#41 | Link |
Resize Abuser
KenBurnsEffect() Updated
KenBurnsEffect() Changes
With these changes I can speed up my work flow.
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer Last edited by mikeytown2; 14th May 2008 at 04:28. |
#42 | Link |
Resize Abuser
Added an example code block near the bottom of post 2 (Simple Usage Example). This should help in understanding how to use KenBurnsEffect(). Be sure to change the OutputWidth and OutputHeight. Trying different output aspect ratios will hopefully make it clear how useful KBE() is.
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer |
#43 | Link |
Resize Abuser
If no one see's any problems with this filter, i'll start to look into rotation. using zoom.dll to do rotation is fairly straightforward, but i am looking at the other 2 options for rotating a clip. FreeFrame's PetePanSpinZoom and EffectsMany's EffectRotation.
I posted about FreeFrame previously in this thread on post # 8-10 Here is code using Effect Rotation. Code:
version()#240 Frames Long stackVertical(last,last) stackVertical(last,last,last) stackHorizontal(last,last) a = last.ConvertToYV12() EffectRotation(a,sf=49,ef=149,id=0, fd=90, cc=$000000).Trim(0,149) last+EffectRotation(a,sf=150,ef=239,id=90, fd=90, cc=$000000).Trim(150,0)
#44 | Link |
Resize Abuser
I decided to get the Align parameter done before i go further. This is what I'm thinking... what are your thoughts?
int Start/End Align: negative values (-) will position where the potential border is placed, to make it fit the given output dimensions. so -5 would be center, center with a border on top/bottom or left/right. -5 would be the same as -1,0,0,0. On the other hand 5 would be the same as 0,0,0,0. The negative option will make the code of Split Screen easier. I can then fully replace ResizeKAR with ZoomBox. Positive values will be what is shown no mater what. So 5 means that the center point will be in the center of the frame. 1 means that the top left pixel will be in the top left, with cropping so there are no black borders. If the aspect ratio is the same across the board then this won't do much. I plan on making all parameters optional and using x/y 1,2 to let you say how many pixels to go. So if i set Align=9 (bottom right), i can set x1 or y1, or both to override the aspect ratio. If i set Align=1 (top left) i can set x2 or y2, or both to override the aspect ratio. Positive x/y values will count from the top left, negative x/y values from the bottom right. This means that using align you can never zoom out to the point of having a black border all the way around your picture. Align=5 (middle center), if i only set x1 then that is the width of the center box; y1 hight of the center box. i can set all 4 values x1,y1,x2,y2 or just 3 to keep AR. Align=1 (top left), can set x2, y2 Align=2 (top center), can set x1, x2, y2 Align=3 (top right), can set x1, y2 Align=4 (middle left), can set x2, y1, y2 Align=5 (middle center), can set x1, x2, y1, y2 Align=6 (middle bottom), can set x1, y1, y2 Align=7 (bottom left), can set x2, y1 Align=8 (bottom center), can set x1, x2, y1 Align=9 (bottom right), can set x1, y1 x1,y1 = top left of a rectangle x2,y2 = bottom right of a rectangle Code:
1:top left. 2:top center. 3:top right. 4:middle left. 5:middle center. 6:middle bottom. 7:bottom left. 8:bottom center. 9:bottom right. ![]()
#45 | Link |
Resize Abuser
I need some help with some Aspect Ratio Math... I am close, but for certain cases, it doesn't work correctly. I develop the ZoomBox Code and then port it to KBE. So here is the latest ZB, i've been trying to correct the DAR/PAR & Final AR. It acts odd when using the (0,0,0,0) or (-1,0,0,0) method.
This Works (HDV Source) ![]() This doesn't work (Still Camera) ![]() Current Code Base Code:
Function ZoomBox(clip c, float x1, float y1, float x2, float y2, int "width", int "height", int "IgnoreAR", string "ResizeMethod", int "OutputARWidth", int "OutputARHeight") { #set defaults width = Default(width, c.width()) height = Default(height, c.height()) ResizeMethod = Default(ResizeMethod, "BilinearResize") IgnoreAR = Default(IgnoreAR, 0) PAR = float(c.width())/float(c.height()) FinalAR = float(width)/float(height) OutputARWidth = Default(OutputARWidth, c.width()) OutputARHeight = Default(OutputARHeight, c.height()) DAR = Float(OutputARWidth)/Float(OutputARHeight) #Take Crop Like Input x2 = x2<=x1 && x2 < 0 ? c.width() + x2 : x2 y2 = y2<=y1 && y2 < 0 ? c.height() + y2 : y2 #If All 0, and x1 =+-1 or 0 then assume clip is to be centered #Display Aspect Ratio = Final Output Ratio. No Change, Show All Pixels EvalString = (x1==1 || x1==0 || x1==-1) && y1==0 && x2==0 && y2==0 && DAR==FinalAR ? \ "x1=0" + " x2=" + String(c.width()) + " y1=0" + " y2=" + String(c.height()) + "" : "x1=x1" Eval(EvalString) #Display Aspect Ratio > Final Output Ratio. Add Height or Crop Width EvalString = x1==-1 && y1==0 && x2==0 && y2==0 && DAR>FinalAR ? \ "y1=" + String((c.height()*(FinalAR/DAR)-c.width()/PAR)/2.0) + " y2=" + String(c.height() - (c.height()*(FinalAR/DAR)-c.width()/PAR)/2.0) + " x1=0" + " x2=" + String(c.width()) \ : (x1==1 || x1==0) && y1==0 && x2==0 && y2==0 && DAR>FinalAR ? \ "x1=" + String((c.width()/(FinalAR/DAR)-c.height()*PAR)/2.0) + " x2=" + String(c.width() - (c.width()/(FinalAR/DAR)-c.height()*PAR)/2.0) + " y1=0" + " y2=" + String(c.height()) + "" : "x1=x1" Eval(EvalString) #Display Aspect Ratio < Final Output Ratio. Add Width or Crop Height EvalString = x1==-1 && y1==0 && x2==0 && y2==0 && DAR<FinalAR ? \ "x1=" + String((c.width()/PAR-c.height()*(FinalAR/DAR))/2.0) + " x2=" + String(c.width() - (c.width()/PAR-c.height()*(FinalAR/DAR))/2.0) + " y1=0" + " y2=" + String(c.height()) + "" \ : (x1==1 || x1==0) && y1==0 && x2==0 && y2==0 && DAR<FinalAR ? \ "y1=" + String((c.height()*(FinalAR/DAR)-c.width()/PAR)/2.0) + " y2=" + String(c.height() - (c.height()*(FinalAR/DAR)-c.width()/PAR)/2.0) + " x1=0" + " x2=" + String(c.width()) : "x1=x1" Eval(EvalString) #Check if x2 or y2 needs to be calculated Assert( ((x2==x1) && (y2==y1))==False, "x2 [" + String(x2) + "] or y2 [" + String(y2) + "] needs a value that is different from x1 [" + String(x1) + "] or y1 [" + String(y1) + "]") y2 = (y2==y1) ? (((x2-x1)/FinalAR + y1)/(PAR/DAR)) : y2 x2 = (x2==x1) ? (((y2-y1)*FinalAR + x1)*(PAR/DAR)) : x2 BoxAR = Float(x2-x1)/Float(y2-y1) #Check For Any Unreasonable Inputs Assert(x1<x2, "ZoomBox: x1[" + String(x1) + "] point larger then x2 Point[" + String(x2) + "]") Assert(y1<y2, "ZoomBox: y1[" + String(y1) + "] point larger then y2 Point[" + String(y2) + "]") Assert(IgnoreAR>0 || BoxAR == FinalAR, "ZoomBox: Box Aspect Ratio [" + String(BoxAR) + "] does not equal clip output Aspect Ratio [" + string(FinalAR) + "]") #Do it all c = c.AddBorders(16,16,16,16) c = Eval(ResizeMethod + "(c, " + String(Round(width)) + ", " + String(Round(height)) + ", src_left=" + String(x1) + "+16, src_top=" + String(y1) + "+16, src_width=" + String(x2-x1) + ", src_height=" + String(y2-y1) + ")") c Subtitle(String(x1) + "," + String(y1) + " " + String(x2) + "," + String(y2) + " " + String(BoxAR),y=40) } Example: Change W or H and you get the correct image. Code:
