16th September 2009, 09:22 | #2021 | Link | |
HDConvertToX author
usually on 2.35 movie the crop is around 72/80 (like matrix) on BD is around 140... use always Visual Crop for check BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
16th September 2009, 11:42 | #2025 | Link |
I'm having trouble with encoding now.
Basically, I'm trying to convert The Game Plan, which uses seamless branching. I use BDinfo to find the main movie. I then use TSMuxer to create a new "Bluray" disc on my hard drive, with the main movie. I then use HDC against this newly created set of data. I open the single m2ts file and HDC analyzes it without any issues. The process is failing during x264 first pass. I've tried running just the command by itself via command line. Same result. Not sure how to troubleshoot further, so any help would be appreciated. Here is the make file. Code:
HDConvertToX v.2.1.471.3569 "Isotta" report Input File: d:\finished\gameplan\bdmv\stream\00000.m2ts ( D:\Finished\Gameplan\BDMV\STREAM\00000.m2ts ) Codec Video: avc Width / Heigh : 1920 / 1080 Framerate / Framecount: 23.976 / 158601 Duration(hh:mm:ss): 1:50:15 Aspect Ratio: 1.7778 Resized resolution: 1920 / 800 Crop Values : 0:140:0:140 Start Video Configuration -> Encoding Settings: X264 Extreme Quality ; Bitrate= 8000 Encoding Preset: 6 Final Size: 700 Priority: idle Denoise Level: Super Light Set Manual Bitrate: 8000 Video Handling: Use Best Decoder -> End Video Configuration Start Audio Configuration -> Audio Codec: Nero AAC Audio Audio Bitrate/Quality: 256 Audio Channels: 6 (5.1) MP3 Mode: abr Normalize: On Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 3: raw/pcm, english, 5.1 channels, 24 bits, 48khz 4: ac3, english, 5.1 channels, 640kbps, 48khz, dialnorm: -27db 5: ac3, french, 5.1 channels, 640kbps, 48khz, dialnorm: -27db 6: ac3, spanish, 5.1 channels, 640kbps, 48khz, dialnorm: -27db 7: ac3, english, 2.0 channels, 192kbps, 48khz, dialnorm: -27db -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE 8: subtitle (pgs), english 9: subtitle (pgs), french 10: subtitle (pgs), french 11: subtitle (pgs), spanish 12: subtitle (pgs), spanish 13: subtitle (pgs), english 14: subtitle (pgs), english -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Queue -> prompt $d $t $_$P$G "C:\Program Files (x86)\hdconvert\applications\eac3to.exe" "d:\finished\gameplan\bdmv\stream\00000.m2ts" 2:"C:\Program Files (x86)\hdconvert\job0\hdconverttox.h264" "C:\Program Files (x86)\hdconvert\applications\DGAVCIndex.exe" -i "C:\Program Files (x86)\hdconvert\job0\hdconverttox.h264" -o "C:\Program Files (x86)\hdconvert\job0\movie.dga" -f 0 -e "C:\Program Files (x86)\hdconvert\applications\eac3to.exe" "d:\finished\gameplan\bdmv\stream\00000.m2ts" 3: stdout.wav -normalize -down6 | "C:\Program Files (x86)\hdconvert\applications\neroaacenc.exe" -if - -br 256000 -ignorelength -of "C:\Program Files (x86)\hdconvert\job0\hdencodertox-pid3.mp4" "C:\Program Files (x86)\hdconvert\applications\x264.exe" --pass 1 --bitrate 8000 --preset medium --trellis 0 --ref 4 --deblock -1,-1 --subme 9 --direct auto --me umh --b-adapt 2 --no-chroma-me --tune film --sar 1:1 --output "C:\Program Files (x86)\hdconvert\job0\hdconverttox_00000.h264" "C:\Program Files (x86)\hdconvert\job0\hdconverttox_00000.avs" "C:\Program Files (x86)\hdconvert\applications\x264.exe" --pass 2 --bitrate 8000 --preset medium --trellis 0 --ref 4 --deblock -1,-1 --subme 9 --direct auto --me umh --b-adapt 2 --no-chroma-me --tune film --sar 1:1 --output "C:\Program Files (x86)\hdconvert\job0\hdconverttox_00000.h264" "C:\Program Files (x86)\hdconvert\job0\hdconverttox_00000.avs" "C:\Program Files (x86)\hdconvert\applications\eac3to.exe" "d:\finished\gameplan\bdmv\stream\00000.m2ts" 