20th August 2011, 03:38 | #11201 | Link |
Banned
No, Arcsoft is the only way to decode DTS-HD Master besides the DTS suite, and the rare and impossible to find Sonic decoder. I want eac3to to mix my stuff because it detects clipping, and it also uses the best possible processing. I also don't care for foobar2000 for anything but playback.
20th August 2011, 06:09 | #11202 | Link | |
I'm sure there's a rational logic behind all that. |
20th August 2011, 10:34 | #11203 | Link | |
sl=WavSource("D:\tmp\SL.wav").ConvertAudioToFloat() # Load channels to mix sr=WavSource("D:\tmp\SR.wav").ConvertAudioToFloat() bc=WavSource("D:\tmp\BC.wav").ConvertAudioToFloat() bl=MixAudio(sl, bc, 1.0, 0.7071) # Mix half power of BC into SL br=MixAudio(sr, bc, 1.0, 0.7071) # Mix half power of BC into SR fl=WavSource("D:\tmp\FL.wav").ConvertAudioToFloat() # Load the rest of channels fr=WavSource("D:\tmp\FR.wav").ConvertAudioToFloat() fc=WavSource("D:\tmp\FC.wav").ConvertAudioToFloat() lf=WavSource("D:\tmp\lf.wav").ConvertAudioToFloat() MergeChannels(fl, fr, fc, lf, bl, br) # Merge the 6 channels Normalize() # Normalize to avoid clip ConvertAudioTo24bit() # Change to desired precision
20th August 2011, 22:47 | #11204 | Link |
Formerly davidh*****
From what I've read, eac3to should be able to extract a core AC3 track from a TrueHD file, but I get this:
M:\TMP\bd>eac3to bd.thd bd.ac3 TrueHD, 7.1 channels, 48kHz, dialnorm: -27dB AC3 encoding doesn't support back channels. Will mix them into the surround. Removing TrueHD dialog normalization... Decoding with libav/ffmpeg... Remapping channels... Mixing surround channels... Encoding AC3 <640kbps> with libAften... David |
20th August 2011, 22:55 | #11205 | Link |
Banned
That file doesn't have an AC3 core, it would be listed.
It would look like this: Code:
d:\>\apps\eac3to\eac3to.exe file.thd TrueHD/AC3, 7.1 channels, 48kHz (embedded: AC3, 5.1 channels, 640kbps, 48kHz) And why does a line get added to the bottom of the code boxes? Last edited by ramicio; 20th August 2011 at 23:06. |
22nd August 2011, 16:53 | #11208 | Link |
@madshi,
I was doing some batch extracts of audio from my media files when I noticed the following that I had not seen before. Code:
eac3to v3.24 command line: eac3to "file1.mkv" 2: "file1.ac3" ------------------------------------------------------------------------------ MKV, 1 video track, 1 audio track, 0:42:01, 24p /1.001 1: h264/AVC, 720p24 /1.001 2: AC3, ???, 5.1 channels, 448kbps, 48kHz, dialnorm: -25dB
Chumbo |
22nd August 2011, 17:07 | #11210 | Link | |
eac3to input stdout.wav | OggEnc2 -q 3 --ignorelength -o output.ogg -
22nd August 2011, 17:32 | #11211 | Link | |
2: AC3, 5.1 channels, 448kbps, 48kHz, dialnorm: -25dB, 17ms Code:
Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 42mn 10s Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : 17ms Stream size : 135 MiB (12%) Language : English
Chumbo |
23rd August 2011, 02:57 | #11212 | Link | |
Maybe your mkv's don't have the language field filled: Code:
eac3to v3.24 command line: "D:\Programa\eac3to\eac3to.exe" "D:\Test\cono3.mkv" ------------------------------------------------------------------------------ MKV, 1 video track, 2 audio tracks, 1 subtitle track, 0:00:22, 25p 1: h264/AVC, English, 720p25 2: DTS, English, 5.1 channels, 24 bits, 755kbps, 48kHz 3: AC3, German, 5.1 channels, 448kbps, 48kHz 4: Subtitle (SRT), Spanish
23rd August 2011, 03:37 | #11213 | Link | |
Chumbo |
23rd August 2011, 11:13 | #11214 | Link |
Mkvmerge (in recent versions) doesn't write the language field if set to "English" and eac3to doesn't recognize that. That's why eac3to doesn't display any language for English tracks if muxed with such a version. I don't know where the "???" comes from. Look at the value of the field "Language" in mkvinfo - maybe you can spot a difference between files with "" (empty) and "???".
24th August 2011, 15:42 | #11215 | Link |
der Name sagt alles
Hi guys!
I don't know if this has been asked before, but how can I prevent eac3to from downsampling wavs when I come from a 24bit, 48KHz, 6ch pcm file, trying to extract mono wav files? I don't know why, but for some reason eac3to from time to time thinks it has to reduce the bit depth to 16bit... I have tried to define all values, like eac3to in-6ch.pcm out\out.wavs -48000 -24 -6 -little -override (even tried -down24)... still receving 16bit wavs, but I do need 24bit. Wht can I do, and why s it doing that anyway? l the best and thanx for the apart from that great tool! all the best swk
SwK |
24th August 2011, 16:02 | #11217 | Link |
Banned
Eac3to detects when a 24-bit file has the 8 least significant bits filled with zeroes (which is easily accomplished by taking a 16-bit file and simply saving it as 24-bit) and drops it to 16 bits. Keeping it 24 bits would be pointless and a waste of space. When eac3to detects that the file is between 17 and 23 bits, it will keep it 24.
25th August 2011, 08:03 | #11218 | Link | ||
"D:\media\eac3to\eac3to.exe" "I:\video\title00 ID3 Lossless.dts" -110ms -normalize -down6 -progressnumbers -log="I:\video\title00 ID3 Lossless_Output_eac3to.txt" | D:\media\OGG\aoTuV\oggenc2.exe -q 5.0 --ignorelength -o "I:\video\title00 ID3 Lossless_Output.ogg" - I get the error: Quote:
25th August 2011, 09:05 | #11219 | Link |
You have to specify "stdout.wav" as a fake output file, like in tebasuna51's example. Try:
"D:\media\eac3to\eac3to.exe" "I:\video\title00 ID3 Lossless.dts" stdout.wav -110ms -normalize -down6 -progressnumbers -log="I:\video\title00 ID3 Lossless_Output_eac3to.txt" | D:\media\OGG\aoTuV\oggenc2.exe -q 5.0 --ignorelength -o "I:\video\title00 ID3 Lossless_Output.ogg" - |
25th August 2011, 09:11 | #11220 | Link | |
If I specify fake output file then the output will go to file and not stdout right?
I tried it now: Code:
"D:\media\eac3to\eac3to.exe" "I:\video\title00 ID3 Lossless.dts" $$fake.wav -110ms -normalize -down6 -progressnumbers -log="I:\video\title00 ID3 Lossless_Output_eac3to.txt" | D:\media\OGG\aoTuV\oggenc2.exe -q 5.0 --ignorelength -o "I:\video\title00 ID3 Lossless_Output.ogg" - Quote:
Sorry I missed the name thankyou!!! Last edited by Anakunda; 25th August 2011 at 09:28. |
eac3to |