Global W = 720 Global H = 720 Global Resizer = "BlackmanResize" Global HDV_Full = HDV.TDeint().ZoomBox( -1,0,0,0, W, H, IgnoreAR=1, ResizeMethod=Resizer, OutputARWidth=1920, OutputARHeight=1080 ) Global HDV_Full_Crop = HDV.TDeint().ZoomBox( 0,0,0,0, W, H, IgnoreAR=1, ResizeMethod=Resizer, OutputARWidth=1920, OutputARHeight=1080 ) Global HDV_Fast = HDV.SeparateFields().SelectEven().ZoomBox( -1,0,0,0, W, H, IgnoreAR=1, ResizeMethod=Resizer, OutputARWidth=1920, OutputARHeight=1080 ) Global HDV_Fast_Crop = HDV.SeparateFields().SelectEven().ZoomBox( 1,0,0,0, W, H, IgnoreAR=1, ResizeMethod=Resizer, OutputARWidth=1920, OutputARHeight=1080 ) Code:
Global W = 720 Global H = 720 Global Resizer = "BlackmanResize" ImageReader("92.JPG",0,0) ZoomBox(last, 0, 0, 0, 0, W, H, IgnoreAR=1, ResizeMethod=Resizer) The "#Check if x2 or y2 needs to be calculated" code seems to give correct output, it takes what ever you throw at it, and handles it correctly. So that is a good starting point. Code:
Global W = 720 Global H = 720 Global Resizer = "BlackmanResize" ImageReader("2.jpg",0,0) ZoomBox(930, 0, 3300, 0, W, H, 1, ResizeMethod=Resizer) Code:
Global W = 720 Global H = 720 Global Resizer = "BlackmanResize" HDV.TDeint() ZoomBox( 0,0,960,0, W, H, IgnoreAR=1, ResizeMethod=Resizer, OutputARWidth=1920, OutputARHeight=1080 ) EDIT This appears to be the correct formula. I only have the first part done Code:
EvalString = x1==-1 && y1==0 && x2==0 && y2==0 && DAR>FinalAR ? \ "y1=" + String(0 - ((height*DAR-width)/2.0)*(c.height()/Float(width))) + " y2=" + String(c.height() + ((height*DAR-width)/2.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width())
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer Last edited by mikeytown2; 24th May 2008 at 04:27. |
#46 | Link |
Resize Abuser
KenBurnsEffect() & ZoomBox() Updated
Changes:
Issues:
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer Last edited by mikeytown2; 24th May 2008 at 08:33. |
#47 | Link | |
Avisynth language lover
y2 = (y2==y1) ? (((x2-x1)/FinalAR + y1)/(SAR/DAR)) : y2 x2 = (x2==x1) ? (((y2-y1)*FinalAR + x1)*(SAR/DAR)) : x2 Code:
y2 = (y2==y1) ? (((x2-x1)/FinalAR)/(SAR/DAR) + y1) : y2 x2 = (x2==x1) ? (((y2-y1)*FinalAR)*(SAR/DAR) + x1) : x2 (You can see the logic behind this if you consider that x2-x1 must end up in the required ratio to y2-y1) |
#48 | Link |
Resize Abuser
Thanks Gavino! I used your way in KBE and in ZB. They both work correctly now. My "i give up" method still didn't work in all cases... man this is not easy.
Updated KBE & ZB. Parameters changed in ZB. I think ZoomBox is easier to use. Changed my huge example to reflect these changes
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer Last edited by mikeytown2; 25th May 2008 at 01:27. |
#49 | Link |
Resize Abuser
Starting to play with the Align option
Here is my test image ![]() I'm working on negative Align values first because it is the easiest to do. Got rid of inputs x1,x2,y1,y2 just for this. Example Test Code Code:
E = ImageReader("traingr4.jpg") E.ZoomBoxer(640,480, "BilinearResize", 16.0/9.0, -3) StackHorizontal(last,E.ZoomBoxer(640,320, "BilinearResize", 16.0/9.0, -7).AddBorders(0,160,0,0,$FF0000)) Function ZoomBoxer(clip c, int "width", int "height", string "ResizeMethod", float "DisplayAR", int "Align", int "color", int "IgnoreAR") { #set defaults ResizeMethod = Default(ResizeMethod, "BilinearResize") IgnoreAR = Default(IgnoreAR, 1) color = Default(color, $000000) width = Default(width, c.width()) height = Default(height, c.height()) Align = Default(Align, 0) SourceAR = float(c.width())/float(c.height()) FinalAR = float(width)/float(height) DisplayAR = Default(DisplayAR, Float(c.width())/Float(c.height())) DisplayAR = DisplayAR == 0 ? Float(c.width())/Float(c.height()) : DisplayAR #BoxAR = ((c.width() + ((width/DisplayAR-height)/2.0)*(c.width()/Float(height)))-(((width/DisplayAR-height)/2.0)*(c.width()/Float(height))))/c.height() #If Align=5 or -5 then center clip. -5: Add borders. 5: Crop. #Display Aspect Ratio = Final Output Ratio. No Change, Show All Pixels #Display Aspect Ratio > Final Output Ratio. Add Height or Crop Width #Display Aspect Ratio < Final Output Ratio. Add Width or Crop Height EvalString = \ Align<>0 && DisplayAR==FinalAR ? \ "x1=0" + " x2=" + String(c.width()) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==-5 || Align==-4 || Align==-6) && DisplayAR>FinalAR ? \ "y1=" + String(0 - ((height*DisplayAR-width)/2.0)*(c.height()/Float(width))) + " y2=" + String(c.height() + ((height*DisplayAR-width)/2.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : Align==5 && DisplayAR>FinalAR ? \ "x1=" + String(0 + ((height-width/DisplayAR)/2.0)*(c.width()/Float(height))) + " x2=" + String(c.width() - ((height-width/DisplayAR)/2.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==-5 || Align==-2 || Align==-8) && DisplayAR<FinalAR ? \ "x1=" + String(0 - ((width/DisplayAR-height)/2.0)*(c.width()/Float(height))) + " x2=" + String(c.width() + ((width/DisplayAR-height)/2.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : Align==5 && DisplayAR<FinalAR ? \ "y1=" + String(0 + ((width-height*DisplayAR)/2.0)*(c.height()/Float(width))) + " y2=" + String(c.height() - ((width-height*DisplayAR)/2.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==-1 || Align==-3) && DisplayAR>FinalAR ? \ "y1=0" + " y2=" + String(c.height() + ((height*DisplayAR-width)/1.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==-1 || Align==-7) && DisplayAR<FinalAR ? \ "x1=0" + " x2=" + String(c.width() + ((width/DisplayAR-height)/1.