1:"C:\Program Files (x86)\hdconvert\job0\chapters.txt" "C:\Program Files (x86)\hdconvert\applications\mp4box.exe" -add "C:\Program Files (x86)\hdconvert\job0\hdconverttox_00000.h264" -fps 23.976 -add "C:\Program Files (x86)\hdconvert\job0\hdencodertox-pid3.mp4":lang=eng -chap "C:\Program Files (x86)\hdconvert\job0\chapters.txt" "C:\Program Files (x86)\hdconvert\hdconverttox_full_00000.mp4" -> End Queue AviSynth Script -> Working with files: C:\Program Files (x86)\hdconvert\job0\hdconverttox_00000.avs SetMemoryMax(512) SetMTMode(2,0) AVCSource("C:\Program Files (x86)\hdconvert\job0\movie.dga") GaussResize(1920,800,0,140,-0,-140,p=75) hqdn3d(1) -> End AviSynth Script |
16th September 2009, 12:17 | #2026 | Link | |
But when I look inside the .idx file created by BDSup2Sub 3.9.6, I find that it set the language to German # VobSub index file, v7 (do not modify this line!) # Created by BDSup2Sub 3.9.6 # Frame size size: 1920x1080 # Origin - upper-left corner org: 0, 0 # Scaling scale: 100%, 100% # Alpha blending alpha: 100% # Smoothing smooth: OFF # Fade in/out in milliseconds fadein/out: 0, 0 # Force subtitle placement relative to (org.x, org.y) align: OFF at LEFT TOP # For correcting non-progressive desync. (in millisecs or hh:mm:ss:ms) time offset: 0 # ON: displays only forced subtitles, OFF: shows everything forced subs: OFF # The palette of the generated file palette: 000000, f0f0f0, cccccc, 999999, 3333fa, 1111bb, fa3333, bb1111, 33fa33, 11bb11, fafa33, bbbb11, fa33fa, bb11bb, 33fafa, 11bbbb # Custom colors (transp idxs and the four colors) custom colors: OFF, tridx: 1000, colors: 000000, 444444, 888888, cccccc # Language index in use langidx: 0 # German id: de, index: 0 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: German # Vob/Cell ID: 1, 1 (PTS: 0) timestamp: 00:00:17:476, filepos: 000000000 timestamp: 00:00:20:854, filepos: 000001800 ++++++ Andraves |
16th September 2009, 12:30 | #2027 | Link |
HDConvertToX author
@Frozen-Figo
on Advanced Options, Utilities tab @whipdancer look here http://forum.doom9.org/showthread.ph...49#post1325649 i should add a workaround... edit: please try the sharc beta ! @andraves thanks for the report i will look at this BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 16th September 2009 at 12:35. |
16th September 2009, 15:02 | #2028 | Link | |
thanks |
16th September 2009, 15:13 | #2029 | Link |
Original File
HDConvertToX v.2.1.458.3528 "Isotta" report Input File: c:\dvb\smartdvb\records\jsc sports +220090916-17_09_19.ts ( C:\DVB\SmartDVB\Records\JSC Sports +220090916-17_09_19.ts ) Codec Video: mpeg Width / Heigh : 720 / 576 Framerate / Framecount: 25.000 / 312 Duration(hh:mm:ss): 0:0:13 Aspect Ratio: 1.3334 Resized resolution: 720 / 528 Crop Values : 0:7:0:9 Start Video Configuration -> Encoding Settings: XviD in AVI Encoding Preset: 7 Final Size: 700 Priority: idle Denoise Level: Super Light Video Handling: Use Best Decoder -> End Video Configuration Start Audio Configuration -> Audio Codec: MP3 Audio Audio Bitrate/Quality: 128 Audio Channels: 2 MP3 Mode: abr Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 2: mp2, arabic, 2.0 channels, 256kbps, 48khz, -658ms -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Queue -> prompt $d $t $_$P$G "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\eac3to.exe" "c:\dvb\smartdvb\records\jsc sports +220090916-17_09_19.ts" 1:"C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox.m2v" "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox.m2v] -OF=[C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\movie] -exit -minimize "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\eac3to.exe" "c:\dvb\smartdvb\records\jsc sports +220090916-17_09_19.ts" 2: stdout.wav -down16 -down2 | "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\lame.exe" - -h --abr 128 "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdencodertox-pid2.mp3" "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\xvid_encraw.exe" -progress 50 -i "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox_jsc sports +220090916-17_09_19.avs" -avi "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox_jsc sports +220090916-17_09_19.avi" -max_bframes 2 -vhqmode 1 -quality 6 -max_key_interval 125 -lumimasking -bquant_ratio 150 -framerate 25.000 -threads 6 -bitrate 490589 -pass1 -turbo "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\xvid_encraw.exe" -progress 50 -i "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox_jsc sports +220090916-17_09_19.avs" -avi "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox_jsc sports +220090916-17_09_19.avi" -max_bframes 2 -vhqmode 1 -quality 6 -max_key_interval 125 -lumimasking -bquant_ratio 150 -framerate 25.000 -threads 6 -bitrate 490589 -pass2 "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\AVIMux_GUI.exe" -stdin "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\mux0.amg" -> End Queue AviSynth Script -> Working with files: C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox_jsc sports +220090916-17_09_19.avs Mpeg2Source("C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\movie.d2v") LanczosResize(720,528,0,7,-0,-9) ColorMatrix(d2v="C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\movie.d2v") hqdn3d(1) -> End AviSynth Script AVIMux-Gui Script > CLEAR LOAD C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox_jsc sports +220090916-17_09_19.avi LOAD C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdencodertox-pid2.mp3 SELECT FILE 1 ADD VIDEOSOURCE SET OPTION CLOSEAPP 1 SET OPTION OVERWRITEDLG 0 SET OPTION DONEDLG 0 SET OPTION ALL AUDIO 1 SET OPTION ALL SUBTITLES 1 SET INPUT OPTIONS SET OUTPUT OPTIONS WITH SET OPTION OPENDML 0 RECLISTS 0 AUDIO INTERLEAVE 1 FR AVI ADDJUNKBEFOREHEADERS 0 PRELOAD 512 END WITH START C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\hdconverttox_full_jsc sports +220090916-17_09_19.avi -> End AVIMux-Gui Script After been saved with MPEG-VCR Code:
HDConvertToX v.2.1.458.3528 "Isotta" report Input File: C:\Documents and Settings\Frozen\Desktop\a.ts ( C:\Documents and Settings\Frozen\Desktop\a.ts ) Codec Video: mpeg Width / Heigh : 720 / 576 Framerate / Framecount: 25.000 / 335 Duration(hh:mm:ss): 0:0:14 Aspect Ratio: 1.3334 Resized resolution: 720 / 528 Crop Values : 0:7:0:9 Start Video Configuration -> Encoding Settings: XviD in AVI Encoding Preset: 7 Final Size: 700 Priority: idle Denoise Level: Super Light Video Handling: Use Best Decoder -> End Video Configuration Start Audio Configuration -> Audio Codec: MP3 Audio Audio Bitrate/Quality: 128 Audio Channels: 2 MP3 Mode: abr Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 2: mp2, 2.0 channels, 256kbps, 48khz, 40ms 3: mp2, 2.0 cha -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Queue -> prompt $d $t $_$P$G "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\eac3to.exe" "c:\dvb\smartdvb\records\jsc sports +220090916-17_09_19.ts" 1:"C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox.m2v" "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox.m2v] -OF=[C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\movie] -exit -minimize "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\eac3to.exe" "c:\dvb\smartdvb\records\jsc sports +220090916-17_09_19.ts" 2: stdout.wav -down16 -down2 | "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\lame.exe" - -h --abr 128 "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdencodertox-pid2.mp3" "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\xvid_encraw.exe" -progress 