Old 2nd January 2006, 00:35   #61  |  Link
Revgen
The avc.plg is in my folder.
Or else The Greatest Game.mp4 video would play slow.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 2nd January 2006, 00:45   #62  |  Link
kurt
sidekick
kurt's Avatar
great player! But a question the developers:
what about AR-signaling (SAR in mp4 / DAR in matroska)? will this be implemented in the future?
greets, kurt.
Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC
kurt is offline   Reply With Quote
Old 2nd January 2006, 00:49   #63  |  Link
Birdy1
This is amazing. I benchmarked a trailer of the movie Serenity. Before I couldn't play it at all.
player: tcpmp.win32.0.71g.zip
plugin: avc.win32.0.71g.zip
Serenity movie trailer serenity_1080p.mov
without avc and aac plugin (no sound) 53%
with avc and aac plug in 171%
P4 3GHz
ATI Radeon 9600 Pro
Birdy1 is offline   Reply With Quote
Old 2nd January 2006, 01:54   #64  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
Revgen and others.... if you have the FFMPEG plug-in installed and the AVC plug-in installed and are trying to play a video with our unsupported AVC features
- interlacing
- custom quantizer matrices
- lossless coding
Playback will the default to the FFMPEG plugin. This is the likely reason it is playing slow. Try another AVC video with the supported features and let us know the results.
Dan "BetaBoy" Marlin
Ubiquitous Multimedia Technologies and Developer Tools
http://corecodec.com
BetaBoy is offline   Reply With Quote
Old 2nd January 2006, 03:41   #65  |  Link
Revgen
Okay, here are the details again.
1) My Beavis and Butthead video doesn't use any of these above features. So it shouldn't be the problem.
2) My video plays well with FFDShow and VLC player. The FFMPEG plugin shouldn't be the problem.
3) My video plays slow using TCPMP 0.71G combined with AVC plugin 0.71G. It also plays slow when the AVC Plugin IS NOT in the folder.
4) I can upload and send a link to my video through www.yousendit.com if you're interested.
Moe: Why?
Old 2nd January 2006, 10:11   #66  |  Link
CruNcher
CruNcher's Avatar
Revgen what does the Media Info show after you load the file ?
It is about Time
Old 2nd January 2006, 17:59   #67  |  Link
Revgen
URL: H:\BEAVIS_BUTTHEAD_VOL_1\VIDEO_TS\Beavis and Butthead Vol 1 Disk 1.mkv
Format: Matroska File (MKV,MKA)
Duration: 1:47:40.960
Filesize: 715821 KB
Video: AVC aka H.264
Codec: CoreCodec AVC
Video Size: 720x480
Frame Rate: 23.976
Language: eng
Audio: AC-3
Codec: LibA52 (AC-3)
Format: 48000 Hz Stereo
Data Bit Rate: 224 kbit/s
Language: und
Played: 0
Frames Dropped: 0
Played FPS: 23.976
Moe: Why?
Old 2nd January 2006, 23:52   #68  |  Link
Hyper Shinchan
Really amzaing this plugin!!! I'll make extended tests later, but I'm really impressed!
Sugoiii!!!
Hyper Shinchan is offline   Reply With Quote
Old 3rd January 2006, 03:37   #69  |  Link
DeathTheSheep
<The VFW Sheep of Death>
DeathTheSheep's Avatar
In having some MKV problems here as well. I think its the same one, actually; an MKV file of mine benches near 400% despite dropping many frames during playback.
AVI works just fine, though.
Recommended all-in-one stop for x264/GCC needs on Windows: Komisar x264 builds!
DeathTheSheep is offline   Reply With Quote
Old 3rd January 2006, 04:08   #70  |  Link
travisbell
Can't wait to see this DirectShow filter you are teasing us with... should be very, very interesting...