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : "" Eval(EvalString) #Take Crop Like Input x2 = x2<=x1 && x2 < 0 ? c.width() + x2 : x2 y2 = y2<=y1 && y2 < 0 ? c.height() + y2 : y2 #Check if x2 or y2 needs to be calculated Assert( ((x2==x1) && (y2==y1))==False, "x2 [" + String(x2) + "] or y2 [" + String(y2) + "] needs a value that is different from x1 [" + String(x1) + "] or y1 [" + String(y1) + "]") y2 = (y2==y1) ? (((x2-x1)/FinalAR)/(SourceAR/DisplayAR) + y1) : y2 x2 = (x2==x1) ? (((y2-y1)*FinalAR)*(SourceAR/DisplayAR) + x1) : x2 BoxAR = Float(x2-x1)/Float(y2-y1) #Check For Any Unreasonable Inputs Assert(x1<x2, "ZoomBox: x1[" + String(x1) + "] point larger then x2 Point[" + String(x2) + "]") Assert(y1<y2, "ZoomBox: y1[" + String(y1) + "] point larger then y2 Point[" + String(y2) + "]") Assert(IgnoreAR>0 || BoxAR == FinalAR, "ZoomBox: Box Aspect Ratio [" + String(BoxAR) + "] does not equal clip output Aspect Ratio [" + string(FinalAR) + "]") #Pad clip so resizer interpolates from border when zooming out. 64 for spline64 c = c.AddBorders(64,64,64,64,color) #Do it c = Eval(ResizeMethod + "(c, " + String(Round(width)) + ", " + String(Round(height)) + ", src_left=" + String(x1) + "+64, src_top=" + String(y1) + "+64, src_width=" + String(x2-x1) + ", src_height=" + String(y2-y1) + ")") c Subtitle(String(x1) + ", " + String(y1) + " " + String(x2) + ", " + String(y2) + " BoxAR " + String(BoxAR) + " " + String()) } I've also got the "easy way" Example here. Using FlipHorizontal() & FlipVertical() Inside SplitScreener. Code:
A = ColorBars().Crop(10, 20, -30, -400).ConvertToYV12() B = ColorBars().invert().FlipHorizontal().Crop(10, 20, -300, -40).ConvertToYV12() C = ColorBars().FlipVertical().Crop(10, 200, -30, -40).ConvertToYV12() D = ColorBars().invert().FlipVertical().FlipHorizontal().Crop(100, 20, -30, -40).ConvertToYV12() #SplitScreener(640, 480, 4, A, B, C, D) function SplitScreener(int Width, int Height, int Border, clip A, clip B, clip C, clip D, string "ResizeMethod", bool "AudioMix") { #Check Clips For Full Chroma - 4:4:4 #Assert((IsYV12(A) || IsYUY2(A))==False, "Clip A is not at full chroma (4:4:4). Convert to RGB") #Assert((IsYV12(B) || IsYUY2(B))==False, "Clip B is not at full chroma (4:4:4). Convert to RGB") #Assert((IsYV12(C) || IsYUY2(C))==False, "Clip C is not at full chroma (4:4:4). Convert to RGB") #Assert((IsYV12(D) || IsYUY2(D))==False, "Clip D is not at full chroma (4:4:4). Convert to RGB") #Set Defaults ResizeMethod = Default(ResizeMethod, "BilinearResize") AudioMix = Default(AudioMix, true) #Set Borders BorderH = Border BorderW = Border #Set Width and Height of individual clips NewW = Round(float(Width)/2.0 - float(BorderW)*1.5) NewH = Round(float(Height)/2.0 - float(BorderH)*1.5) #Process Video A = A.FlipHorizontal().FlipVertical().ZoomBox(NewW, NewH, ResizeMethod, 0, 0,0, width(C),0).FlipHorizontal().FlipVertical() A = A.AddBorders(BorderW, BorderH, 0, 0) B = B.FlipVertical().ZoomBox(NewW, NewH, ResizeMethod, 0, 0,0, 0,height(B)).FlipVertical() B = B.AddBorders(BorderW, BorderH, 0, 0) C = C.FlipHorizontal().ZoomBox(NewW, NewH, ResizeMethod, 0, 0,0, width(C),0).FlipHorizontal() C = C.AddBorders(BorderW, BorderH, 0, 0) D = D.ZoomBox(NewW, NewH, ResizeMethod, 0, 0,0, 0,height(D)) D = D.AddBorders(BorderW, BorderH, 0, 0) #Merge Clips X = StackHorizontal(A, B).AddBorders(0,0,BorderW,0) Y = StackHorizontal(C, D).AddBorders(0,0,BorderW,0) StackVertical(X, Y).AddBorders(0,0,0,BorderH).KillAudio() #Fix Audio LongestClip = Int(Max(Framecount(A), Framecount(B), Framecount(C), Framecount(D))) A = (Framecount(A) <> LongestClip) ? A ++ BlankClip(A, LongestClip-Framecount(A)) : A B = (Framecount(B) <> LongestClip) ? B ++ BlankClip(B, LongestClip-Framecount(B)) : B C = (Framecount(C) <> LongestClip) ? C ++ BlankClip(C, LongestClip-Framecount(C)) : C D = (Framecount(D) <> LongestClip) ? D ++ BlankClip(D, LongestClip-Framecount(D)) : D #Mix Audio Sound = (AudioMix) ? MergeChannels(MixAudio(ConvertToMono(A).Amplify(0.49), ConvertToMono(C).Amplify(0.49)), MixAudio(ConvertToMono(B).Amplify(0.49), ConvertToMono(D).Amplify(0.49))): \ MergeChannels(GetLeftChannel(A), GetRightChannel(A), GetLeftChannel(B), GetRightChannel(B), GetLeftChannel(C), GetRightChannel(C), GetLeftChannel(D), GetRightChannel(D)) AudioDub(last, Sound) }
#50 | Link |
Mike,
Have you looked at the UI and capabilities of Proshow Gold/Producer? If not, I encourage you to take a look at it, and consider using their parameters for panning, zoom and rotation. Rather than choosing starting and ending X and Y coordinates for upper left / lower right, their system pans by referencing a center point (0,0), so panning from left to right would simply be -15, 0 => +15, 0. Zoom is done by percentage, and X and Y zoom are locked together by default, but that can be "broken" so the aspect ratio can change. I've been trying to figure out how to convert some Proshow shows to Avisynth, and your KBE is the key to the conversion. Anyway, you posted about trying to figure out a good way to handle the parameters, a bonus of using Proshow would be that there would be a way to review the effect and get the parameter values. Proshow is great for photos and for a very easy UI to do some amazing stuff, my whole project was based on this before I realized that large videos will frequently crash it (and it's painfully slow with video). Avisynth is awesome for scripting (and amazingly fast for preview), but coding in all the numbers can be overwhelming. Proshow has a eval/preview version, it's worth checking out as you continue to improve your KBE, just pop a photo on the timeline, double-click, then click on the Motion tab and play around with the values. Tac |
#51 | Link | |
Resize Abuser
After looking at Proshow, there are multiple ways to do rotate (before or after zoom, xy location), so I'll keep them in mind when i finally take the plunge and add it. I'll probably use the zoom.dll rotate option, when using zoom(), and Effect Rotation with ZoomBox(). This won't be added for some time though... In case your wondering, I will fully develop the Align option, then add in the zoom pan to it after. Going this route prevents this from being stalled from the dev being too hard. So align will make the initial box, and then use the pan zoom on that box, thus i shouldn't have to redo a lot of code, since it will be 2 different code blocks. This also will allow pan zoom in Mode 1, although it would be kinda odd to use it that way. This of course brings up the question of, when align is not at 5, should it expand into the black area, or should it avoid it all all costs? I personally think it should avoid it at all costs, thus zooming out 2000% with align=1, and the image is in the upper left corner. If it does it the other way then when zooming out 2000% the image will be a little off center. Please keep the input coming in. The more ideas I have, the better this can be.
#52 | Link |
Resize Abuser
So i had a brain storm, and decided to code. If i could get some testing of ZB, that would be great! Here is my test code block...