50 -i "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox_jsc sports +220090916-17_09_19.avs" -avi "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox_jsc sports +220090916-17_09_19.avi" -max_bframes 2 -vhqmode 1 -quality 6 -max_key_interval 125 -lumimasking -bquant_ratio 150 -framerate 25.000 -threads 6 -bitrate 490589 -pass1 -turbo "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\xvid_encraw.exe" -progress 50 -i "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox_jsc sports +220090916-17_09_19.avs" -avi "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox_jsc sports +220090916-17_09_19.avi" -max_bframes 2 -vhqmode 1 -quality 6 -max_key_interval 125 -lumimasking -bquant_ratio 150 -framerate 25.000 -threads 6 -bitrate 490589 -pass2 "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\AVIMux_GUI.exe" -stdin "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\mux0.amg" -> End Queue -> End AviSynth Script AVIMux-Gui Script > CLEAR LOAD C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdconverttox_jsc sports +220090916-17_09_19.avi LOAD C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\analysis\hdencodertox-pid2.mp3 SELECT FILE 1 ADD VIDEOSOURCE SET OPTION CLOSEAPP 1 SET OPTION OVERWRITEDLG 0 SET OPTION DONEDLG 0 SET OPTION ALL AUDIO 1 SET OPTION ALL SUBTITLES 1 SET INPUT OPTIONS SET OUTPUT OPTIONS WITH SET OPTION OPENDML 0 RECLISTS 0 AUDIO INTERLEAVE 1 FR AVI ADDJUNKBEFOREHEADERS 0 PRELOAD 512 END WITH START C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\hdconverttox_full_jsc sports +220090916-17_09_19.avi -> End AVIMux-Gui Script Regards |
16th September 2009, 19:01 | #2030 | Link | |
HDConvertToX author
@Frozen-Figo have your tried with soundout ? BHH
16th September 2009, 22:27 | #2031 | Link |
Have problems using subtitles and HDC.
Normaly i take the forced subs. but after Vob ripper the cmd console closes the encode proces dosent start. Tried, embed in video stream and also in container with different DVDs. I think the right way for forced subs should be embed in video stream ? So i must not select the subtitle option on my Media Tank (WD TV) Here is a log Last edited by Jaspa; 16th September 2009 at 22:31. |
17th September 2009, 01:18 | #2032 | Link |
I received an error with alarm, and final file has one audio channel.
"The source file doesn't contain a track with the number 3" Code:
HDConvertToX v.2.1.458.3528 "Isotta" report Input File: c:\documents and settings\frozen\desktop\3.ts ( C:\Documents and Settings\Frozen\Desktop\3.ts ) Codec Video: mpeg Width / Heigh : 704 / 576 Framerate / Framecount: 25.000 / 251 Duration(hh:mm:ss): 0:0:11 Aspect Ratio: 1.3334 Resized resolution: 512 / 368 Crop Values : 0:7:0:9 Start Video Configuration -> Encoding Settings: X264 in MKV Encoding Preset: 7 Final Size: 20 Priority: idle Denoise Level: Super Light Video Handling: Use Best Decoder Deinterlace: Interlaced -> End Video Configuration Start Audio Configuration -> Audio Codec: Nero AAC Audio Audio Bitrate/Quality: 64 Audio Channels: 2 MP3 Mode: abr Audio handling: Use NicAudio/SoundOut plugin Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 2: mp2, 2.0 channels, 256kbps, 48khz, 40ms *** 3: mp2, 2.0 cha -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> Basic Filter: FFT3DFilter(sigma=2.5) QMF Filter: QMLF_3_motions_Fast_Degrain.avs MVDegrain: MVDegrain3 ColorMatrix: On -> End Advanced AviSynth Start Queue -> prompt $d $t $_$P$G "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\eac3to.exe" "" 2: "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job3\hdencodertox--pid2.mp2" "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\x264.exe" --crf 18 "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job3\hdconvert_audio_1_.avs" -o "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job3\testaudio.h264" "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\x264.exe" --crf 20 --preset slow --tune animation --sar 1:1 --output "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job3\hdconverttox_.h264" "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job3\hdconverttox_.avs" "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\mkvmerge.exe" -o "C:\Documents and Settings\Frozen\Desktop\5.MKV" --default-duration 0:25.000fps "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job3\hdconverttox_.h264" --language -1:ara "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job3\hdencodertox-pid2.mp4" --title "Done with HDConvertToX v.2.1.471.3569 _Isotta_" -> End Queue AviSynth Script -> Working with files: C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7\hdconverttox_3.avs Mpeg2Source("C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7\movie.d2v") TDeint(mode=0,order=-1) LanczosResize(512,368,0,7,-0,-9) ColorMatrix(d2v="C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7\movie.d2v") hqdn3d(1) FFT3DFilter(sigma=2.5) QMLF_3_motions() backward_vec3 = last.MVAnalyse(isb = true, delta = 3, pel = 2, overlap=2, sharp=1, idx = 1) backward_vec2 = last.MVAnalyse(isb = true, delta = 2, pel = 2, overlap=2, sharp=1, idx = 1) backward_vec1 = last.MVAnalyse(isb = true, delta = 1, pel = 2, overlap=2, sharp=1, idx = 1) forward_vec1 = last.MVAnalyse(isb = false, delta = 1, pel = 2, overlap=2, sharp=1, idx = 1) forward_vec2 = last.MVAnalyse(isb = false, delta = 2, pel = 2, overlap=2, sharp=1, idx = 1) forward_vec3 = last.MVAnalyse(isb = false, delta = 3, pel = 2, overlap=2, sharp=1, idx = 1) last.MVDegrain3(backward_vec1,forward_vec1,backward_vec2,forward_vec2,backward_vec3,forward_vec3,thSAD=300,idx=1) -> End AviSynth Script Code:
C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7>"C:\Docu ments and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\eac3to. exe" "c:\documents and settings\frozen\desktop\3.ts" 1:"C:\Documents and Setting s\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7\hdconverttox.m2v" TS, 1 video track, 2 audio tracks, 0:00:10, 50i 1: MPEG2, 704x576 50i (4:3) 2: MP2, 2.0 channels, 256kbps, 48khz, 40ms 3: MP2, 2.0 channels, 256kbps, 48khz, 40ms v01 Extracting video track number 1... v01 Creating file "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458 .3528\job7\hdconverttox.m2v"... Video track 1 contains 251 frames. eac3to processing took 1 second. Done. C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7>"C:\Docu ments and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\dgindex .exe" -FO=0 -OM=0 -YR=2 -AIF=[C:\Documents and Settings\Frozen\Desktop\HDConvert ToX_2.1.458.3528\job7\hdconverttox.m2v] -OF=[C:\Documents and Settings\Frozen\De sktop\HDConvertToX_2.1.458.3528\job7\movie] -exit -minimize C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7>"C:\Docu ments and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\eac3to. exe" "c:\documents and settings\frozen\desktop\3.ts" 2: "C:\Documents and Settin gs\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7\hdencodertox--pid2.mp2" TS, 1 video track, 2 audio tracks, 0:00:10, 50i 1: MPEG2, 704x576 50i (4:3) 2: MP2, 2.0 channels, 256kbps, 48khz, 40ms 3: MP2, 2.0 channels, 256kbps, 48khz, 40ms a02 Extracting audio track number 2... a02 Applying MPx delay... a02 A remaining delay of -8ms could not be fixed. a02 Creating file "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458 .3528\job7\hdencodertox--pid2.mp2"... Video track 1 contains 251 frames. eac3to processing took 1 second. Done. C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7>"C:\Docu