Old 3rd November 2020, 23:35   #321  |  Link
gispos
Originally Posted by FranceBB View Post
Same.
This returns unhandled C++ exception:
Ah, Ferenc is here.
I'm running Avisynth+ 3.6.1 r3300 on x86 under Windows XP with PAE turned on and 32 GB of RAM.
Does that work for you now with MP_Pipeline?
If not then my posting was a bump
Live and let live
gispos is offline   Reply With Quote
Old 4th November 2020, 08:05   #322  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Not really...
I'm still stuck...
EDIT: For the sake of avoid a potential Windows-related thing, I tried the very same script on Windows 10 x64 Enterprise with the very same version of MPP and AVS+; same result, unhandled C++ exception...
Let's see if great master Ferenc is gonna jump on this one and come to rescue...
Old 4th November 2020, 11:15   #323  |  Link
pinterf
Not really...
I'm still stuck...
You know well if a problem is unexplainable than after hesitating a bit, sooner or later I can't resist and dig into the mistery.
So I have put some debugging into MP_Pipeline.
The error comes from parsing the inherit block (my new error message, much better than unknown exception).
"Error in regex library while copying 'inherit block':
regex_error(error_stack): There was insufficient memory to determine whether the regular expression could match the specified character sequence"
Parsing is done with the standard std::regex C++ library.
Pattern is
^\s*### inherit start ###\s*$(?:.|\s)*?^\s*### inherit end ###\s*$
Probably this pattern is too complex for the engine to analyze against the source. Right now I have not any clue about the workaround.
This is what I have found about the topic.
https://stackoverflow.com/questions/...ultiline-match
edit: of course one can do it w/o involving the regex library, though this present method is more elegant (but fails)
pinterf is offline   Reply With Quote
Old 4th November 2020, 18:18   #324  |  Link
gispos
Pattern is
Could that have something to do with the fact that I get strange errors when I pass an Ansi String with 'Eval'.
I think I didn't have any problems with older Avisynth versions without 'Plus', but I can also be wrong.
Live and let live
Old 11th November 2020, 19:29   #325  |  Link
pinterf
No, those long inherit sections are not affecting Eval. Nevertheless I have already fixed this error (release later, patience please)
Old 13th November 2020, 22:58   #326  |  Link
gispos
Too bad.
I am sure that I opened Avisynth scripts with 'Eval' back then. After an update to a newer version (I think it was one of the first MT versions at that time),
I could only open scripts with AviSource, depending on the content. The current Avisynth versions are at war with Ansi Strings.
Edit:
...Nevertheless I have already fixed this error (release later, patience please)
I don't know if I got it right. Have you already fixed something in this regard?
Live and let live
Old 13th November 2020, 23:31   #327  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Just for the sake of testing, I tested the very same script with the new Avisynth Test 4 version and it still behaves the same.
By the way and totally unrelated, ConvertBits() no longer throws an error for 8-16 when the input = output bit depth correctly!
Old 14th November 2020, 07:21   #328  |  Link
pinterf
Yes, fixed the crash by not using regex. It is not avisynth related. (On my machine at the moment, I have to cleanup the source before commiting it and release)
Old 16th November 2020, 09:29   #329  |  Link
pinterf
New version, download v0.22
Fix crash when there were too many characters (over some hundred) in script between
inherit start and inherit end markers (regex library limitation)
Old 16th November 2020, 18:24   #330  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Thanks!
Now I no longer have an unhandled C++ exception and I get an error message from all the scripts.
