Old 1st May 2008, 14:43   #61  |  Link
Inventive Software
Turkey Machine
Firstly, try VirtualDub 1.8. It's unstable, but has better colourspace support. Secondly, in Lagarith's config, select RGBA as the output.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline   Reply With Quote
Old 6th May 2008, 04:24   #62  |  Link
LeeWilson
Hi, thanks for the reply.
I tried VirtualDub 1.8.0 with the same results as 1.7.8. It still says Dummy Alpha Channel in the color depth options for 32 bit RGB. And I have the mode set to RGBA in the Lagarith configuration.
I suppose I will have to look writing an app to compress my own avi from images or uncompressed avi with Lagarith.
LeeWilson is offline   Reply With Quote
Old 6th May 2008, 16:14   #63  |  Link
[P]ako
A geek wannabe
[P]ako's Avatar
Avisynth supports RGBA and you could use avs2avi to encode it to lagarith, in that very same thread you can also find a GUI for it (avs2avidrop).
It just occurred to me, did you set virtualdub to work in fast processing mode?
[P]ako is offline   Reply With Quote
Old 7th May 2008, 11:56   #64  |  Link
Zarxrax
I have often created lagarith files containing alpha channel with Adobe After Effects or Adobe Premiere. I think free trial versions may be available. Avisynth can also generate video with alpha channel like [P]ako said, and thats probably the easier way to just test it.
Zarxrax is offline   Reply With Quote
Old 26th August 2008, 00:20   #65  |  Link
video_magic
I have noticed that the Lagarith codec has been updated to version 1.3.18! Thanks for the updates Ben Greenwood
http://lags.leetcode.net/codec.html
Thankyou!, I am grateful for any help
Last edited by video_magic; 26th August 2008 at 00:21. Reason: typing error put Quote
video_magic is offline   Reply With Quote
Old 26th August 2008, 00:42   #66  |  Link
totya
Hi!
Version 1.3.17, and 1.3.18 uninstall function is bad.
if I use lagarith.inf form 1.3.15, uninstall works.
Different is "setupapi.dll" - "setupx.dll"
My system is XP, 32 bit.
totya is offline   Reply With Quote
Old 3rd September 2008, 07:06   #67  |  Link
benwaggoner
So, I'm very annoyed by the Adobe video apps (I've seen this in Premiere Pro and After Effects CS3) inabilty to actually take settings with Lagarith. I can choose the options like normal, but when I close the dialog and go back, it's always RGB without multithreading, and regardless of what I set the options to, the output is always RGB single-threaded.
Anyone know of any workaround for this? A reg key I can set for default behavior or something?
Ben Waggoner
Principal Video Specialist, Amazon Instant Video
My Compression Book
Amazon Instant Video is hiring! PM me if you're interested.
Old 3rd September 2008, 07:12   #68  |  Link
squid_80
Take a look at c:\windows\lagarith.ini.
squid_80 is offline   Reply With Quote
Old 5th September 2008, 23:16   #69  |  Link
video_magic
I have been trying out the newest version of MLC and the newest Lagarith, and Lagarith has been my winner!
Capturing from a NTSC Laserdisc at 29.97 720x480 YV12 using virtualvcr and through S-Video to S-Video via BT878a based board. Capturing audio as PCM 44100 stereo.
My PC has a SL9KE chip which is a P4 3.2ghz HT 2mb and 1gb PC3200 2-2-2-5 ram. XP SP2 running clean and defragged.
39 minutes of video resulted in a 12.6GB file!
MLC was too slow to be usable even on the fastest setting. Lagarith is excellent!
Capture Stats
Frames Captured: 70261
Frames Dropped1: 0
Frames Dropped2: 1
Time : 00:39:04
Time Left: 07:08:19
Free Space: 148,803,293,184
Video Bytes: 13,163,442,847
Audio Bytes: 413,569,800
Total Bytes: 13,577,012,647
Video Bytes Sec: 5,613,729
Audio Bytes Sec: 176,372
Total Bytes Sec: 5,790,101
Video Compression: 2.767
Video Rate: 29.970013
Audio Rate: 44100.241432
AV Diff: -0.000005
AV Adjust: 0.000000
AV Actual: 0.000000
Old 10th September 2008, 17:29   #70  |  Link
benwaggoner
I don't see any way to set default modes in there, but in my ~\AppData\Local\VirtualStore I see
[settings]
multithreading=1
lossy_option=3
Anyone know what the right numbers are for multithreaded and YV12?
