26th April 2009, 22:23 | #82 | Link |
Kid for Today
BTW, if more ppl wanna try this player there's a free 5.1 24/96 DVD-A here : http://www.diatonis.com/downloads_dts_ac3.html
it's released under the "Creative Commons" licence terms : http://www.archive.org/details/DIATO...AUDIO_2GB_ISO3 |
30th April 2009, 19:31 | #83 | Link |
Hey Shadson - I came in just to say thanks! I have Creative hardware, but in Vista I am hooped for my DVD-Audio disks. I have an Audigy 2, and an External Audigy 2 NX for my laptop, which does still have XP on it. But anyway, I am really excited about SHAplay, and I will be watching very closely for any updates!
Note: I am getting a crash on 24 bit 192 khz tracks, is this a known bug? PD |
30th April 2009, 21:21 | #84 | Link | |
30th April 2009, 22:13 | #88 | Link | |
Kid for Today
now the doubt start to haunt me, but clearly 24/96 stuff sounds better than CDDA and much better than w/ DirectSound...it sounds identical to ASIO. PS: phew, M-Audio does 24bit MME...I'm saved http://downloads.zdnet.com/abstract.aspx?docid=434277 the wiki infos are not very accurate I'm afraid. Last edited by leeperry; 30th April 2009 at 22:48. |
5th May 2009, 21:19 | #89 | Link |
@leeperry: I'm curious how you direct your sound to use the MME path. Is it just by choosing "WaveOut" as the audio interface to use for PCM sound in ReClock? Or what exactly?
Also, I assume using MME limits it to 2 channels. Correct? --------- A side issue question for Creative DVD-Audio Player owners while we hopefully wait for a new ShaPlay release: I don't get gapless playback (in concerts) when using my Creative DVDA player, but I obtained it many years ago with my Audigy 2 ZS card. Do newer versions of the Creative DVDA Player still fail to play concerts gaplessly? Last edited by puck; 5th May 2009 at 21:21. Reason: clarify |
19th May 2009, 12:17 | #93 | Link | |
3 eyed CRT supporter
Oohh I really like this - it's right up my alley. Sweet. |
19th May 2009, 12:36 | #94 | Link |
I've just bought my first DVD-Audio disc - Talking Heads Remain In Light.
And this player is the only thing I've found which will play it! Thanks Shadson. I'm having a couple of minor issues: 1. Ffdshow just causes ShaPLAY to crash. Yes, Uncompressed is set to All Supported. I really want this to work, as I use ffdshow delay, and I need to upmix 5.0 (from diatonis for instance) to 5.1, as Reclock doesn't seem to load for 5.0. Any ideas anyone? It's the most recent tryouts SVN version. I also want to load Convolver Wrapper/Plugin after ffdshow, but ffdshow is the first step in the chain (as convolver will only accept 32bit, not 24bit, I need it to upconvert.) Basically I want the filter path to be ShaPLAY (MLP decoding) ->Ffdshow (processing delay, upmixing to 5.1, zero pad to 32 bit) -> Convolver (Digital Room Correction) -> Reclock as a WASAPI render - > Perfection 2. Reclock shows an unknown video track and proceeds to resample. Yes, it can be set not to resample, but normally when reclock is used for an audio-only file (say in Zoom Player) it shows no video track, and resampling is automatically disabled. Not sure what's going on there. Big thanks for the player Shadson, it really fills a gaping hole. Mark |
19th May 2009, 21:54 | #95 | Link | |
But most computer systems should be able to use ASIO with ASIO4ALL: http://fileforum.betanews.com/detail...L/1080068068/1 Haven't tried this player yet, but thanks for it! |
20th May 2009, 08:50 | #96 | Link | ||
- your OS (Vista64?) - ffdshow build - extended log from ShaPLAY Quote:
- use dll from yesgrey3 - use ReClock 1.8.4.4 with registry setting 'BypassResampler' In both cases resampling will be turned off for all applications that use ReClock. If you want to disable resampling in ReClock for ShaPLAY only - wait for v0.5, it will be able to turn on/off BypassResample only during ShaPLAY work. |
20th May 2009, 13:46 | #97 | Link |
Ahh....that was you asking about those reg settings in the Reclock forum
- Vista32 - ffdshow tryouts revision 2951 18 may 2009 (2 days old), Uncompressed set to all supported. Actually, ShaPLAY doesn't crash. Ffdshow crashes as it loads. Log here...but not much use: 22:42:57.023 - Next Track: 0-0-0 22:42:57.023 - Got size=602726400... 22:42:57.023 - Filling status bar... 22:42:57.024 - Creating thread... 22:42:57.024 - Starting DVDAStreamWriter 22:42:57.025 - Starting writing WAV-header (WavStream) 22:42:57.025 - Header complete (WavStream) 22:42:57.025 - Starting DVDAStreamWriter loop 22:42:57.026 - Header ready! 22:42:57.026 - Calling first block decoding... 22:42:57.030 - Got first block! 22:42:57.030 - Creating stream... 22:42:57.030 - *** Creating Mem2Stream... 22:42:57.040 - *** Creating Buf1... 22:42:57.040 - *** Creating Buf2... 22:42:57.172 - Creating rdr... 22:42:57.172 - Creating Graph... 22:42:57.172 - Creating GraphBuilder... 22:42:57.177 - Getting mpSource pin... 22:42:57.177 - Adding reader to graph... 22:42:57.177 - Creating 'ffdshow' decoder filter ... Then ffdshow crashes as it loads. Oh, and about the Reclock video stream issue. Yep, I know how to disable resampling. What I'm saying is for some reason a video stream is being detected - hence the resampling. Normally when playing audio only tracks this does not happen - at least on my system it doesn't, using Zoomplayer. I do have a request.....would it be possible to spit out wav files (a single 2 to 6 channel one, for conversion to flac)? DVDAExplorer doesn't work on my DVD-A disc, but ShaPLAY does Oh oh, a Directshow Filter would be nice too Thanks, without your Player I couldn't listen to my DVD-A! Last edited by Mark_A_W; 20th May 2009 at 13:50. |
20th May 2009, 16:10 | #98 | Link |
I tried b2951 in Vista32 SP1 - works as it must. I set 32bit output and mixing to 5.0 (I think it's your case)...
Are you sure that ffdshow version you use is installed and working correctly? Set audio ffdshow as default codec and try to play some files (6ch WAV will be the best test) in WMP or VMC for example. Or in MPC-HC, but disable internal MPC filters for raw audio. If you see the icon of ffdshow and all data on CPU tab is real - I don't know what is going on with you system. I use mostly XP (or MCE2005), but have also Vista 32 and Vista 64 virtual machines for testing. Everywhere ShaPLAY + ffdshow works (but Vista64 wants 32-bit version of ffdshow. May be becouse of 32bit ShaPLAY). Hard to believe you, it can't be May be old DVDAExlorer? ShaPLAY uses sources of DVDAExplorer beta 3 (2008.07.21). Last edited by Shadson; 20th May 2009 at 16:41. |
20th May 2009, 18:40 | #100 | Link | |
dvd-audio |
