Old 8th December 2007, 14:46   #161  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 1.2.1 is available.
Change log:
- Lots of minor bugs fixed
- MediaInfo updated to 0.7.5.5
- Added required software presence check during start-up
- Removed MultiCoreEnc as QuEnc multithread wrapper because of several "Access Violation" error reports
As usual, comments and suggestions are welcome.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 8th December 2007, 15:28   #162  |  Link
buzzqw
HDConvertToX author
thanks for the update!
btw an italian version ??? or possibility to translate string (if you don't know italian )
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 9th December 2007, 15:00   #163  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
BHH
My will is to add the possibility to choose customizable skins and languages (DVDShrink-like)... the only point is when...
However AVStoDVD is opensource and VB6 code is quite modular: any contribute is welcome!
Bye
MrC
AVStoDVD Homepage
Old 9th December 2007, 16:05   #164  |  Link
buzzqw
HDConvertToX author
seems there is some problem downloading the noinstall version
every servers fails..
have you got some problem uploading it ?
BHH
Old 9th December 2007, 17:32   #165  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
SourceForge seems to be a little overloaded this afternoon.
Try Bologna server direct link:
http://garr.dl.sourceforge.net/sourc...1_NoInstall.7z
Italians do it better...
Bye
MrC
AVStoDVD Homepage
Old 9th December 2007, 17:44   #166  |  Link
buzzqw
HDConvertToX author
sorry pal.. but i got no download even from the city at 120km from here
(i have alice .. don't know if could be a problem)
i will wait tomorrow!
thanks anyway
BHH
Old 17th December 2007, 07:36   #167  |  Link
krisso
Chiming in again regarding my subtitle issues. I've only had luck converting an AVI accompanied with SUP subtitles. The issue however is that the subtitles are only partially shown. Say the subtitle is suppose to show something like:
Today is the day that
we will party with AVStoDVD
I will only see the "Today is the day that" part, but only a small portion of the top of each letter. Think cutting the letters in half and only seeing the top half. That is what I'm getting.
Any suggestions on what might be the problem. Also, any chance to support SRT subtitles in the future?
P.S. I'm using the latest AVStoDVD 1.2.1
krisso is offline   Reply With Quote
Old 17th December 2007, 11:59   #168  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@krisso
Could you please send me (avstodvd@gmail.com) the SUP file you are using?
If you want to directly use SRT subs, download AVStoDVD 1.1.3 which is the last supporting txt based subs.
Bye
MrC
AVStoDVD Homepage
Old 28th January 2008, 21:34   #169  |  Link
chaparral
chaparral's Avatar
Hi MrC, donīt know if you remember me(long time,no see...), anyway, iīve passed here just to see what progress made avstodvd and now it seems that i'm a bit out of it...
For example, iīve downloaded last version and i tried with a sample and putted one srt subtitle and when the job became done couldnīt see any subtitles in the movie sample...
Doesnīt avstdvd recognize srt subtitles anymore?
Best regards
chaparral is offline   Reply With Quote
Old 29th January 2008, 13:59   #170  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Best regards
No problem! I have hard time in continuing AVStoDVD development too...
About subtitles: since release 1.2.0 I have removed SRT support, because I have switched from DVDAuthor to MuxMan as authoring cli sw, and MuxMan support only Scenarist Sub Script (*.sst) and IfoEdit Subpicture File (*.sup).
If you have a txt-based subtitle (like SRT format), you have to:
- convert to SUP format (i.e. using SubtitleCreator)
or
- hard encode your SRT using AviSynth's TextSub
or
- go back to AVStoDVD 1.1.3 which is last release supporting txt based subs.
Bye
MrC
AVStoDVD Homepage
Old 30th January 2008, 00:09   #171  |  Link
chaparral
chaparral's Avatar
Thanks for your reply for my question, Mrc...
Now i have a new one, doesnīt avstodvd allow us to add 2 avi files for a conversion at same time? Does we have to previous join them because your program only converts one file?
