21st June 2007, 20:02 | #341 | Link |
1) Make sure you demux elementary and not PES stream.
2) What's the source of your DD+ m2ts file? Blu-ray DD+ standard is different from HD-DVD. In blu-ray the stream has a regular DD base where all the frames have bsid set to standard syntax and a DD+ extension where the frames have bsid set to enhanced syntax. In HD-DVD DD+ all the frames are set to the enhanced syntax. Can eac3to cope with that? |
22nd June 2007, 09:04 | #345 | Link |
Here's a 10mb sample, box.net won't allow bigger files.
http://www.box.net/shared/a1nphdioh9 |
22nd June 2007, 20:49 | #346 | Link |
I think there's a problem with .ts files that contain aac audio. I have a .ts file with mpeg2 video and aac audio and when I run it through TsRemux to make an .m2ts file, only the video plays. I'm using a ps3 to play these files and it tells you information about the file being played. All that showed up in the info was mpeg2 video. Usually, it also tells you what the audio format is, but this time instead of saying aac audio, it appeared that there was no audio in the file. When I was selecting streams to keep in my output file in TsRemux, the audio showed up as mpeg2 audio, which is wrong. So I think aac audio isn't being handled properly in TsRemux. Hope you can fix this bug! Great work on TsRemux though! |
23rd June 2007, 08:30 | #349 | Link |
Flyboys BD
Has anyone remuxed/demuxed Flyboys BD? The only multi-channel English track is DTS-HD. It doesn't have a DDP or LPCM track to demux. I can use Tsremux to remux the track, but xport 0.96 cannot demux it. I have demuxed other DTS-HD tracks, (Ghost Rider), but this one doesn't seem to work. I even tried from the source m2ts with xport, but could not make it work.
I am happy to post a sample of the DTS-HD track in an m2ts container, but I don't know how to chop a usable section of it. Can someone give me an idea on how to do that? Thanks. |
23rd June 2007, 11:12 | #350 | Link | |
http://www.w6rz.net/head.zip Usage is: head <infile> <outfile> <length> For example: head movie.m2ts clip.m2ts 10000000 Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
23rd June 2007, 11:18 | #351 | Link | |
23rd June 2007, 11:24 | #352 | Link | |
Ron
23rd June 2007, 14:59 | #353 | Link | ||
23rd June 2007, 15:01 | #355 | Link | |
23rd June 2007, 15:09 | #356 | Link | ||
23rd June 2007, 16:33 | #357 | Link | |
23rd June 2007, 17:43 | #358 | Link | |
But I'm wondering: Would a conventional AC3 splitter even be able to find out the correct run length? Normally a splitter probably devides the file size through the bitrate to find out the run length, right? So having additional frames in the stream would confuse the run length calculation, or not? Thanks! |
23rd June 2007, 18:10 | #359 | Link | |
