19th July 2013, 17:18 | #1581 | Link |
Banned
is Pel pertaining to whether your source is interlaced, telecined and/or progressive, or does it pertain to something else? I was under the assumption that Pel=1 was used if your source is progressive, and Pel=2 if it is interlaced.
But then in the FastDegrain doc, I read that the higher the Pel, the better the motion vector. Can someone please clarify this? Thanks |
19th July 2013, 17:21 | #1582 | Link | ||
No, it's motion estimation accuracy Quote:
19th July 2013, 17:26 | #1583 | Link |
Pig on the wing
Please consult http://avisynth.org.ru/mvtools/mvtools2.html
Pel is not related to progressive or interlaced material. It is used to tell how accurately the motion will be estimated. At pel=1, the super clip is not scaled at all, at pel=2 it is twice as big and at pel=4 it's four times as big. A bigger value for pel is not necessarily better as there's no way to scale an image by four times and not have any errors created by the extrapolation. Unless you live in the CSI world, that is Personally I would leave it at the default which is pel=2. Basically I would leave all the values at their defaults as there's probably a reason why they are select. If you got the CPU power to spare, maybe use dct=5 and search=5 in the MAnalyse calls.
19th July 2013, 19:52 | #1584 | Link |
Banned
I understand that using dct=5 uses the SATD (sum of absolute transformed differences) instead of SAD (sum of absolute differences) for luma. In your experiences, does this improve the motion estimation accuracy in a significant manner? for instance, in fast motion with animation, does it help in preventing blurring/ghosting at quick motion in dark scenes? I'm gonna try this for myself when I get home, but it's nice to hear from others while I'm stuck at this desk.
19th July 2013, 20:09 | #1586 | Link |
Pig on the wing
It's been quite a long time since I tested the differences, but if I recall correctly, the differences were mostly in the areas of higher contrast. I didn't test performance in the dark frames/areas much, but I think someone (was it *.mp4guy?) did some testing and found out that it helps there.
19th July 2013, 20:15 | #1589 | Link |
Pig on the wing
Smaller is more accurate but more affected by noise. I personally use 8 with overlap 4 for all my stuff. If I use MRecalculate after that, I use blksize 4 and overlap 2 for SD stuff and blksize 8, overlap 4 for anything higher than that.
19th July 2013, 20:23 | #1590 | Link |
Banned
I use overlap 2. But in my script it's written as 8/2 (as per the way it's in the documentation). Is adding the / even necessary?
My stuff is analog SD and I'm using Mdegrain3. I'm thinking of using blcksize 4 if that's the case, since I'm prefiltering anyway. |
29th July 2016, 17:11 | #1592 | Link |
what rfilter in MSuper do (Technical details, I know it did smoothing)? is it effect if pel = 1?
See My Avisynth Stuff Last edited by real.finder; 29th July 2016 at 17:14. |
29th July 2016, 22:11 | #1594 | Link | |
Search 6 and 7 works the best for me, based on the dominant movement in particular source/scene. I asked if this could be dynamically changed ahead of final calculations. 5 gives very different characteristic for final frames, never as good as when correct option 6 or 7 is chosen based on scene dominant movement. Another interesting (or not) thing is fallback method. When you try interpolate low fps sources than quite often motion adaptive method fails giving huge artefacts. Some pro solution have fallback mode, which at some threshold switches to simple frame blending for given frames. In case of fps conversion (in current world of hybrid sources, e.g. 25p mixed with 50i) this is sometimes useful option. Other than this mvtools results are very good. I'm thinking if anything more can be done. There is something called phase correlation, is this used in mvtools? I would like to see something reliably converting 24p to 25p, which is at the moment only a dream DCT hits performance a lot, but sometimes helps on fades etc. Last edited by kolak; 29th July 2016 at 22:13. |
30th July 2016, 13:24 | #1595 | Link |
why it there then?
pel use resizer to upscale frame, is rfilter for the downsize to original dimension?
See My Avisynth Stuff |
30th July 2016, 13:41 | #1597 | Link |
and if pel = 1? did nothing?
10th March 2023, 13:19 | #1599 | Link |
Some not very fast but better answer - rfilter is used when generating smaller sized images for higher levels of search (levels=0 mean all possible levels).
It work at all pel (if levels count all or high enough). Disabling usage rfilter is for example pel=1 levels=1. So make only refine search at largest (full size) level. The used filter may cause generating different MVs at each level (used as a predictor after interpolation at larger levels of search). So initial developers of mvtools put several different filters for reduction of size for smaller levels and also recommend to try filtering to smaller levels: From documentation: You may also try to apply some external filter to superclip or its coarse bottom part (by appropriate crop and overlay). |
