Old 28th September 2009, 18:43   #1861  |  Link
Jawed
Would demuxing software make a difference? Should I upload the .h264 file that I extract from the MKV? Should I try the .h264 file that you extracted?
I have tried previewing the clip (F5) within DGAVCIndex at full resolution (Display HD Full Sized) and the artefacts also appear there.
Jawed
Jawed is offline
Old 28th September 2009, 19:15   #1862  |  Link
You should upload the source file. Don't make a new MKV out of anything. What did you download and do you have legitimate rights to have it?
See, how can I do that with your sample??? DGAVCIndex does not open MKV.
Finally, post a screenshot showing the artifact.
Guest is offline
Old 28th September 2009, 20:11   #1863  |  Link
Jawed
It's 1.3GB.
I originally made the MKV (from the .h264 extracted from the .flv) in order to extract 10+ seconds out of the source video. The artefacts are the same regardless of whether I muxed or not - and indeed the directshowsource version shows no artefacts, indicating that muxing is irrelevant.
The filename tells you and I already said it came from iPlayer, which provides a 30 days licence to people like me who are UK residents.
I was suggesting that I send you the .h264 that I extracted from the MKV. Or that you send me the .h264 you extracted. But I don't think that's going to lead to a solution anyway...
I made the MKV so that anyone else could compare directshowsource to avcsource with the minimum fuss as well as it being a convenient way to extract a few seconds showing the problem.
See two images here:
http://www.mediafire.com/?3dimyjznn2y
frames 240 and 241.
This is the script used to create the pix:
a=avcsource("Dan_Cruickshanks_Adventures_in_Architecture_-_Pleasure_b00brpqp_default-002_Track1.dga")
b=directshowsource("Dan_Cruickshanks_Adventures_in_Architecture_-_Pleasure_b00brpqp_default-002.mkv")
a=a.crop(400,300,-400,-200,align=true).subtitle("dga")
b=b.crop(400,300,-400,-200,align=true).subtitle("mkv")
stackvertical(a,b)
I'm wondering if this has something to do with the GOPs. I'm not sure if this is the correct interpretation, but in DGIndex when I press the ">" button in the bottom right corner the frame-slider moves in steps and the second step appears to be the start of GOP 3 in this clip. It looks like it might be frame 241, which is the first frame that's artefact-free.
Thanks,
Jawed
Jawed is offline
Old 28th September 2009, 20:43   #1864  |  Link
I can't duplicate it. And those don't look like decoding errors anyway.
Guest is offline
Old 28th September 2009, 21:01   #1865  |  Link
poisondeathray
Those errors are replicated in my testing with DGAVCDec 1.0.9, in frames beginning around 120 or so and ending at 240 (basically the entire zoom in on the black & white picture sequence), and the errors disappear on frame 241
Not present with ffms2() or directshowsource()/dss2() +ffdshow
poisondeathray is offline
Old 28th September 2009, 21:43   #1866  |  Link
Jawed
For what it's worth I'm running an Athlon X2 3500+ and detected SIMD is MMX, SSE MMX, SSE2, SSE FPU, 3D Now!
In general with this entire video I'm noticing that there are "snap changes" in the appearance of the video. I might upload a sample encode of a short sequence that shows this, later (after midnight my time). The comparison encode using DSS has a very slight "snap" change at the same time - much harder to see. I suppose this snap could be the start of a new GOP in the source.
Jawed
Jawed is offline
Old 28th September 2009, 21:55   #1867  |  Link
OK, I see it now. Seems to be caused by the old version of libavcodec that I am using. I cannot upgrade due to newer regressions and so cannot do anything about this.
It works fine with DGAVCDecNV.
Guest is offline
Old 28th September 2009, 22:07   #1868  |  Link
Jawed
Thanks. I'll try FFMS2, never heard of it before (thanks poisondeathray for your report) - just to have something that avoids having to frobnicate FFDShow settings between encoding and viewing conditions.
Jawed
Jawed is offline
Old 28th September 2009, 22:31   #1869  |  Link
poisondeathray
Thanks. I'll try FFMS2, never heard of it before...
Sorry , to be more precise it's ffmpegsource2() or ffvideosource() , "ffms2" is the short name
http://forum.doom9.org/showthread.php?t=127037
http://code.google.com/p/ffmpegsource
Old 28th September 2009, 22:52   #1870  |  Link
Jawed
Thanks, I'd already completed a test encode, which I find preferable (less obnoxious blocking crud and barely noticeable "snap"), and will re-encode Dan Cruickshank's programme...
Jawed
Jawed is offline
Old 5th October 2009, 03:03   #1871  |  Link
medp7060
I just found that there is a huge difference for avcsource and directshowsource. Sample clip is here:
http://rapidshare.com/files/288791896/Flag.rar
In this case, avcsource screwed the clip while directshowsource handled it well. I used DGAVCDec Version 1.0.9.
LoadCplugin("C:\Program Files\AviSynth 2.5\plugins\yadif.dll")
directshowsource("Flag.ts").AssumeTFF
#avcsource("Flag.dga").AssumeTFF
#avcsource("Flag.dga", deblock=false).AssumeTFF
Yadif (order=1)
crop(4,4,706,572).BicubicResize(704,528)
Edited: so either DGAVCDec or avcsource has a bug.
medp7060 is offline
Old 5th October 2009, 04:09   #1872  |  Link
halsboss
likes to tinker
dss2 ? directshowsource was thought to be less reliable than dss2 in some cases depending on source.
halsboss is offline
Old 5th October 2009, 05:22   #1873  |  Link
PAFF is not supported by the early version of libavcodec I use in DGAVCDec, as mentioned in the readme.
The stream is properly handled by DGAVCDecNV.
Guest is offline
Old 5th October 2009, 06:34   #1874  |  Link
medp7060
I see. Unfortunately, I cannot use it because
DGAVCDecNV 1.0.13: GPU decoding on Nvidia
ATTENTION: If you do not use an Nvidia graphics card 8xxx or higher, this thread is not for you!
medp7060 is offline
Old 7th October 2009, 20:11   #1875  |  Link
b66pak
b66pak's Avatar
hi,
beside indexing .h264 streams i use this tool for trimming...how can i see the number of the current frame when i move the slider?
_
b66pak is offline
Old 7th October 2009, 22:37   #1876  |  Link
You can't.
Guest is offline
Old 24th October 2009, 21:03   #1877  |  Link
Thank you for notifying us.
The killer for me is Issue 475.
https://roundup.mplayerhq.hu/roundup/ffmpeg/issue475
I have several files that do this. As upgrading is a big effort, I prefer to wait until this major issue in PAFF support is fixed. Note that after more than 6 months it is still unassigned.
This is now shown as fixed so I will do some testing and if things are OK, I'll try to upgrade to the latest libavcodec, and thereby provide working PAFF support.
Guest is offline
Old 24th October 2009, 21:43   #1878  |  Link
My initial test shows that the blocking issue is fixed!
So I'll make an updated version of DGAVCDec with the latest libavcodec.
Guest is offline
Old 24th October 2009, 22:11   #1879  |  Link
elguaxo
elguaxo's Avatar
elguaxo is offline
Old 25th October 2009, 00:29   #1880  |  Link
hydra3333
Thanks !
hydra3333 is offline