ments and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\x264.ex e" --crf 18 "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\ job7\hdconvert_audio_1_3.ts.avs" -o "C:\Documents and Settings\Frozen\Desktop\HD ConvertToX_2.1.458.3528\job7\testaudio.h264" avis [info]: 8x8 @ 25.00 fps (255 frames) x264 [warning]: width or height not divisible by 16 (8x8), compression will suff er. x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile High, level 1.0 x264 [info]: slice I:2 Avg QP:18.00 size: 15 x264 [info]: slice P:65 Avg QP:23.65 size: 13 x264 [info]: slice B:188 Avg QP:23.54 size: 13 x264 [info]: consecutive B-frames: 0.8% 0.0% 1.2% 98.0% x264 [info]: mb I I16..4: 100.0% 0.0% 0.0% x264 [info]: mb P I16..4: 0.0% 0.0% 0.0% P16..4: 0.0% 0.0% 0.0% 0.0% 0 .0% skip:100.0% x264 [info]: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.0% 0.0% 0.0% direct: 0.0% skip:100.0% L0:-1.$% L1:-1.$% BI:-1.$% x264 [info]: 8x8 transform intra:0.0% inter:-1.$% x264 [info]: coded y,uvDC,uvAC intra:0.0% 0.0% 0.0% inter:0.0% 0.0% 0.0% x264 [info]: kb/s:2.6 encoded 255 frames, 907.47 fps, 3.10 kb/s C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7>"C:\Docu ments and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\eac3to. exe" "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7\hd encodertox--pid2.mp2" 3: "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_ 2.1.458.3528\job7\hdencodertox--pid3.mp2" MP2, 2.0 channels, 0:00:10, 256kbps, 48khz The source file doesn't contain a track with the number 3. C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7>"C:\Docu ments and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\x264.ex e" --crf 18 "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\ job7\hdconvert_audio_2_3.ts.avs" -o "C:\Documents and Settings\Frozen\Desktop\HD ConvertToX_2.1.458.3528\job7\testaudio.h264" avis [error]: unsupported input format (DIB ) x264 [error]: could not open input file 'C:\Documents and Settings\Frozen\Deskto p\HDConvertToX_2.1.458.3528\job7\hdconvert_audio_2_3.ts.avs' C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7>"C:\Docu ments and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\applications\x264.ex e" --crf 20 --preset slow --tune animation --sar 1:1 --output "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7\hdconverttox_3.h264" "C:\Documents and Settings\Frozen\Desktop\HDConvertToX_2.1.458.3528\job7\hdconve rttox_3.avs" avis [info]: 512x368 @ 25.00 fps (251 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile High, level 2.2 [36.7%] 92/251 frames, 4.71 fps, 448.17 kb/s, eta 0:00:33 Last edited by Frozen-Figo; 17th September 2009 at 01:20. |
17th September 2009, 02:02 | #2033 | Link | |
17th September 2009, 07:48 | #2036 | Link | ||
HDConvertToX author
@Frozen-Figo is eac3to to detect a third audio track.. i cannot help on it are you sure your ts streams are correct ? @whipdancer can you post the FIRST avs with multithreaded on ? BHH
17th September 2009, 12:20 | #2037 | Link |
[HTML]
HDConvertToX v.2.1.471.3569 "Isotta" report Input File: d:\mainmovie\star_wars_episode_iv\video_ts\vts_01_1.vob ( D:\MainMovie\STAR_WARS_EPISODE_IV\VIDEO_TS\VTS_01_0.IFO ) PGC : PGC 1. Length: 1:59:37:13 / chained=1 Codec Video: mpeg Width / Heigh : 720 / 576 Framerate / Framecount: 25.000 / 179425 Duration(hh:mm:ss): 1:59:38 Aspect Ratio: 1.7778 Resized resolution: 720 / 416 Crop Values : 0:72:0:72 Activate: Follow ITU Resizing Activate: Anamorphic Resize Start Video Configuration -> Encoding Settings: X264 Extreme Quality ; Quality= 18.5 NMT Compatibility: On Encoding Preset: 6 Final Size: 18.5 Priority: idle Denoise Level: Super Light Video Handling: Use Best Decoder -> End Video Configuration Start