22nd May 2004, 15:37 | #41 | Link |
Capture, Deinterlace
Manao, this is sick
as some of u might know, i much prefere 50fps playback over 25fps when it comes to video (i.e. live sport events, etc). i usually capture <something>x576 interlaced with ffdshow with some processing thrown in, and i don't re-process my caps as i mainly use it as pvr (playback with ffdshow, deinterlacing using a dscaler filter). now, i tried taking one of my encoded clips (400x576), take one field only, and MVConvertFPS (0.9.2.2) to 50fps, and it's awesome i reduces the threshold a bit (quite a bit), and i truely get a 'video-like' expreience still few glitches here and there, but generally, it rocks. i'm now thinking of using ffdshow to capture, with deinterlacing filter (encode 25fps 'progressive'), and then use MVConvertFPS during playback to record full res at 25fps and playback interpolated 50fps. might save quite some bits during encoding i think. although so far, MVConvertFPS doesn't play good in zoomplayer (both direct avs and through ffdshow with ebmedded avisynth script). vdub plays it well. i don't know what's the cause yet. i'll try to update the thread if i have new conclusions. cheers Manao, great work Last edited by avih; 22nd May 2004 at 15:41. |
24th May 2004, 10:57 | #42 | Link |
While I was playing with motion vectors calculated by SearchMVs I noticed the following problem that sometime makes vectors found in a certain area useless. Suppose you have an object moving in front and near the edge of a very dark static background area. Now suppose that beside that edge there is another static area with the brightness level similar to that of the moving object and that the distance between the object and this similar area is less than displacement of the object between n and n-1 frames. It appears that the vector search algorithm finds this closer background area more similar to the original object than the object itself in n-1 frame so the resulting vectors point from surrounding background to the object, instead from object in n-1 to object in n. Is it possible to do something about it? Perhaps increasing vector search space?
Another question, how is it possible to fetch vectors from higher levels? I'm familiar now to using BlockData class after SearchMVs, but I fail to see how to get field of blocks for higher levels. Manao? EDIT: Fetching higher level vectors solved (I think). Last edited by violao; 24th May 2004 at 11:35. |
24th May 2004, 12:00 | #43 | Link | |||
First, the easy question :
Now, for the other one. There are several reasons that may lead to such results, could you provide a screenshot, it would help determine whether it's a failure of the search algorithm, or something inherent to block matching. For the principle of the search algorithm, there is no such thing as "space search". The multilevel analysis allows to fetch long vectors, while the use of a non exhaustive recursive search ( One Time Search, Diamond Search ) tries to find the local minimum around the best predictor ( either the one from the multilevel analysis, or the motion vector from surrounding blocks ). It you want an exhaustive search, in PlaneOfBlocks::SearchMVs(), replace Quote:
avih : thank you for the kind words. I don't know what's wrong with ZoomPlayer, but if I had to make a guess, I would say it's the DirectShow interface. |
24th May 2004, 14:42 | #44 | Link | |
24th May 2004, 14:52 | #45 | Link |
No, it's given in pixel unit. The search is made for all the vectors whose coordinates don't differ from the best predictor by more than 'radius'.
But be warned, a radius as small as 5 will imply 121 SAD computations by blocks, so it will be slow. |
25th May 2004, 09:04 | #46 | Link | |
Therefore all I need/can do is to supress the filter processing in the area of 'invalid' vectors. Only problem is - how to tell what vectors are invalid? |
25th May 2004, 09:24 | #47 | Link | |
I have implemented two measurement of validity for a vector : the SAD, and what I call 'DifferenceFromNeighbours', which is basically by how much the motion vector is different from motion vectors of the surrounding blocks. So you have to use both of them, but it won't be easy. |
25th May 2004, 09:36 | #48 | Link | |
8 surrounding blocks? Is this a difference between MV length? |
25th May 2004, 10:01 | #49 | Link |
No, not exactly. If the value is high, it means that the motion vector is a singularity ( it doesn't belong here ), because it isn't homogenous with its neighbours. If it was a mere difference of MVLengths, vectors could be very different and the value still be low.
