Old 2nd February 2010, 08:47   #1401  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
First things first: Having to set up a mingw build environment sucks. Big time. I've done it a couple of times and each and every time I spend hours until everything's working fine.
Originally Posted by whatever-ever View Post
Ok here goes...
I've tried for 5 days to compile mkvtoolnix (or any part thereof) for windows. I compiled it with no hassle on my ubuntu pc, but for some reason i'm having a lot of trouble compiling with either mingw or cygwin.
Use mingw, forget about cygwin. I don't use mingw on Windows myself, I use a mingw cross compilation environment on Ubuntu.
All libraries have been compiled under mingw (./configure --prefix=/mingw), except boost, which i'm not sure i've "installed" properly. took a bit of copying and pasting files from here and there to /lib before i could finally get mingw to recognize that i have boost. but it get erros like this (currently only this one):
I usually have to use explicit arguments for configure so that it will find the Boost libraries. Here's my current script for configuring mkvtoolnix:
#!/bin/zsh
M=$HOME/prog/video/mingw
TFT=$M/src
test -z $WX && WX=$(cat ~/prog/video/mingw/default_wxwidgets_version)
W=$M/wxWidgets-$WX
test -d $W || {
echo "$W" does not exist
exit 1
if pwd | grep -q -E 'nogui$' ; then
WX=""
NOGUI="--disable-gui"
else
WX="--with-wx-config=$W/bin/wx-config"
NOGUI=""
fi
./configure \
--host=i586-mingw32msvc \
--cache-file=config.cache \
--with-extra-includes=$TFT/libebml\;$TFT/libmatroska\;$M/include \
--with-extra-libs=$TFT/libebml/make/mingw32\;$TFT/libmatroska/make/mingw32\;$M/lib \
--with-boost=$HOME/prog/video/mingw/boost \
$WX $NOGUI \
As you can see my base path to all mingw stuff (except the compiler itself) is ~/prog/video/mingw
Sorry if this is an obvious question, but for the life of me I cannot figure out how to fix this.
It isn't, but I cannot help you either; debugging Boost linking problems is one of the areas that suck so much. It might be a couple of reasons:
1. It is missing other libraries that your Boost build requires but that configure does not tell the link check to use.
2. You Boost build has been done with a different/incompatible mingw version and the link check fails due to unknown symbols.
3. The configure script itself cannot find a suitable file (!) to hand over to the link check. Configure itself tries to find the proper name for the Boost libraries because Boost's library names consist of various parts like architecture, multi threading on/off, version etc.
The configure checks I use have only been tested on bash/sh/zsh like shells on Linux. I haven't tested them on Windows with msys or cygwin's bash.
PS: "have you tried building boost?", yes, however not with any luck. i tried so by running bootstrap.sh etc., but it doesn't go so well, http://pastebin.com/f761baf28 (forever paste).
I wouldn't suggest building Boost on mingw yourself Mostly because I haven't had much luck with it myself, at least not with my cross compilation environment.
A couple of months ago another user asked for support on building Windows builds. Back then I uploaded my ~/prog/video/mingw tree along with my self-built mingw cross compiler. Those packages won't work anymore (mingw 3.4 cross compiler didn't support Unicode, newer mkvtoolnix versions require Unicode support), but I can create a new tree and upload it along with slightly patched mingw .deb packages for Ubuntu 9.10 64bit if that would help you. It would probably not help you getting mkvtoolnix to compile on Windows with mingw, I guess, but it is a working cross compilation environment.
Latest MKVToolNix is v54.0.0
Mosu is online now
Old 2nd February 2010, 18:56   #1402  |  Link
whatever-ever
Hi Mosu,
thanks a lot for the thorough answer.
I was not aware of cross compilation (besides having bumbed into it a couple of times). I'll try that out, thanks!
and thanks for the script, will help me configure it properly.
whatever-ever is offline
Old 2nd February 2010, 19:10   #1403  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
If you do try to cross compile then you should be aware of a bug in the mingw runtime package for Ubuntu. I have a diff that fixes this bug available at http://www.bunkus.org/videotools/mkv...-snprintf.diff
Applying and compiling the package works something like this (from memory and vague, adjust file names/paths as necessary):
cd /usr/src
apt-get source mingw32-runtime
apt-get build-dep mingw32-runtime
cd mingw32-runtime-VERSION
patch -p1 < ~/mingw32-runtime-snprintf.diff
dpkg-buildpackage -b
Mosu is online now
Old 2nd February 2010, 19:18   #1404  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
BTW: The tarball of my mingw cross compilation directory is up and available at http://www.bunkus.org/videotools/mkv...mingw.tar.lzma
The file http://www.bunkus.org/videotools/mkv...in32-build.txt mentions a couple of things to keep in mind (it's an IRC log excerpt and not up to date but still relevant).