A = ColorBars().Crop(10, 20, -30, -400).ConvertToYV12() B = ColorBars().invert().FlipHorizontal().Crop(10, 20, -300, -40).ConvertToYV12() C = ColorBars().FlipVertical().Crop(10, 200, -30, -40).ConvertToYV12() D = ColorBars().invert().FlipVertical().FlipHorizontal().Crop(100, 20, -30, -40).ConvertToYV12() E = ImageReader("traingr4.jpg") SplitScreener(640, 480, 4, A, B, C, D, ZoomToFill=1) E.ZoomBoxer(640,480, "BilinearResize", DisplayAR=16.0/9.0, Align=1, zoomFactor=-1, panX=-500, panY=-20) function SplitScreener(int Width, int Height, int Border, clip A, clip B, clip C, clip D, int "ZoomToFill", string "ResizeMethod", bool "AudioMix") { #Set Defaults ResizeMethod = Default(ResizeMethod, "BilinearResize") AudioMix = Default(AudioMix, true) ZoomToFill = Default(ZoomToFill, -1) #Check Inputs Assert(ZoomToFill==1 || ZoomToFill==-1, "ZoomToFill must be 1 or -1. Input of " + String(ZoomToFill) + " doesn't work") #Set Borders BorderH = Border BorderW = Border #Set Width and Height of individual clips NewW = Round(float(Width)/2.0 - float(BorderW)*1.5) NewH = Round(float(Height)/2.0 - float(BorderH)*1.5) NewAR = Float(NewW)/Float(NewH) OutAR = Float(Width)/Float(Height) #Process Video A = A.ZoomBoxer(NewW, NewH, ResizeMethod, Float(A.width())/Float(A.height())*(NewAR/OutAR), ZoomToFill*(9)) A = A.AddBorders(BorderW, BorderH, 0, 0) B = B.ZoomBoxer(NewW, NewH, ResizeMethod, Float(B.width())/Float(B.height())*(NewAR/OutAR), ZoomToFill*(7)) B = B.AddBorders(BorderW, BorderH, 0, 0) C = C.ZoomBoxer(NewW, NewH, ResizeMethod, Float(C.width())/Float(C.height())*(NewAR/OutAR), ZoomToFill*(3)) C = C.AddBorders(BorderW, BorderH, 0, 0) D = D.ZoomBoxer(NewW, NewH, ResizeMethod, Float(D.width())/Float(D.height())*(NewAR/OutAR), ZoomToFill*(1)) D = D.AddBorders(BorderW, BorderH, 0, 0) #Merge Clips X = StackHorizontal(A, B).AddBorders(0,0,BorderW,0) Y = StackHorizontal(C, D).AddBorders(0,0,BorderW,0) StackVertical(X, Y).AddBorders(0,0,0,BorderH).KillAudio() #Fix Audio LongestClip = Int(Max(Framecount(A), Framecount(B), Framecount(C), Framecount(D))) A = (Framecount(A) <> LongestClip) ? A ++ BlankClip(A, LongestClip-Framecount(A)) : A B = (Framecount(B) <> LongestClip) ? B ++ BlankClip(B, LongestClip-Framecount(B)) : B C = (Framecount(C) <> LongestClip) ? C ++ BlankClip(C, LongestClip-Framecount(C)) : C D = (Framecount(D) <> LongestClip) ? D ++ BlankClip(D, LongestClip-Framecount(D)) : D #Mix Audio Sound = (AudioMix) ? MergeChannels(MixAudio(ConvertToMono(A).Amplify(0.49), ConvertToMono(C).Amplify(0.49)), MixAudio(ConvertToMono(B).Amplify(0.49), ConvertToMono(D).Amplify(0.49))): \ MergeChannels(GetLeftChannel(A), GetRightChannel(A), GetLeftChannel(B), GetRightChannel(B), GetLeftChannel(C), GetRightChannel(C), GetLeftChannel(D), GetRightChannel(D)) AudioDub(last, Sound) } Function ZoomBoxer(clip c, int "width", int "height", string "ResizeMethod", float "DisplayAR", int "Align", float "zoomFactor", float "panX", float "panY", int "color", int "IgnoreAR") { #set defaults ResizeMethod = Default(ResizeMethod, "BilinearResize") IgnoreAR = Default(IgnoreAR, 1) color = Default(color, $000000) width = Default(width, c.width()) height = Default(height, c.height()) Align = Default(Align, 0) zoomFactor = Default(-zoomFactor, 0.0) panX = Default(panX, 0) panY = Default(panY, 0) SourceAR = float(c.width())/float(c.height()) FinalAR = float(width)/float(height) DisplayAR = Default(DisplayAR, Float(c.width())/Float(c.height())) DisplayAR = DisplayAR == 0 ? Float(c.width())/Float(c.height()) : DisplayAR #If Align=5 or -5 then center clip. -5: Add borders. 5: Crop. #Display Aspect Ratio = Final Output Ratio. No Change, Show All Pixels #Display Aspect Ratio > Final Output Ratio. Add Height or Crop Width #Display Aspect Ratio < Final Output Ratio. Add Width or Crop Height EvalString = \ Align<>0 && DisplayAR==FinalAR ? \ "x1=0" + " x2=" + String(c.width()) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==-5 || Align==-4 || Align==-6) && DisplayAR>FinalAR ? \ "y1=" + String(0 - ((height*DisplayAR-width)/2.0)*(c.height()/Float(width))) + " y2=" + String(c.height() + ((height*DisplayAR-width)/2.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==5 || Align==2 || Align==8) && DisplayAR>FinalAR ? \ "x1=" + String(0 + ((height-width/DisplayAR)/2.0)*(c.width()/Float(height))) + " x2=" + String(c.width() - ((height-width/DisplayAR)/2.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==-5 || Align==-2 || Align==-8) && DisplayAR<FinalAR ? \ "x1=" + String(0 - ((width/DisplayAR-height)/2.0)*(c.width()/Float(height))) + " x2=" + String(c.width() + ((width/DisplayAR-height)/2.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==5 || Align==4 || Align==6) && DisplayAR<FinalAR ? \ "y1=" + String(0 + ((width-height*DisplayAR)/2.0)*(c.height()/Float(width))) + " y2=" + String(c.height() - ((width-height*DisplayAR)/2.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==-1 || Align==-2 || Align==-3) && DisplayAR>FinalAR ? \ "y1=" + String(0) + " y2=" + String(c.height() + ((height*DisplayAR-width)/1.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==-1 || Align==-4 || Align==-7) && DisplayAR<FinalAR ? \ "x1=" + String(0) + " x2=" + String(c.width() + ((width/DisplayAR-height)/1.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==-9 || Align==-8 || Align==-7) && DisplayAR>FinalAR ? \ "y1=" + String(0 - ((height*DisplayAR-width)/1.0)*(c.height()/Float(width))) + " y2=" + String(c.height()) + " x1=0" + " x2=" + String(c.width()) \ : (Align==-9 || Align==-6 || Align==-3) && DisplayAR<FinalAR ? \ "x1=" + String(0 - ((width/DisplayAR-height)/1.0)*(c.width()/Float(height))) + " x2=" + String(c.width()) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==2 || Align==1 || Align==3) && DisplayAR<FinalAR ? \ "y1=" + String(0) + " y2=" + String(c.height() - ((width-height*DisplayAR)/1.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==8 || Align==7 || Align==9) && DisplayAR<FinalAR ? \ "y1=" + String(0 + ((width-height*DisplayAR)/1.0)*(c.height()/Float(width))) + " y2=" + String(c.height()) + " x1=0" + " x2=" + String(c.width()) \ : (Align==4 || Align==1 || Align==7) && DisplayAR>FinalAR ? \ "x1=" + String(0) + " x2=" + String(c.width() - ((height-width/DisplayAR)/1.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==6 || Align==3 || Align==9) && DisplayAR>FinalAR ? \ "x1=" + String(0 + ((height-width/DisplayAR)/1.0)*(c.width()/Float(height))) + " x2=" + String(c.width()) + " y1=0" + " y2=" + String(c.height()) + "" \ : "" Eval(EvalString) #Take Crop Like Input x2 = x2<=x1 && x2 < 0 ? c.width() + x2 : x2 y2 = y2<=y1 && y2 < 0 ? c.height() + y2 : y2 #Check if x2 or y2 needs to be calculated Assert( ((x2==x1) && (y2==y1))==False, "x2 [" + String(x2) + "] or y2 [" + String(y2) + "] needs a value that is different from x1 [" + String(x1) + "] or y1 [" + String(y1) + "]") y2 = (y2==y1) ? (((x2-x1)/FinalAR)/(SourceAR/DisplayAR) + y1) : y2 x2 = (x2==x1) ? (((y2-y1)*FinalAR)*(SourceAR/DisplayAR) + x1) : x2 #Calc Zoom Factor Align = abs(Align) x1 = Align==0 || Align==5 || Align==2 || Align==3 || Align==8 || Align==9 ? x1-(x2-x1)*zoomFactor/4.0 : Align==6 ? x1-((x2-x1)*zoomFactor)/2.4 : x1 y1 = Align==0 || Align==5 || Align==4 || Align==6 || Align==7 || Align==9 ? y1-(y2-y1)*zoomFactor/4.0 : Align==8 ? y1-((y2-y1)*zoomFactor)/2.4 : y1 x2 = Align==0 || Align==5 || Align==1 || Align==2 || Align==7 || Align==8 ? x2+(x2-x1)*zoomFactor/4.0 : Align==4 ? x2+((x2-x1)*zoomFactor)/2.4 : x2 y2 = Align==0 || Align==5 || Align==1 || Align==3 || Align==4 || Align==6 ? y2+(y2-y1)*zoomFactor/4.0 : Align==2 ? y2+((y2-y1)*zoomFactor)/2.4 : y2 #Calc Pan Factor x1 = x1+panX y1 = y1+panY x2 = x2+panX y2 = y2+panY BoxAR = Float(x2-x1)/Float(y2-y1) #Check For Any Unreasonable Inputs Assert(x1<x2, "ZoomBox: x1[" + String(x1) + "] point larger then x2 Point[" + String(x2) + "]") Assert(y1<y2, "ZoomBox: y1[" + String(y1) + "] point larger then y2 Point[" + String(y2) + "]") Assert(IgnoreAR>0 || BoxAR == FinalAR, "ZoomBox: Box Aspect Ratio [" + String(BoxAR) + "] does not equal clip output Aspect Ratio [" + string(FinalAR) + "]") #Pad clip so resizer interpolates from border when zooming out. 64 for spline64 #Conditional Borders... only add if it's going to be used. borderSize = 64 borderLeft = x1 < 0 ? borderSize : 0 borderTop = y1 < 0 ? borderSize : 0 borderRight = x2 > c.width() ? borderSize : 0 borderBottom = y2 > c.height() ? borderSize : 0 c = c.AddBorders(borderLeft,borderTop,borderRight,borderBottom,color) #Do it c = Eval(ResizeMethod + "(c, " + String(Round(width)) + ", " + String(Round(height)) + ", src_left=" + String(x1+borderLeft) + ", src_top=" + String(y1+borderTop) + ", src_width=" + String(x2-x1) + ", src_height=" + String(y2-y1) + ")") c Subtitle(String(x1) + ", " + String(y1) + " " + String(x2) + ", " + String(y2) + " BoxAR " + String(BoxAR) + " " + String()) }
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer Last edited by mikeytown2; 27th May 2008 at 08:46. |
#53 | Link | ||
A = ColorBars().Crop(10, 20, -30, -400).ConvertToYV12() B = ColorBars().invert().FlipHorizontal().Crop(10, 20, -300, -40).ConvertToYV12() C = ColorBars().FlipVertical().Crop(10, 200, -30, -40).ConvertToYV12() D = ColorBars().invert().FlipVertical().FlipHorizontal().Crop(100, 20, -30, -40).ConvertToYV12() SplitScreener(640, 480, 4, A, B, C, D, ZoomToFill=1) Code:
zoomFactor = Default(-zoomFactor, 0.0) Code:
zoomFactor = -Default(zoomFactor, 0.0) Quote:
#54 | Link |
I'd also prefer to see something like zoom=100 mean that there was no zoom, rather than having negative zoom go in and positive zoom go out. It fits into the common percentage model -- show this picture at 25%, or 200%.
