Old 30th October 2019, 13:07   #1  |  Link
Starduster
Starduster's Avatar
What codec for webm?
On a new Server 2019 and trying to use .avs input to ffmpeg and getting similar, but different, errors on DirectShowSource and FFVideoSource.
sld2=DirectShowSource("8_0_0_2.webm", fps=15, convertfps=True)
Gives the error: The format is not supported and
v=FFVideoSource("8_0_0_2.webm")
Gives the error: Video codec not found. If I switch the sequence so I call FFAudioSource first, I get the error: Access Violation.
I have installed the K-Lite Basic codec pack but I thought that's all I had installed previously. The MediaInfo for the file is:
Format : WebM
Format version : Version 4
File size : 3.17 MiB
Duration : 11 s 939 ms
Overall bit rate : 2 230 kb/s
Writing application : Lavf58.33.100
Writing library : Lavf58.33.100
Video
Format : VP9
Codec ID : V_VP9
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Language : English
Default : Yes
Forced : No
Color range : Limited
ALPHA_MODE : 1
Audio
Format : Opus
Codec ID : A_OPUS
Duration : 11 s 640 ms
Channel(s) : 1 channel
Channel layout : C
Sampling rate : 48.0 kHz
Bit depth : 32 bits
Compression mode : Lossy
Language : English
Default : Yes
Forced : No
I assume there is a missing codec but this stuff has surprised me before!
Life is more interesting viewed upside down
Starduster is offline   Reply With Quote
Old 30th October 2019, 15:42   #2  |  Link
sneaker_ger
Can you try the following ffms2 binary?
https://ln2.sync.com/dl/917b6fe60/d9...xwnur-j9bbdfcz
Old 31st October 2019, 11:56   #3  |  Link
Starduster
Starduster's Avatar
Excellent!! That worked. I had a fffms2.dll in the plugins directory but it was from 2013. Thanks for the great help!
avisynth, codec, webm