MP_Pipeline("""
video1=FFVideoSource("I:\temp\Raw Canon EOS R\20190806_1220_001.MP4")
### export clip: video1
video2=FFVideoSource("I:\temp\Raw Canon EOS R\20190806_1226_001.MP4")
### export clip: video2
### pass clip: video1
video3=FFVideoSource("I:\temp\Raw Canon EOS R\20190807_2005_001.MP4")
### export clip: video3
### pass clip: video1, video2
video4=FFVideoSource("I:\temp\Raw Canon EOS R\20190807_2008_001.MP4")
### export clip: video4
### pass clip: video1, video2, video3
video5=FFVideoSource("I:\temp\Raw Canon EOS R\20190807_2010_001.MP4")
### export clip: video5
### pass clip: video1, video2, video3, video4
video6=FFVideoSource("I:\temp\Raw Canon EOS R\20190807_2011_001.MP4")
### export clip: video6
### pass clip: video1, video2, video3, video4, video5
video7=FFVideoSource("I:\temp\Raw Canon EOS R\20190807_2013_001.MP4")
### export clip: video7
### pass clip: video1, video2, video3, video4, video5, video6
video8=FFVideoSource("I:\temp\Raw Canon EOS R\20190808_1014_001.MP4")
### export clip: video8
### pass clip: video1, video2, video3, video4, video5, video6, video7
video9=FFVideoSource("I:\temp\Raw Canon EOS R\20190808_1015_001.MP4")
### export clip: video9
### pass clip: video1, video2, video3, video4, video5, video6, video7, video8
video10=FFVideoSource("I:\temp\Raw Canon EOS R\20190808_1016_001.MP4")
### export clip: video10
### pass clip: video1, video2, video3, video4, video5, video6, video7, video8, video9
video11=FFVideoSource("I:\temp\Raw Canon EOS R\20190808_1531_002.MP4")
### export clip: video11
### pass clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10
video12=FFVideoSource("I:\temp\Raw Canon EOS R\20190808_1619_001.MP4")
### export clip: video12
### pass clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11
video13=FFVideoSource("I:\temp\Raw Canon EOS R\20190808_1620_001.MP4")
### export clip: video13
### pass clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12
video14=FFVideoSource("I:\temp\Raw Canon EOS R\20190808_1621_001.MP4")
### export clip: video14
### pass clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12, video13
video15=FFVideoSource("I:\temp\Raw Canon EOS R\20190812_1400_001.MP4")
### export clip: video15
### pass clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12, video13, video14
video16=FFVideoSource("I:\temp\Raw Canon EOS R\20190812_1947_001.MP4")
### export clip: video16
### pass clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12, video13, video14, video15
video17=FFVideoSource("I:\temp\Raw Canon EOS R\20190812_1948_001.MP4")
### export clip: video17
### pass clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12, video13, video14, video15, video16
video18=FFVideoSource("I:\temp\Raw Canon EOS R\20190812_2006_001.MP4")
### export clip: video18
### pass clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12, video13, video14, video15, video16, video17
video1++video2++video3++video4++video5++video6++video7++video8++video9++video10++video11++video12++video13++video14++video15++video16++video17++video18
return last
MP_Pipeline("""
### export clip: video1, video2
### export clip: video1, video2, video3
### export clip: video1, video2, video3, video4
### export clip: video1, video2, video3, video4, video5
### export clip: video1, video2, video3, video4, video5, video6
### export clip: video1, video2, video3, video4, video5, video6, video7
### export clip: video1, video2, video3, video4, video5, video6, video7, video8
### export clip: video1, video2, video3, video4, video5, video6, video7, video8, video9
### export clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10
### export clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11
### export clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12
### export clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12, video13
### export clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12, video13, video14
### export clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12, video13, video14, video15
### export clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12, video13, video14, video15, video16
### export clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12, video13, video14, video15, video16, video17
### export clip: video1, video2, video3, video4, video5, video6, video7, video8, video9, video10, video11, video12, video13, video14, video15, video16, video17, video18
return last
