Old 14th May 2020, 08:15   #461  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Originally Posted by Boulder View Post
What does MFinest actually do? There's no real documentation anywhere to be found.
If you look at the output of Super with pel=2 you'll see at the bottom of the frame 4 identically-sized images, and with pel=4 you'll see 16 identically-sized images. Those 4 or 16 images are actually one large image. I imagine they are stored like that so that Super doesn't waste lots of RAM in the top part of the frame.
Finest takes those 4 or 16 images and reassembles them into one (separate) image for the filters that need it. I think it's mostly the Flow* filters. They automatically invoke Finest when they need it.
I think this hack could be eliminated in the VapourSynth version because the various images produced by Super could be attached to the source frame as separate frame properties. If someone had the motivation to look into that.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 15th May 2020, 23:02   #462  |  Link
Pat357
I'm getting quite strange results considering the possible speed increases on my Ryzen 3900X. I would have expected the new Zen generation to be able to utilize the AVX2 optimizations really well, because they did help the first gen one when I tested Stephen R. Savage's early builds.
The first 2500 frames using vspipe:
v21 : 57.25 fps
v22 : 55.14 fps
What is so strange about these results ? I would expect better speed from a Ryzen 3900... did you limit the nr. of threads ?
Which was the optimized build ?
Tested your script with 1920x1080 YUV420P8 clip on my i7940X (14c/28t):
Mvtools R22 (optimized by Stephen R. Savage)
>vspipe -e 1999 boulder.vpy .
Output 2000 frames in 14.63 seconds (136.66 fps)
Mvtools R23 (current version)
Output 2000 frames in 17.34 seconds (115.37 fps)
I hope Stephen finds the time to optimize this new version
Pat357 is offline   Reply With Quote
Old 15th May 2020, 23:30   #463  |  Link
Are_
From a bluray?
Are_ is offline   Reply With Quote
Old 16th May 2020, 12:37   #464  |  Link
Boulder
Pig on the wing
Boulder's Avatar
R22 was the first official build with AVX2 optimizations. The thing looks like a compiler issue, the libraries built with MSVC are faster.
https://github.com/dubhater/vapoursy...ools/issues/47
Old 17th May 2020, 12:10   #465  |  Link
feisty2
I'm Siri
feisty2's Avatar
Originally Posted by tormento View Post
Would you please add MDegrainN (up to 6, at least)?
I need it to run G41Fun.py on noisy material.
I have tried MVTools single precision but it's simply too slow to have any use of it, at least the one without AVX2 requirement.
I might be able to add mvmulti functionalities (MAnalyze, MRecalculate, MCompensate, MFlow with radius, and MDegrainN) and cosine annealing ("thsad2") to this branch as well if the branch owner allows C++20 snippets in the code base.
feisty2 is offline   Reply With Quote
Old 17th May 2020, 12:33   #466  |  Link
tormento
Acid fr0g
tormento's Avatar
Great. I hope the SMDegrain script will be modified too.
@turment on Telegram
Old 17th May 2020, 12:39   #467  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Would you mind taking a stab at the scaling of vectors between different bitdepths (in case jackoneill doesn't have the interest to do it)?
Old 17th May 2020, 13:04   #468  |  Link
feisty2
I'm Siri
feisty2's Avatar
the thing is I'm not sure if jackoneill would accept C++20 code for 2 reasons
1) it breaks compatibility with tons of older compilers, in fact, GCC 10.1 is the only compiler that supports most of C++20 features currently.
2) the inserted snippets would have a very different coding style, it would look much more similar to dynamically typed languages than typical statically typed languages with a nominal type system (C, Java, C++98 (excluding template metaprogramming), etc.) some people find such code much easier to read and write and others find it hard to decipher. people have different coding mindsets, I personally think in structural typing and find type declarations useless, but lots of people rely on nominal typing and find code without type declarations hard to understand. jackoneill might also reject my code because he/she thinks the code is hard to maintain.
and I don't wanna create yet another mvtools branch if jackoneill decides not to merge my code.
Old 17th May 2020, 20:34   #469  |  Link
Pat357
Is there a MSVC compiled version for the new R23 available somewhere ?
I not smart enough to do it myself without a ready available .sln and other settings...
Old 18th May 2020, 08:11   #470  |  Link
ChaosKing
Thx HolyWu
Tested with SMDegrain and the clang version is the fastest, up to 3fps faster compared to R23. MSVC is the slowest, even slower then R23. ICL is a tiny bit slower then clang.
Tested with Ryzen 2600 on 1080p source.
Ranking
clang
icl
R23 release
msvc
Old 18th May 2020, 11:50   #471  |  Link
tormento
Acid fr0g
tormento's Avatar
I am losing a bit the thread. Has been MDegrain up to 6 and N implemented or not?
Old 18th May 2020, 11:55   #472  |  Link
feisty2
I'm Siri
feisty2's Avatar
no, judging from jackoneill's lack of response, I don't think he/she will merge C++20 code, and I don't wanna create another mvtools branch.
your best shot is with the floating point branch if you do need arbitrary radius MDegrain and cosine annealing
Old 18th May 2020, 12:48   #473  |  Link
tormento
Acid fr0g
tormento's Avatar
Too slow. I will keep on using AVS+. What a pity.
Old 19th August 2020, 07:33   #474  |  Link
feisty2
I'm Siri
feisty2's Avatar
is this a typo? https://github.com/dubhater/vapoursy...lowBlur.c#L392
shouldn't it be d.blur * 256. / 100?
Old 19th August 2020, 12:56   #475  |  Link
jackoneill
unsigned int
jackoneill's Avatar
It looks deliberate. It's 200 again just a few lines above.
Old 2nd January 2023, 11:34   #476  |  Link
ChaosKing
Happy new year
https://github.com/dubhater/vapoursy...f67254580b7ab9
Old 5th January 2023, 22:15   #477  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Haha you池e welcome.
Thanks for posting this, I壇 neglected to. A few more cleanups have been made since then as well. May minorly increase speed, but only minorly.
I知 still working on more updates in my free time. I知 working on AVX2 degrain cleanups and then hopefully incorporating more x264 code for higher bit depths, but we値l see about that.
Longer term id like to add some basic DegrainN support (but limit it to radius 6 for now), add high bit depth degrain AVX and SSE2 code, support block size 24 (with a simple C implementation for now), and add high bit depth support to Mask. I say all that, but it痴 not all trivial amounts of work, and I知 doing this in my random free time, so we値l see how it goes.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
