Old 30th May 2018, 15:37   #4081  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
For 32-bit, VapourSynth, UV is in the -.5 to .5 range. Everything else is 0 to 1.
Is it now the same with Avisynth?
MysteryX is offline   Reply With Quote
Old 30th May 2018, 15:48   #4082  |  Link
pinterf
Yes.
I also had to update some external filters, most of their sub-filters are o.k., will work as-is, but some filters need to be updated for the new 32bit float UV ranges.
For example:
masktools2: mt_diff, predefined constants in lut expressions (finished, not released yet)
fft3dfilter: chroma center
pinterf is offline   Reply With Quote
Old 3rd June 2018, 11:23   #4083  |  Link
pinterf
New test build
Avisynth+ r2696
https://drive.google.com/open?id=1yU...bDpSdEbR6yugUm
Compared to last test build (r2693):
- ConvertBits from/to 32 bits assume full source/destination range only for RGB. Additional fix was in limited range conversion when source is 32 bits
- Avisource: Greyscale 10, 12, 14, 16 bits for Y1[0][10] .. Y1[0][16] (not tested)
Full list since last official release (r2664)
- AviSource to support more formats with 10+ bit depth.
  http://avisynth.nl/index.php/AviSource
  When pixel_type is not specified or set to "FULL", AviSource will try to request the formats one-by-one in the order shown in the table below.
  When a classic 'pixel_type' shares more internal formats (such as YUV422P10 first tries to request the v210 then P210 format)
  you can specify one of the specific format directly. Note that high bit-depth RGBP is prioritized against packed RGB48/64.
  The 'FourCCs for ICDecompressQuery' column means that when a codec supports the format, it will serve the frame in that one, Avisource then will convert it to the proper colorspace.
  Full support list (* = already supported):
  'pixel_type' Avs+ Format   FourCC(s) for ICDecompressQuery
  YV24         YV24          *YV24
  YV16         YV16          *YV16
  YV12         YV12          *YV12
  YV411        YV411         *Y41B
  YUY2         YUY2          *YUY2
  RGBP10       RGBP10        G3[0][10]  r210  R10k
  r210         RGBP10        r210
  R10k         RGBP10        R10k
  RGBP         RGBP10        G3[0][10]  r210  R10k
               RGBP12        G3[0][12]
               RGBP14        G3[0][14]
               RGBP16        G3[0][16]
               RGBAP10       G4[0][10]
               RGBAP12       G4[0][12]
               RGBAP14       G4[0][14]
               RGBAP16       G4[0][16]
  RGB32        RGB32         *BI_RGB internal constant (0) with bitcount=32
  RGB24        RGB24         *BI_RGB internal constant (0) with bitcount=24
  RGB48        RGB48         BGR[48]    b48r
  RGB64        RGB64         *BRA[64]   b64a
  Y8           Y8            Y800       Y8[32][32]   GREY
  Y            Y8            Y800       Y8[32][32]   GREY
               Y10           Y1[0][10]
               Y12           Y1[0][12]
               Y14           Y1[0][14]
               Y16           Y1[0][16]
  YUV422P10    YUV422P10     v210       P210
  v210         YUV422P10     v210
  P210         YUV422P10     P210
  YUV422P16    YUV422P16     P216
  P216         YUV422P16     P216
  YUV420P10    YUV420P10     P010
  P010         YUV422P10     P010
  YUV420P16    YUV420P16     P016
  P016         YUV422P16     P016
  YUV444P10    YUV444P10     v410
  v410         YUV444P10     v410
- Changed (finally): 32bit float YUV colorspaces: zero centered chroma channels.
  U and V channels are now -0.5..+0.5 (if converted to full scale before) instead of 0..1
  Note: filters that relied on having the U and V channel center as 0.5 will fail.
  Why: the old UV 0..1 range was a very-very early decision in the high-bitdepth transition project. Also it is now
  compatible with z_XXXXX resizers (zimg image library, external plugin at the moment).
- New function: bool IsFloatUvZeroBased()
  For plugin or script writers who want to be compatible with pre r2672 Avisynth+ float YUV format:
    Check function availablity with FunctionExists("IsFloatUvZeroBased").
