Old 8th August 2012, 17:12   #1  |  Link
zmejce
Anything like DivX vs XviD vs x264 2012 tests?
Im interested which one is better in 2012,
Back in the days of DivX 3.11 and nanDub there wasnt XviD.
Later XviD came out, and became (probably?) better than DivX 3.
How are they compared in 2012 with the latest releases?
I saw few screenshots, DivX vs XviD, the results from what i saw was that XviD has sharper image (better), DivX has smoother image (worse), but DivX has slightly better colors than XviD.
Also, what about the filesize, encoding and decoding speed (which one can be played on weaker pc)?
If latest DivX is smoother than XviD, than maybe it can be compared with x264 for HD content?
zmejce is offline
Old 8th August 2012, 20:47   #2  |  Link
Asmodian
I don't think much has changed in the MPEG-4 ASP world.
File size cannot be separated from quality. Both are very fast to decode or encode in software (decode is the same for both) but now there is a lot of hardware available to decode mpeg-4 AVC which is not used for mpeg-4 ASP.
Anything can be compared with x264 but I know DivX doesn't compare well to x264, HD or not.
Last edited by Asmodian; 8th August 2012 at 21:56. Reason: fixed H.264 = mpeg-4 confusion
Asmodian is offline
Old 8th August 2012, 21:06   #3  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
it should be written as
mpeg-4 asp (divx,xvid...)
mpeg-4 avc or h.264 (x264,atheme...)
Atak_Snajpera is offline
Old 8th August 2012, 21:53   #4  |  Link
Asmodian
oops! Thanks
Asmodian is offline
Old 8th August 2012, 23:41   #5  |  Link
zmejce
I've did some dvd encodes to x264, they were smooth... XviD was better.
zmejce is offline
Old 8th August 2012, 23:51   #6  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
If, at the same bitrate, XviD looks better than x264, you did something seriously wrong... maybe with your pre-processing, maybe with your encoder settings or maybe with your comparing method.
See also:
http://x264.nl/developers/Dark_Shika...e/compare.html
LoRd_MuldeR is offline
Old 9th August 2012, 00:44   #7  |  Link
zmejce
Originally Posted by LoRd_MuldeR View Post
Interesting site, maybe that's what I'm looking for. Do you know from which date are those screenshots?
According to them, x264 is best, then DivX, then others (maybe XviD, & a good mp2 encoder should be similar to -original source- screenshots).
Which birate do you recommend for HQ rip at 720x480 res. from dvd?
zmejce is offline
Old 9th August 2012, 09:24   #8  |  Link
Atak_Snajpera
Old 9th August 2012, 20:19   #9  |  Link
Asmodian
I don't understand what you what to know. Are you really thinking Xvid might be better quality compared to x264?
Currently x264 is accepted as the highest quality video encoder available. I think this is true even counting the many thousands of dollars encoder packages (they offer other advantages of course) but it certainly true compared to the cheap or free options.
MPEG-4 ASP (Xvid, Divx) is a simpler standard that's easier to decode, as such it cannot achieve the same quality per size. This is even more true of MPEG2.
Which bit rate to use is up to you just make sure it is the same for all comparison encodes.
Asmodian is offline
Old 9th August 2012, 21:18   #10  |  Link
zmejce
I wanted to know which one of DivX and XviD is better in 2012.
I think to go with 1500-2000kbps birate DivX rip for video with 720x480 resolution from DVD source.
zmejce is offline
Old 9th August 2012, 23:03   #11  |  Link
zmejce
Oh no, Ive just used Handbrake 0.9.5 with High x264 preset, I didnt do any processing besides deinterlacing, still image is smoother with those rips, mp4 asp (divx or xvid) is sharper and clearer.
But on 1080p, x264 is absolutely best.
zmejce is offline
Old 10th August 2012, 08:01   #12  |  Link
hello_hello
I go out on a limb here, maybe set myself up for ridicule...
If someone were to ask me, I'd say x264 is better than Xvid. No doubt. No room for discussion.
Very occasionally though, and I can't quite put my finger on it... sometimes when encoding low quality sources, Xvid seems a little more pleasing to the eye to me. Probably because it's not as good at retaining detail so where normally you'd lose some fine detail (compared to x264) you lose some of the unwanted noise or compression artifacts instead. Just a theory anyway.... but for 99% of the video I encode, I'd use x264, and I don't think I'd ever say Xvid was sharper or clearer.
hello_hello is offline
Old 12th August 2012, 22:21   #13  |  Link
poisondeathray
Maybe that was your problem?