#55 | Link |
I've ditched SplitScreener from your example and used ZoomBoxer directly with my own test image. It seems to work fine for the simple cases I tried. However, I have a few questions and comments.
What is the meaning of align=0 (the default value)? In the case align=0 and the ARs match (DisplayAR=FinalAR), x1 etc are undefined as there is no code to handle this combination. Are panX and panY in pixel units of the input clip or the output clip? It seems to be the former, but how are they meant to interact with zoom? I'm still confused about the intended meaning of zoomFactor - I think this is partly because there is already an implicit zoom happening if the input and output clips differ in size. Can you explain this further please? In any case (whatever the answer to the above), the code to recalculate x1 (etc) based on zoomFactor looks wrong to me because x2 and y2 are calculated using the possibly already changed values of x1 and y1 (and where on earth does the value 2.4 come from?) Last edited by Gavino; 27th May 2008 at 21:02. |
#56 | Link | |||||
Resize Abuser
I'm looking on the web for code on how to do the zoom. Right now mine is linear, which is why it messes up when zooming in too much. I think it needs to be shaped like a Logarithm, thus 100*.01=1, and it can never reach 0 when zooming out. I just need to figure out how to limit the zooming in so that the zoom point doesn't cross it's self. I'll post some new code in an hr or 2... but if you can point me to some code where zoom of 100% is unchanged and 200% is twice as much, ect... i would appreciate it.
#57 | Link | ||||
![]() Quote:
For limiting, you just have to add a validation check that the requested zoom (scale) factor is > 0. |
#58 | Link |
Resize Abuser
I fixed the bug in zoomFactor with my current logic (Thanks Gavino!) I also gave Log() a shot... it's sorta close. Keep in mind that when zooming out, x1,y1 needs to go negative and x2,y2 need to go positive. Zooming in, x1,y1 gets larger, x2,y2 gets smaller.
![]() After checking in GIMP, this is 200%. I would like it to behave like this, how GIMP does. If you could code a better way then what i got, shouldn't be that hard, lol, i would greatly appreciate it! Code:
A = ColorBars().Crop(10, 20, -30, -400).ConvertToYV12() B = ColorBars().invert().FlipHorizontal().Crop(10, 20, -300, -40).ConvertToYV12() C = ColorBars().FlipVertical().Crop(10, 200, -30, -40).ConvertToYV12() D = ColorBars().invert().FlipVertical().FlipHorizontal().Crop(100, 20, -30, -40).ConvertToYV12() E = ImageReader("testp2cz4.png",0,0) E = E.ConvertToYV12().AssumeFPS("ntsc_video") W = 640 H = 480 DAR = 0 #16.0/9.0 Resize = "BilinearResize" #SplitScreener(640, 480, 8, A, B, C, D, ZoomToFill=1).Trim(0,4).KillAudio() E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=50, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-2, zoomFactor=50, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-3, zoomFactor=50, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-4, zoomFactor=50, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-5, zoomFactor=50, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-6, zoomFactor=50, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-7, zoomFactor=50, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-8, zoomFactor=50, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-9, zoomFactor=50, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=100, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=200, panX=0, panY=0).Subtitle("Incorrect at 200%", y=200) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=272, panX=0, panY=0).Subtitle("Correct for 200%", y=200) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=400, panX=0, panY=0).Subtitle("Incorrect at 400%", y=200) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=448, panX=0, panY=0).Subtitle("Correct for 400%", y=200) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=576, panX=0, panY=0).Subtitle("Correct for 800%", y=200) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=100, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=75, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=50, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=25, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=10, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=1, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=.1, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=.01, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=.001, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=.0001, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=.00001, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=.0000000000000000000000001, panX=0, panY=0) Function ZoomBoxer(clip c, int "width", int "height", string "ResizeMethod", float "DisplayAR", int "Align", float "zoomFactor", float "panX", float "panY", int "color", int "IgnoreAR") { #set defaults ResizeMethod = Default(ResizeMethod, "BilinearResize") IgnoreAR = Default(IgnoreAR, 1) color = Default(color, $000000) width = Default(width, c.width()) height = Default(height, c.height()) Align = Default(Align, 0) zoomFactor = -Log(Default(zoomFactor, 100.0)*0.01) panX = Default(panX, 0) panY = Default(panY, 0) SourceAR = float(c.width())/float(c.height()) FinalAR = float(width)/float(height) DisplayAR = Default(DisplayAR, Float(c.width())/Float(c.height())) DisplayAR = DisplayAR == 0 ? Float(c.width())/Float(c.height()) : DisplayAR #If Align=5 or -5 then center clip. -5: Add borders. 5: Crop. #Display Aspect Ratio = Final Output Ratio. No Change, Show All Pixels #Display Aspect Ratio > Final Output Ratio. Add Height or Crop Width #Display Aspect Ratio < Final Output Ratio. Add Width or Crop Height EvalString = \ Align<>0 && DisplayAR==FinalAR ? \ "x1=0" + " x2=" + String(c.width()) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==-5 || Align==-4 || Align==-6) && DisplayAR>FinalAR ? \ "y1=" + String(0 - ((height*DisplayAR-width)/2.0)*(c.height()/Float(width))) + " y2=" + String(c.height() + ((height*DisplayAR-width)/2.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==5 || Align==2 || Align==8) && DisplayAR>FinalAR ? \ "x1=" + String(0 + ((height-width/DisplayAR)/2.0)*(c.width()/Float(height))) + " x2=" + String(c.width() - ((height-width/DisplayAR)/2.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==-5 || Align==-2 || Align==-8) && DisplayAR<FinalAR ? \ "x1=" + String(0 - ((width/DisplayAR-height)/2.0)*(c.width()/Float(height))) + " x2=" + String(c.width() + ((width/DisplayAR-height)/2.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==5 || Align==4 || Align==6) && DisplayAR<FinalAR ? \ "y1=" + String(0 + ((width-height*DisplayAR)/2.0)*(c.height()/Float(width))) + " y2=" + String(c.height() - ((width-height*DisplayAR)/2.