Old 22nd August 2013, 20:06   #81  |  Link
opteronup
I managed to compile d2vsource with ffmpeg 2.0.1.
Thanks, jackoneill.
The problem with git version of ffmpeg was that my vapoursynth was built with ffmpeg 1.2.1.
I didn't know that I must use the same ffmpeg for compile vapoursynth and d2vsource.
Then I tried to build vapoursynth with ffmpeg git but I also received errors.
And now I used ffmpeg 2.0.1 to compile vapoursynth and d2vsource and everything works fine.
opteronup is offline   Reply With Quote
Old 17th November 2013, 15:40   #82  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Please read several posts starting from this one:
http://forum.doom9.org/showthread.ph...50#post1653750
Not sure, but it seems that d2v.Source hangs if requested a frame with number beyond the real source length.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 17th November 2013, 16:40   #83  |  Link
handaimaoh
Posts: n/a
Yeah, the filter simply doesn't handle such a case. It seems to just assume that any frame number it is given is in the valid range. I'll send them a pull request real fast with a fix.
If you want a compile a test version to try the fix I have it here. If it works, I'll do the pull request up. Fix in the getframe functions was to add:
    if (n >= d->d2v->frames.size()) {
        n = d->d2v->frames.size() - 1;
Old 17th November 2013, 16:57   #84  |  Link
Gavino
Avisynth language lover
Normally, the Avisynth cache filter (inserted automatically after all script filters) will ensure that all frame requests actually received by your filter are in range.
However, I guess that does not apply in Vapoursynth. (?)
(and it's still bad practice anyway for a source filter)
Old 17th November 2013, 17:01   #85  |  Link
handaimaoh
Posts: n/a
Well it's just a quirk of the API like Myrsloik says. It's such a simple thing to check for though. And as he says, it's going to be changed.
Originally Posted by Myrsloik View Post
I'm going to change it for r22, that's why I didn't notice all the crashes you were getting.
Also, I've fixed the check once again to be a ">=" as it was originally.
Old 17th November 2013, 17:58   #86  |  Link
handaimaoh
Posts: n/a
I've created a pull request that fixes this issue and set it off.
Old 17th November 2013, 18:03   #87  |  Link
n  = (n<0)	? 0 : (n>= vi.num_frames) ? vi.num_frames - 1 : n;		// Range limit frame n
In Avisynth speak.
Old 17th November 2013, 18:08   #88  |  Link
handaimaoh
Posts: n/a
n  = (n<0)	? 0 : (n>= vi.num_frames) ? vi.num_frames -1 : n;		// Range limit frame n
In Avisynth speak.
Yeah that would work as well. I just forgot about using the VSVideoInfo. Probably more elegant that way too. Fixed up the pull request to be like this instead. Looks like:
// Range limit n
n  = (n < 0) ? 0 : (n >= d->vi.numFrames) ? d->vi.numFrames - 1 : n;
Old 17th November 2013, 18:58   #89  |  Link
Gavino
Even more elegant is
n = min(vi.num_frames-1, max(0,n));
which is what the Avisynth Cache filter uses.
Old 17th November 2013, 20:00   #90  |  Link
Daemon404
Please see: https://github.com/dwbuiten/d2vsourc...mment-28655105
Daemon404 is offline   Reply With Quote
Old 17th November 2013, 21:39   #91  |  Link
Mystery Keeper
Beyond Kawaii
In my opinion it is not wise to omit a guard based on assumption that it won't be needed in the next release. It might be broken later. Or some other software might misuse the library interface. Since the check is only made once per frame - 'tis a quite welcome and non-hindering precaution.
...desu!
Old 17th November 2013, 21:55   #92  |  Link
Daemon404
Sorry, scattering basic sanity checks over every single plugin for VapourSynth, because it was once a bug in the core, is retarded. It negates the point of a framework. It's a hack.
Maybe I should also add a check to make sure water is wet too.
Old 17th November 2013, 22:04   #93  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
I don't intend to change the behavior back ever. This change is permanent since it makes sense and slightly simplifies plugin writing. It also means that not all plugins have to be littered with the same check again and again. Or more exactly as many different versions of the check as there are coders on doom9.
On the subject of backseat coders (which we've been having quite a few of recently), the correct answer is:
if (d->vi->numFrames && d->vi->numFrames <= n)
  n = d->vi->numFrames -1;
Number of people posting in this this thread who got it right: 0
Myrsloik is offline   Reply With Quote
Old 17th November 2013, 22:43   #94  |  Link
Best place for check on having video is in constructor, not getframe. Guess it means -ve n is ok then.
Maybe so.
Old 17th November 2013, 22:54   #95  |  Link
lansing
may we be expecting a 64bit version soon?
Old 18th November 2013, 15:13   #96  |  Link
Daemon404
Done. As of Beta 6, the windows zip contains both 32bit and 64bit builds.
ChangeLog here.
I also SHOULD get to writing the d2v creation utility... life is busy. Meh. There's still this, though.
Old 19th November 2013, 19:53   #97  |  Link
Mystery Keeper
Beyond Kawaii
This video makes VapourSynth crash near the end when loaded with D2V Source. Other d2v projects don't, so the bug most likely is not in VS.
...desu!
Old 23rd November 2013, 22:58   #98  |  Link
Daemon404
I'll look into it on Monday.
Old 29th November 2013, 02:23   #99  |  Link
Mystery Keeper
Beyond Kawaii
Hope this crash report can help.
...desu!
Old 29th November 2013, 11:22   #100  |  Link
Daemon404
Sorry, I've been busier this week than expected. I've filed an issue for it, and will poke it this weekend (I am currently on a transatlantic flight after a week of work).
d2v, dgindex, vapoursynth
