Old 5th November 2008, 10:22   #701  |  Link
Renzz
Can I make a minor, aesthetic request? Could the server process be made to run in the System Tray? As far as I can see, it doesn't need to be a windowed process and it would be nice to keep it out the way - I do like a tidy desktop
Renzz is offline
Old 5th November 2008, 11:45   #702  |  Link
slip_
Originally Posted by nm View Post
G80 chips don't have VP2, so you'll need to get a new graphics card.
Is this true ??
What Nvidia driver version are you running?
Using version 178.08
slip_ is offline
Old 5th November 2008, 14:04   #703  |  Link
Originally Posted by slip_ View Post
Is this true ??
It's not fully clear to me. I think it may be, as Nvidia just told me that indeed that card does not have the VP2. On the other hand, I think it works for Badaboom and crypto and bob0r have things working with it. E.g.:
http://forum.doom9.org/showthread.ph...74#post1183174
Hopefully they will comment on it, or you could PM them about it.
I have recently upgraded to a 9600GT, and the performance is leaps and bounds above the 8500GT.
Guest is offline
Old 5th November 2008, 14:19   #704  |  Link
Good idea, I'll do that.
Guest is offline
Old 5th November 2008, 14:42   #705  |  Link
nm
bob0r has the 512 MB G92 version of 8800 GTS instead of 320 MB G80.
nm is offline
Old 5th November 2008, 20:06   #706  |  Link
crypto
@DVBPortal
crypto's Avatar
..I think it works for Badaboom and crypto and bob0r have things working with it
I have a 8600 GTS 256MB (not 8800 GTS) and DGAVCDecNV working with it.
I guess DGAVCDecNV does not only need CUDA (which is supported on 8800 GTS) but also a VP2.
The 8600 GTS (G84) has a VP2, the 8800 GTS (G80) not (with the exception of the 512 MB model which has a G92).
Sorry for that.
As I see it, all GPUs since G84 have a VP2 and can be used with DGAVCDecNV.
GeForce 8300 GS
GeForce 8400 GS
GeForce 8500 GT
GeForce 8600 GS
GeForce 8600 GT
GeForce 8600 GTS
GeForce 8800 GS
GeForce 8800 GT
GeForce 8800 GTS 512MB only
All GeForce 9 series
crypto is offline
Old 6th November 2008, 09:32   #707  |  Link
ultratoto14
I have some problems with the CUDA server. I've got 2Go of memory. Windows has 1Go of free memory when the AVS starts. After a while, the Cuda server takes only few megs but windows complains about low memory and want to close only CUDA Server. When i close the server it crashes Firefox. Is it a bad shared memory allocation this is random but it occurs 3 times on 10 encodes.
ultratoto14 is offline
Old 6th November 2008, 13:27   #708  |  Link
There is no dynamic allocation at all in the server. And the shared memory is completely static.
There is a memory sizing issue with 1920-wide clips that I have fixed in my local build. Maybe it's related. I'll release a new version tonight with that fix, minimize to systray, and double rate deinterlacing.
Guest is offline
Old 6th November 2008, 13:31   #709  |  Link
ultratoto14
This is on a 1920 clip. So i wait for it to launch my encode. Thanks again for your work.
Old 6th November 2008, 13:52   #710  |  Link
I also just reviewed the code and I see that I haven't freed the shared memory when the server is closed! So if you've opened and closed it multiple times you may accumulate orphaned memory. I have just now fixed that and will release it tonight.
Guest is offline
Old 7th November 2008, 14:40   #711  |  Link
Sorry, release got delayed by a crisis in transport parsing. Shooting for this evening.
Guest is offline
Old 8th November 2008, 01:09   #712  |  Link
Version 1.0.6
1. Added support for double rate deinterlacing.
2. Released shared memory properly on termination.
3. Fix memory issue causing crash with latest Nvidia drivers.
4. Fix for streams with cropping on the right.
5. Server opens in the system tray.
6. Fix problem with transport streams that have a PES header split between transport packets.
http://neuron2.net/dgavcdecnv/dgavcdecnv.html
Guest is offline
Old 9th November 2008, 20:55   #713  |  Link
ultratoto14
Still have memory problem with the last version. I'm trying to encode Irobot Blu-ray EUROPE version to 8Gb 1080p. There's free memory on my computer even if windows complains there's not. It happens when i launch a compressibility check. @ 77% of compressibility check -> memory crash. I tried to launch directly the encode, it stops working on the first pass a few frame before the end. Just stop serving frames. The Server runs, if i cancel the first pass and tried another script just after, the script get frames. So i think there's something between the client and the server. If you need more infos...
Old 9th November 2008, 21:23   #714  |  Link
What OS are you on?
Can you post a clip that will allow me to duplicate the server hang? For example, cut from the end of the stream.
Guest is offline
Old 9th November 2008, 22:09   #715  |  Link
ultratoto14
I'm on Windows Vista 32 ultimate. I will try to cut a part of the clip to see if it crashes again. Name:  Crash.jpg
Here is what i get sometimes on the server too.
Old 10th November 2008, 00:52   #716  |  Link
I'll install StaxRip if I have to, but you have to give me a stream and a process that I can use to duplicate your issue.
Do these things happen outside of StaxRip too?
Guest is offline
Old 10th November 2008, 18:14   #717  |  Link
ultratoto14
I tried again and the first pass lock at 165020 frame of 165048. I tried to cut out and encode only the 10000 last frames and the encode was not locked. As it seems to lock only on full encode, do you have a debug version of the server to log on my machine(i cannot send you the complete blu-ray ...)
Old 10th November 2008, 18:18   #718  |  Link
Please give me the blu-ray disk details so I can buy it to reproduce your issue.
As a workaround, you can try adding this to your script:
trim(0,165019)
Loss of a second at the end should not be a big deal.
Guest is offline
Old 10th November 2008, 19:46   #719  |  Link
ultratoto14
This is the last thing i will do, i want to help you finding a bug if there's one. Thanks.
Old 10th November 2008, 21:19   #720  |  Link
You won't give me the blu-ray disk details so that I can get it to duplicate your issue?
If you don't give me a link to purchase the blu-ray, there's no way I can help you any further.
Guest is offline
