Old 25th January 2009, 16:12   #1  |  Link
cobe
Issue withe LAME and XSPF WMP with IE
Hi there,
I'm having a funny issue with the LAME encoder (that's what I narrowed it down to), which I used to encode .wav to 96kbps, nonvbr, joint stereo, normal quality MP3s. Those are supposed to be played back by the XSPF Web Music Player (http://musicplayer.sourceforge.net/), which does work fine with Firefox (3.*) and Opera (9*), but not with IE (7 & 8 Beta 2). With Internet Explorer, the music is played faster, making it sound like The Chipmunks ... I tested that on 3 different PCs, and used multiple LAME settings (Mono, Stereo, VBR, high quality etc.) and versions (3.90alpha & 3.98). I use LAME via Audiograbber 1.82, but that should not affect this.
MP3s which are not encoded with LAME (different encoder mentioned in the .nfo) play back normal under IE as well ...
Has anyone heard of that before? Or could anyone imagine what to do here besides using a different encoder? (and if not, I would appreciate a recommendation)
Thanks in advance
cobe
cobe is offline   Reply With Quote
Old 3rd February 2009, 19:57   #2  |  Link
cobe
Hmm,
could maybe someone recommend another (free) mp3 encoder ?
Thank you very much in advance!
cobe
Old 3rd February 2009, 20:16   #3  |  Link
Irakli
Irakli's Avatar
You can try free MP3 encoder that comes with iTunes. Recent listening test shows that iTunes MP3 performs quite well in terms of quality (the test was done at 128kbps though).
Irakli is offline   Reply With Quote
Old 4th February 2009, 14:49   #4  |  Link
cobe
Thanks,
I found the responsible .dll's, quite a bit of work to unpack that thing and crawl through the .msi ... but sadly I have no idea on how to control it via parameters as an external encoder via EAC ... oh well, guess I have to install the monster
Thanks to everyone who gave it a thought though!
cobe
faster, internet explorer, lame, playback, xspf
