Old 3rd August 2019, 11:03   #121  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Originally Posted by mparade View Post
Does anyone know if there is any solution for this yet? The same is happening to my 2990WX at the moment. Maybe if using Coreprio?
According to guy from level1techs ( https://youtu.be/cTmnyOZ0pE4?t=34m ) you should
1) install Linux
2) setup virtual machine on linux
3) install windows 10 on virtual machine
Done.
Old 8th August 2019, 12:05   #122  |  Link
TEB
https://www.phoronix.com/scan.php?pa...502-7742&num=4
Looks like Phoronix´s benchmark isnt able to saturate all these cores... but nevertheless.. impressive numbers for the new EPYC 7xx2 series
TEB is offline   Reply With Quote
Old 14th September 2019, 20:10   #123  |  Link
jfcarbel
Programmer
Again
Was this done on a Windows 7 or Windows 10 machine?
I think I read that Windows 10 performs much faster for the Ryzen 3000
jfcarbel is offline   Reply With Quote
Old 14th September 2019, 22:09   #124  |  Link
Atak_Snajpera
Within margin of error. Do not expect miracles.
Old 14th September 2019, 22:41   #125  |  Link
jfcarbel
Programmer
Thanks, so not significant.
So is your windows 7 updater able to get Windows 7 running well with the Ryzen 3000 CPUs?
Old 14th September 2019, 22:52   #126  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Example for a bad Encoding CPU (i7700k) ~70hours for an 2h video
I would say, minimum 8 cores (I9900k or Ryzen 7 3xxx for example)
i7700k@4,8 Ghz / ASUS STRIX Z270e / 16GB DDR4 Corsair / ASUS STRIX GeForce GTX1070 8GB GDDR5
-QfG- is offline   Reply With Quote
Old 14th September 2019, 23:40   #127  |  Link
Atak_Snajpera
Yep. However If you have x570 then you will have to add this step to get USB 3 ports to work
https://www.sevenforums.com/drivers/...l?#post3441921
Old 16th September 2019, 19:57   #128  |  Link
NikosD
For those who are still wondering which is the fastest platform for HEVC encoding:
8K real-time HEVC encoding at 79fps with just one CPU (!)
https://www.tomshardware.com/news/am...ing,40400.html
Win 10 x64 (18363.476) - Core i3-9100F - nVidia 1660 (441.41)
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 16th October 2019, 17:55   #129  |  Link
archer75
I have a question that hopefully someone can help me with.
I have two computers, a PC I built and a 2018 mac mini. Using handbrake on both, using the same settings with the same file and encoding with HEVC 10bit I get very different results.
The PC uses an Intel 5820 and the Mac uses an Intel 8700.
The encode that comes out of the macs 8700 is quite a bit smaller file size than the one produced by the 5820 and it also has noticeably better image quality. Why is that? I'm considering an upgrade and knowing why the file is both smaller with better quality would help me in choosing which processor for a new build.
archer75 is offline   Reply With Quote
Old 16th October 2019, 17:59   #130  |  Link
Nico8583
Do you use the same handbrake version with the same third-party tools version ?
The OS are different so executable must be different (I don't know MAC OS very well).
Nico8583 is offline   Reply With Quote
Old 16th October 2019, 19:29   #131  |  Link
Nico8583
I think the OS but I'm not sure.
Old 17th October 2019, 05:52   #132  |  Link
RanmaCanada
Is one using quicksync and the other using pure software? Realistically there should be no difference between the 2 if you are using the exact same settings, profiles, etc.
Old 21st October 2019, 01:02   #133  |  Link
benwaggoner
How big is the file size and quality gap? Does one of the systems have way more cores than the other? There used to be quality regressions using frame threading, although this has gotten quite a big better in recent years.
Ben Waggoner
My Compression Book
Old 1st November 2019, 11:47   #134  |  Link
DotJun
Does anyone know why avx2 is being used when set to auto detect on my intel 7820x? I typically set it to avx512, but forgot to do so on my last batch.
DotJun is offline   Reply With Quote
Old 1st November 2019, 11:56   #135  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Because AVX512 is not generally recommended, so you need to enable it manually if you want to use it. Basically you should test to see if you benefit from it or not, seems to depend on the case quite a lot.
Old 1st November 2019, 12:13   #136  |  Link
DotJun
Ok, I didn’t know it was excluded from auto detection, thanks for the info and I tested it a while back. My results showed a slight improvement in FPS, even with a negative offset, so I just stuck with it.
Old 1st November 2019, 13:24   #137  |  Link
hajj_3
AVX512 makes the processor too hot so the clock speed of the AVX portion is reduced and as a result it isn't very fast. I think Intel might have fixed that in their latest processors.
Old 1st November 2019, 13:45   #138  |  Link
DotJun
Yep, that’s the reason for the negative offset. From the small amount of testing I did, avx512 still came out with slightly higher FPS even with a couple hundred mghz lower clock due to offset.
Though I will admit that I wouldn’t be able to run 512 if my computer wasn’t located in a 65-70f temp room.
Old 2nd November 2019, 00:43   #139  |  Link
RanmaCanada
Ha with winter coming, you can just place it outside and run without an offset :P haha.
Old 9th November 2019, 08:16   #140  |  Link
DotJun
I had a chance to do a small sample test and here are my results:
system: 7820x oc'd to 4.4ghz with 32g of memory. A -3 offset was used for both avx2 and avx512 as explained below.
10 minute 1080p sample on auto detect: 5.38fps
10 minute 1080p sample on avx512: 5.72fps
5 minute 4k sample on auto detect: 0.84fps
5 minute 4k sample on avx512: 0.92fps
crf and slower settings were used on all samples.
The odd part is that both auto detect (avx2) and avx512 needed the same -3 offset or windows becomes unstable and crash. Also, avx2 ran 5-10c hotter than avx512, which is the opposite of what I thought would happen.
Results might be different on a longer sample clip, but I really didn't want to invest too much time into it since for whatever reason avx2 was pushing out more heat than what I am comfortable with.