Ben Waggoner
My Compression Book
Old 10th September 2008, 19:11   #71  |  Link
squid_80
Well, wherever settings go when WritePrivateProfileInt/String is used.
multithreading=1 means use multithreading (who would have guessed?).
lossy_option=3 means YV12. (0:RGBA, 1:RGB (Default), 2:YUY2, 3:YV12, 4:Reduced Resolution)
suggest=1 means always suggest RGB for output.
nullframes=1 means enable Null frames.
From the sounds of it this isn't going to fix your problem though.
Old 10th September 2008, 19:15   #72  |  Link
benwaggoner
Bummer. So I've got it set correctly, but Premiere and After Effects are somehow overriding the defaults!
Ben Waggoner
My Compression Book
Old 10th September 2008, 19:29   #73  |  Link
smok3
brontosaurusrex
smok3's Avatar
my workaround is to use huffyuv with adobe apps (for RGB and for RGBA), after the project is finnished i would reconvert those huffs to lags for backups.
(ask for bat which controls vdub.exe and converts *.avi to *_lags.avi))
certain other member
smok3 is offline   Reply With Quote
Old 11th September 2008, 05:18   #74  |  Link
henryho_hk
smok3, you can use the command-line utility avs2avi.exe (http://www.moitah.net/).
I've drafted a batch file (totally untested):
SETLOCAL ENABLEEXTENSIONS ENABLEDELAYEDEXPANSION
if "%~1"=="" (
    echo Usage: "%~f0" <source avi>
    echo        Defaults to RGBA output
    echo        For RGB24, name it as "blahblah_rgb.avi"
    goto :EOF
set HOMEDIR=%~sdp0
set WORKDIR=%~sdp1
set PIXTYPE=%~n1
set PIXTYPE=%PIXTYPE:~-4%
if /i "%PIXTYPE%"=="_RGB" (
    set PIXTYPE=RGB24
) else (
    set PIXTYPE=RGB32
set SRCFILE=%~sf1
set AVSFILE=%~sdpn1_%PIXTYPE%.avs
set DSTFILE=%~sdpn1_lags_%PIXTYPE%.avi
set LAGSCFG=%HOMEDIR%lags_%PIXTYPE%.cfg
echo AVISource^("%SRCFILE%",pixel_type="%PIXTYPE%"^)>"%AVSFILE%"
if exist "%LAGSCFG%" (
    "%HOMEDIR%avs2avi.exe" "%AVSFILE%" "%DSTFILE%" -w -p 0 -l "%LAGSCFG%"
) else (
    "%HOMEDIR%avs2avi.exe" "%AVSFILE%" "%DSTFILE%" -w -p 0 -s "%LAGSCFG%"
:EOF
henryho_hk is offline   Reply With Quote
Old 11th September 2008, 08:24   #75  |  Link
smok3
brontosaurusrex
smok3's Avatar
henryho_hk: oh, sorry for confusion, i allready have a batch, what i meant is if somebody needs an example, i can provide. However, good batches are always welcome.
edit1: why do you need avisynth for this?
edit2: ok, i just realized my batches wont do RGBA to RGBA but for some reason it ends with RGB lags, must take a look into this..
Old 12th September 2008, 01:37   #76  |  Link
henryho_hk
I use AVISynth because I use avs2avi. It seems difficult to fiddle with Virtualdub's (<1.6) VFW config in batch files. Mencoder supports VFW compression too but for unknown reasons it runs slower than avs2avi in my computer.
Old 21st September 2008, 18:05   #77  |  Link
lilhobo
how can i install for vista64?? the bat wont work for me
lilhobo is offline   Reply With Quote
Old 22nd September 2008, 07:01   #78  |  Link
henryho_hk
Sorry, I dun have any Vista (32 or 64) for testing. But you can send me the error messages (seems out-of-topic for this thread) and see if I can help.
Old 24th September 2008, 23:32   #79  |  Link
lilhobo
well vista u need the admin rights or something which the bat doesnt give
Old 25th September 2008, 00:12   #80  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
What if you run it from an Admin account?
lagarith
