Old 29th July 2020, 05:42   #41  |  Link
Asmodian
Try running only the ffmpeg part and see what it says. It sounds like ffmpeg cannot open the file, so yes, not outputting to SDOUT. Changing to -loglevel info instead of -loglevel fatal would also help gain insight into what is going wrong.
madVR options explained
Old 29th July 2020, 17:28   #42  |  Link
BobbyBoberton
it works if I specify the -pix_fmt as yuv420p10 on the FFmpeg command but I cant figure out how to generate that from staxrip so its still not really able to automate it...
actually tried putting -pix_fmt yuv420p10le (as that is what the source is but I still get the error
Guessed Channel Layout for Input Stream #0.1 : 5.1
[yuv4mpegpipe @ 0000020f7ba0a740] Warning: generating non standard YUV stream. Mjpegtools will not work.
y4m [info]: 3840x1920 fps 24000/1001 i420p10 sar 1:1 unknown frame count
BobbyBoberton is offline   Reply With Quote
conservation, ffmpeg, hdr, hevc, metadata
