12th September 2019, 11:24 | #57361 | Link | |
When I try to play a file with build 87 my TV turns black and then reports no input signal !! After turning off and on the TV MPC-BE has loaded the file but with wrong refresh rates, etc. Build 86 works perfectly fine. |
12th September 2019, 12:20 | #57363 | Link |
Yeah you won't get a response to test build issues here. You should post any issues you have with them in the proper thread on avsforum. You may want to try downloading it again and see if that helps though.
Sent from my SM-G975U using Tapatalk
12th September 2019, 12:48 | #57364 | Link |
QBhd
Just curious, what other settings used? What dithering, any image enhancements? What happens if you set HDR to let madVR decide? What happens with fast chroma upscaling algo like bicubic? Also is there any reasons why you prefer FSE instead of FSW? I belive 8350/270x is suitable for 23fps HDR. And for 1080@23 -> 2160 too. |
12th September 2019, 15:23 | #57365 | Link |
QB the Slayer
Just to be clear... Everything works, I just want to figure out why. It makes no sense. High bitrate 4k HDR should he a slideshow with the settings I am using. I hate not being able to figure something out.
For some reason Windowed mode does not work as well as FSE so it's what I use. Letting madVR decide for HDR won't work since Windows and I think madVR both don't recognize the GPU as being HDR capable... But I haven't really tried that since passthrough and tonemapping both work. Ordered dithering, no enhancements. My settings are not super crazy, but they should be swamping my system with a 4k UHD HDR bluray remux. Any ideas on why this IS working? QB
12th September 2019, 17:55 | #57366 | Link |
If it's decided that Envy should use an Nvidia Gpu,
They might as well release Madvr as a PC KIT, some sort of HDMI pcie input card,you can stamp these out by the thousands. Then have a PAID Madvr software version on desktop, compatible with ALL GPUS, Why make it a standalone device, it sounds like a good idea if you got a completely different hardware branch, But if it's gonna be Nvidia GPU, Madvr is already right here working all dandy like. .. Keep it simple.. Turn the PC into a receiver.. that's fine.. and we won't require a second $2000 for a Specialized device, which does the same thing, but is less versatile. The majority of people don't even have a living room anymore, they just sit in their rooms with a tv hooked up to PC> The living room is dead, <let's build more living room devices ?>
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 12th September 2019 at 18:00. |
12th September 2019, 19:36 | #57367 | Link | |
Looks like 1080p and 720p upscaling more demanding for your GPU than native 4K resolution playback. On my experience (fx8350 ex-user) this CPU can decode 4k remux very fine with LAV Video. But I'm not sure about your GPU. What exactly mean "bigger Present queues work with 4k but not work well with 1080p upscaled to 4k"? VRAM limitation? For example, NGU doubling/quadrupling increases the vram usage. As i remember i used bicubic chroma and med or low NGU luma with my 2gb nvidia GPU for good performance. |
12th September 2019, 19:45 | #57368 | Link |
QB the Slayer
Yeah. I go above and beyond VRAM, but it still plays smooth without dropped frames. I want to figure out how this is possible.
And no, upscaling is not more demanding with the same settings. I don't have a problem. I have a puzzle. Why do I have no dropped frames even though the GPU is constantly running out of VRAM. QB
12th September 2019, 20:22 | #57369 | Link |
The render queue is very big (1 full second of playback), maybe this is masking the latency of using system RAM as a crutch and the rendering jitter that would result from that (that 120 ms max render time stat is frightening).
Present queue should in theory not be influenced by the rendering load, it's just there to compensate random delays that could occur at the critical time when frames need to be displayed. So you're saying if you lower it to 6 or 4, playback is less smooth? The fact you said playback would initially turn into a slideshow with high bitrates scenes would point to decoding as the bottleneck, so in theory just upping the decoding queue should be the only thing needed. Did you try with a big decoding queue but a normal rendering/presenting? I have given up trying to understand how the older Radeons like yours or mine work with madVR, I have seen all kinds of weird behaviour with it, sometimes bringing up the UI or pausing or seeking back completely screws up rendering times on my desktop until I pause or seek again. Sometimes it drops a frame even though the GPU is only at 60-65% reported load. I have tried all combination of Radeon control panel and madVR settings to no avail.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
12th September 2019, 20:44 | #57370 | Link | |
locking powerstate in afterburner works for that.
