Old 6th July 2016, 20:52   #2021  |  Link
pinterf
Originally Posted by Wilbert View Post
Question: what happens when doing for example ConvertToYV12(available options) on a 16/32 bit YUV source? Is that implemented already?
ConvertToYV12/16/24 operates only on 8 bit.
But within bitdepth ConvertTo420 inherited the same functionality as ConvertToYV12. Of course, no 16/32 bit RGB input (yet)
pinterf is offline
Old 6th July 2016, 21:00   #2022  |  Link
pinterf
Basic bitdepth converters are ready and pull requested.
ConvertTo8bit, ConvertTo16bit, ConvertToFloat
No dithering or whatever, plain c, float conversions accept a scale parameter, which is defaulting to 1.0 (0..1.0)
SetFilterMTMode("DEFAULT_MT_MODE", 2)
SetFilterMTMode("lsmashvideosource", 3)
lsmashvideosource("13HoursCUT.mp4", format="YUV420P8")
x=last # 8 bit source test cases
x = x.ConvertToFloat() # 8-32
x = x.ConvertTo16bit() # 32-16
x = x.ConvertToFloat() # 16-32
x = x.ConvertTo8bit()  # 16-8
x = x.ConvertTo16bit() # 8-16
x = x.Crop(0, 140, 0, -140)
x = x.Spline64Resize(900,500)
c8_420 = x.ConvertToYUV420(chromaresample="spline64", chromaOutPlacement = "mpeg2") #chromaInPlacement = "mpeg2",
c8_422 = x.ConvertToYUV422(chromaresample="bilinear") # chromaInPlacement = "mpeg2"
c8_444 = x.ConvertToYUV444()
c8_420_b = c8_444.ConvertToYUV420(chromaresample="point", chromaOutPlacement = "dv")
c8_420 = c8_420.ConvertToYUV444(chromaInPlacement = "mpeg1")
c8_422 = c8_422.ConvertToYUV444()
c8_444 = c8_444.ConvertToYUV444()
c8_420_b = c8_420_b.ConvertToYUV444()
StackHorizontal(StackVertical(c8_420,c8_420_b),StackVertical(c8_422,c8_444))
ConvertTo8bit()
Prefetch(8)
btw, it turned out that Float resizers don't look healty
pinterf is offline
Old 6th July 2016, 21:03   #2023  |  Link
jackoneill
unsigned int
jackoneill's Avatar
feature requests:
1) ConvertToYUV400 (same naming as ConvertYUV444, instead of ConvertToY16/32),
One would expect a format called "YUV4XX" to have three planes. Will this have three planes or will it surprise users by having just one plane?
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline
Old 6th July 2016, 21:12   #2024  |  Link
Wilbert
@Ultim, Pinterf,
Sounds great. Once high bit-depth planar RGB is also supported, it's possible to load and save high bit-depth images using DevIL (sadly DevIL supports only interleaved and not planar RGB formats).
I implemented such a thing a long time ago: https://sourceforge.net/p/avisynth2/patches/6/ At least i got it working
@jackoneill, i see what you mean. I thought it would be a good idea to have a consistent naming of those conversions. I guess better would be ConvertToY400.
Wilbert is offline
Old 6th July 2016, 21:32   #2025  |  Link
ultim
AVS+ Dev
ultim's Avatar
Dah... my two cents: let's just stick to ConvertToY().
AviSynth+
ultim is offline
Old 6th July 2016, 22:54   #2026  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
https://github.com/AviSynth/AviSynth...nvert.cpp#L742
I wouldn't like these conversions
on 8bit to 16bit
dstp0[x] = srcp0[x] << 8;
on 16bit to 8bit
dstp[x] = min((srcp0[x] >> 8) + ((srcp0[x] & 0x00FF) >> 7), 255);
on float to integer
dstp0[x] = static_cast<pixel_t>(srcp0[x] * factor + 0.5f);
I think these are general way.
- on high precision to low precision, rounding is better than truncation because less error.
- bit shift and saturate is easier to optimize than multiplication and division.
my repositories
Chikuzen is offline
Old 7th July 2016, 01:33   #2027  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Why do you post this here? Trying to get your post count up? You already announced it in your own thread.
Is this now becoming a permanent thing that you fill almost every thread on this forum with your random ramblings?
I will try my best to not take these attacks personal and to reduce the opportunities for verbal violence
MysteryX is offline
Old 7th July 2016, 05:10   #2028  |  Link
ultim
AVS+ Dev
ultim's Avatar
on 8bit to 16bit
on 16bit to 8bit
on float to integer
Both of your 16bit <-> 8bit conversions are very wrong.