    When the function does not exists, the center value of 32 bit float U and V channel is 0.5
    When IsFloatUvZeroBased function exists, it will return true (always for official releases) if U and V is 0 based (+/-0.5)
- Fix: RGB64 Turnleft/Turnright (which are also used in RGB64 Resizers)
- Fix: Rare crash in FrameRegistry
- Enhanced: Allow ConvertToRGB24-32-48-64 functions for any source bit depths
- Enhanced: ConvertBits: allow fulls-fulld combinations when either clip is 32bits
  E.g. after a 8->32 bit fulls=false fulld=true:
  Y: 16..235 -> 0..1
  U/V: 16..240 -> -0.5..+0.5
  Note: now ConvertBits does not assume full range for YUV 32 bit float.
  Default values of fulls and fulld are now true only for RGB colorspaces.
- Fix: couldn't see variables in avsi before plugin autoloads (colors_rgb.avsi issue)
- Fix: LoadVirtualdubPlugin: Fix crash on exit when more than one instances of a filter was used in a script
- New: LoadVirtualdubPlugin update:
  - Update from interface V6 to V20, and Filtermod version 6 (partial)
  - VirtualDub2 support with extended colorspaces
    Allow RGB24, RGB48, RGB64 besides RGB32
    AutoConvert 8 bit Planar RGB to/from RGB24, RGBPA to/from RGB32 (lossless)
    AutoConvert RGB48 and 16 bit Planar RGB(A) to/from RGB64 (lossless)
    Support YUV(A) 8 bits: YV12, YV16, YV24, YV411, YUVA420P8, YUVA422P8, YUVA444P8
    Support YUV(A) 10-16 bits (properly set "ref_x" maximum levels, no autoconvert)
  - Supports prefetchProc2 callback (API >= V14 and prefetchProc2 is defined) for multiple input frames from one input clip
    PrefetchFrameDirect and PrefetchFrame are supported. PrefetchFrameSymbolic not supported
  - Supports prefetchProc callback (API >= V12 and prefetchProc is defined)
  - Supports when filter changes frame count of the output clip
  - Extra filter parameter added at the end of filter's (unnamed) parameter list
    Imported Virtualdub filters are getting and extra named parameter to the end:
      String [rangehint]
    This parameter can tell the filter about a YUV-type clip colorspace info
    Allowed values:
      "rec601": limited range + 601
      "rec709": limited range + 709
      "PC.601": full range + 601
      "PC.709": full range + 709
      ""      : not defined (same as not given)
    Parameter will be ignored when clip is non-YUV
    How it works: the hint will _not_ change the internal VirtualDub colorspace
    constant (e.g. kPixFormat_YUV420_Planar -> kPixFormat_YUV420_Planar_709 will not happen).
    Instead the base color space is kept and colorSpaceMode and colorRangeMode will set in PixmapLayout.formatEx.
    Filter can either use this information or not, depending on supported API version and its implementation.
    E.g. Crossfade(20,30) -> Crossfade(20,30,"rec601") though this specific filter won't use it.
- New function: BuildPixelType
  Creates a video format (pixel_type) string by giving a colorspace family, bit depth, optional chroma subsampling and/or a
  template clip, from which the undefined format elements are inherited.
  "[family]s[bits]i[chroma]i[compat]b[oldnames]b[sample_clip]c"
  string family: YUV, YUVA, RGB, RGBA, Y
  int bits: 8, 10, 12, 14, 16, 32
  string chroma: for YUV(A) 420,422,444,411. Ignored for RGB(A) and Y
  bool compat (default false): returns packed rgb formats for 8/16 bits (RGB default: planar RGB)
  bool oldnames (default false): returns YV12/YV16/YV24 instead of YUV420P8/YUV422P8/YUV444P8
  clip sample_clip: when supported, its format is overridden by specified parameters (e.g. only change bits=10)
  Example#1: define YUV 444 P 10
    family = "YUV"
    bits = 10
    chroma = 444
    compat = false
    oldformat = false
    s = BuildPixelType(family, bits, chroma, compat, oldformat)
    BlankClip(width=320,height=200,length=len,pixel_type=s,color=$008080).Info()
  Example#2: Change only the bit depth of the format to 16
    newbits = 16
    c = last
    s = BuildPixelType(bits=newbits, sample_clip=c)
- Source: move to c++17, 'if constexpr' requires. Use Visual Studio 2017 (or GCC 7?). CMakeLists.txt changed.