To compute it, you compute the difference between the motion vector and one of its neighbours ( hence you obtain a vector ), you consider its length, and you sum the square of the lengths of difference obtained for all the surrounding blocks. For the moment, I detect scenechanges using only that value, and it works ( not perfectly, I will later use a combination of SAD and this value ). |
25th May 2004, 10:55 | #50 | Link | |
25th May 2004, 11:24 | #51 | Link |
brainless
manao, is it possible, to create a function, that returns a float value of the currently present motion?
i.e. summarizing the vectors lenghts of the largest, moving object? this would help, detecting framedrops, skips and duplications. it also may help setting the fieldorder automatically...
Don't forget the 'c'! Don't PM me for technical support, please. |
25th May 2004, 11:30 | #52 | Link |
violao : you're right, but since it took more time to code, I prefered implement the easy version, i.e. the mean. I'll put that on my TODO list.
scharfi : yes, it's easy, but what do you want exactly ? The mean of the length of the motion vectors ? The median ? If not, what else ? |
25th May 2004, 11:41 | #53 | Link |
brainless
I'll try to explain
imagine a constant horizontal scrolling video. origonal Frames: A B C D E F G H I J K L now, frame F gets dropped: Frames: A B C D E E G H I J K L this means, the (simplified) output of the wished function should be: Frames: A B C D E E G H I J K L output: 1 1 1 1 1 0 1 1 1 1 1 1 another more weird sample: a frame gets dropped, but isn't replaced with is predecessor. It is replaced with any of the previous frames: Frames: A B C D E A G H I J K L output: 1 1 1 1 1-5 1 1 1 1 1 1 as you can see, the dropped frame F gets replaced with A, this means, the output of my wished function should be the (at least) inverse of the previous value. the calculation method of the length of those vectors, seems to be irrelevant for this kind of detection, I think.... What do you think?
25th May 2004, 12:00 | #54 | Link |
Alright, so you need the vector, not its length. It's not hard to do, it will be in the next release. But I wonder if this can't already be done with the Global Motion Compensation tools made by Fizick.
27th May 2004, 14:52 | #55 | Link |
An idea for 2 pass motion compensation process.
Lets assume the source is progressive. 1.upsize the source x2 using some advanced resizer (Smart_resize_filter or Didee's iiP or similar) 2.aplly the best denoiser on the upsized source (don't know which exactly) -the targed is almost perfectly denoised and stabilized (without flickering) picture 3.apply some advanced sharpener filter (VirtualDub MSU Smart Sharpen Filter for example) -the target is to produce an almost extremely contrast picture (looking like synthetic one) 4.run MVTools over that "synthetic" source,calculate needed data and save it in a "1-pass.log" file 5. 2-pass process - run it again over original (not enhanced) source,taking in mind scaling x2 Is it possible in theory ? P.S. I'm not familiar with MVTools yet... Best Regards! |
27th May 2004, 14:57 | #56 | Link |
It's possible in theory. No need to upscale I think ( anyway, MVTools can work at subpel precision ). But it would need be able to export motion vectors to a file, which isn't yet in the TODO list ( but since it interests a lot of people, it will soon get there I think ).
Now, I don't think results will be far better than without preprocessing. |
27th May 2004, 22:00 | #58 | Link |
AviSynth plugger
Vinetu:
For noisy source (also luma flicker, blotch, etc), pre-cleaning must give more regular vectors. But why to write vectors to file? Manao: I stil hope that you will release not only forward, but full backward compensation as general using function. |
27th May 2004, 22:16 | #59 | Link |
I think you can have it by using the following trick :
source.duplicateframe(1).reverse().mvshow(cm = true).reverse() Hence, you'll be able to wait the next release in which it'll be possible. Edit : oh, and the "file" idea : most codec still need two passes to work, that's why I was speaking of outputting it to a file. Anyway, as soon as I defined a structure to store the motion vectors data, it won't matter whether I output it in a file or in an array in order other filters to use it (i.e. client / server as you're doing with depan ) Last edited by Manao; 27th May 2004 at 22:20. |
27th May 2004, 23:22 | #60 | Link | |
improve MVectors detection is to split the input video stream in 2 -one for proccesing and another for MVectors analysis. This second stream could be resized,denoised,sharpened,luma-chroma stabilized and even slightly blured ...I'll try soon if this "preprocessing" can help. So generally there is no need for 2-passes... But now I see another usefull trick : at 1-pass you can load a completely different "reference" file and save MVectors.log and then at 2-pass load the "video" file and procces it in relation to "reference" file... I don't know yet where this could be used,but it's sound intriguing for SpecialFX compositing... Best Regards! |
