Old 26th September 2008, 00:35   #401  |  Link
Version 1.0.1 fixes memory leak
The fix is released at my web site. Thank you for pointing it out.
Guest is offline
Old 26th September 2008, 00:44   #402  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Another bug (affects both DGAVCDecNV and DGAVCDec)
is DGAVCDec fixed as well?
Atak_Snajpera is offline
Old 26th September 2008, 00:49   #403  |  Link
I'm doing it now. Patience please.
Guest is offline
Old 26th September 2008, 01:34   #404  |  Link
Sagekilla
x264aholic
neuron2: I have a feature request. Would it be possible to merge DGAVCIndex and DGAVCIndexNV into one program, and offer a license to enable GPU decoding? I could imagine that for AVCSource() you could call it like so: AVCSource("file.dga",GPU=true,deinterlace=true). I'd think that you could somehow just have it check for a license key before it allows GPU decoding.
Just a thought It would be nice to see but if it's not possible then no worries.
Sagekilla is offline
Old 26th September 2008, 01:51   #405  |  Link
I could probably do it, but it's not high on the list of priorities compared to VC1 support, MPEG integration, and MKV/MOV support. Thanks for the suggestion.
Guest is offline
Old 26th September 2008, 06:08   #406  |  Link
lucassp
There's a very limited amount of GPUs supporting full VC-1 Decoding, so you could put it on a lower priority.
lucassp is offline
Old 26th September 2008, 06:27   #407  |  Link
Comatose
Will MKV/MOV support be in DGAVCIndex as well?
Comatose is offline
Old 26th September 2008, 07:14   #408  |  Link
ultratoto14
Test it for the first time, it's impressive. I think about a new feature. I think that cuda have optimized functions to resize the image. Is there a possibility to serve already resized frames ? As 1920x1080 -> 1280x720 is CPU consuming.
Great job.
ultratoto14 is offline
Old 26th September 2008, 08:08   #409  |  Link
turbojet
any news on the radmin/windows rdp causing encodes to hang?
you'll have another customer if this issue is resolved.
turbojet is offline
Old 26th September 2008, 09:46   #410  |  Link
drelin
Just a question.
I've installed the CUDA driver, and now the Hardware accelration on POWERDVD (7.3) not run. If I desactive the PureVideo Acceleration on POWERDVD, the display is correct (but I lost the Hardware accelration) and the pureVideo activated no video displayed (black sreen with error message and video run).
Anybody have a solution for that ?
Thank and sorry for my bad english.
drelin is offline
Old 26th September 2008, 10:08   #411  |  Link
drelin
OK
I 've found the solution.
Just a update of POWERDVD is needed for DXVA works correctly.
drelin is offline
Old 26th September 2008, 12:56   #412  |  Link
Yes, the two will track. The only difference will be use of the GPU for decoding.
Guest is offline
Old 26th September 2008, 12:56   #413  |  Link
yonta
Setup;
E8200@2.66G
9600GT
2GB RAM
Source is Blu-ray 1080p
dgavcdecnv 1.0 alpha3
script used;
LoadPlugin("f:\dgavcdecnv100a3\DGAVCDecodeNV.dll")
AVCSource("f:\test.gpu.dga")
Crop(0, 144, -0, -136)
LanczosResize(1280, 528)
LoadPlugin("f:\dgavcdeca35\DGAVCDecode.dll")
AVCSource("f:\test.dga")
x264 987 logs;
F:\samples>x264.exe --bframes 3 --ref 5 --crf 18 --direct auto --weightb --me umh --subme 6 --b-rdo --mixed-refs --bime --trellis 1 --no-fast-pskip --level 4.1 --progress --threads 3 --output DGAVCDecode.mkv DGAVCDecode.avs
avis [info]: 1280x528 @ 23.98 fps (2414 frames)
x264 [info]: PSNR Mean Y:46.967 U:49.524 V:49.814 Avg:46.782 Global:42.528 kb/s:5658.03
encoded 2414 frames, 5.84 fps, 5658.21 kb/s
F:\samples>x264.exe --bframes 3 --ref 5 --crf 18 --direct auto --weightb --me umh --subme 6 --b-rdo --mixed-refs --bime --trellis 1 --no-fast-pskip --level 4.1 --progress --threads 3 --output DGAVCDecodeNV.mkv DGAVCDecodeNV.avs
x264 [info]: PSNR Mean Y:46.967 U:49.523 V:49.814 Avg:46.782 Global:42.528 kb/s:5651.09
encoded 2414 frames, 6.69 fps, 5651.28 kb/s
So, I get approx. 0.85fps speedup.
If the full movie has 200000 frames, using DGAVCDecodeNV will finish encoding about 1h12min earlier.
yonta is offline
Old 26th September 2008, 12:56   #414  |  Link
I'll ask Nvidia if is possible.
Guest is offline
Old 26th September 2008, 13:00   #415  |  Link
Please explain in detail what I need to do to duplicate this issue. What environment, what software, what operations.
Guest is offline
Old 26th September 2008, 13:43   #416  |  Link
lucassp
It should work, but you have to do "real" CUDA programming for that.
http://forums.nvidia.com/index.php?showtopic=60853
lucassp is offline
Old 26th September 2008, 14:11   #417  |  Link
I meant possible with the nvcuvid.dll interface.
Guest is offline
Old 26th September 2008, 14:35   #418  |  Link
turbojet
neuron2 for the radmin\microsoft rdp issue. You might have rdp (remote desktop protocol) installed, check for computer properties, advanced settings, remote, and tick allow if it isnt already.Otherwise you'll need to install radmin on a dgavcindexnv capable computer. Start an encode, and if you either login or logout from either service the encoder hangs.
turbojet is offline
Old 26th September 2008, 14:58   #419  |  Link
Do I need to have two machines and login remotely? If you want this looked at you're going to have to spoon feed me.
Give me an exact step by step of what to install and do.
Guest is offline
Old 26th September 2008, 14:59   #420  |  Link
Quark.Fusion
Quark.Fusion's Avatar
Donald, what about to make free version with limit to half of source framerate for example? It will not be suited for realtime decoding, but provide good demo of technology. Also with heavy encoding settings I'm don't think that 1-5% speedup is worth 15$.
Quark.Fusion is offline
