Old 16th May 2008, 17:26   #1  |  Link
boilerlt1
How can I locate a keyframe in a DivX stream?
Hi guys, major video newbie here.
I'm encoding DivX 3 video using ffdshow, and I'm encapsulating it in Matroska. I'm using mkvmerge, a Matroska utility, to pull the DivX stream out of the container. What I'd like to do is read the stream and locate the keyframes. However, I haven't found any luck finding information on how frames are encoded, other than that DivX 3 is based on Microsoft's MPEG-4 Version 3 codec.
Can anyone offer any tips? I couldn't find much when I searched the board.
Thanks!
boilerlt1 is offline   Reply With Quote
Old 16th May 2008, 17:42   #2  |  Link
setarip_old
setarip_old's Avatar
Hi!
Load the DivX-compressed video into VirtualDub and press the keyframe radiobutton (looks like a key)...
setarip_old is offline   Reply With Quote
Old 16th May 2008, 17:51   #3  |  Link
boilerlt1
setarip_old -- unfortunately, I need to do this programatically, through code. Thanks for the tip though.
Old 16th May 2008, 18:40   #4  |  Link
unskinnyboy
unskinnyboy's Avatar
This isn't 1999. Why are you using DivX 3 for encoding?
unskinnyboy is offline   Reply With Quote
Old 16th May 2008, 19:51   #5  |  Link
boilerlt1
Long story. I'll try to summarize it:
The project is a DirectShow-based program where one process records video to disk. Another process (also DirectShow based) reads that video, while it's still being recorded to disk, and lets you seek around it. You could loosely think of it as a TiVo, but this is actually for monitoring video output from a scientific instrument. The video will be sync'ed with a considerable amount of metadata.
Now that that's out of the way...
The project requirements don't really bind me to using DivX 3, but so far anything newer than version 3 won't let me seek around video while it's still being recorded. EDIT -- if it matters, I've done initial testing with ffdshow, which is GPL'ed, so I can't really use that for production anyways.
On that note, how can I find keyframes in files recorded with newer versions of DivX?
Old 16th May 2008, 20:05   #6  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Isn't DivX 3 the hacked version of DivX using Microsoft's MPEG-4 codec?
Old 16th May 2008, 20:17   #7  |  Link
boilerlt1
Why, yes it is.
Old 16th May 2008, 20:35   #8  |  Link
unskinnyboy
boilerlt1, I see. Your issue is very specific - seeking on a video while recording it, and you say anything above DivX 3 doesn't allow it? I am surprised. If anything, I'd have expected a newer version of an ASP codec to support this. I suppose you have already tried the latest builds of Xvid & DivX?
Why is ffdshow being GPL'd stopping you? AFAIK, GPL doesn't restrict any production usage (however, if you are using it for a commercial purpose and making money of it, then your program should also be GPL'd).
Now, about the frame list, I don't think you should reinvent the wheel, when there are existing tools which can do this.
Here is one way -
  • Get MPEG4 Modifier CL from here.
  • In your program call it with the following parms:
    mmcl --frame-list "C:\path_to_frame_list\frame_list.txt" "C:\path_to_your_video\yourvideo.avi"
  • Now do a:
    findstr I-VOP "C:\path_to_frame_list\frame_list.txt">"C:\path_to_frame_list\I-frame_list.txt"
  • Your I-frame_list.txt will be in the following format:
         0: I-VOP    (0:00:00.000)
       300: I-VOP    (0:00:12.512)
       600: I-VOP    (0:00:25.025)
       900: I-VOP    (0:00:37.537)
      1200: I-VOP    (0:00:50.050)
      1245: I-VOP    (0:00:51.926)
      1249: I-VOP    (0:00:52.093)
      1266: I-VOP    (0:00:52.802)
      1268: I-VOP    (0:00:52.886)
      1271: I-VOP    (0:00:53.011)
      1273: I-VOP    (0:00:53.094)
      1573: I-VOP    (0:01:05.607)
      1873: I-VOP    (0:01:18.119)
      2173: I-VOP    (0:01:30.632)
      2372: I-VOP    (0:01:38.932)
      2486: I-VOP    (0:01:43.686)
      2671: I-VOP    (0:01:51.402)
      2971: I-VOP    (0:02:03.915)
      3024: I-VOP    (0:02:06.126)
      3221: I-VOP    (0:02:14.342)
      3321: I-VOP    (0:02:18.513)
      3369: I-VOP    (0:02:20.515)
  • I-VOP = I-frame
Old 16th May 2008, 20:50   #9  |  Link
boilerlt1
Correct, this is a paid project. I understand mkvmerge is GPL'ed as well, and ultimately we will avoid using anything that doesn't have a commercial-compatible license. There are some killer GPL-based tools out there... but unfortunately we're not in a position to make this project open-source as well.
Old 16th May 2008, 21:06   #10  |  Link
Dark Shikari
x264 developer
First of all, in that case, you better not use DivX 3; being hacked, its totally illegal and has no commercial use clause whatsoever.
Perhaps you should use ffmpeg, which is available under the far less restrictive LGPL?
Old 16th May 2008, 22:49   #11  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
You know you could hit the Divx guys up on a feature request for the read behind writing ability that divx 3 has...
Probubly not going to happen so If not I would go with ffmpeg...
My Installer's ||
Ajax_Undone is offline   Reply With Quote
divx, keyframes, matroska