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==-1 || Align==-2 || Align==-3) && DisplayAR>FinalAR ? \ "y1=" + String(0) + " y2=" + String(c.height() + ((height*DisplayAR-width)/1.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==-1 || Align==-4 || Align==-7) && DisplayAR<FinalAR ? \ "x1=" + String(0) + " x2=" + String(c.width() + ((width/DisplayAR-height)/1.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==-9 || Align==-8 || Align==-7) && DisplayAR>FinalAR ? \ "y1=" + String(0 - ((height*DisplayAR-width)/1.0)*(c.height()/Float(width))) + " y2=" + String(c.height()) + " x1=0" + " x2=" + String(c.width()) \ : (Align==-9 || Align==-6 || Align==-3) && DisplayAR<FinalAR ? \ "x1=" + String(0 - ((width/DisplayAR-height)/1.0)*(c.width()/Float(height))) + " x2=" + String(c.width()) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==2 || Align==1 || Align==3) && DisplayAR<FinalAR ? \ "y1=" + String(0) + " y2=" + String(c.height() - ((width-height*DisplayAR)/1.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==8 || Align==7 || Align==9) && DisplayAR<FinalAR ? \ "y1=" + String(0 + ((width-height*DisplayAR)/1.0)*(c.height()/Float(width))) + " y2=" + String(c.height()) + " x1=0" + " x2=" + String(c.width()) \ : (Align==4 || Align==1 || Align==7) && DisplayAR>FinalAR ? \ "x1=" + String(0) + " x2=" + String(c.width() - ((height-width/DisplayAR)/1.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==6 || Align==3 || Align==9) && DisplayAR>FinalAR ? \ "x1=" + String(0 + ((height-width/DisplayAR)/1.0)*(c.width()/Float(height))) + " x2=" + String(c.width()) + " y1=0" + " y2=" + String(c.height()) + "" \ : "" Eval(EvalString) #Take Crop Like Input x2 = x2<=x1 && x2 < 0 ? c.width() + x2 : x2 y2 = y2<=y1 && y2 < 0 ? c.height() + y2 : y2 #Check if x2 or y2 needs to be calculated Assert( ((x2==x1) && (y2==y1))==False, "x2 [" + String(x2) + "] or y2 [" + String(y2) + "] needs a value that is different from x1 [" + String(x1) + "] or y1 [" + String(y1) + "]") y2 = (y2==y1) ? (((x2-x1)/FinalAR)/(SourceAR/DisplayAR) + y1) : y2 x2 = (x2==x1) ? (((y2-y1)*FinalAR)*(SourceAR/DisplayAR) + x1) : x2 SubString = "Align=" + String(Align) + " zoomFactor=" + String(zoomFactor) + " panX=" + String(panX) + " panY=" + String(panY) #Calc Pan Factor x1 = x1+panX y1 = y1+panY x2 = x2+panX y2 = y2+panY #Calc Zoom Factor Align = abs(Align) x1tmp = Align==0 || Align==5 || Align==2 || Align==8 ? x1-(x2-x1)*zoomFactor/4.0 : Align==3 || Align==6 || Align==9 ? x1-((x2-x1)*zoomFactor)/2.0 : x1 y1tmp = Align==0 || Align==5 || Align==4 || Align==6 ? y1-(y2-y1)*zoomFactor/4.0 : Align==7 || Align==8 || Align==9 ? y1-((y2-y1)*zoomFactor)/2.0 : y1 x2 = Align==0 || Align==5 || Align==2 || Align==8 ? x2+(x2-x1)*zoomFactor/4.0 : Align==1 || Align==4 || Align==7 ? x2+((x2-x1)*zoomFactor)/2.0 : x2 y2 = Align==0 || Align==5 || Align==4 || Align==6 ? y2+(y2-y1)*zoomFactor/4.0 : Align==1 || Align==2 || Align==3 ? y2+((y2-y1)*zoomFactor)/2.0 : y2 x1 = x1tmp y1 = y1tmp BoxAR = Float(x2-x1)/Float(y2-y1) #Check For Any Unreasonable Inputs Assert(x1<x2, "ZoomBox: x1[" + String(x1) + "] point larger then x2 Point[" + String(x2) + "]") Assert(y1<y2, "ZoomBox: y1[" + String(y1) + "] point larger then y2 Point[" + String(y2) + "]") Assert(IgnoreAR>0 || BoxAR == FinalAR, "ZoomBox: Box Aspect Ratio [" + String(BoxAR) + "] does not equal clip output Aspect Ratio [" + string(FinalAR) + "]") #Pad clip so resizer interpolates from border when zooming out. 64 for spline64 #Conditional Borders... only add if it's going to be used. borderSize = 64 borderLeft = x1 < 0 ? borderSize : 0 borderTop = y1 < 0 ? borderSize : 0 borderRight = x2 > c.width() ? borderSize : 0 borderBottom = y2 > c.height() ? borderSize : 0 c = c.AddBorders(borderLeft,borderTop,borderRight,borderBottom,color) #Do it c = Eval(ResizeMethod + "(c, " + String(Round(width)) + ", " + String(Round(height)) + ", src_left=" + String(x1+borderLeft) + ", src_top=" + String(y1+borderTop) + ", src_width=" + String(x2-x1) + ", src_height=" + String(y2-y1) + ")") c Subtitle(String(x1) + ", " + String(y1) + " " + String(x2) + ", " + String(y2) + " BoxAR " + String(BoxAR) + " " + String()) Subtitle(SubString, y=100) } function SplitScreener(int Width, int Height, int Border, clip A, clip B, clip C, clip D, int "ZoomToFill", string "ResizeMethod", bool "AudioMix") { #Set Defaults ResizeMethod = Default(ResizeMethod, "BilinearResize") AudioMix = Default(AudioMix, true) ZoomToFill = Default(ZoomToFill, -1) #Check Inputs Assert(ZoomToFill==1 || ZoomToFill==-1, "ZoomToFill must be 1 or -1. Input of " + String(ZoomToFill) + " doesn't work") #Set Borders BorderH = Border BorderW = Border #Set Width and Height of individual clips NewW = Round(float(Width)/2.0 - float(BorderW)*1.5) NewH = Round(float(Height)/2.0 - float(BorderH)*1.5) NewAR = Float(NewW)/Float(NewH) OutAR = Float(Width)/Float(Height) #Process Video A = A.ZoomBoxer(NewW, NewH, ResizeMethod, Float(A.width())/Float(A.height())*(NewAR/OutAR), ZoomToFill*(9)) A = A.AddBorders(BorderW, BorderH, 0, 0) B = B.ZoomBoxer(NewW, NewH, ResizeMethod, Float(B.width())/Float(B.height())*(NewAR/OutAR), ZoomToFill*(7)) B = B.AddBorders(BorderW, BorderH, 0, 0) C = C.ZoomBoxer(NewW, NewH, ResizeMethod, Float(C.width())/Float(C.height())*(NewAR/OutAR), ZoomToFill*(3)) C = C.AddBorders(BorderW, BorderH, 0, 0) D = D.ZoomBoxer(NewW, NewH, ResizeMethod, Float(D.width())/Float(D.height())*(NewAR/OutAR), ZoomToFill*(1)) D = D.AddBorders(BorderW, BorderH, 0, 0) #Merge Clips X = StackHorizontal(A, B).AddBorders(0,0,BorderW,0) Y = StackHorizontal(C, D).AddBorders(0,0,BorderW,0) StackVertical(X, Y).AddBorders(0,0,0,BorderH).KillAudio() #Fix Audio LongestClip = Int(Max(Framecount(A), Framecount(B), Framecount(C), Framecount(D))) A = (Framecount(A) <> LongestClip) ? A ++ BlankClip(A, LongestClip-Framecount(A)) : A B = (Framecount(B) <> LongestClip) ? B ++ BlankClip(B, LongestClip-Framecount(B)) : B C = (Framecount(C) <> LongestClip) ? C ++ BlankClip(C, LongestClip-Framecount(C)) : C D = (Framecount(D) <> LongestClip) ? D ++ BlankClip(D, LongestClip-Framecount(D)) : D #Mix Audio Sound = (AudioMix) ? MergeChannels(MixAudio(ConvertToMono(A).Amplify(0.49), ConvertToMono(C).Amplify(0.49)), MixAudio(ConvertToMono(B).Amplify(0.49), ConvertToMono(D).Amplify(0.49))): \ MergeChannels(GetLeftChannel(A), GetRightChannel(A), GetLeftChannel(B), GetRightChannel(B), GetLeftChannel(C), GetRightChannel(C), GetLeftChannel(D), GetRightChannel(D)) AudioDub(last, Sound) } ![]()
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer Last edited by mikeytown2; 28th May 2008 at 01:07. |
#59 | Link |
Resize Abuser
I got this really close to being done... zoomFactor works correctly at align=5,6,8,9. when using zoomfactor it will not "cross over" on the zoom-in anymore; any positive number you give it, it should be able to use.