Travis Bell
Consumeroo!
travisbell is offline   Reply With Quote
Old 3rd January 2006, 05:03   #71  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
ok... you have been warned!!! This is a pre-pre-pre-alpha directshow version of CoreAVC.... bond has tested it and it needs alot of work still ;-)
<bond> ffdshow: 47.16
<bond> ateme: 50.62
<bond> coreavc: 73.33
<bond> that is with a stream that has pretty much everything enabled
CoreCodec AVC DirectShow Video Decoder
ALPHA VERSION FOR TESTING PURPOSE ONLY
Changelog:
Version 0.0.0.1 Alpha :
Use a very high merit in this alpha release, don't install it if you
don't want to use it.
Should support anamorphic from Matroska (native mode) and MP4 files.
Limitations :
- Only output to YV12 and I420
- No dynamic output mediatype change
- No flushing for buffered frame at end of file
- Linked with some unecessary code from TCPMP
- no cqm, lossless or interlacing support
There are way too many issues to even bother posting about... but hey, I did say it was a pre-pre-pre alpha build... so with that.... Have fun.
Download here: http://cc.serveftp.org:8884/CoreAVC20060102.7z
Old 3rd January 2006, 06:03   #72  |  Link
falcon2000eg
falcon2000eg's Avatar
thanx i just tried it and loved it keep the good work.
falcon2000eg is offline   Reply With Quote
Old 3rd January 2006, 06:14   #73  |  Link
Revgen
Beavis and Butthead plays great with this one. Good Job!
The Greatest Game trailer (1920x1080) also plays great.
Your pre pre pre alpha build has earned a right to graduate!
Moe: Why?
Old 3rd January 2006, 06:16   #74  |  Link
Sirber
retired developer
Sirber's Avatar
On my 3000+ (running in low power mode, RealAnime is not encoding )
On 640x480 with (x264 + AAC+v2 = MKV), in overlay mode
FFDShow: ~50% CPU
CoreAVC: ~38% CPU
MPlayer: ~30% CPU
Detritus Software
Sirber is offline   Reply With Quote
Old 3rd January 2006, 09:25   #75  |  Link
CruNcher
CruNcher's Avatar
yep it's like Bond said blasting 40% faster then any of the other Decoders
It is about Time
Old 3rd January 2006, 12:29   #76  |  Link
sillKotscha
what's this for?
sillKotscha's Avatar
first time I can watch these trailers...
sample H264 High Profil
KingKong
1280*720*25
1500 Kbps
Harry potter IV
1280*720*25
1250 Kbps
IceAge
1280*720*25
1250 Kbps
really flawless with my system...
sillKotscha is offline   Reply With Quote
Old 3rd January 2006, 13:48   #77  |  Link
bond
<bond> ateme: 50.62
note that with the tcpmp i get on the same stream a decoding speed of 90fps, so its even a lot faster than coreavc dshow
edit:
so on this sample (720x288_B3-Ref_Ref5_p4x4-i8x8_loop-5_wbp_cabac_770kbps) with my pentium3 866mhz cpu
- coreavc-dshow is ~45% faster than ateme
- coreavc-tcpmp is ~75% faster than ateme
ateme _was_ the fastest decoder till now (and not publically available). compared to the available other fast decoders (libavcodec, moonlight) the speed increase is obviously even bigger
so this decoder really rocks! great job!
Ogg Theora | Ogg Vorbis
Old 3rd January 2006, 14:08   #78  |  Link
PicardGK
Please upload it, if there is a little chance it will make faster finding problem. In next few days I will be still busy with some other stuff I need to finish, but I will get back to coreavc after that (cqm support is coming also).
PicardGK is offline   Reply With Quote
Old 3rd January 2006, 14:23   #79  |  Link
bond
uhm, actually it seems the 0.0.0.1 version of coreavc already handles cqm!
did this happen automagically?
no lossless and interlacing tough
Old 3rd January 2006, 21:14   #80  |  Link
Revgen
Uploaded the file and the link has been sent to your e-mail address.
Moe: Why?
codec, coreavc, corecodec, coremvc, cuda, decoder, dxva, h.264, mvc, scam
