Old 27th January 2015, 21:06   #21  |  Link
Selur
Selur's Avatar
When I call:
ffmpeg -y -threads 8 -loglevel fatal -i "H:\Output\test.ac3" -ac 6 -ar 48000 -acodec pcm_s16le -f wav h:\Output\test.wav"
the channel order inside the test.wav file is okay, when I call:
ffmpeg -y -threads 8 -loglevel fatal -i "H:\Output\test.ac3" -ac 6 -ar 48000 -acodec pcm_s16le -f wav - > h:\Output\pipe.wav"
the channel order inside the pipe.wav file is okay, when I call:
ffmpeg -y -threads 8 -loglevel fatal -i "H:\Output\test.ac3" -ac 6 -ar 48000 -acodec pcm_s32le -f wav - | sox --multi-threaded --ignore-length --temp "H:\Temp" --buffer 524288 -S -t wav - -b 16 -t wav h:\Output\sox.wav
the channel order inside the sox.wav file is okay, when I call:
opusenc --bitrate 192 --comp 10 --framesize 20 --expect-loss 0 --max-delay 1000 h:\Output\sox.wav "H:\Output\test.opus"
the channel order of the test.opus file is okay, when I call:
ffmpeg -y -threads 8 -loglevel fatal -i "H:\Output\test.ac3" -ac 6 -ar 48000 -f sox - | sox --multi-threaded --ignore-length --temp "H:\Temp" --buffer 524288 -S -t sox - -t wav h:\Output\sox2.wav
the channel order of the sox2.wav file is okay, when I call:
ffmpeg -y -threads 8 -loglevel fatal -i "H:\Output\test.ac3" -ac 6 -ar 48000 -f sox - | sox --multi-threaded --ignore-length --temp "H:\Temp" --buffer 524288 -S -t sox - -t wav -b 16 - | opusenc --bitrate 192 --comp 10 --framesize 20 --expect-loss 0 --max-delay 1000 --ignorelength --raw-bits 16 --raw-rate 48000 --raw-chan 6 - "H:\Output\test.opus
the channel order is messed up.
Using:
 524288 -S -t sox - -t raw -b 16 - | opusenc --bitrate 192 --comp 10 --framesize 20 --expect-loss 0 --max-delay 1000 --ignorelength --raw --raw-bits 16 --raw-rate 48000 --raw-chan 6 - "H:\Output\test.opus"
channels are still messed up, but in another way.
Checked LameXP, and from the look of it, LameXP avoids the problem by creating a temporal wav file.
Found a workaround by using flac as intermediate:
ffmpeg -y -threads 8 -loglevel fatal -i "H:\Output\test.ac3" -ac 6 -ar 48000 -f sox - | sox --multi-threaded --ignore-length --temp "H:\Temp" --buffer 524288 -S -t sox - -t flac - | opusenc --bitrate 192 --comp 10 --framesize 20 --expect-loss 0 --max-delay 1000 --ignorelength - "H:\Output\test.opus"
alternatively if sox isn't used
ffmpeg -y -threads 8 -loglevel fatal -i "H:\Output\test.ac3" -ac 6 -ar 48000 -f flac - | opusenc --bitrate 192 --comp 10 --framesize 20 --expect-loss 0 --max-delay 1000 --ignorelength - "H:\Output\test.opus"
in both cases the channel order is correct.
Cu Selur
Old 28th January 2015, 09:14   #22  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
This looks silly to me...why you do not use the libopusenc directly in FFmpeg ?
Old 28th January 2015, 22:25   #23  |  Link
Selur
Selur's Avatar
Since I normally use sox for filtering.
Yes, I could probably decode with ffmpeg pipe to sox and then pipe to ffmpeg and use that for encoding.
Old 29th January 2015, 17:14   #24  |  Link
Reino
Reino's Avatar
@ Selur:
ffmpeg.exe -hide_banner -i test.ac3 -af "aresample=resampler=soxr:osr=48000:precision=28" -c:a libopus -vbr 0 -b:a 192k test.opus
or
ffmpeg.exe -hide_banner -i test.ac3 -c:a pcm_f32le -f wav - | sox.exe -t wav - -t wav - rate -v 48k | opusenc.exe --bitrate 192 - test.opus
My hobby website
Reino is offline   Reply With Quote
Old 30th January 2015, 20:01   #25  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Does anybody know what's going on with Opus development? Is it considered "mature" now? Have the core developers even moved on to another project?
