#2201 | Link | |
Even in this leak there is a discrepancy. In the table there is 10 bit for video but the text says it's 8 bit for video. I'm keen to believe the table in this case but not sure. In the RKL-S slide there is 12 bit AV1, it could be just a mistake (confused with 12 Bit HEVC), it could refer to still image or it could be that the Gen12LP in RKL-S uses a newer decoding unit than TGL-U. |
#2202 | Link |
I think you're misreading a table converted to text. The table says "profile 0 (8-bit and 10-bit 4:2:0) 4k60 video, 16k still (HW decode)". The text says "AV1 codec support<newline>Profile 0 (10-bit 4:2:0)<tab>16k (still picture)<newline>Profile 0 (8-bit 4:2:0)<tab>4k x 2k (video)". I inserted the <tab> because it matches what the table says: 4k60 (4k x 2k) video, 16k still (picture) and each supporting profile 0 (8-bit & 10-bit, 4:2:0).
#2203 | Link | |
Testeur de codecs
You have command line exemple?
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 |
#2205 | Link | |
Testeur de codecs
for exemple.
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 23rd May 2020 at 21:19. |
#2206 | Link |
Dithering should be fine. Does --help include a description for --denoise-noise-level? It might be built without CONFIG_DENOISE (in which case the --help output will be missing also). Otherwise I'm not entirely sure, it has worked fine for me. Does it work on 8-bit material?
#2207 | Link | |
Testeur de codecs
#2209 | Link |
Oh man, the new Cortex X1 CPU core has twice the NEON units of the A78 and previous Axx cores.
At 4x 128 bit units that's some real grunt for an off the shelf design, should be noice for encoding. |
#2210 | Link |
What kind of beast of a computer would you need to play 8k AV1?
I wanted to check out a few 8k videos on Youtube, but I accidentally downloaded AV1 streams, and the videos ate up my R5 1600. Even VP9 did... I wonder if any mere mortal will have such a machine in the next decade. Last edited by mzso; 28th June 2020 at 16:30. |
#2211 | Link |
Beast machine? You used the wrong player!
In my browser it is almost smooth, with some dopped frames In mpv it is perfect with ~ 55% cpu My pc: ryzen 2600 (no oc) + gtx 1070 8K Video: https://www.youtube.com/watch?v=ChOhcHD8fBA
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository |
#2213 | Link |
gtx 1070 does not have a HW AV1 decoder...
And mpv uses the dav1d decoder which works on cpu only.
#2214 | Link |
My 7900X (OC) can also play that video in 8K without drops, at 40% usage at most - straight in Chrome 83. Make sure its not your GPU that struggles downscaling the 8K video.
With Ryzen making 8 cores available to "mere mortals" for relatively low pricing, I don't think you need any particular "beast" right now, nevermind the next decade.
#2215 | Link | |
![]() Join Date: Jan 2006
AV1 is certainly going to be more parallizable than VP9. But how far have the best decoders gone so far? |
#2216 | Link | ||
if there is a AV1 version i could try it with an R7 3700X which could yield up to ~2.5x more performance then a r5 2600 in this special case Quote:
#2217 | Link | |
I think I activated AV1 on YT, it was under /testtube or so. Just google it.
I used youtube-dl.exe to download the video, it was the av1 version. @nevcairiel I use Vivaldi and have currently over 100 tabs open xD It can have an effect on performance Quote:
Over 300fps for 4k is not bad I hope 10bit decoding will be faster on ARM soon too. My 4k fire tv stick struggles with 1080p 10bit video
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository Last edited by ChaosKing; 18th June 2020 at 08:24. |
#2219 | Link | |
They probably will fill out the ARM32 NEON asm over time, though I'm not sure if the performance will match the ARM64 equivalent code path. 10 bit on x86 is another matter entirely - as far as I am aware there are zero SIMD assembly optimisations currently for AVX2, SSSE3 or SSE2 where 10+ bpc video is concerned. |
#2220 | Link | |
The practical problem in ffvp9 is that it decided (to fit in FFmpeg's more static design) to only allow one threading type (frame or tile) instead of multiple concurrently (frame and tile) like dav1d does. That's the only reason dav1d scales better with multi-threading. We could have resolved that, but it was decided that ffvp9 was fast enough and it wasn't worth it. (I can explain libaom's and libvpx' threading models if you want to learn more, but since they are a subset of dav1d/ffvp9, I was assuming this would be enough. I'm not familiar with gav1's threading model.) |
