Old 18th August 2009, 16:56   #9201  |  Link
TinTime
Originally Posted by LeXXuz View Post
Because Nero AC3 Decoder does not allow to process more than one track at a time.
Fair enough. In that case demux the tracks you need except for TrueHD ones - convert them. Multiple libav decodes are ok.
TinTime is offline
Old 18th August 2009, 17:59   #9202  |  Link
BlackJack1
How to disable fixes using AV gaps during eac3to demuxing ts source?
After eac3to finishing job I've got out of sync mkv while ts source is in sync.
Eac3to found 11 gaps and discontinuous in stream.
Only one ts part has problems. Five others w/o
Thx in advance.
BlackJack1 is offline
Old 19th August 2009, 12:45   #9203  |  Link
Fiffy
Originally Posted by Revgen View Post
libav does not support EAC3 (Dolby Digital Plus) 7.1. Only 5.1. It supports 7.1 for Dolby True-HD aka MLP.
You're right, I mixed that up.
AFAIK, there are no 7.1 EAC3 Blu-Rays or HD-DVD's. Discs that use 7.1 are usually Dolby True-HD or DTS-HD.
I am not aware of any either.
Fiffy is offline
Old 19th August 2009, 12:49   #9204  |  Link
Fiffy
Originally Posted by jruggle View Post
Both AC3 and E-AC3 use random noise as part of the decoding process. From the tests I have done so far, the difference between the output of libavcodec and Nero is approx. the same as the difference between using 2 different types of random number generators in the libavcodec decoder. The type of RNG used is not defined in the specification. It even says that the level of the noise, which should be 0.707, can be approximated to 0.5 and still be compliant.
Maybe I'm missing something (haven't looked into the spec in a long time), but as far as I know, an AC3 decoder only uses random noise if dithflag is set in the stream. Apart from that the decoder is deterministic (of course an implementation may still use dithering to reduce the word length for output). I'm sure Dolby takes this into account in the certification process.
Fiffy is offline
Old 19th August 2009, 22:56   #9205  |  Link
jruggle
Yes, and the dithflag is typically set to true for nearly every block. That is the recommendation for encoders, except for blocks where the short block MDCT is used for transients or in other rare cases.
(E-)AC-3 decoding is not deterministic. Selected parts of it are, but certainly not the format as a whole. The specification hints that 24-bit fixed point would be a typical implementation for AC-3, but it is not explicitly required or even suggested. There are 16-bit fixed point tables, and even some hints at 6-bit fixed point for downmixing. For E-AC-3, some floating point tables and calculations are shown, but again it is not stated what the implementation must be. I'm sure Dolby does have some some certification tests and requirements, but those are not publicly available.
jruggle is offline
Old 20th August 2009, 01:15   #9206  |  Link
BLKMGK
Am stuck pulling AC3 out of a claimed TrueHD track, feature list for 3.16 claims it can be done however ->
can extract AC3 stream from Blu-Ray TrueHD/AC3 tracks
. When I attempt this I get an error stating that the audio conversion isn't supported. I am running NO 3rd party plug-ins although I do have Nero7-Ultra just not ever bought the plug-in. Output is as follows ->
D:\Video\eac3to>eac3to x: 1) 2: f:\bunny\bunny-vid.mkv 3: f:\bunny\bunny-ac3 1: f:\bunny\bunny-chap.txt
M2TS, 1 video track, 5 audio tracks, 10 subtitle tracks, 1:37:18, 24p /1.001
1: Chapters, 16 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: TrueHD/AC3, English, 5.1 channels, 48khz
   (embedded: AC3, 5.1 channels, 640kbps, 48khz)
<snip>
This audio conversion is not supported.
Where did I go wrong? I've used eac3to forever and this has me stumped!
Thanks!
P.S. Movie is The House Bunny on BluRay...
BLKMGK is offline
Old 20th August 2009, 01:21   #9207  |  Link
Killroy™
Originally Posted by BLKMGK View Post
Am stuck pulling AC3 out of a claimed TrueHD track, feature list for 3.16 claims it can be done however -> . When I attempt this I get an error stating that the audio conversion isn't supported. I am running NO 3rd party plug-ins although I do have Nero7-Ultra just not ever bought the plug-in. Output is as follows ->
4: TrueHD/AC3, French, 5.1 channels, 48khz
5: AC3, Spanish, 5.1 channels, 640kbps, 48khz
6: TrueHD/AC3, Portuguese, 5.1 channels, 48khz
7: AC3, Thai, 5.1 channels, 640kbps, 48khz
8: Subtitle (PGS), English
9: Subtitle (PGS), English
10: Subtitle (PGS), French
11: Subtitle (PGS), Spanish
12: Subtitle (PGS), Portuguese
13: Subtitle (PGS), Chinese
14: Subtitle (PGS), Chinese
15: Subtitle (PGS), Indonesian
16: Subtitle (PGS), Korean
17: Subtitle (PGS), Thai
Thanks!
