Old 1st January 2009, 05:40   #81  |  Link
idbirch2
Although the problem you reported will most likely be fixed, I have to say that you're not particularly clever if you go out buying 1TB hard drives for the sole purpose of using untested homebrew software.
idbirch2 is offline   Reply With Quote
Old 1st January 2009, 09:14   #82  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
@asherungar: yes, three menu files are the last in compilation. Uncheck Move files to avoid this error and delete temp folder after you close multiAVCHD.
multiAVCHD is just a week old and currently under constant changes - it is expected to be unstable.
I'm working on it when I have time, and I believe soon we'll have a nice and clean working build.
Dean
Old 1st January 2009, 10:06   #83  |  Link
asherungar
Thanks dean!!! ill try that.
and i have to say, i have a PS3, a full HD sony bravia 40", and a 1TB External Drive,
This is definitley the MOST PROMISING thread i've seen so far about watching HD movies easily using the above.
thanks for your hard work!!
donations?
asherungar is offline   Reply With Quote
Old 1st January 2009, 12:39   #84  |  Link
asherungar
deank: my "move input movies" was never checekd, so now i did check it and didnt get that error.
i cant test it because im at work..
thanks!
edit: did you remove that check box from build 81? maybe its needed...
Old 1st January 2009, 12:45   #85  |  Link
deank
deank's Avatar
@idbirch2: Can you test again with the new version (build 81+)?
I think I found the problem with messed titles and some other wrong settings.
@asherungar: yes, I removed it. Will enable it again when I find the problem with locked folders/files.
Titles mixup, sequental play and skip top menu are all fixed now... i think...
Dean
Old 1st January 2009, 16:46   #86  |  Link
idbirch2
Dean, I've tried build 81 and it does indeed fix the problem, I can now playback all 3 of the titles I added, great work!
Old 1st January 2009, 16:52   #87  |  Link
deank
deank's Avatar
That's great!
So i'm still trying to create custom menu from scratch - no luck.
Nero Vision 5 won't recognise my generated file if used for menu.
If I play it alone - it says AVC bla bla.. all okay.
If I use it for menu - it says MPEG2 progressive (which is not true).
Here are the files again:
*** [DELETED - 22nd FEB 2009] ***
I can easily see that my output has additional 192 bytes in the header but can't figure out what to do.
If I can accomplish creating this file, then it's just matter of hours to make custom titled motion top menu, and decrease multiAVCHD size to 2MBs Also custom backgrounds, audio background and other exotic things, that most of you will really like.
Soon the interface of the program will be changed completely, following your requests.
Dean
Old 1st January 2009, 20:17   #88  |  Link
Krawhitham
AVCHD standard supports framerates up to 59.94 fps (for 1080p up to 29.97fps) so you don't have to change anything. My PS3 (euro) plays 23.976 and 29.97 fps without problems so I see no reason why your version would not play 25 fps!
OK, I finally got around to burning a disc to try on the PS3 (I'm in North America so I'm NTSC). The disc does not play on the PS3, the system sees it as an AVCHD disc but just has a black screen when I try to play it. The same disc works perfect using PowerDVD on my PC
Krawhitham is offline   Reply With Quote
Old 1st January 2009, 20:39   #89  |  Link
asherungar
So im not the only one with this problem! YEY .. (but sorry to hear it didnt work for you..)
did you get any error messages while creating the project?
Old 1st January 2009, 20:52   #90  |  Link
Krawhitham
just an error about not being able to delete a folder, but at the point the program is finished and just trying to delete its temp files
Old 1st January 2009, 20:54   #91  |  Link
asherungar
I had the same error (see some posts back),
if you check "move input files" under settings the error is gone (or use build 81).
but i havent gotten home yet to check.
Old 1st January 2009, 21:23   #92  |  Link
b66pak
b66pak's Avatar
for twisted reasons $ony dont alow PAL content on NTSC ps3!!! anyway NTSC content play ok on PAL ps3!!!
_
Old 1st January 2009, 21:43   #93  |  Link
asherungar
Thanks!
Old 2nd January 2009, 00:46   #94  |  Link
~bT~
н∂-ƒαиαтι¢
Originally Posted by deank View Post
So, I'll add a drop-down option to select PAL/NTSC menu and it should be fine.
And folder-removal-error will be gone if you update now.
Dean
i think if we stick to just NTSC then it should cater for all (i'm in PAL land btw)
Old 2nd January 2009, 00:48   #95  |  Link
~bT~
н∂-ƒαиαтι¢
_
so does that mean it wont play anything PAL and just not the menus?
Old 2nd January 2009, 01:30   #96  |  Link
odin24
odin24's Avatar
Location: The Great North (the better half of North America)
NTSC PS3s will play 25fps content as m2ts, not as AVCHD or BD. With the latest firmware you can still use the sequential playback option, not as fancy but at least the content will still play.
odin24 is offline   Reply With Quote
Old 2nd January 2009, 13:40   #97  |  Link
asherungar
Yes please!
Old 2nd January 2009, 13:44   #98  |  Link
odin24
odin24's Avatar
I'll try too if you need a second opinion.
Old 2nd January 2009, 14:04   #99  |  Link
~bT~
н∂-ƒαиαтι¢
does the cut option.. cut from each file added or from total files?
Old 2nd January 2009, 14:06   #100  |  Link
deank
deank's Avatar
Cut is used each time MKV is transformed by tsMuxer to avchd folder.
Not very clever of me, duh... I use it for testing purposes
