11th January 2005, 11:09 | #81 | Link | ||||
But anyways, if you say you have all options exposed... I'll just shut up |
11th January 2005, 12:25 | #83 | Link | |
stupid
cu Joe ------------------------ freedom is just another word for nothing left to loose |
11th January 2005, 12:44 | #84 | Link |
My most recent mencoder compile uses r88/89 of x264 and I have no idea if r90 fixes your problem in particular.
I did put up r90 x264 commandline and VFW though. Not sure when I will do new mplayer compiles. Last edited by celtic_druid; 11th January 2005 at 12:46. |
11th January 2005, 13:26 | #85 | Link | |||
clueless n00b
There is a GUI that exposes the lavc MPEG-4 encoder (see initial post), though it focuses more on mencoder parameters. I'm an AviSynth -> whatever GUI so I focus purely on codec settings and just use a minimal set of core mencoder switches. Quote:
So, if you like more codec parameters (lavc mpeg-4 only), more mencoder switches, you either prove to me that it'll improve usability, or you wait for next Sunday and add it on your own. Here are a few things I will not do: More codecs (Snow will come, and if mencoder ever gets Theora or Dirac output I'll add those as well but I have no interest in any other codec and XviD already has its own VfW interface) mencoder input switches (different input types, range selections, resizing, filtering, the works) all lavc mpeg-4 settings @akupenguin: are there certain settings you could recommend for a first pass turbo switch?
11th January 2005, 13:41 | #86 | Link | |
stupid
11th January 2005, 13:48 | #87 | Link | |
stupid
11th January 2005, 14:07 | #88 | Link | |
x264 developer
The bug you refer to is probably an issue with ratecontrol. I think I have fixed it, but I'm still running some encodes to make sure I didn't degrade other aspects. |
11th January 2005, 15:07 | #89 | Link | |
stupid
11th January 2005, 15:13 | #90 | Link | |
clueless n00b
11th January 2005, 15:30 | #91 | Link | ||
stupid
11th January 2005, 22:40 | #92 | Link |
clueless n00b
version 0.11 is out.
still no turbo mode for x264 as I don't know which settings can be safely used for a quick first pass. also no queueing yet as this looks like a bit of a challenge if I want to encode job after job rather than write one batch file. However, that means I cannot start the batchfile as I do now (this keeps the command window open so that you can see what's going on and get some stats after encoding). If I redirect stdout, once encoding starts I cannot read line by line as the current line is always overwritten (you see the percentage complete moving up.. always on the same line). I don't quite know yet how I can handle this so if anybody has any ideas, now is the time.
11th January 2005, 23:16 | #93 | Link |
Just One Calorie
Forgive me for replying without having a solid grasp on what you're saying. But here's a thought that might at least be related.
With some command line proggies i've written in the past I send some messages to stdout and others to stderr. That way, I can > the stdout to a file and still view the stderr on the console. or vice versa. So--are there some CRLFs that are getting sent to the wrong io stream, making the console not advance? Once again, I apologize for answering without either understanding your concern or having used the program in question. At a glance it just sounded like maybe this was related and it might spark some thought. Disregard if not. Cheers! |
11th January 2005, 23:22 | #94 | Link | |
clueless n00b
progress - 5% - 1000 frames, fps = 15.07 then at time X + 10 progress - 7% - 1200 frames, fps = 15.07 but, there has been no CRLF in between time X and time X+10, rather the line at time X has been overwritten by the line at time X+10. So, from the program's point of view that's reading lines from the redirected stdout, we're still at the same line. I don't know yet what mencoder sends to stdout and what to stderr.. a quick trial seemed to send everything to stdout. And here's a quick howto for the profiles: Enter a profilename in the text are for the profile dropdown (by default it says "Default"). Press new creates a new profile with the name you typed and all the currently active GUI settings. To change an existing profile, select it, make changes in the GUI, then select another profile from the dropdown. For now, changes to a selected profile are only stored when you change to another profile.. exiting the program will not change anything. I'm also wondering whether after selecting a job (perhaps you've noted, it loads all the job's settings in the GUI), you'd want to make changes, then write those changes back to the job (an automatism as for profiles could probably be irritating, but I could add a button "update job" that would overwrite the settings from the currently selected job with the active GUI settings).
11th January 2005, 23:34 | #95 | Link | |
x264 developer
11th January 2005, 23:48 | #96 | Link |
Just One Calorie
@doom9
OK, and are you trying to intercept the stdout from the encoder and display it yourself in the GUI? If so, consider what akupenguin has said. I don't remember for sure, but I think you may need to use a different IO stream handler that isn't line-based. |
12th January 2005, 01:09 | #97 | Link |
I've found a small issue in the latest version. It's probably easier explained if you see it for yourself - activate the Snow codec, then head over to the 'Snow Codec' tab. Tick Qpel or V4MV and take note of what it does to the command line.
Additionally, is it just me, or when using the ASP codec, by selecting the Macroblock Decision Algorithm as "VHQ" or "RDO", you get an "Option lavcopts: Unknown suboption mbc" error in the command window, upon encoding (using CD's MEncoder dev-CVS-050110-15:31-3.4.2)? However, when using the Default option, the encoding starts as it should. |
12th January 2005, 09:12 | #99 | Link | |
clueless n00b
@paced: I'll check those when I get home.