Ghetto | 2500k 5Ghz |
12th September 2019, 22:44 | #57371 | Link | |
12th September 2019, 23:36 | #57372 | Link | ||
QB the Slayer
I just checked with AIDA64... my RAM latency is around the 60 ns mark... that's really low isn't it? Does that help when it needs to bail out the VRAM? (WOW I did not notice the 120 ms max stat! yikes!) As for weird things with pauses/seeks on our cards, I do notice it more with render queue at 8... I never had issues with it at 4. But that is the tradeoff for me to get zero dropped frames for the 4k HDR stuff. Quote:
QB
13th September 2019, 01:21 | #57373 | Link | |
NOW, all they need to do is build HALF of it for the PC Kit.
13th September 2019, 01:27 | #57374 | Link |
We already have it. My 2070 sits just above the specs for the base Envy's GPU and obviously lower than the 2080ti. While it would be nice to be able to "madvr-ify" any source, I'm happy with my HTPC right now. What would be GREAT is if the pro version of madvr would include some of the tensor core algorithms he's currently developing. madshi said this is the reason he's been *HEAVILY* hinting that people looking at new cards should go RTX. This isn't to say the AMD cards won't benefit, but, if he really does make the tensor core stuff available to us HTPC users, very exciting times are coming.
Don't get me wrong, I've been contemplating a capture card myself for 4K HDR sources, but, 1) it won't be real time like the Envy, and 2) There's likely some limitations around audio capture which has nothing at all to do with madvr. Wouldn't be as nice as an Envy, but, still beneficial IMO.
13th September 2019, 14:59 | #57375 | Link | |
anyways... the "best" "pro" version should not cost more than 25-30 bucks for a Lifetime license. otherwise he wont make much money with madVR, because people wont buy it or pirate/crack it. (just my 2 cents) |
13th September 2019, 15:28 | #57376 | Link |
So you're suggesting that all the work madshi has put in to this product is only worth "25-30 bucks for a lifetime license" to you? I would disagree with that assertion. Many of us have been asking for a donation link to give him far more than that to show our appreciation. He's consistently said wait for the pro version. If you're not willing to pay for a pro version, then the free version will always be available according to madshi.
13th September 2019, 16:17 | #57377 | Link |
Has madshi ever addressed whether the Pro version will lock current features behind a pay wall? Or will the Pro version just add as-yet-unreleased functionality? FWIW, I plan on buying the Pro version either way. Just curious...
Vizio P75-F1 | Denon AVR-S740H | Dayton B652-AIR/C452-AIR L/C/R | Boston VRS Micro Surrounds | Dayton Sub-1200 | HTPC (Win10, Red Dragon RX 5700 XT, Kodi, MPC-HC/MadVR) | PS4 | XBone |
13th September 2019, 17:10 | #57378 | Link |
No, he hasn't said ANYTHING about what a "pro" version would entail or how it would be different from the free version. Only that a pro version is planned "soon(ish)" <-- his word. I would very much be interested in a pro version myself, if only to support the man who has brought such an amazing video experience to us all.
13th September 2019, 17:40 | #57379 | Link | |
I would also be very interested in a pro version and quite happy to pay for it. |
13th September 2019, 17:50 | #57380 | Link |
Yes, of course it's been a very large community effort to get madvr where it is today! Look at the dynamic tone mapping testing that's going on now. But for all the community effort that's gone into giving madshi feedback, ultimately until now it's only been him developing it. But the community....that's why he's insisting that there is always going to be a free version of madvr going forward. I can imagine the pro version to be more refined in what it offers and how it offers it. Closer (but not identical) to the Envy experience except on an HTPC. That's just my own guesswork. We shall see what his plans are. I'm ready to support it by buying a license for Pro.