I ask, because since v1.1, which contained huge improvements and was released more than a year ago, development has mostly ceased. At least judging from what's visible in official Git repository.
(In the last couple of months, there were mostly documentation updates and some smaller fixes. I also see no activity in any of the development branches)
Old 30th January 2015, 20:34   #26  |  Link
Selur
Selur's Avatar
through https://www.youtube.com/watch?v=Dmho4gcRvQ4 which is mainly about Daala it sounded like opus is kind of finished
Old 31st January 2015, 01:51   #27  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
It's all arm/neon optimizations now. There's no effort being put into quality improvement, maybe it's seen as good enough; we'll probably have to wait for someone else, the way 蒼弓 improved Vorbis so much. It's definitely mature and stable, though.
Old 12th February 2015, 00:48   #28  |  Link
Bloax
The speed of stupid
Bloax's Avatar
I'm somewhat disappointed that the encoder has been practically dropped what with them having teased us multiple times with a two-pass "the encoder actually knows what's coming" mode.
:v
Bloax is offline   Reply With Quote
Old 26th March 2015, 22:21   #29  |  Link
LoRd_MuldeR
Software Developer
libopus v1.1.x / opus-tools v0.1.9 [2015-03-14]
FWIW, fresh Opus builds from Git Master:
http://sourceforge.net/projects/muld...6.zip/download
Old 20th February 2016, 14:25   #30  |  Link
LoRd_MuldeR
Software Developer
libopus v1.1.2 / opus-tools v0.1.9 [2016-02-20]
Fresh Opus v1.1.2 builds, for your pleasure:
https://sourceforge.net/projects/mul...0.zip/download
Old 20th February 2016, 16:21   #31  |  Link
Brazil2
I was looking for recent OPUS builds which would run on XP without the need to hack them with an hex editor because they have been compiled without changing the MajorSubsystemVersion from 6 to 5.
These ones natively run on XP, thanks for doing it
Brazil2 is offline   Reply With Quote
Old 20th February 2016, 17:22   #32  |  Link
Reino
Reino's Avatar
Thanks, LoRd_MuldeR.
Unfortunately Xiph didn't include the 32-bit float piping bug fix (see here and here)
My hobby website
Old 20th February 2016, 18:08   #33  |  Link
LoRd_MuldeR
Software Developer
Can you point me to the latest patch? Rarewares.org seems to have patched binaries, but no patch (or link to patch).
Old 20th February 2016, 18:46   #34  |  Link
LoRd_MuldeR
Software Developer
Please try this:
https://mega.nz/#!2ctTHSqS!SEs9Ln698...RdDOmkW6wmYRWo
This should fix the Win32 seeking issue with pipe'd input.
Old 20th February 2016, 19:37   #35  |  Link
Reino
Reino's Avatar
It does. Thanks a lot!
In the meantime I've asked John Edwards to post the exact patch here, but it seems that's not necessary anymore.
I initially thought you were asking for the patch to approach Xiph with it. In my opinion this bug is important enough for them to include in the original git. Now you'd always have to patch it afterwards.
My hobby website
Old 21st February 2016, 12:23   #36  |  Link
LoRd_MuldeR
Software Developer
Now I'm confused. The problem in the seek_forward() function (only with pipes and only on Win32), which was discussed in the thread you linked, clearly seems not fixed in latest Opus Tools (Git).
So is the patch still needed or not?
Old 21st February 2016, 12:35   #37  |  Link
Reino
Reino's Avatar
Sorry for the confusion. You're right. I actually meant it wasn't necessary anymore for John to post the patch in order for you to create patched builds, but for the official Opus Tools git it would still be appreciated if he would.
On the other hand, since your build now also work, you could do it as well.
My hobby website
Old 24th February 2016, 21:48   #38  |  Link
Reino
Reino's Avatar
For those who can't download from MEGA.nz:
http://www.mediafire.com/download/00jvw3goex6fv6k/opus-tools.2016-02-20.pipe-fix.zip
My hobby website
Old 25th February 2016, 10:16   #39  |  Link
tebasuna51
tebasuna51's Avatar
LoRd_MuldeR update their upload at post http://forum.doom9.org/showthread.ph...72#post1757872 , I think is already patched now.
Is correct?
Old 25th February 2016, 11:04   #40  |  Link
Brazil2
Thanks a lot
Is correct?
This version doesn't have the piping bug fix.