- Source: C api: AVSC_EXPORT to dllexport in capi.h for avisynth_c_plugin_init
- Source: C api: avs_is_same_colorspace VideoInfo parameters to const
- Project struct: changelog to git.
- Planned: include current header files and def/exp file in installer
Old 4th June 2018, 15:03   #4084  |  Link
pinterf
Another test build, r2700, installer w/o Visual C++ Redistributables
https://drive.google.com/open?id=1LP...No3Bi6--2NtdzF
Change since r2696: RGBAdjust fix and enhancements
Full change since last official release (r2664):
- Fix: RGBAdjust memory leak when used in ScriptClip
- Enhanced: RGBAdjust new parameter: conditional (like in ColorYUV)
  The global variables "rgbadjust_xxx" with xxx = r, g, b, a, rb, gb, bb, ab, rg, gg, bg, ag are read each frame, and applied.
  It is possible to modify these variables using FrameEvaluate or ConditionalReader.
- Enhanced: RGBAdjust: support 32 bit float ('analyze' not supported, 'dither' silently ignored)
- Enhanced: AviSource to support more formats with 10+ bit depth.
  YV24         YV24          *YV24
  YV16         YV16          *YV16
  YV12         YV12          *YV12
  YV411        YV411         *Y41B
  YUY2         YUY2          *YUY2
  r210         RGBP10        r210
  R10k         RGBP10        R10k
               RGBP12        G3[0][12]
               RGBP14        G3[0][14]
               RGBP16        G3[0][16]
               RGBAP10       G4[0][10]
               RGBAP12       G4[0][12]
               RGBAP14       G4[0][14]
               RGBAP16       G4[0][16]
               Y10           Y1[0][10]
               Y12           Y1[0][12]
               Y14           Y1[0][14]
               Y16           Y1[0][16]
  v210         YUV422P10     v210
  P210         YUV422P10     P210
  P216         YUV422P16     P216
  P010         YUV422P10     P010
  P016         YUV422P16     P016
  v410         YUV444P10     v410
  Y: 16..235 -> 0..1
      String [rangehint]
    Allowed values:
    family = "YUV"
    bits = 10
    chroma = 444
    compat = false
    oldformat = false
    newbits = 16
    c = last
Old 5th June 2018, 13:23   #4085  |  Link
`Orum
As I understand it, when using GetFrame(), pitch can vary on a per-frame basis for all planes. Is it possible to get the maximum possible pitch for each plane?
The reason I ask is I'd like to avoid painful reallocations, so if I can simply allocate the maximum pitch * vi.height (right shifted by GetPlaneHeightSubsampling()) for each plane, then I don't have to worry about it exceeding my initial allocation later on.
My filters: DupStep | PointSize
`Orum is offline   Reply With Quote
Old 5th June 2018, 14:23   #4086  |  Link
I would say NO, unless you can find the maximum possible size of a frame.
Pitch can change because of interleaving of cropped clips, I forget what the new rules are on avs+ concerning crop and Align arg, but on v2.6 standard, Align is False by default, and so is much more likely to do a Soft Crop, ie Subframe() and SubframePlanar(), so pitch could be pretty much any size.
(I take it that you would like it to work on avs standard too).
Output frame pitch is guaranteed identical. [EDIT: When calling NewVideoFrame, ie not simply passing though a frame like in ClipClop or ReplaceFramesSimple.]
IanB Torture Test
A=SelectEvery(3, 0).AddBorders(0,0, 16,0).Crop(0,0, -16,0)
B=SelectEvery(3, 1).AddBorders(0,0, 32,0).Crop(0,0, -32,0)
C=SelectEvery(3, 2).AddBorders(0,0, 64,0).Crop(0,0, -64,0)
Interleave(A, B, C)
https://forum.doom9.org/showthread.p...re#post1613005
https://forum.doom9.org/showthread.p...re#post1603626
https://forum.doom9.org/showthread.p...re#post1628159
Old 5th June 2018, 14:53   #4087  |  Link
pinterf
Alignment:
Plane pointers and pitches are 64 bytes aligned in recent Avisynth+ versions (but it was 32 bytes before - avx and avx2-safe), this is the minimum.