MP_Pipeline("""
video1 = String(ScriptDir()) + "20190806_1220_001.MP4"
video1 = Exist(video1) ? video1 : "I:\temp\Raw Canon EOS R\20190806_1220_001.MP4"
video2 = String(ScriptDir()) + "20190806_1226_001.MP4"
video2 = Exist(video2) ? video2 : "I:\temp\Raw Canon EOS R\20190806_1226_001.MP4"
video3 = String(ScriptDir()) + "20190807_2005_001.MP4"
video3 = Exist(video3) ? video3 : "I:\temp\Raw Canon EOS R\20190807_2005_001.MP4"
video4 = String(ScriptDir()) + "20190807_2008_001.MP4"
video4 = Exist(video4) ? video4 : "I:\temp\Raw Canon EOS R\20190807_2008_001.MP4"
video5 = String(ScriptDir()) + "20190807_2010_001.MP4"
video5 = Exist(video5) ? video5 : "I:\temp\Raw Canon EOS R\20190807_2010_001.MP4"
video6 = String(ScriptDir()) + "20190807_2011_001.MP4"
video6 = Exist(video6) ? video6 : "I:\temp\Raw Canon EOS R\20190807_2011_001.MP4"
video7 = String(ScriptDir()) + "20190807_2013_001.MP4"
video7 = Exist(video7) ? video7 : "I:\temp\Raw Canon EOS R\20190807_2013_001.MP4"
video8 = String(ScriptDir()) + "20190808_1014_001.MP4"
video8 = Exist(video8) ? video8 : "I:\temp\Raw Canon EOS R\20190808_1014_001.MP4"
video9 = String(ScriptDir()) + "20190808_1015_001.MP4"
video9 = Exist(video9) ? video9 : "I:\temp\Raw Canon EOS R\20190808_1015_001.MP4"
video10 = String(ScriptDir()) + "20190808_1016_001.MP4"
video10 = Exist(video10) ? video10 : "I:\temp\Raw Canon EOS R\20190808_1016_001.MP4"
video11 = String(ScriptDir()) + "20190808_1531_002.MP4"
video11 = Exist(video11) ? video11 : "I:\temp\Raw Canon EOS R\20190808_1531_002.MP4"
video12 = String(ScriptDir()) + "20190808_1619_001.MP4"
video12 = Exist(video12) ? video12 : "I:\temp\Raw Canon EOS R\20190808_1619_001.MP4"
video13 = String(ScriptDir()) + "20190808_1620_001.MP4"
video13 = Exist(video13) ? video13 : "I:\temp\Raw Canon EOS R\20190808_1620_001.MP4"
video14 = String(ScriptDir()) + "20190808_1621_001.MP4"
video14 = Exist(video14) ? video14 : "I:\temp\Raw Canon EOS R\20190808_1621_001.MP4"
video15 = String(ScriptDir()) + "20190812_1400_001.MP4"
video15 = Exist(video15) ? video15 : "I:\temp\Raw Canon EOS R\20190812_1400_001.MP4"
video16 = String(ScriptDir()) + "20190812_1947_001.MP4"
video16 = Exist(video16) ? video16 : "I:\temp\Raw Canon EOS R\20190812_1947_001.MP4"
video17 = String(ScriptDir()) + "20190812_1948_001.MP4"
video17 = Exist(video17) ? video17 : "I:\temp\Raw Canon EOS R\20190812_1948_001.MP4"
video18 = String(ScriptDir()) + "20190812_2006_001.MP4"
video18 = Exist(video18) ? video18 : "I:\temp\Raw Canon EOS R\20190812_2006_001.MP4"
### inherit end ###
FFVideoSource(video1, cache=False)
v2=FFVideoSource(video2, cache=False)
last=last++v2
return last
v3=FFVideoSource(video3, cache=False)
last=last++v3
return last
Perhaps these messages will make something pop in your mind, 'cause as things stands, I'm glad that I don't get "unhandled C++ expression" anymore, but I still have no idea about what's wrong...
Old 16th November 2020, 19:43   #331  |  Link
pinterf
Thanks!
Thanks! v0.22 Removed until I check what had happened.
Edit: release re-enabled (w/o modification)
Last edited by pinterf; 16th November 2020 at 20:41. Reason: update release status
Old 16th November 2020, 20:23   #332  |  Link
pinterf
Your new errors fortunately are not related to any new bugs.
Your first sample does not work because there must be at least one "last" in the first section. When I insert a dummy "BlankClip" there, it will work* (*: see later)
It even fails if I skelenonize it to a single video1:
MP_Pipeline("""
video1=FFVideoSource("V01.m2v")
video1
last
But this one is O.K.
MP_Pipeline("""
BlankClip() ## providing a "last" clip variable
video1
last
*... until clip count reached 8.
Then we have another error message.
"MP_Pipeline: Unable to create slave process. Message: Script error: SharedMemoryServer: Each process can only export no more than 8 clips."
Old 16th November 2020, 20:35   #333  |  Link
pinterf
The 3rd example is probably wrong as well.
I think you mustn't use "return last" there. MP_Pipeline inserts some "hidden" lines before and after the script blocks, when you put there a return last, this "epilog" will not be reached.
### inherit end ###
last=last++v2
return last
last=last++v3
return last
Works:
### inherit end ###
last=last++v2
last=last++v3
return last
Old 17th November 2020, 12:28   #334  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I tested again with your suggestion and this indeed works!