Mosu is online now
Old 2nd February 2010, 20:40   #1405  |  Link
whatever-ever
Oh thanks. seems i just need to point it to some valid libiconv, other than that things seems to be in order
Old 2nd February 2010, 21:10   #1406  |  Link
whatever-ever
Hmm, as soon as i switch to cross-compilation libiconv won't be found. (and yes there is libiconv in your tree, and i also tried building it myself). have i put it in a wrong place? i installed into /home/../prog/video/mingw/
UPDATE:
I got mkvtoolnix 3.10 compiled now. All credit goes to you, Mosu, as all it took was to use your tree and your zsh. The reason I failed before with iconv was that my own EXPORT commands apparently did not work the way i expected them to. Relying on your zsh it worked.
One little heads up to what you said earlier about a mingwruntime bug... I was not able to apply the patch as the file didn't exist. But before I started googling to see where I could get a source with the needed file, I got it to compile. So what I'm saying is, I did not need that patch in order to build mkvtoolnix 3.10.
Thanks again for your patience and helpful effort!
Old 2nd February 2010, 22:05   #1407  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
I don't really have an idea, sorry.
Mosu is online now
Old 6th February 2010, 07:19   #1408  |  Link
mikeyakame
lookin for my sanity
Location: it all depends on the day and which country comes to mind
Any chance you guys could add the following "Add command-line options" to the next build of MKVToolnix?
--segmentinfo
--segment-uid
I have no real problem with adding them manually each time, but it'd handy to have them available in the drop down list! I've been using --segmentinfo quite a lot recently and find its amazingly useful.
Cheers for all the work on the app anyway
mikeyakame is offline
Old 6th February 2010, 14:09   #1409  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
--segmentinfo
--segment-uid
mmg 3.1.0 already contains support for --segment-uid: "global" tab, option "segment UIDs".
The following build adds an option for the segment info XML file, also on the "global" tab: http://www.bunkus.org/videotools/mkv...-214-setup.exe (still uploading)
Mosu is online now
Old 6th February 2010, 18:52   #1410  |  Link
thetoof
Sleepy overworked fellow
I'm trying to figure how file linking works with mkv and I am quite puzzled. Here's what I'm trying to do:
5.1 AC3 audio / 1 file
h.264 video / 2 files with different resolution and DAR (somehow it changed in the middle of the DVD)
Subtitles
So, I need the 2 videos linked together, but since the audio is muxed with the first video segment, I can't link them as "play this file, then this one" since I lose audio this way. How would I use advanced editing to achieve what I want?
Thanks
AnimeIVTC() - v2.00
-http://boinc.berkeley.edu/-
Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p)
thetoof is offline
Old 6th February 2010, 19:17   #1411  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Please create a new thread for this. This is more a general Matroska & playback question, not really a mkvtoolnix question.
Mosu is online now
Old 8th February 2010, 07:34   #1412  |  Link
RadioactiveMan
Muxing error
I tried to rip a bluray and save it as mkv.
x264 gives a me .mp4 with about 4.5 GB. When muxing it with mkvtoolnix it says "everything ok" but the resulting mkv is just 17 KB in size.
What could be the error?
I want to add that I can watch the video without problems in mpchc.
RadioactiveMan is offline
Old 8th February 2010, 08:46   #1413  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
I don't know.
Mosu is online now
Old 8th February 2010, 16:19   #1414  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
RadioactiveMan
I'm not sure, but I believe mp4 normally not supports such huge files. Even if it is possible to create them, maybe they need some special treatment on demuxer side... Try to do all the same steps but cut some of the movie to get small but similar file and check if it works.
EDIT: anyway if you want mkv, why you not using mkv or raw output in x264?
Keiyakusha is offline
Old 11th February 2010, 09:19   #1415  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
MP4 files can have arbitrary sizes with 64bit atoms. mkvmerge supports such files & atoms.
Mosu is online now
Old 11th February 2010, 14:08   #1416  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
I'd like to get to the bottom of this. Can you please tell me how you created that file (which programs in which version)? I'll try to create such a problematic file myself.
Alternatively you can upload the file to my FTP server if you have the bandwidth to spare even though it is quite huge
Mosu is online now
Old 11th February 2010, 19:00   #1417  |  Link
RadioactiveMan
I have just used x264 r1416 32bit from x264.nl. Input was an avs. I fear I can't give you more information than you can see in the screenshot. It might be of interest that DsMux from haalis Splitter was able to mux it but was terrible slow (i.e. it took 30 minutes from a hdd to an sdd). Additionally the resulting file was completely out of sync. So it looks like something must have been wrong with the file.
Unfortunately I have already reencoded it directly into an mkv container and deleted all temporary files.
Old 11th February 2010, 19:16   #1418  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
I tried to reproduce it with x264 but didn't succeed. Do you still have the AVS file? If not then I guess it'll remain a mystery.
Mosu is online now
Old 11th February 2010, 19:21   #1419  |  Link
73ChargerFan
73ChargerFan's Avatar
I was thinking, that his snapshot of the directory showed that he hadn't refreshed the view. Windows will sometimes show a small file size as it is being created, and then updates to the size are half-hazzard. Perhaps the file is in his recycle bin?
73ChargerFan is offline
Old 11th February 2010, 19:24   #1420  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Nah. mmg also shows that muxing only took three seconds. And muxing a 4 GB file in three seconds is... unrealistic
Mosu is online now
