Old 21st June 2012, 16:28   #21  |  Link
Groucho2004
This thread is ridiculous and has pretty much run its course.
Unless there is some language related misunderstanding, the OP claims that it should be possible to restore the original (raw) data from H.264 video streams. Which of course is not possible.
Groucho2004 is offline
Old 21st June 2012, 18:02   #22  |  Link
dadix
Reverse engineering x264 (compression) i think must to have connections with a fractal based software + Fibonacci Sequence.
About fractal :http://video.google.com/videoplay?do...98277666323857
dadix is offline
Old 21st June 2012, 18:12   #23  |  Link
@dadix
Did you even bother to think about my analogy here:
http://forum.doom9.org/showthread.ph...29#post1579129
If information is discarded it cannot be recovered. Period.
Tell us if you do not understand that analogy and how it applies to x264 compression.
Guest is offline
Old 21st June 2012, 19:17   #24  |  Link
Biggiesized
Biggiesized's Avatar
Originally Posted by Dark Shikari View Post
This program already exists; it's called a video decoder
HAHAHAHAHA
I came here to post the same thing!
Once information has been lost, it's impossible to reconstruct it without proper embedded error coding.
Biggiesized is offline
Old 21st June 2012, 23:40   #25  |  Link
dadix
@nouron2 : i read
Using fractal algorithms to generate details is a good ideea but the firs step is to extract this algorithms from x264 encoder output, from vectors , coefficients and so on.
Example: http://www.outerra.com/index.html
dadix is offline
Old 22nd June 2012, 00:00   #26  |  Link
Groucho2004
Now you're just trolling.
Old 22nd June 2012, 00:40   #27  |  Link
Closing as the OP has taken the thread off topic.
Guest is offline
restoration, reverse engineering, x264
