Old 27th November 2008, 14:26   #41  |  Link
Originally Posted by woah! View Post
with the 00006.m2ts file i linked earlier too, i get a error 700 message with it. not with the other 2 tho...
I can't duplicate that. Does it happen at the beginning or end?
and here another clip for you..
http://tinyurl.com/6bsdt4
Thanks but I don't know what to do with an AVI.
Guest is offline
Old 27th November 2008, 14:31   #42  |  Link
Originally Posted by bigotti5 View Post
Here are real interlaced samples, PAL and NTSC
Thank you.
Pulldowned stream is only a selfmade bars sample
How did you make it?
Guest is offline
Old 27th November 2008, 14:36   #43  |  Link
Audionut
Windows Media 9 Advanced Profile - aka VC1 - Encoded by
Adobe Media Encoder CS4.ts
Sony Vegas Pro 8.ts
Audionut is offline
Old 28th November 2008, 01:31   #44  |  Link
Audionut
batman.split.13.ts
Audionut is offline
Old 28th November 2008, 05:00   #45  |  Link
woah!
at the beginning but after that it previews the file fine.
that avi? was cut using mkv, then demuxed to the raw vc1 or so i thought. it plays fine through your program tho heh..
what is the best way to cut a clip from a m2ts file then?
woah! is offline
Old 28th November 2008, 11:01   #46  |  Link
Audionut
ATM for VC1 i'm using this.
http://forum.doom9.org/showthread.ph...66#post1196166
It can load mkv files and save to .ts or .m2ts which is fine for DGVC1DecNV.
It can also demux from .ts or .m2ts and split files.
Audionut is offline
Old 29th November 2008, 05:52   #47  |  Link
woah!
thx i was doing mkv that way, but had slow playback of the resulting clips? but by doing what ACrowley said here:
http://forum.doom9.org/showthread.ph...72#post1197472
and then process the vc1 dumped file to tsmuxer, cutting the vc1 file in m2ts clips i have no slow playback and the files are attached here to test (hopefully not avi)
split.34.m2ts from a hddvd hotfuzz movie has a pulldown showing in tsmuxer, so here are the same files, 1 with pulldown left in, and the other with tsmuxer removing pulldown:
pulldown: http://tinyurl.com/6f3wmp
pulldown removed: http://tinyurl.com/5n4nb5
another clip no pulldown: http://tinyurl.com/6gb3le
all 3 seems to play ok in DGVC1DecNV...
woah! is offline
Old 29th November 2008, 06:07   #48  |  Link
woah!
also i get this alot in all the files i have processed so far, even the 3 i originally posted which are untouched straight off the disc:
SEQ 43151838 !INTERLACE !PULLDOWN
ENTRY 43151860 !BROKEN !CLOSED
dont know if that is normal?
woah! is offline
Old 29th November 2008, 13:38   #49  |  Link
It's just indexing the file positions of the sequence header and entry point and values of some of their flags.
Guest is offline
Old 29th November 2008, 15:25   #50  |  Link
Sharc
Pre-alpha works here in preview and play mode, - tested with PAL BD
Edit:
Audio tracks (6 streams) are not demuxed when saving a project, only .dgv is output like:
STREAM 1
PKTSIZ 192
VPID 4113
FO 2
YUVRGB 1
LUMFILT 0 0
CLIP 0 0 0 0
RANGE 0 21613498367
AUDIO 1100,1101,1102,1103,1104,1105,1106
SEQ 990 !INTERLACE PULLDOWN
ENTRY 1012 !BROKEN CLOSED
FRM I PROG
FRM Pskip PROG
FRM B PROG
FRM B PROG
FRM Pskip PROG
FRM B PROG
FRM B PROG
FRM Pskip PROG
FRM B PROG
FRM B PROG
FRM Pskip PROG
FRM B PROG
FRM B PROG
FRM Pskip PROG
SEQ 175326 !INTERLACE PULLDOWN
ENTRY 175348 !BROKEN !CLOSED
FRM I PROG
FRM B PROG
FRM B PROG
FRM Pskip PROG
FRM B PROG
etc.
Sharc is offline
Old 29th November 2008, 16:19   #51  |  Link
If you want it fixed, you'll have to give me the stream so I can duplicate the issue. Use DGSplit to cut the first 50 MB.
Guest is offline
Old 29th November 2008, 19:29   #52  |  Link
DGVC1DecodeNV is done and working. I just have to do the documentation and revise the web site. Shooting for tomorrow or Monday.
Guest is offline
Old 29th November 2008, 19:30   #53  |  Link
rica
Hi, i get this when i try to open a raw VC1 file/or vc1ts.
(TS forms have been uploaded here:
http://forum.doom9.org/showthread.ph...18#post1217818 )
rica is offline
Old 29th November 2008, 19:38   #54  |  Link
Copy your license file to the same directory as DGVC1IndexNV.exe.
Guest is offline
Old 29th November 2008, 19:39   #55  |  Link
Never mind. I found the problem. Thank you for pointing it out.
Guest is offline
Old 29th November 2008, 19:43   #56  |  Link
rica
Sorry but what licence file do you mean?
rica is offline
Old 29th November 2008, 19:48   #57  |  Link
My CUDA-enabled tools require a license. See here:
http://neuron2.net/dgavcdecnv/dgavcdecnv.html
The license is good for all closed tools I may ever release and for all future versions thereof. Please take further discussion of this to PM. We've already had one flame fest about this.
Guest is offline
Old 29th November 2008, 20:07   #58  |  Link
rica
Thanks a lot.
rica is offline
Old 30th November 2008, 01:36   #59  |  Link
woah!
ah ok i just see ! with BROKEN and thought maybe i was still not clipping the files correctly or something.
cant wait to try the decoder
woah! is offline
Old 30th November 2008, 01:55   #60  |  Link
That's why I like to complete the documentation.
BROKEN refers to the syntax element "broken link".
Guest is offline