It can be larger, when NewVideoFrame is called with a larger align value, e.g. 128
But there is no guarantee that a pitch is simply an up-aligned value of the plane width, framebuffers are mostly re-used internally to avoid reallocation.
Plus, as StainlessS mentioned, a Crop (in avs+ always producing an aligned output, the alignment rule can never be broken), or SeparateRows can simply change the pitch value internally w/o making a frame copy.
Last edited by pinterf; 5th June 2018 at 15:33. Reason: SeparateRows instead of SelectEven
Old 5th June 2018, 15:25   #4088  |  Link
Made edit in my previous post, I should have caught that.
Presumably, MakeWritable can change Pitch from original input too.
EDIT: On frame like this for instance:
Old 5th June 2018, 16:18   #4089  |  Link
`Orum
Okay, so I'm guessing the best bet here is to get the per plane pitches for the first frame, and for every later frame check if they're increased. If so, recreate my buffer with a larger size. Unless there is some better option I'm not thinking of...
Old 5th June 2018, 16:27   #4090  |  Link
shekh
I guess you don't have to repeat any pitch for your own buffer, just allocate whatever is sufficient?
VirtualDub2
Old 5th June 2018, 17:05   #4091  |  Link
`Orum
You bring up a good point. As I'm using OpenCL, that probably makes sense in some circumstances; namely, when copying a frame to a discrete GPU for processing. The trick is probably going to be figuring out the best way to perform the copy efficiently, as you either have to map the buffer and memcpy() row-by-row into the mapped buffer and then unmap, or queue each row via separate calls to clEnqueueWriteBuffer(). Neither is pretty, but may still be faster than what I'm doing now (which is copying the memory including the pitch bytes), and would at the very least avoid any reallocation.
However, if processing is done on a CPU or integrated GPU (or really anything with unified memory between host and device), this incurs an additional copy operation, which I'd like to avoid. Fortunately, this can be avoided in these circumstances (and already is in my current code), as when you create a buffer with CL_MEM_USE_HOST_PTR no copying is done anyway—or so I assume. It certainly is faster than an explicit copying of the buffer.
Old 9th June 2018, 10:00   #4092  |  Link
`Orum
On another note, I've noticed what I think is some color shift toward Cb-/Cr- with the ColorYUV(levels="TV->PC") / ColorYUV(levels="PC->TV"). The results look different from what I see with the conversion filters within MPC-HC, and while that means that problem could be in either MPC-HC or AviSynth+, I suspect it's in AviSynth+. Why? Consider the following script:
function s(clip c) {
	return c.ColorYUV(levels="TV->PC").ColorYUV(levels="PC->TV")
ColorBars(pixel_type="YV12")
Interleave(last.s(), last.s().s().s().s().s().s().s().s().s().s().s().s().s().s().s().s()) # Initial clip calls s() once because ColorBars() has some strange levels
ColorYUV(analyze=true)
Yes, it's an extreme example, and while this only proves that the functions are not reciprocal, it shows a clear trend toward green. If someone knows of another way to perform the conversion (I know "levels" is not accurate for chroma planes) to compare it against instead, let me know.
Edit: Animated for those too lazy or unable to run the script on their devices
Old 9th June 2018, 10:56   #4093  |  Link
Is it (in the main) perhaps down to a part of the 'pluge' (think thats what its called) being @ luma value 7 [EDIT: and 242] (ie non TV range).
A=ColorBars(pixel_type="YV12").BicubicResize(480,360)
B=A.ColorYUV(levels="TV->PC")
C=B.ColorYUV(levels="PC->TV")
A=A.ColorYUV(analyze=true)
B=B.ColorYUV(analyze=true)
C=C.ColorYUV(analyze=true)
StackVertical(A,B,C)
First image minimum luma is 7.