If it was a theatrical source (e.g. a movie), you wouldn't deinterlace it
poisondeathray is offline
Old 15th August 2012, 03:17   #14  |  Link
CWR03
Custom User Title
CWR03's Avatar
I know exactly what you mean. I had a Creative DVR card that captured in half-height resolution even at its best settings - I exported a lot of its files and saved them encoded in XviD, some of which look nearly as good (if not a bit better) as the DVD release of the same show that I encoded to x264. I never tried to figure out why, just always thought it was interesting.
CWR03 is offline
Old 16th August 2012, 16:26   #15  |  Link
datauser
datauser's Avatar
QUOTE by hello_hello
Have to agree too! Might also explain why if you use a high bitrate/high resolution x264 source and recompress it to avi, to find that it mostly comes out looking better than if you just encoded to avi/Xvid in the first place from your direct source to same specifications in my subjective opinion.
The x264 has done all the hard work preserving the source detail etc, so all you are really doing is some fine tuning with Xvid and losing unwanted noise artifacts in the compression process rather like a fine tooth comb filtering process/sieve. Ironic since there are no denoise options built in Xvid unlike the option in DivX to remove noise during the encoding process.
datauser is offline
Old 2nd September 2012, 14:46   #16  |  Link
zmejce
It might be strange, but DivX 6.9 1080p rip @ 7500kbps (2pass encoding and Highest quality setting) is better than x264 rip (with Handbrake's High Profile @ ~13.3Mbps).
Also, for DivX 2pass Insane Quality encodes, it takes half the time of x264 High Profile 1pass with Handbrake.
Also DivX it's very light on the pc for decoding.
TESTED ON 37" 1080 LED TV with vivid color setting and crystal clear image.
BTW I was surprised when I saw a lot of dirty artifacts, from 2m distance from the TV on the x264 High Profile encodes that were ripped from Blu-Ray disc from ~40GB. DivX @ 7500kbps has dirty artifacts that can be seen only from being few inches away from the TV.
x264 High Profile's dirty artifacts can't be seen on my 24" monitor, neither the ones from DivX (as they would probably be very hard to be noticed on 32" TV).
zmejce is offline
Old 2nd September 2012, 18:36   #17  |  Link
poisondeathray
Are you sure you didn't mix them up? DivX @ 7.5Mbps vs. x264 @ 13.3Mbps
There is no contest here . There must be a mistake somewhere
Maybe you're misinterpreting the "dirty artifacts" - are you referring to grain in the original? Because x264 will do a better job at preserving the original quality (this includes grain)
Old 2nd September 2012, 22:05   #18  |  Link
zmejce
No, I'm not messing the stuff.
The videos that I've encoded were different for x264 and DivX, however the DivX is better in that case.
I'll probably do tests to the same video when I'll have time and post screen shots.
zmejce is offline
Old 2nd September 2012, 22:32   #19  |  Link
Bloax
The speed of stupid
Bloax's Avatar
The best way to compare codecs is to test them on different sources and compare the results.
Yes, logic is good definitely here absolutely quite yes.
Bloax is offline
Old 3rd September 2012, 11:59   #20  |  Link
hello_hello
Maybe that's part of the problem.... your TV is trying to do clever things to the picture. If you really want to compare the two using your TV, do so with all the picture enhancing junk disabled. "Dirty artifacts" isn't really descriptive enough to know what it is you're seeing. Ideally you'd want to calibrate the TV properly first too." Vivid color" sounds particularly nasty to me.
I've never seen image enhancements in a TV which I thought improved the picture. I can't imagine why people use them. The first thing I do when setting up a TV is to go into it's settings and disable all of it completely.
Also you didn't say what you're using to play the encodes. ie a media player built into the TV, or a Bluray player etc. I've had fairly limited experience using different types of media players but even so it's fairly obvious they're not created equally. Even the image produced when playing the same encode using the two different Bluray players in this house (same TV) looks slightly different. Neither is bad, just one's a little more pleasing to the eye. If you're comparing encodes using a TV then ideally you'd probably want to be playing them on a PC connected to it, as chances are it'll be the best media player you own anyway (assuming you're using a decent software player).
The fact you say you can't see these "dirty artifacts" when playing the encodes and viewing them on your PC monitor would seem to indicate you need to find out what's messing with the picture when you're viewing them on the TV. Artifacts don't magically disappear and if they're encoded into the video you should be able to see them using your PC monitor too. Often when people post regarding visual problems playing encodes it's a problem with sending the TV the wrong levels or something similar.
2012, divx, tests, x264, xvid