MP_Pipeline("""
### inherit end ###
last=last++v2
last=last++v3
v4=FFVideoSource(video4, cache=False)
last=last++v4
v5=FFVideoSource(video5, cache=False)
last=last++v5
v6=FFVideoSource(video6, cache=False)
last=last++v6
v7=FFVideoSource(video7, cache=False)
last=last++v7
v8=FFVideoSource(video8, cache=False)
last=last++v8
v9=FFVideoSource(video9, cache=False)
last=last++v9
v10=FFVideoSource(video10, cache=False)
last=last++v10
v11=FFVideoSource(video11, cache=False)
last=last++v11
v12=FFVideoSource(video12, cache=False)
last=last++v12
v13=FFVideoSource(video13, cache=False)
last=last++v13
v14=FFVideoSource(video14, cache=False)
last=last++v14
v15=FFVideoSource(video15, cache=False)
last=last++v15
v16=FFVideoSource(video16, cache=False)
last=last++v16
v17=FFVideoSource(video17, cache=False)
last=last++v17
v18=FFVideoSource(video18, cache=False)
last=last++v18
return last
Thank you!!
Old 6th June 2022, 17:34   #335  |  Link
Music Fan
I didn't use Avisynth for 1 or 2 years and would like to re-install it. As I'm quite confused with 32/64 bit mixed plugins, I have some questions.
If I understand correctly, Avisynth+ 64 bit is not supposed to work with 32 bit plugins but it can be achieved with MP_Pipeline.
I use Windows 10 pro 64 and would like to install Avisynth+ 64 bit.
1) Is it enough to make work in a single script 32 and 64 bit plugins (thanks to MP_Pipeline) or Avisynth+ 32 bit has to be installed anyway to make work 32 bit plugins, even when used in a script using Avisynth+ 64 bit ?
2) Do I have to put only the 4 MP_Pipeline files of the x64 folder (dll, dll.slave.exe, ...) in Avisynth+ 64 bit's plugin folder to make the whole stuff work with 32 and 64 bit plugins ?
3) In which folder should I place the 32 bit plugins ?
Thanks
Music Fan is offline   Reply With Quote
Old 2nd November 2022, 19:02   #336  |  Link
mastrboy
Is there a known bug with using Internal String functions with MP_Pipeline?
As soon as I include a Internal Avisynth function like "findstr" or "leftstr" I get a "Unable to create slave process" exception.
Example script not working:
MP_Pipeline("""
script_folder = LeftStr(ScriptDir(),StrLen(ScriptDir()) - 1)
filename_no_ext = ReplaceStr(scriptfile(),".avs",".mkv")
src_file = script_folder + "\" + filename_no_ext
### inherit end ###
LWLibavVideoSource(src_file)
# crop borders
crop(240,0,-240,0)
If I just set the script_folder and filename_no_ext manually it works as expected, but defeats the idea of loading a source file based on the Avisynth script name...
(i have a tendency to drunk post)
mastrboy is offline   Reply With Quote
Old 2nd November 2022, 21:15   #337  |  Link
gispos
For ScriptDir() you have to use string(ScriptDir()), the other things I haven't tested yet.
Live and let live
Old 2nd March 2023, 20:05   #338  |  Link
flossy_cake
Hello, is there any possibility of audio support?
I want to do audio compression to make audio louder without clipping ("soft clipping") but there are only 32-bit plugins for that.
I would have used Soxfilter 64-bit compander but it's broken & linear access only.
Old 2nd March 2023, 21:27   #339  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
+1 for audio support.
I asked for it long time ago (I guess last time I begged was probably 2015) but the original author was gone.
Heck, MPPipelins would have also been broken with newer Avisynth+ colorspaces if it wasn't for the always available and irreplaceable C++ & ASM Supreme Grandmaster Ferenc Pinter who picked it up and updated it to version 0.22.
I mean, honestly, pinterf has been picking up almost every project the community has left behind and single handedly updated everything to modern standard. If it wasn't for him I don't know where we would have been...
Sox you said, uh?
Indeed the last Avisynth compatible version was 2.6.1 from 2016, however I guess we're gonna be in for a 2023 miracle after it being broken since 2017, 'cause Grandmaster Ferenc has picked up the "challenge":
https://forum.doom9.org/showthread.p...81351&page=115
avisynth, multi-process, pipeline
