Old 2nd January 2005, 15:37   #21  |  Link
Socio
Well what ever pruned did it works well!
Soulhunter,
The hacked LimitedSharpen script works great!
I tried it out using Zoomplayer+ffdshow-avisynth in real time and got noticeable image improvement with only about an average 5% increase in CPU usage.
Here are some pic's ( I know not the exact same frame but you can get the idea):
Normal
LimitedSharpen @ LimitedSharpen(ss_x=1.0,ss_y=1.0,Smode=3,strength=40
LimitedSharpen2 @ LimitedSharpen2(ss_x=1.0,ss_y=1.0,Smode=4,strength=40,aSharpS=1)
LimitedSharpen @ aSharp(0.4,0,0.LimitedSharpen(ss_x=1.0,ss_y=1.0,Smode=3,strength=40
LimitedSharpen2 with hacked version of IIP
Socio is offline   Reply With Quote
Old 2nd January 2005, 16:47   #22  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Ok, I asked pruned for the exact changes...
- Chroma to luma warper
- Improved stability
- Improved precision
- Other small fixes
@ Leak
Seems he wont release the source!
Bye
Visit my IRC channel
Soulhunter is offline   Reply With Quote
Old 2nd January 2005, 18:10   #23  |  Link
Didée
Shall I calm down the hype a little?
Regarding usage within LimitedSharpen:
LimitedSharpen(strength=150) gives practically the same result than LimitedSharpen2(), except for some of the minor warping effects (obviously) - only that the original function runs 2%~3% faster, at least on the machine I tested it on (Celeron2600). Honestly, I see hardly an improvement.
Regarding the plain combo:
Generally, aSharp oversharps just like any other sharpener does. The genious trick here is that it's only used with such low settings that no visible oversharpening occurs with usual input. So it could have been any other sharpener as well, it's not like this was the "magic combo" ... except perhaps for some aSharp specific things like the block adaptive stuff - but I think those are disabled anyways with the suggested settings (are they? I don't know aSharp that good )
Old 2nd January 2005, 18:17   #24  |  Link
Socio
Problem;
After watching a DVD a bit using the new LimitedSharpen2 I noticed that some edges are askew and develop a life of their own. Vertical edges tend to have strange spiraling lines that move along those edges from bottom to top. Horizontal edges have jagged lines that move as well.
The lower I set "aSharpS=" the less predominant the anomalies become however this also reduces the aSharp sharpening enhancement to the point of a no gain for no anomalies.
I have no such problems with the Original LimitedSharpen so it must have something to do with either the new script or the dll's themselves.
Old 2nd January 2005, 18:29   #25  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
@ Socio
Do you get this effect also with the original combo?
aSharp(0.5,0,0).aWarpsharp(3,1,bm=3,cm=0,thresh=0.99)
Bye
Old 2nd January 2005, 19:14   #26  |  Link
Socio
Here is a pic of the strange edges (they move or are animated during playback) I get using LimitedSharpen2, the image has been re-sized to easier to see the anomalies. (just look at the back of the chair)
Normal
LimitedSharpen2
Old 2nd January 2005, 19:56   #27  |  Link
Socio
Originally posted by Soulhunter
@ Socio
Do you get this effect also with the original combo ???
Maybe its possible to replace aSharp with something else (maybe even with LS) !?!
Bye
I have not tried just the combo yet but have found just the opposite of replacing aSharp with LS. I tried using the new aSharp before LS and get excellent results no anomalies, looks like this;
aSharp(0.4,0,0)
If I tried the same thing with aWarpsharp and I get the edge anomalies so it appears it is aWarpsharp that is causing my problems not aSharp. So perhaps pruned needs to turn something down a bit in that aWarpsharp.dll.
I am going to post a fourth pick with the above settings in my previous post with the other three pic's
Old 2nd January 2005, 21:17   #28  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
@ Leak
Seems he wont release the source !!!
Well, I at least had to try...
np: Gescom - Megamix (ISS:SA)
Leak is offline   Reply With Quote
Old 2nd January 2005, 21:30   #29  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Have you used aWarpSharp before or after LimitedSharpen?
And, are this artefacts already in the source?
Maybe aWarpSharp just amplified them...
Bye
Old 2nd January 2005, 22:38   #30  |  Link
Socio
Have you used aWarpSharp before or after LimitedSharpen ???
Both
And, are this artefacts already in the source ???
No
No, it is for sure the aWarpSharp.dll though;
I tried the combo with the same results I will mess with the settings some more maybe turn them down some to see if it effects it.
Bye
Old 2nd January 2005, 23:14   #31  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
@ Socio
Could you maybe post the source frame of the pic above?
Bye
Old 2nd January 2005, 23:37   #32  |  Link
Socio
@ Socio
Could you maybe post the source frame of the pic above ???
Bye
Done, I put it in the post with the other pic for easier comparison.
Old 3rd January 2005, 03:36   #33  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Hmm, for some reason Im not able to reproduce your result...
Here is the source frame + Limitedsharpen2(ss_x=1,ss_y=1,aSharpS=2)
Bye
Old 3rd January 2005, 15:57   #34  |  Link
Socio
Wow!
Your pic looks real good, yet when I try the exact same settings I get the bad edges I even get them using aWarpsharp by it self.
Obviously something is interfering with aWarpsharp do not know if it is my video drivers, perhaps another dll in my plugin folder is causing a conflict I will have to do some more investigating.
Thanks
Old 3rd January 2005, 22:33   #35  |  Link
Socio
I figured it out;
I changed the thresh to 0.5 and BM to 2 and no more edges problems. I edited the Limitedsharpen2 script to refelect those changes and it works great.
Old 4th January 2005, 16:26   #36  |  Link
Socio
I added another Yoda pic using LimitedSharpen2 and my hacked version of IIP\LimitedSharpen combo which I removed the LimitedSharpen part.
Old 4th January 2005, 17:09   #37  |  Link
Didée
hack!hack!hack!hack!
Well, congratulations for "hacking" the script, where you simply could have called iiP with "Xstren=0" ...
(In future, I will make all my scripts sans parameters, and say "if you wanna adjust anything, please hack the script yourself." - Fine with me: that's less work. *much* less ...)
BTW, your latest picture reminds me a little of LS-EX, which (hopefully) should run faster than iiP, once it's fully finished. Currently, both are roughly on par.
Old 4th January 2005, 18:04   #38  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Added a parameter to change aWarpSharp's treshold... ^^
Bye
Old 4th January 2005, 23:33   #39  |  Link
Socio
Re: hack!hack!hack!hack!
I spent half a day doing trial and error trying to remove LimitedSharpen from IIP and all I had to do was change one parameter to 0 to turn it off. Talk about not seeing the forest for the trees!
Old 5th January 2005, 08:59   #40  |  Link
Didée
Hah, I found an even faster method than this aSharp().aWarpsharp() combo !!!
Try the following:
sharpen(0.2)
W00T!
But seriously. A method to *really* do a minimal version of LS was pointed out by kassandro, uses his RemoveGrain filter set, and was named ModerateSharpen():
#  a function by kassandro.
# (just made "repmode" a parameter / Didée)
function ModerateSharpen(clip input, float amount, int "repmode")
	repmode = default(repmode,1)
	sharpened = Sharpen(input, amount)
	return Repair(sharpened, input, mode=repmode)
This one should run above realtime without any problems. Practicable "repmode"s are 1 & 2. Maximal "amount" is 1.0, but one should use less, because of the aliasing problem.