A = ColorBars().Crop(10, 20, -30, -400).ConvertToYV12() B = ColorBars().invert().FlipHorizontal().Crop(10, 20, -300, -40).ConvertToYV12() C = ColorBars().FlipVertical().Crop(10, 200, -30, -40).ConvertToYV12() D = ColorBars().invert().FlipVertical().FlipHorizontal().Crop(100, 20, -30, -40).ConvertToYV12() E = ImageReader("testp2cz4.png",0,0) E = E.ConvertToYV12().AssumeFPS("ntsc_video") Global W = 640 Global H = 480 Global DAR = 0 #16.0/9.0 Global Resize = "BilinearResize" SplitScreener(W, H, 8, A, B, C, D, ZoomToFill=1).Trim(0,-1).KillAudio() last + SplitScreener(W, H, 8, A, B, C, D, ZoomToFill=-1).Trim(0,-1).KillAudio() last + TestC(E) #Try different image, it fails... E = ImageReader("traingr4.jpg",0,0) E = E.ConvertToYV12().AssumeFPS("ntsc_video") Global DAR = 16.0/9.0 last + TestC(E) Return Last Function TestC(Clip E) { TestA(E,-1) last + TestA(E,-2) last + TestA(E,-3) last + TestA(E,-4) last + TestA(E,-5) last + TestA(E,5) last + TestA(E,-6) last + TestA(E,-7) last + TestA(E,-8) last + TestA(E,-9) last + TestB(E, 25) last + TestB(E, 50) last + TestB(E, 75) } Function TestA(clip E, int al) { E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=100, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=75, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=50, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=25, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=10, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=5, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=2, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=75, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=100, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=200, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=400, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=600, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=800, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=2000, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=al, zoomFactor=20000, panX=0, panY=0) } Function TestB(clip E, int zf) { E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-5, zoomFactor=zf, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-1, zoomFactor=zf, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-3, zoomFactor=zf, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-7, zoomFactor=zf, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-9, zoomFactor=zf, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-2, zoomFactor=zf, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-4, zoomFactor=zf, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-6, zoomFactor=zf, panX=0, panY=0) last + E.ZoomBoxer(W,H, Resize, DisplayAR=DAR, Align=-8, zoomFactor=zf, panX=0, panY=0) } Function ZoomBoxer(clip c, int "width", int "height", string "ResizeMethod", float "DisplayAR", int "Align", float "zoomFactor", float "panX", float "panY", int "color", int "IgnoreAR") { #set defaults ResizeMethod = Default(ResizeMethod, "BilinearResize") IgnoreAR = Default(IgnoreAR, 1) color = Default(color, $000000) width = Default(width, c.width()) height = Default(height, c.height()) Align = Default(Align, 0) zoomFactor = Default(zoomFactor, 100.0) zoomFactor = (zoomFactor/100.0) #zoomFactor = -(Log(zoomFactor*0.01)/Log(4)) panX = Default(panX, 0) panY = Default(panY, 0) SourceAR = float(c.width())/float(c.height()) FinalAR = float(width)/float(height) DisplayAR = Default(DisplayAR, Float(c.width())/Float(c.height())) DisplayAR = DisplayAR == 0 ? Float(c.width())/Float(c.height()) : DisplayAR #If Align=5 or -5 then center clip. -5: Add borders. 5: Crop. #Display Aspect Ratio = Final Output Ratio. No Change, Show All Pixels #Display Aspect Ratio > Final Output Ratio. Add Height or Crop Width #Display Aspect Ratio < Final Output Ratio. Add Width or Crop Height EvalString = \ Align<>0 && DisplayAR==FinalAR ? \ "x1=0" + " x2=" + String(c.width()) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==-5 || Align==-4 || Align==-6) && DisplayAR>FinalAR ? \ "y1=" + String(0 - ((height*DisplayAR-width)/2.0)*(c.height()/Float(width))) + " y2=" + String(c.height() + ((height*DisplayAR-width)/2.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==5 || Align==2 || Align==8) && DisplayAR>FinalAR ? \ "x1=" + String(0 + ((height-width/DisplayAR)/2.0)*(c.width()/Float(height))) + " x2=" + String(c.width() - ((height-width/DisplayAR)/2.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==-5 || Align==-2 || Align==-8) && DisplayAR<FinalAR ? \ "x1=" + String(0 - ((width/DisplayAR-height)/2.0)*(c.width()/Float(height))) + " x2=" + String(c.width() + ((width/DisplayAR-height)/2.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==5 || Align==4 || Align==6) && DisplayAR<FinalAR ? \ "y1=" + String(0 + ((width-height*DisplayAR)/2.0)*(c.height()/Float(width))) + " y2=" + String(c.height() - ((width-height*DisplayAR)/2.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==-1 || Align==-2 || Align==-3) && DisplayAR>FinalAR ? \ "y1=" + String(0) + " y2=" + String(c.height() + ((height*DisplayAR-width)/1.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==-1 || Align==-4 || Align==-7) && DisplayAR<FinalAR ? \ "x1=" + String(0) + " x2=" + String(c.width() + ((width/DisplayAR-height)/1.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==-9 || Align==-8 || Align==-7) && DisplayAR>FinalAR ? \ "y1=" + String(0 - ((height*DisplayAR-width)/1.0)*(c.height()/Float(width))) + " y2=" + String(c.height()) + " x1=0" + " x2=" + String(c.width()) \ : (Align==-9 || Align==-6 || Align==-3) && DisplayAR<FinalAR ? \ "x1=" + String(0 - ((width/DisplayAR-height)/1.0)*(c.width()/Float(height))) + " x2=" + String(c.width()) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==2 || Align==1 || Align==3) && DisplayAR<FinalAR ? \ "y1=" + String(0) + " y2=" + String(c.height() - ((width-height*DisplayAR)/1.0)*(c.height()/Float(width))) + " x1=0" + " x2=" + String(c.width()) \ : (Align==8 || Align==7 || Align==9) && DisplayAR<FinalAR ? \ "y1=" + String(0 + ((width-height*DisplayAR)/1.0)*(c.height()/Float(width))) + " y2=" + String(c.height()) + " x1=0" + " x2=" + String(c.width()) \ : (Align==4 || Align==1 || Align==7) && DisplayAR>FinalAR ? \ "x1=" + String(0) + " x2=" + String(c.width() - ((height-width/DisplayAR)/1.0)*(c.width()/Float(height))) + " y1=0" + " y2=" + String(c.height()) + "" \ : (Align==6 || Align==3 || Align==9) && DisplayAR>FinalAR ? \ "x1=" + String(0 + ((height-width/DisplayAR)/1.0)*(c.width()/Float(height))) + " x2=" + String(c.width()) + " y1=0" + " y2=" + String(c.height()) + "" \ : "" Eval(EvalString) #Take Crop Like Input x2 = x2<=x1 && x2 < 0 ? c.width() + x2 : x2 y2 = y2<=y1 && y2 < 0 ? c.height() + y2 : y2 #Check