Audio Configuration -> Audio Codec: Copy Audio Audio Bitrate/Quality: 128 Audio Channels: 2 MP3 Mode: abr Normalize: On Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 81: Deutsch (AC3 6ch, 0xBD 0x81) [0] -> End Full Audio List Full Subtitle List-> (*** mean selected) NONE Deutsch 0 (0xBD 0x2E) [0] wide *** Deutsch 0 (0xBD 0x2F) [0] letbox -> End Full Subtitle List Encrust Subtitle in Video file: On Start Advanced AviSynth -> Basic Filter: Undot() ColorMatrix: On -> End Advanced AviSynth Start Queue -> prompt $d $t $_$P$G "F:\HDConvertToX_2.1.458.3528\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[d:\mainmovie\star_wars_episode_iv\video_ts\vts_01_1.vob] -OF=[F:\HDConvertToX_2.1.458.3528\job5\movie] -exit -minimize "F:\HDConvertToX_2.1.458.3528\applications\eac3to.exe" "D:\MainMovie\STAR_WARS_EPISODE_IV\VIDEO_TS\VTS_01_1.vob"+"D:\MainMovie\STAR_WARS_EPISODE_IV\VIDEO_TS\VTS_01_2.vob"+"D:\MainMovie\STAR_WARS_EPISODE_IV\VIDEO_TS\VTS_01_3.vob"+"D:\MainMovie\STAR_WARS_EPISODE_IV\VIDEO_TS\VTS_01_4.vob"+"D:\MainMovie\STAR_WARS_EPISODE_IV\VIDEO_TS\VTS_01_5.vob"+"D:\MainMovie\STAR_WARS_EPISODE_IV\VIDEO_TS\VTS_01_6.vob" 3: "F:\HDConvertToX_2.1.458.3528\job5\hdencodertox-pid3.ac3" -no2ndpass "F:\HDConvertToX_2.1.458.3528\applications\VSrip.exe" "F:\HDConvertToX_2.1.458.3528\job5\hdc_subs.list" "F:\HDConvertToX_2.1.458.3528\applications\x264.exe" --crf 18.5 --preset medium --trellis 0 --ref 3 --deblock -1,-1 --subme 9 --direct auto --me umh --b-adapt 1 --no-chroma-me --tune film --sar 1022361600:727833600 --output "F:\HDConvertToX_2.1.458.3528\job5\hdconverttox_vts_01_1.h264" "F:\HDConvertToX_2.1.458.3528\job5\hdconverttox_vts_01_1.avs" --level 4.0 "F:\HDConvertToX_2.1.458.3528\applications\Chapter\ChapterXtractor.exe" "D:\MainMovie\STAR_WARS_EPISODE_IV\VIDEO_TS\VTS_01_0.IFO" "F:\HDConvertToX_2.1.458.3528\job5\chapters.txt" -p5 "F:\HDConvertToX_2.1.458.3528\applications\mkvmerge.exe" -o "D:\Star Wars 4.MKV" --default-duration 0:25.000fps --aspect-ratio -1:2.524653 "F:\HDConvertToX_2.1.458.3528\job5\hdconverttox_vts_01_1.h264" --language -1:deu "F:\HDConvertToX_2.1.458.3528\job5\hdencodertox-pid3.ac3" --chapters "F:\HDConvertToX_2.1.458.3528\job5\chapters.txt" --title "Done with HDConvertToX v.2.1.471.3569 _Isotta_" -> End Queue AviSynth Script -> Working with files: F:\HDConvertToX_2.1.458.3528\job5\hdconverttox_vts_01_1.avs Mpeg2Source("F:\HDConvertToX_2.1.458.3528\job5\movie.d2v") GaussResize(720,416,0,72,-0,-72,p=75) ColorMatrix(d2v="F:\HDConvertToX_2.1.458.3528\job5\movie.d2v") hqdn3d(1) Undot() VobSub("F:\HDConvertToX_2.1.458.3528\job5\hdc_subs.idx") -> End AviSynth Script |
17th September 2009, 12:26 | #2038 | Link |
HDConvertToX author
open the avs script with virtualdub
got error ? launch from dos "F:\HDConvertToX_2.1.458.3528\applications\x264.exe" --crf 18.5 --preset medium --trellis 0 --ref 3 --deblock -1,-1 --subme 9 --direct auto --me umh --b-adapt 1 --no-chroma-me --tune film --sar 1022361600:727833600 --output "F:\HDConvertToX_2.1.458.3528\job5\hdconverttox_vts_01_1.h264" "F:\HDConvertToX_2.1.458.3528\job5\hdconverttox_vts_01_1.avs" --level 4.0 what is the error ? BHH
17th September 2009, 13:05 | #2039 | Link |
Here are the error messages i get.
And if you have some time can you take a look at this thread. http://forum.doom9.org/showthread.php?t=149504 Tested today another DVD and the same broken line after encoding with HDC. In Megui it is ok. Last edited by Jaspa; 17th September 2009 at 13:08. |
17th September 2009, 13:49 | #2040 | Link |
HDConvertToX author
copy libsndfile-1.dll from \applications folder to \windows\system32
and reopen the script .. about your row.. do you got it without subtitles ? BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
