE=5372 SPLITS=1 NSIZE=28631040 FLINK=-1 MLINK=-1 [00003] AUDIO=10 PGS=11 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=8336575661 RATE=7807 SPLITS=1 NSTART=27000000 NEND=345805920 NSIZE=7652677632 FLINK=0 MLINK=0 [00004] AUDIO=1 PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=42534382 RATE=3930 SPLITS=1 NSTART=27000000 NEND=30075840 NSIZE=40366080 FLINK=0 MLINK=0 [09/05/12] BD Rebuilder v0.41.01 (beta) [00:35:07] Source: The Four - Input BD size: 23.00 GB - Approximate total content: [01:59:46.450] - Target BD size: 7.84 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - Auto Quality: Good (Very Fast), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [00:35:08] PHASE ONE, Encoding - [00:35:08] Processing: VID_00000 (1 of 5) - [00:35:08] Extracting A/V streams [VID_00000] - [00:35:15] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 802 frames - Bitrate: 5,372 Kbs - [00:35:15] Reencoding: VID_00000, Pass 1 of 2 - [00:35:22] Reencoding: VID_00000, Pass 2 of 2 - [00:35:28] Video Encode complete - [00:35:28] Processing audio tracks - Track 4352 (zho): Keeping original audio - Track 4353 (zho): Keeping original audio - [00:35:28] Multiplexing M2TS - [00:35:33] Processing: VID_00003 (2 of 5) - [00:35:33] Extracting A/V streams [VID_00003] - [00:50:41] Reencoding video [VID_00003] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 170,030 frames - Bitrate: 7,807 Kbs - [00:50:41] Reencoding: VID_00003, Pass 1 of 2 - [01:18:55] Reencoding: VID_00003, Pass 2 of 2 - [01:46:58] Video Encode complete - [01:46:58] Processing audio tracks - Track 4352 (zho): Keeping original audio - [01:46:58] Multiplexing M2TS - [01:49:50] Processing: VID_00004 (3 of 5) - [01:49:50] Extracting A/V streams [VID_00004] - [01:49:58] Reencoding video [VID_00004] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 1,641 frames - Bitrate: 3,930 Kbs - [01:49:58] Reencoding: VID_00004, Pass 1 of 2 - [01:50:12] Reencoding: VID_00004, Pass 2 of 2 - [01:50:25] Video Encode complete - [01:50:25] Processing audio tracks - Track 4352 (zho): Keeping original audio - [01:50:25] Multiplexing M2TS - [01:50:29] Blanking: VID_00005 (4 of 5) - [01:50:29] Blanking: VID_00009 (5 of 5) [01:50:29]PHASE ONE complete [01:50:29]PHASE TWO - Rebuild Started - [01:50:29] Rebuilding BD file Structure [01:50:30] - Encode and Rebuild complete - WORKFILES folder removed. [01:50:31] JOB: The Four finished. - Extracting video streams [VID_00005] |
6th September 2012, 02:06 | #15654 | Link |
What would cause this error:
- [10:58:23] Remuxing DTSX/IGS stream(s) - [10:58:33] Processing: VID_50469 (36 of 47) - [10:58:33] Extracting A/V streams [VID_50469] - Error in attempt to extract audio/subs. - [11:02:54] - Failed to retrieve audio, aborted It's happening on every source I try, however same settings different computer completes with no issue. Inspect shows everything is ok. |
6th September 2012, 04:47 | #15657 | Link | |
Any other suggestions? Manually editing the structure is not the most desirable solution.
6th September 2012, 08:22 | #15659 | Link |
Braveheart Update:
Using the Movie and Menus (Auto-blank Extras) then selectively unchecking the extras I want produces my desired backup. It's the only mode that showed what I couldn't select to blank. Are you able to change that in the other modes? I checked with BD-25, encode High Speed. Now I'll use Highest, for quality. Thank ~a lot~ for FORCE_NOENCODE=n!! I'm going to test more with that. May I also suggest, when a SubProgram crashes that BD-RB _ makes _Sure_ that "tsmuxer.exe" is exited checking the process better? Even when the Info checker says all is good... I restarted a later than midnight process twice, that...come to find in other moemnts what the challenge was...I killed it, and got a good result when I was....more awake. :-D What I noticed is that TsMuxer had locked a file in use even though BD-RB showed everything had quit. So the 2nd attempt, was futile because of that. I hadn't cleaned the trash, so the "locked" file (over a Gig) remained for 2 reset (sleepy) attempts... Thanks.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 6th September 2012 at 08:47. |
6th September 2012, 08:58 | #15660 | Link |
Don't think he was taking to me because my issue included multiple sources so wasn't source specific, but rather machine specific.
As for my issue, I found out what the issue was, turns out I was low on disk space. I thought BD Rebuilder would have a check for this but I guess it doesn't. Anyway, thanks jdobbs for this great piece of software! |