When going from 8 to 16, you need to map the whole range of 0..225 to 0..65535. In your suggestion, you are simply multiplying by 256. 255x256 is 65280 instead of 65535. You actually need to scale by 257 instead of 256 for correct results, and pinterf is doing it correctly (257=65535/255).
When going down from 16 to 8, you need the reverse: x*255/65535. Unlike when going up, here it is sufficient to just shift by 8 bits for exact reults, because if your input is not a power of 2, your result will be like an integer-truncated division by 256.
Both these conversions from pinterf are correct. There is however an optimization potential he did not make use of when converting up to 16bit. The same upscaling can be done using only simple bit-arithmetic which often takes less machine cycles. If x is an 8-bit number, you can do (x << 8) | x to arrive at the 16-bit range, and this will also give exact results.
You are right about the float->int conversion though, adding 0.5f before the cast would minimize truncation errors.
AviSynth+
ultim is offline
Old 7th July 2016, 07:01   #2029  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
When going from 8 to 16, you need to map the whole range of 0..255 to 0..65535.
It's not the only correct conversion. Actually standarts (BT.709/BT.2020) define another conversion, which uses 2^(n-8) as scaling factor. And so does msdn.
Data is interpreted as having integer (higher 8 bits) and fractional (lower 8 bits) components. And this makes 16.0 and 235.0 (240.0) black and peak values regardless of the bitdepth.
I rememeber when ffmpeg first implemented high bit depth support is also used x >> 8 || x conversion, but it was then corrected.
vivan is offline
Old 7th July 2016, 07:53   #2030  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
I remembered that msdn page, too.
pinterf is correct about down scale to 8bit.
my repositories
Chikuzen is offline
Old 7th July 2016, 08:44   #2031  |  Link
pinterf
They are healthy now.
pinterf is offline
Old 7th July 2016, 08:46   #2032  |  Link
pinterf
This is important.
pinterf is offline
Old 7th July 2016, 08:52   #2033  |  Link
shekh
This is not exact
65404*255/65535 = 254.49 -> rounds to 254
65404>>8 = 255
VirtualDub2
shekh is offline
Old 7th July 2016, 11:44   #2034  |  Link
ultim
AVS+ Dev
ultim's Avatar
Originally Posted by shekh View Post
This is not exact
65404>>8 = 255
"because if your input is not a power of 2, your result will be like an integer-truncated division by 256" ... and not by 257, which is why it is nonsense what I wrote here. You are right, sorry, I don't know what I was thinking.
AviSynth+
ultim is offline
Old 7th July 2016, 11:59   #2035  |  Link
ultim
AVS+ Dev
ultim's Avatar
Ok, I didn't know that the scaling factor here is defined explicitly as 2^n. The boundaries 16-235/240 just come from TV-levels though.
AviSynth+
ultim is offline
Old 7th July 2016, 12:11   #2036  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
btw, I modified RawSource26 to support HDB formats.
Binary
note that this plugin will not work on avs2.6.
my repositories
Chikuzen is offline
Old 7th July 2016, 13:10   #2037  |  Link
LigH
LigH's Avatar
Then maybe it should be called RawSourcePlus instead...
New German Gleitz board
LigH is offline
Old 7th July 2016, 17:15   #2038  |  Link
pinterf
1.) TemporalSoften 16bit/float ready.
Parameter ranges for thresholds and scenechange are unchanged 0-255. They are scaled internally to have the same effect on all bitdepth.
2.) 8->16 bit conversion reverted to p << 8. Let's not reinvent the wheel.
pinterf is offline
Old 7th July 2016, 18:16   #2039  |  Link
ultim
AVS+ Dev
ultim's Avatar
Ok so I got home, and since I know that at least for RGB 16-bit images pixels are scaled to 65535, I wanted to make sure that this 256-factor for YUV is not just some shit from MS. I fired up the bt709 spec, and it's true. While I haven't found a direct mention of how to scale to larger bitdepths (it doesn't define 16bit at all, only 10), it still implies simple power-of-two factors simply from the allowed data ranges in 8- and 10-bits. So I guess we should switch to this scale too. EDIT: Oh, I see pinterf already changed it. Good work :thumbs up:
AviSynth+
ultim is offline
Old 7th July 2016, 18:42   #2040  |  Link
Wilbert
Groucho2004 is right. #2018 has nothing to do with AviSynth+ development. See #1875 for another example of a useless post. I suggest you remove those posts and respect the forum rules a little bit.
Wilbert is offline
