11th September 2008, 17:13 | #122 | Link | |
AviSynth plugger
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
11th September 2008, 17:28 | #123 | Link |
Avisynth language lover
I imagine it's for debugging. Particularly if the filter string is constructed dynamically (eg by string concatenation which is a common approach inside functions).
It's curious that 'show' in ScriptClip (and FrameEvaluate) disables the actual filtering (it just returns the input clip) whereas in ConditionalFilter it acts in addition to the normal function. |
11th September 2008, 17:56 | #124 | Link |
AviSynth plugger
OK, I uploaded the updated text to CVS.
I hope that new text is fine not only with Wilbert, but with Avisynth code too
12th September 2008, 01:38 | #125 | Link |
Avisynth Developer
AVS 2.5.8 RC4a [080912]
Changelist with respect to 2.5.8 RC4 [080831] :
Changes: * Updated Russian documentation (Fizick). Note : Other contents are the same as AviSynth_080831.exe Changelist with respect to 2.5.8 RC3: See 1st post for full change list. Additions: * Updated Japanese documentation [20080813] (Niiyan). Bugfixes: * Fixed DirectShowSource() grey frames after end of stream + 30 frames. * Fixed Histogram() Classic mode restore graph brightness. Regression. * Fixed Compare() graph pixel values exceeding YUV limits. * Fixed AddBorders() args negative value clamping. Changes: * Initial Memory Max value clamped to 512MB. * Default Memory Max value restored to quarter of Free memory. Minimum 16Mb. As per 2.5.7. As usual download from Sourceforge. Enjoy! If we do not find any show stopper problems this could become the official 2.5.8 release. |
12th September 2008, 04:16 | #126 | Link |
TCPsource/TCPserver sometime lost connection and broke my encode, also AviSynth crash a lot when I run script with TCPsource second time. (not tested with today's build)
Why TCPsource not tries to reconnect? Last edited by Quark.Fusion; 12th September 2008 at 04:52. |
23rd September 2008, 16:53 | #128 | Link |
AviSynth plugger
IanB,
sorry, but I made litle changes of doc again (more compact look of overview.htm, english and russian)
2nd October 2008, 13:04 | #130 | Link |
Not sure if this is the right place to report possible bugs for RC4, if not, please let me know where is a better place.
I installed RC4, and the sound came out slower, a much lower frequency. I replaced DirectShowSource.dll with an older one Code:
12/24/2006 05:12 AM 24,576 DirectShowSource.dll Tac |
2nd October 2008, 13:17 | #131 | Link |
AviSynth plugger
tacman1123, of course, please provide link to your previous thread (post), and may be some Avi fragment.
2nd October 2008, 15:01 | #133 | Link |
cool, I'll do that! (The avi file is very big). Of course, now I'm having a hard time replicating the problem. Question: if I rename the dll in my plugins directory, is it definitely using the new version when the script runs? Or might it be caching a version? Is there a way I can force my script to use one over the other? I tried simply renaming the dll and calling it with that name, but that didn't work.
7th October 2008, 16:34 | #135 | Link |
AviSynth plugger
small doc update again
(SetMemoryMax according to http://forum.doom9.org/showthread.ph...19#post1177819 )
12th October 2008, 23:54 | #137 | Link |
No, the error message he reported was "Video framerate doesn’t match" when importing into DVD slideshow GUI, which makes me suspect the fault lies with that program.
Further evidence is that he also got the same error for AssumeFPS(30000,1001,true). Last edited by Gavino; 12th October 2008 at 23:59. |
17th October 2008, 22:18 | #138 | Link |
<The VFW Sheep of Death>
Ever since 2.5.8 alpha 2, directshowsource with convertfps is terrible. The resultant video is very choppy. All I'm doing is converting an mkv's framerate from 24000/1001 to 23.976. I've tried every release up until RC4a, and all have the same glaring bug. Going back to alpha 1 [070518] works perfectly. I've reported this bug before and was told simply that directshowsource was hopelessly b0rked. Well, over a year's worth of releases, and getting to a late 'release candidate' stage... the bug's still here.
Great work nonetheless!
Recommended all-in-one stop for x264/GCC needs on Windows: Komisar x264 builds! |
18th October 2008, 08:03 | #139 | Link |
Avisynth Developer
@DeathTheSheep,
Seems you have made 3 posts alluding to the subject, 12th November 2007, 03:38, 28th March 2008, 07:50 and 28th March 2008, 09:15. None really form a concise bug report with any evidence, logs or supporting material. CVS history of directshow_source.cpp Code:
---------------------------- revision 1.28 date: 2008/06/12 04:17:26; author: ianb1957; state: Exp; lines: +46 -7 Remember Allocator given in NotifyAllocator(), return it for GetAllocator(); GetAllocatorRequirements() E_NOTIMPL. ---------------------------- revision 1.27 date: 2008/05/26 22:22:17; author: ianb1957; state: Exp; lines: +106 -47 Add TID + PrintState to log, nuke PulseEvent + Use IGraphBuilder (Avery Lee), Fix QueryId() need CoTaskMemAlloc (Dean Pavlekovic), Fix QueryAccept change VideoInfo (Haali). ---------------------------- revision 1.26 date: 2007/10/08 23:09:39; author: ianb1957; state: Exp; lines: +14 -6 get convertfps=false logic right, fix Flush task interlock. ---------------------------- revision 1.25 date: 2007/09/11 06:43:04; author: ianb1957; state: Exp; lines: +122 -18 Refactor GetFrame, ConvertFPS now only relies on get_sample.GetSampleStartTime, fix jitter problems with recent M$ asf spliter giving bogus SampleEndTime values. ---------------------------- revision 1.24 date: 2007/05/01 05:49:58; author: ianb1957; state: Exp; lines: +6 -1 support WAVE_FORMAT_EXTENSIBLE ---------------------------- The algorithm I implemented is to calculate the start time of the requested frame number. Compare this value with the DirectShow sample start time of the next sample, for as long as the value is strictly less than, keep returning copies of the current frame. I have extensively tested the code and it does exactly as intended. I have to assume the algorithm is not what you require, but you have not offered any suggestion for an alternate algorithm. One issue I am aware of that may be affecting your results is timecode rounding that a few splitters seem to do. For a CFR 23.976 fps stream, we would expect timecodes to be :- --- 0, 4170837, 8341675, 12512512, 16683350, 20854187, 25025025, ..., 95929262, 100100100, 104270937, ... but a splitter might give something like this :- --- 0, 4200000, 8300000, 12500000, 16700000, 20900000, 25000000, ..., 95900000, 100100000, 104300000, ... This results in returned samples being 0, 0, 2, 3, 3, 4, 6, ..., 23, 24, 24, ... not exactly what one might find useful. You can limp around this particular issue by doubling the request framerate and selecting the odd samples, i.e. Code:
DirectShowSource(... , fps=23.967*2, convertfps=true).SelectOdd() |
18th October 2008, 11:59 | #140 | Link |
AviSynth plugger
Directshow si never will be finished complitely
In any case, Directshowsource is a plugin and may be updated later (if needed), as an small independent upgrade to Avisynth 2.5.8. Also for same reason DeathTheSheep can use older (alpha 1) DirectshowSource if he do not want provide a log .