Old 30th January 2008, 09:32   #172  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD converts only one file at a time. And only one file can go into a DVD structure.
However you can automate the process of converting more "single" files by using the Jobs List feature.
Bye
MrC
AVStoDVD Homepage
Old 9th February 2008, 09:53   #173  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 1.2.2 is available.
Change log:
- Minor bugs fixed
- Added "Half-D1" (352x576 PAL, 352x480 NTSC) to Video Format settings
- Added possibility to change Media Player used to preview output
- Added check on output m2v file FPS before starting DGPulldown
- Added check on output filename. If it exists, a "_1" extension is added
- Added check on DVD disc presence in drive before burning
- Added "DefaultCustomSize" preference in AVStoDVD.ini
- MediaInfo.dll is now required only in AVStoDVD folder (no need to copy it in Windows\System32)
- MediaInfo updated to 0.7.5.6
- QuEnc updated to 0.75Alpha
- HCenc is now feeded by .ini file and not by full command line instructions.
- Removed mscomct2.ocx ActiveX Control from installer package
- CreateInstall Free replaced by NSIS as installer creating software
Bye
MrC
AVStoDVD Homepage
Old 11th February 2008, 05:12   #174  |  Link
wg
First of all thanks for the software, this is the first time I have used it, but I'm having exactly the same problem as some other users namely,I've tried adding subtitles to the converted AVI to DVD, but when playing it back on my DVD player or computer no subtitles show. The option to enable English subtitles is available during playback but they do not show when selected. I used Subtitle Workshop to convert an srt file to sst. Using the latest release of AVStoDVD 1.2.2.
wg is offline   Reply With Quote
Old 11th February 2008, 10:40   #175  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
1. Did you try to use sup instead of sst?
2. Opening DVD structure (VIDEO_TS, AUDIO_TS) with DVD Shrink/ReJig/IfoEdit, can you see subtitles info?
Bye
MrC
AVStoDVD Homepage
Old 11th February 2008, 11:52   #176  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@wg & other user with problems with subs
Very important question: are you sure to have setup correctly video size in Subtitle Creator? Otherwise subs could go outside video frame....
a) Select "Formatting" and then "Video Format". Choose PAL or NTSC depending on your output DVD format
b) Select "Profile" and "Apply Profile". Choose your favorite profile. Be sure to choose 16:9 wide if your video frame widescreen
Bye
MrC
AVStoDVD Homepage
Old 14th February 2008, 09:44   #177  |  Link
rendez2k
rendez2k's Avatar
Just to report, tested 1.2.2 on my new quad core and everything completed perfectly in just over 40mins with HCEnc.
Any chance that HCEnc could be set to be used with the other profiles? I prefer it over QuEnc.
rendez2k is offline   Reply With Quote
Old 14th February 2008, 09:48   #178  |  Link
Filbert
v.122 Run-time error '5' Invalid procedurecall or argument
since installing version 122 I get an AVStoDVD error "Run-time error '5' Invalid procedure call or argument". This doesn't appear the first time AVStoDVD is run, but after the second time.
I tested it on various PC, running XP Professional (german version). It appears on systems I had AVStoDVD running before and on fresh systems. Though, on some PC the error is in english (I think the fresh system), on the others it's in german.
Thanks for any help, Filbert
Filbert is offline   Reply With Quote
Old 14th February 2008, 13:42   #179  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Glad to hear that!
Yes, I am working on CQ prediction to let HCenc encode with 1-pass VBR (aka OPV).
Bye
MrC
AVStoDVD Homepage
Old 14th February 2008, 13:53   #180  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by Filbert View Post
Yes, I know: there is a very silly bug in AVStoDVD.ini reading procedure...
You can avoid the error message following these steps:
- delete AVStoDVD.ini file
- run AVStoDVD
- click on "Settings" and choose your favourite settings (if you will)
- check "Save current settings as default"
- click "OK"
Release 1.2.3 will be out ASAP to fix that bug.
Bye
MrC
AVStoDVD Homepage
[IMG] code is Off