3: f:\bunny\bunny-ac3 should be 3: f:\bunny\bunny.ac3 (period, not dash)
Killroy™ is offline
Old 20th August 2009, 01:23   #9208  |  Link
BLKMGK
OMG! Geez, I sat staring at that for freaking ever and read multiple pages here looking to see if this was unique. D'oh!!
Thank you for pointing out the obvious. I'll edit the previous to shorten it up <sigh>
BLKMGK is offline
Old 21st August 2009, 19:14   #9209  |  Link
deathlord
Hi
I have a big problem:
eac3to does not write to my raid array.
When I write to a normal disk, everything is ok. As soon as I write to a raid 5 array (highpoint controller), eac3to becomes extremely slow (essentialy zero).
Can anyone help?
deathlord is offline
Old 21st August 2009, 20:25   #9210  |  Link
hoju3508
24fps subtitle out of sync
I'm trying to re-encode a Blu-ray that's 24fps instead of the usual 23.976fps. Video and audio are fine, but the sub is out of sync.
-slowdown convert 25.000 and 24.000 content to 23.976 fps
Will this option fix my subtitle sync issue? Or will this cause other problems?
-Hoju
hoju3508 is offline
Old 21st August 2009, 22:12   #9211  |  Link
setarip_old
setarip_old's Avatar
@hoju3508
Hi!
That's rather unusual. May I ask the name of the BluRay?
setarip_old is offline
Old 21st August 2009, 22:45   #9212  |  Link
raquete
first time using eac3to with flac-1.2.1-win
log file:
"eac3to v3.16
command line: eac3to RingoWave.wav RingoWave.flac
WAV, 5.1 channels, 0:03:55, 24 bits, 6912kbps, 48khz
Reading WAV...
Encoding FLAC with libFlac...
Creating file "RingoWave.flac"...
The original audio track has a constant bit depth of 24 bits.
eac3to processing took 1 minute, 8 seconds.
Done."
RingoWave.wav : 193Mb
RingoWave.flac : 145Mb
comment:
wave sounds brilliant, .flac result seems dry(opac)
2 questions:
how to get more compression?
as flac is lossless why sounds worse?
raquete is offline
Old 21st August 2009, 23:09   #9213  |  Link
Snowknight26
You don't, eac3to compresses FLAC with the best compression. And yes, it's lossless, so it's just an illusion or your software is altering it on playback.
Snowknight26 is offline
Old 21st August 2009, 23:47   #9214  |  Link
raquete
is the best compression? ok....lol, i need more.
illusion? no, i really can hear (8 speakers, 2 sub-woofers and 6.1 amplifier/decoder here).
but is possible 3 differents softwares altering it on playback?
(VLC media player, adobe audition(in multitrack view), sound forge)
curious: winamp play lots of 5.1 formats(dts, ac3,waves...) but is crashing with this 5.1.flac.
raquete is offline
Old 22nd August 2009, 03:13   #9215  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Originally Posted by raquete View Post
but is possible 3 differents softwares altering it on playback? (VLC media player, adobe audition(in multitrack view), sound forge)
Yes, it is possible (although not probable).
It seems the FLAC plugin was designed to deal with stereo (and mono) files only.
Midzuki is offline
Old 22nd August 2009, 03:27   #9216  |  Link
Thunderbolt8
anyhow possible to use madflac as winamp plugin? like its quality better
Thunderbolt8 is offline
Old 22nd August 2009, 06:51   #9217  |  Link
raquete
yes,...lol
of course i don't blame eac3to for altering the audio result but flac plugin or any other mysterious issue.
after search about madflac features i could not find answers if can be used as winamp plugin.
raquete is offline
Old 22nd August 2009, 12:12   #9218  |  Link
Fiffy
The compression ratio depends heavily on the content. Audio with a high degree of entropy is more difficult to compress. Some extreme cases (white noise) cannot be compressed at all. So try a few other examples.
Fiffy is offline
Old 22nd August 2009, 12:44   #9219  |  Link
raquete
please, take a look in this post from this link in another thread: http://forum.doom9.org/showpost.php?...5&postcount=12
Well, I've just created a 6-channel "test.wav", and by using the "normal"/"well-known" options, I haven't managed to make flac 1.2.0 generate a 24-bit && 88.2 kHz "test.flac".
OTOH, eac3to worked as it should and gave me no HeadAC3hes:
eac3to input.wav output.flac
was done following this recommendations and work very fine!
now look here in the bottom of this other post where i wrote "edit" :
http://forum.doom9.org/showpost.php?...0&postcount=20
now help me to understand the reason of differents sizes in the result.
cheers!
raquete is offline
Old 22nd August 2009, 13:50   #9220  |  Link
qyot27
qyot27's Avatar
My guess is that FLAC's default compression level differs between using the standalone and using it via eac3to (FLAC uses a scale from 0 to 8, with 0 being fastest but largest filesize, and 8 being slower but producing smaller files). That's the only thing I can think of to produce a size difference like that.
If you try compressing other files in both, does roughly the same size difference occur as well? If you recompress the eac3to-generated FLAC in FLAC.exe, does it happen also?
qyot27 is offline
eac3to
