Old 9th July 2009, 11:26   #9101  |  Link
tebasuna51
tebasuna51's Avatar
@AnryV
The field info at header is useless, any DTS, also the core or with original bitdepth 16 bits, must be decoded to 24 bits to preserve the maximum precision.
The free dts decoders, at least, never read this field to output a bitdepth or other.
tebasuna51 is offline
Old 9th July 2009, 13:41   #9102  |  Link
AnryV
@AnryV
I know.
I spoke about core extraction - a procedure at which does not have decoding. I do not understand what for to change something in an original file of a core.
AnryV is offline
Old 9th July 2009, 14:07   #9103  |  Link
tebasuna51
tebasuna51's Avatar
You know, madshi always try to improve the output
Old 9th July 2009, 23:10   #9104  |  Link
killa_kid
Hey madshi I have a script which parses the output of eac3to to automatically add video/audio information to a database. This worked beautifully up to 3.15. For some reason PHP (the language the script is written in) will not capture any of the output from 3.16. Are you doing something different with the output now? I've tried redirecting output, which didn't work. According to PHP the program has no output, except my command line window says something different :P
Any help would be appreciated, I would like to upgrade if possible
Thanks!
killa_kid is offline
Old 10th July 2009, 01:47   #9105  |  Link
tebasuna51
tebasuna51's Avatar
You can use the eac3to parameter:
-log="X:\folder\file.log"
to obtain the output in a logfile.
Old 10th July 2009, 16:31   #9106  |  Link
buzzqw
HDConvertToX author
@killa_kid
yep.. i got the same error in my application (but i read stdout)
the last line is truncated
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 10th July 2009, 21:21   #9107  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
That's exactly what I did. Weird. I'll try it again after reinstalling TMT3 and see if it's some sort of conflict. Thanks for the help.
sorry but I forgot that this checkactivate.dll file is also required.
Atak_Snajpera is offline
Old 10th July 2009, 22:33   #9108  |  Link
SomeJoe
@killa_kid
BHH
Yes, I can confirm the same. I'm using the ShellExecute method from a .NET 2.0 front end, and the last line of eac3to.exe 3.16's output is not present when reading StdOut.
I have reverted to 3.14 for the time being.
- SomeJoe
SomeJoe is offline
Old 10th July 2009, 22:44   #9109  |  Link
Inspector.Gadget
Ah, no worries. I gave up and reinstalled but now I'll know for next time. Thank you.
Inspector.Gadget is offline
Old 11th July 2009, 15:07   #9110  |  Link
odin24
odin24's Avatar
Location: The Great North (the better half of North America)
Would demuxing a TrueHD stream, using 384kb/s as the core... as opposed to 640kb/s have a negative effect on the performance of the TrueHD stream?
I often include TrueHD audio on DVD9 recodes, using a 384k core would save some MBs.
odin24 is offline
Old 12th July 2009, 02:20   #9111  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
Originally Posted by TinTime View Post
You can demux streams by specifying the target as the same type as the source. For example, if track 3 is ac3, 4 is dts...
eac3to.exe source 3: output3.ac3 4: output4.dts
...will demux those tracks.
Got to try that out.
LeXXuz is offline
Old 12th July 2009, 07:18   #9112  |  Link
MrVideo
MrVideo's Avatar
AC3 audio output from 3 dual channel MP2 files
Here is the situation. I have a transport stream that has three MPEG-2 audio streams that comprise the 6 channels for AC3 encoding. They map as follows:
1) L/R
2) C/LFE
3) LS/RS
How do I tell eac3to to use those three dual channel streams as input to aften AC3 encoding?
Can it even be done?
MrVideo is offline
Old 12th July 2009, 07:21   #9113  |  Link
Snowknight26
No, not with eac3to.
Snowknight26 is offline
Old 12th July 2009, 07:29   #9114  |  Link
MrVideo
MrVideo's Avatar
Ok, thanks.
Rats!
MrVideo is offline
Old 13th July 2009, 19:39   #9115  |  Link
rik1138
The core stream shouldn't have any affect on the TrueHD stream at all. Obviously your core stream won't sound quite as good, but if you are playing the THD anyway, that shouldn't matter.
rik1138 is offline
Old 13th July 2009, 20:33   #9116  |  Link
odin24
odin24's Avatar
Thanks for the clarification.
odin24 is offline
Old 13th July 2009, 21:56   #9117  |  Link
DoomBot
Originally Posted by shambles View Post
eac3to has used -31db instead of 0db for a while now for that exact reason.. unless something is broken in the latest build, just running the file through eac3to again should set the flag to -31db eventhough eac3to doesn't show it (with -31db and 0db, no dialnorm value is shown)
So can the dialnorm info be restored to the file if eac3to has removed it? How would you restore it if its possible?
DoomBot is offline
Old 13th July 2009, 22:56   #9118  |  Link
73ChargerFan
73ChargerFan's Avatar
re-rip the audio track
73ChargerFan is offline
Old 13th July 2009, 23:00   #9119  |  Link
DoomBot
re-rip from the file that has no dialnorm info?
DoomBot is offline
Old 14th July 2009, 01:05   #9120  |  Link
73ChargerFan
No, from the original source disk, using the option " -keepDialnorm ".
Also, log file created when you ran eac3to will have the dialnorm setting. I don't know of any way to put it back into the stream.
eac3to
