23rd January 2013, 18:48 | #17121 | Link |
madVR v0.85.8 released
http://madshi.net/madVR.zip Code:
* fixed: 3:2 IVTC timestamps (film mode forced on) were not optimal * fixed: files which turn from progressive to interlaced don't get deint * fixed: SoftCubic + Mitchell produced artifacts with exact 3x scaling * fixed: frame stepping sometimes froze for up to 3 seconds * fixed: some bugs found through crash report emails * fixed: videos with non-mod-4 height were unnecessarily cropped * fixed: when using DXVA decoding, 60i clips sometimes switched to 30Hz * fixed: "refreshRate" tag didn't work * added "repeated frames" OSD info (only when framerate = refresh rate) * added new interface IMadVRSubclassReplacement (for JRiver MC18) * added support for "deint=ivtc" tag * internal software video decoders are now disabled by default |
23rd January 2013, 19:00 | #17124 | Link | ||
23rd January 2013, 19:12 | #17125 | Link |
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 23rd January 2013 at 19:14. |
23rd January 2013, 19:40 | #17128 | Link |
madshi, repeated frames don't appear for me. My display is at 60hz. I'm interpolating everything to 60hz using SVP so the rates pretty much match exactly.
Does it only work if the original file rate matches the display rate or should it work if the actual rate after passing through the other filters in the chain matches the display rate. |
23rd January 2013, 20:06 | #17130 | Link |
Banned
Don't know if this longstanding small cosmetic issue was ever mentioned so here it is: madVRs OSD sometimes shows "1 frame repeat every 1.#J days" i.e. division by zero results in infinity, i guess.
23rd January 2013, 23:25 | #17132 | Link |
Holy crap madshi (and I speak for the rest of us when I say this) we love you! IVTC is smooth as butter now. 29.976 -> 23.976 with the monitor set to 48Hz by madVR and with Reclock taking it to 24.000 fps makes it perfect!
Thanks so much! Eventually I'm going to encode the few DVDs I still have to mkv files via AviSynth with IVTC, etc. but for now madVR is taking care of it very well Last edited by dansrfe; 23rd January 2013 at 23:28. |
23rd January 2013, 23:45 | #17133 | Link | |||
24th January 2013, 03:41 | #17139 | Link |
Hey madshi, since it's a new build I should mention something. Do you plan to fix the issue with ReClock in 24p@60Hz that you mentioned some time ago any soon? I kinda miss ReClock here. Oh, about that bug I was having with Overlay and stuff, seems like it totally disappears the moment I use copy-back instead of native in DXVA2, strange stuff.
Here they are disabled by default, are you sure you didn't miss anything?
madVR scaling algorithms chart - based on performance x quality | KCP - A (cute) quality-oriented codec pack |
24th January 2013, 06:42 | #17140 | Link |
Wanezhiling is correct, if I click on the reset default settings batch file the internal filters are still enabled. If I disable the internal filters and click on the default settings batch they're enabled again.
