Old 19th September 2016, 09:23   #1  |  Link
qiangbro
qiangbro's Avatar
Are there any avisynth filter can render subtitle with Emoji?
Emoji is very popular today, Huge number of people use it, and there're also a lot of emoji libraries :
https://github.com/twitter/twemoji
http://emojione.com/
so, my question is:
Are there any avisynth/VapourSynth filter can render SubStationAlpha file with Emoji in it?
I am not a c-language programmer, I don't know how to develop this function, so I came here for help.
I hope in the future, someone can develop an emoji filter with these features:
1. works like vsfilter / xy-vsfilter / vsfiltermod
2. render SubStationAlpha with colorful emoji in it
3. allow user to switch emoji library (eg. twemoji / google emoji / apple emoji ...)
qiangbro is offline   Reply With Quote
Old 19th September 2016, 10:20   #2  |  Link
qiangbro
qiangbro's Avatar
I have tried vsfilter, xy-vsfilter, vsfiltermod.
It seems they do not support emoji yet, because emoji is a new thing for those period.
Old 19th September 2016, 20:56   #3  |  Link
did you made sure the font you are using has support for this?
Old 19th September 2016, 21:06   #4  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
I tried using "Segoe UI Emoji" (included with Win 8.1) which has color emoji, but the subtitles are monocolor. The problem is the ASS subtitle format defines fill, outline & shadow colors, so a non-standard renderer would be required to show color emoji.
raffriff42 is offline   Reply With Quote
Old 20th September 2016, 07:44   #5  |  Link
filler56789
SuperVirus
filler56789's Avatar
IMHO, the actual problem is, ALL the current implementations of "built-in" color characters in fonts are hacks && non-standard...
https://typography.guru/journal/windows-color-fonts/
Also, and for a change, M$ products don't follow their own specifications
filler56789 is offline   Reply With Quote
Old 20th September 2016, 11:46   #6  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
That's interesting thanks, filler56789
Old 21st September 2016, 04:34   #7  |  Link
qiangbro
qiangbro's Avatar
I hope in the future, someone can develop an emoji filter ☺
Old 21st September 2016, 11:39   #8  |  Link
filler56789
SuperVirus
You mean "add support for «fonts with color glyphs»", alright
Because if you don't have a desperate need for "native" color emojis,
then the current versions of (xy-)vsfilter should do fine
Cheers 😇
P.S.: besides, never ever apply italics onto emojis...
not even because of someone's birthday...
Last edited by filler56789; 21st September 2016 at 11:50. Reason: This undead vBulletin surely has a problem with emojis...
Old 25th September 2016, 10:58   #9  |  Link
filler56789
SuperVirus
Very well, at last I have created and seen emoji subs through TextSub()...
and I don't know what to say about them
Old 7th October 2016, 15:14   #10  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
Supposedly ASS supports [Picture] events, but I couldn't get them to work. I don't think there is renderer support for them.
If someone was motivated enough, they might try converting emoji to SVG somehow (eg, Inkscape) and using SVG2SSA to make ASSDraw vector art.
EDIT original emoji as SVG here: https://github.com/rodrigopolo/minEm...ji-SVG/img/svg
avisynth, emoji, twemoji, vapoursynth