EDIT: Did not notice this line,
that would be the pluge 7 [EDIT: and 242] thing I think.
But even with pluge fixed with eg limiter, does exhibit strange behaviour as pin pointed by Orum.
ie like this
ColorBars(pixel_type="YV12").Limiter
Interleave(last, last.s().s().s().s().s().s().s().s().s().s().s().s().s().s().s().s())
Still flickers a helluva lot.
EDIT:
Limiter dont work as required, mod to Levels [EDIT: This is rubbish, dont know why I thought Limiter did not work, it does]
function s(clip c) { return c.ColorYUV(levels="TV->PC").ColorYUV(levels="PC->TV") }
ColorBars(pixel_type="YV12").Bicubicresize(480,360)
Levels(16,1.0,235,16,235,coring=false)  # Limiter dont work as required, results in luma Min = 10, not 16, so use Levels
A=Last
B=last.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s
StackVertical(A.ColorYUV(analyze=true),B.ColorYUV(analyze=true))
EDIT: Only 1 iteration
A=Last
B=last.s                                         #.s.s.s.s.s.s.s.s.s.s.s.s.s.s
Old 9th June 2018, 15:12   #4094  |  Link
Motenai Yoda
Motenai Yoda's Avatar
maybe it's caused by coloryuv levels work as levels(16,1,235,0,255)~levels(0,1,255,16,235)
without maintain chroma planes centered on 128, like a
mergechorma(levels(16,1,235,0,255),levels(16,1,240,0,255)) will do
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 9th June 2018, 20:45   #4095  |  Link
Stereodude
What if you run the test script in 16-bits dithering back to 8-bits at the end instead of running it multiple times in 8-bits? That should point to either rounding errors or perhaps a rounding bias vs. an error in the calculations.
Stereodude is offline   Reply With Quote
Old 9th June 2018, 21:10   #4096  |  Link
poisondeathray
Alternatively, you can use smoothlevels and set the chroma processing to zero
By default, lato set it at 100 (from 0-200) or intermediate
e.g using stainlesss's (enough sssss's ? )test
A=Last
#function s(clip c) { return c.ColorYUV(levels="TV->PC").ColorYUV(levels="PC->TV") }
function s(clip c) { return c.smoothlevels(preset="tv2pc", chroma=0).smoothlevels(preset="pc2tv",chroma=0) }
Old 9th June 2018, 21:25   #4097  |  Link
`Orum
The crux of the issue is I think it happens on a single instance of ColorYUV(levels="TV->PC"), at 8-bit and possibly other depths. I originally noticed it when comparing it to MPC-HC's conversion which I think is accurate.
When you add dithering, I think if anything that would only muddy the waters (as then you wouldn't be sure if the source of any shift was ColorYUV() or ConvertBits()). It would be interesting to know if it affects HBD clips, though I suspect if it does it may take more instances of conversion to get the same amount of error (in terms of relative distance).
Sure you can do that, but aren't chroma planes supposed to be changed when doing TV->PC level conversion? If not one could simply do a MergeChroma() as well...
Old 9th June 2018, 22:26   #4098  |  Link
but aren't chroma planes supposed to be ...
Yes, avoid color shift.
Old 9th June 2018, 22:30   #4099  |  Link
poisondeathray
Maybe. I think that was the reason he chose intermediate as the default setting (chroma is processed intermediate strength). You can leave it default 100, or increase it to 200 , or 0 for YLevels like behaviour. Eitherway, you don't get contamination of greyscale patches with smoothlevels (you can disable dithering too as well) . ie. U=V . So it is a problem with coloryuv
Old 9th June 2018, 23:15   #4100  |  Link
poisondeathray
I took RGB test pattern (0-255), greyscale, R,G,B . ConvertToYV24(matrix="pc.709") , then PC->TV, PC->TV eight times , then back to TV. Dithering is disabled for all . The RGB screenshot used "PC" levels for the original, "REC" for the others (because they were scaled to TV)
"TV" levels means U,V should be limited 16-240, so chroma=100 looks correct at least for the max U,V value
Not only is there a green shift for coloryuv, there are more weird patterns
