Old 23rd October 2009, 16:21   #161  |  Link
dstln
Person
dstln's Avatar
And if anyone still cares about the benchmarks, I was burning in/testing a new cpu last night.
Source: C:\temp\test.avs
Preset: Medium
Tuning: None
Profile: High
Params: --level 4.1 --thread-input --deblock -2:-2 --bframes 7 --b-adapt 2 --direct auto --ref 10 --merange 24 --me umh --subme 10 --partitions all --trellis 2 --psy-rd 1.0:0.0 --no-dct-decimate --no-fast-pskip --psnr --ssim --sar 33:27
[Type: 32-Bit, Pipe Buffer Size: 0 MByte]
encoded 9750 frames, 7.53 fps, 2582.80 kb/s
encoded 9750 frames, 7.58 fps, 2582.80 kb/s
encoded 9750 frames, 7.50 fps, 2582.80 kb/s
[Type: 64-Bit, Pipe Buffer Size: 0 MByte]
encoded 9750 frames, 8.68 fps, 2582.80 kb/s
encoded 9750 frames, 8.59 fps, 2582.80 kb/s
[Type: 64-Bit, Pipe Buffer Size: 1 MByte]
encoded 9750 frames, 8.76 fps, 2582.80 kb/s
encoded 9750 frames, 8.74 fps, 2582.80 kb/s
encoded 9750 frames, 8.53 fps, 2582.80 kb/s
[Type: 64-Bit, Pipe Buffer Size: 2 MByte]
encoded 9750 frames, 8.80 fps, 2582.80 kb/s
encoded 9750 frames, 8.72 fps, 2582.80 kb/s
[Type: 64-Bit, Pipe Buffer Size: 4 MByte]
encoded 9750 frames, 8.64 fps, 2582.80 kb/s
encoded 9750 frames, 8.66 fps, 2582.80 kb/s
[Type: 64-Bit, Pipe Buffer Size: 8 MByte]
encoded 9750 frames, 8.63 fps, 2582.80 kb/s
encoded 9750 frames, 8.60 fps, 2582.80 kb/s
encoded 9750 frames, 8.69 fps, 2582.80 kb/s
further proof that 2m buffer seems to perform best, and with a nice ~1.16x speedboost over 32-bit x264
dstln is offline   Reply With Quote
Old 24th October 2009, 19:55   #162  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by ACrowley View Post
Cab you add a minimize Button please ?
Done.
Old 24th October 2009, 20:35   #163  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
I just downloaded and re-downloaded latest ver but don't see minimize button...
Old 24th October 2009, 21:31   #164  |  Link
LoRd_MuldeR
Software Developer
http://img188.imageshack.us/img188/9380/minimize.png
Old 24th October 2009, 21:55   #165  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Originally Posted by LoRd_MuldeR View Post
Ahaa! I didn't think I need to start the encode, I expected to see it near the "close" button!
Thanks for this useful feature!
Old 24th October 2009, 21:56   #166  |  Link
LoRd_MuldeR
Software Developer
I think minimizing the window is only of interest for the user while encoding
(BTW: Tool windows cannot have a "normal" minimize buttons)
Old 26th October 2009, 21:18   #167  |  Link
prOnorama
Thanks for this LordMulder, I was looking for a MeGUI replacement just to do the encoding part, I just want to encode using the latest x264 32 bit (MeGUI is contantly out of date and sometimes buggy)
Did a test and it worked with the latest x264 32 bit (1310) using my own custom command line
I know this is not meant as a full GUI but it would be nice if you can store custom command lines under (a few) profiles and give them your own name (like "DXVA 720p HQ" or "DXVA 1080p SHQ").
An option to auto-save the log file would be nice too (especially for lazy people like me )
Cheers
PS: there's a small typo in the log-> "Analayzing Source File" ->
"Analyzing Source File"
prOnorama is offline   Reply With Quote
Old 27th October 2009, 00:42   #168  |  Link
prOnorama
Bummer, it doesn't let you set an exact bitrate (like 7238), just rounded to the nearest 100, if I enter it manually on the command line I get a "Please don't specify the "--bitrate parameter", I will do this for you, if required" warning.
Old 27th October 2009, 01:17   #169  |  Link
Darth Viorel
You can set an exact bitrate, but the automatic correction will change wron values. So as 7 kbit/sec isn't allowed, it will make 100 out of it. If you just paste your desired bitrate into the box even 7238 is possible.
Darth Viorel is offline   Reply With Quote
Old 27th October 2009, 10:21   #170  |  Link
egrimisu
egrimisu's Avatar
great too, a queue would be excelent. Thanks
I7 920 @ 3.60GHz + Thermalright Ultra 120 Extreme
Asus P6T Deluxe, 6GB Corsair XMS3 1600MHZ 8-8-8-24
2x1TB Samsung + 1x500GB Samsung,
Corsair 520W, Thermaltake Soprano DX
GeForge GTX280
egrimisu is offline   Reply With Quote
Old 27th October 2009, 12:35   #171  |  Link
LoRd_MuldeR
Software Developer
The behavior of the SpinEdit control to enforce the Min value isn't very convenient, I know.
However you can enter the desired bitrate manually using number-keys. But the intermediate value must not be too small.
So don't erase the complete number. Better change one digit at a time...
Old 28th October 2009, 21:06   #172  |  Link
Zarxrax
Could I get a sample command line for how to use avs2yuv and pipebuf with x264? Thanks.
Zarxrax is offline   Reply With Quote
Old 28th October 2009, 21:07   #173  |  Link
LoRd_MuldeR
Software Developer
I'd say look at my GUI. It prints out the full command-line to the log/progress window
Old 28th October 2009, 21:10   #174  |  Link
Zarxrax
Oh, ok
Old 28th October 2009, 21:37   #175  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
This is a great tool, Lord_Mulder!!!
I will be using this for all my x264 encoding needs for the time being!
~MiSfit
Old 29th October 2009, 20:21   #176  |  Link
LoRd_MuldeR
Software Developer
Updated x264 to r1310 (Komisar's builds). Also made the "Bitrate" SpinEdit box easier to edit. Download link in first post updated!
Old 31st October 2009, 07:18   #177  |  Link
McArty
Thank you LoRd_MuldeR for your continuous work.
P.S.That minimize button was very useful for me.
McArty is offline   Reply With Quote
Old 31st October 2009, 10:08   #178  |  Link
turbojet
Is there any chance of being able to type in the path\file boxes?
Also since I notice x86 x264 is faster then x64 on first pass or really fast settings is there any chance of adding an option to use x86 on first pass, x64 on second pass?
Also an option to use x86 x264 would be very useful for everyone that are still on x86 OS's and want to use a simple GUI.
Old 31st October 2009, 11:51   #179  |  Link
LoRd_MuldeR
Software Developer
Nope
Runtime x86 -vs- x64 is already implemented
Old 31st October 2009, 14:06   #180  |  Link
sjakke
sjakke's Avatar
Image in first post is broken.
What do you think rubber ducky? Quack. Quack. My thoughts exactly.
sjakke is offline   Reply With Quote