if x2 or y2 needs to be calculated Assert( ((x2==x1) && (y2==y1))==False, "x2 [" + String(x2) + "] or y2 [" + String(y2) + "] needs a value that is different from x1 [" + String(x1) + "] or y1 [" + String(y1) + "]") y2 = (y2==y1) ? (((x2-x1)/FinalAR)/(SourceAR/DisplayAR) + y1) : y2 x2 = (x2==x1) ? (((y2-y1)*FinalAR)*(SourceAR/DisplayAR) + x1) : x2 SubString = "Align=" + String(Align) + " zoomFactor=" + String(zoomFactor*100) + " panX=" + String(panX) + " panY=" + String(panY) #Calc Pan Factor x1 = x1+panX y1 = y1+panY x2 = x2+panX y2 = y2+panY #Calc Zoom Factor BoxAR = Float(x2-x1)/Float(y2-y1) CenterX = (x2-x1)/2.0 CenterY = (y2-y1)/2.0 CenterY = (Align<0 && DisplayAR>FinalAR)? CenterY*(FinalAR/DisplayAR): (Align>0 && DisplayAR<FinalAR)? CenterY*(FinalAR/DisplayAR): CenterY CenterX = (Align>0 && DisplayAR>FinalAR)? CenterX/(FinalAR/DisplayAR): (Align<0 && DisplayAR<FinalAR)? CenterX/(FinalAR/DisplayAR): CenterX Align = abs(Align) sY = " CenterY: " + String(CenterY) + " y2: " + String(y2) + " y1: " + String(y1) sX = " CenterX: " + String(CenterX) + " x2: " + String(x2) + " x1: " + String(x1) x1 = (Align==0 || Align==5 || Align==2 || Align==8) && zoomFactor<>1 ? CenterX-((CenterX-x1)/(zoomFactor)) : (Align==3 || Align==6 || Align==9) && zoomFactor<>1 ? CenterX*2.0-((CenterX*2.0-x1)/zoomFactor) : x1 y1 = (Align==0 || Align==5 || Align==4 || Align==6) && zoomFactor<>1 ? CenterY-((CenterY-y1)/(zoomFactor)) : (Align==7 || Align==8 || Align==9) && zoomFactor<>1 ? CenterY*2.0-((CenterY*2.0-y1)/zoomFactor) : y1 x2 = (Align==0 || Align==5 || Align==2 || Align==8) && zoomFactor<>1 ? CenterX+((x2-CenterX)/(zoomFactor)) : (Align==7 || Align==4 || Align==1) && zoomFactor<>1 ? CenterX+((x2-CenterX)/zoomFactor) : x2 y2 = (Align==0 || Align==5 || Align==4 || Align==6) && zoomFactor<>1 ? CenterY+((y2-CenterY)/(zoomFactor)) : (Align==3 || Align==2 || Align==1) && zoomFactor<>1 ? CenterY+((y2-CenterY)/zoomFactor) : y2 BoxAR = Float(x2-x1)/Float(y2-y1) #Check For Any Unreasonable Inputs Assert(x1<x2, "ZoomBox: x1[" + String(x1) + "] point larger then x2 Point[" + String(x2) + "]") Assert(y1<y2, "ZoomBox: y1[" + String(y1) + "] point larger then y2 Point[" + String(y2) + "]") Assert(IgnoreAR>0 || BoxAR == FinalAR, "ZoomBox: Box Aspect Ratio [" + String(BoxAR) + "] does not equal clip output Aspect Ratio [" + string(FinalAR) + "]") #Pad clip so resizer interpolates from border when zooming out. 64 for spline64 #Conditional Borders... only add if it's going to be used. borderSize = 64 borderLeft = x1 < 0 ? borderSize : 0 borderTop = y1 < 0 ? borderSize : 0 borderRight = x2 > c.width() ? borderSize : 0 borderBottom = y2 > c.height() ? borderSize : 0 c = c.AddBorders(borderLeft,borderTop,borderRight,borderBottom,color) #Do it c = Eval(ResizeMethod + "(c, " + String(Round(width)) + ", " + String(Round(height)) + ", src_left=" + String(x1+borderLeft) + ", src_top=" + String(y1+borderTop) + ", src_width=" + String(x2-x1) + ", src_height=" + String(y2-y1) + ")") c Subtitle(String(x1) + ", " + String(y1) + " " + String(x2) + ", " + String(y2) + " BoxAR " + String(BoxAR) + " " + String()) Subtitle(SubString, y=100) Subtitle(sY, y=140) Subtitle(sX, y=160) } function SplitScreener(int Width, int Height, int Border, clip A, clip B, clip C, clip D, int "ZoomToFill", string "ResizeMethod", bool "AudioMix") { #Set Defaults ResizeMethod = Default(ResizeMethod, "BilinearResize") AudioMix = Default(AudioMix, true) ZoomToFill = Default(ZoomToFill, -1) #Check Inputs Assert(ZoomToFill==1 || ZoomToFill==-1, "ZoomToFill must be 1 or -1. Input of " + String(ZoomToFill) + " doesn't work") #Set Borders BorderH = Border BorderW = Border #Set Width and Height of individual clips NewW = Round(float(Width)/2.0 - float(BorderW)*1.5) NewH = Round(float(Height)/2.0 - float(BorderH)*1.5) NewAR = Float(NewW)/Float(NewH) OutAR = Float(Width)/Float(Height) #Process Video A = A.ZoomBoxer(NewW, NewH, ResizeMethod, Float(A.width())/Float(A.height())*(NewAR/OutAR), ZoomToFill*(9)) A = A.AddBorders(BorderW, BorderH, 0, 0) B = B.ZoomBoxer(NewW, NewH, ResizeMethod, Float(B.width())/Float(B.height())*(NewAR/OutAR), ZoomToFill*(7)) B = B.AddBorders(BorderW, BorderH, 0, 0) C = C.ZoomBoxer(NewW, NewH, ResizeMethod, Float(C.width())/Float(C.height())*(NewAR/OutAR), ZoomToFill*(3)) C = C.AddBorders(BorderW, BorderH, 0, 0) D = D.ZoomBoxer(NewW, NewH, ResizeMethod, Float(D.width())/Float(D.height())*(NewAR/OutAR), ZoomToFill*(1)) D = D.AddBorders(BorderW, BorderH, 0, 0) #Merge Clips X = StackHorizontal(A, B).AddBorders(0,0,BorderW,0) Y = StackHorizontal(C, D).AddBorders(0,0,BorderW,0) StackVertical(X, Y).AddBorders(0,0,0,BorderH).KillAudio() #Fix Audio LongestClip = Int(Max(Framecount(A), Framecount(B), Framecount(C), Framecount(D))) A = (Framecount(A) <> LongestClip) ? A ++ BlankClip(A, LongestClip-Framecount(A)) : A B = (Framecount(B) <> LongestClip) ? B ++ BlankClip(B, LongestClip-Framecount(B)) : B C = (Framecount(C) <> LongestClip) ? C ++ BlankClip(C, LongestClip-Framecount(C)) : C D = (Framecount(D) <> LongestClip) ? D ++ BlankClip(D, LongestClip-Framecount(D)) : D #Mix Audio Sound = (AudioMix) ? MergeChannels(MixAudio(ConvertToMono(A).Amplify(0.49), ConvertToMono(C).Amplify(0.49)), MixAudio(ConvertToMono(B).Amplify(0.49), ConvertToMono(D).Amplify(0.49))): \ MergeChannels(GetLeftChannel(A), GetRightChannel(A), GetLeftChannel(B), GetRightChannel(B), GetLeftChannel(C), GetRightChannel(C), GetLeftChannel(D), GetRightChannel(D)) AudioDub(last, Sound) }
#60 | Link | |
![]() I said I was confused about the details of your zoom feature, and I now realise why. In my view, there are two different sorts of zooming required:
It seems that your current scheme mixes these up together (and in a hard-to-understand way), when for me they should be separate. Here's an example to help explain what I mean. Let's say we have an input clip 640x480 and we want to select the top left quadrant at its original resolution. I would like to say Code:
ZoomBoxer(320, 240, align=1, zoomFactor=100) Ah, perhaps I can just increase the zoomFactor (to 200, say) to compensate? In fact, I found no matter how much I increased it (even with ridiculous values like 1000000) the clip never reached the desired resolution! So it's very difficult (and in the above example, impossible) for a user to figure out what value of zoomFactor to use to achieve the effect he/she desires. It might be that what I'm seeing is due to bugs in the implementation rather than something you intended, but in any case, to my mind the following scheme would be more useful:
What do you (and others) think? Last edited by Gavino; 28th May 2008 at 19:16. |
anamorphic, crop, dar, pan and scan, resize |
