Old 19th June 2007, 18:14   #401  |  Link
Eragon4ever
lost program in the net
http://ffdshow-tryout.sourceforge.ne...opic.php?t=362
Eragon4ever is offline
Old 19th June 2007, 20:22   #402  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
With gcc you get some assembly optimizations that VC isn't able to compile. But you then have to use gdb to debug it, which is irritating when the VC debugger is so much more powerful.
foxyshadis is offline
Old 20th June 2007, 00:30   #403  |  Link
adrianmak
does DGAVCIndex support h264 stream in mkv container ???
I failed to load mkv in DGAVCIndex.
adrianmak is offline
Old 20th June 2007, 04:26   #404  |  Link
Please read the help file. Thank you.
Guest is offline
Old 25th June 2007, 02:43   #405  |  Link
adrianmak
When I tried to open a raw .h264 file,
dgavcindex crash and maybe it is related to lubavcodec.dll
Old 25th June 2007, 03:09   #406  |  Link
Have you tried any of the remedies discussed here?
Does VLC play the file correctly?
Guest is offline
Old 25th June 2007, 13:56   #407  |  Link
dukey
tried this with some streams i capped from bbc hd
works fine
only problem is
when i demux the audio and video streams
the audio gets miles outa sync
(when you adding .ts support ? )
dukey is offline
Old 25th June 2007, 14:10   #408  |  Link
Originally Posted by dukey View Post
when you adding .ts support?
It is in progress.
What kind of audio is in those streams?
Guest is offline
Old 25th June 2007, 15:21   #409  |  Link
dukey
Audio: PCM (AC3) 48000Hz 6ch 384Kbps [Output]
btw, thanks for your awesome tools :]
dukey is offline
Old 25th June 2007, 16:07   #410  |  Link
I don't know what you mean by PCM (AC3). When you demux do you get an AC3 file?
Guest is offline
Old 25th June 2007, 16:15   #411  |  Link
dukey
thats just what media player classic said the stream was
I think it's just a bog standard AC3 file ..
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71}
subtype: MEDIASUBTYPE_DOLBY_AC3 {E06D802C-DB46-11CF-B4D1-00805F6CBBEA}
formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 1
cbFormat: 18
WAVEFORMATEX:
wFormatTag: 0x0001
nChannels: 6
nSamplesPerSec: 48000
nAvgBytesPerSec: 48000
nBlockAlign: 0
wBitsPerSample: 0
cbSize: 18 (extra bytes)
dukey is offline
Old 25th June 2007, 16:56   #412  |  Link
OK, thanks. I'll start by supporting AC3 first then.
Guest is offline
Old 26th June 2007, 01:23   #413  |  Link
bob0r
Pain and suffering
bob0r's Avatar
AC3 and MP2 are the most common audio in satellite broadcasts, i have seen some HE-AAC test broadcast samples, but thats about it.
As for samples for .ts video/audio my link is still active: http://x264.nl/h.264.samples/
I am no expert in .ts at all, but i helped Haali fix many ts issues by supplying samples.
I do not know anything about .ts theoretical specs or practical specs, but i guess Haali can get you a list of all "tweaks" he had to perform for his splitter(and muxer).
http://haali.cs.msu.ru/mkv some are briefly explained here, some were called "work around".
I have had many H.264 ts files with issues, but ever since the fixes/work arounds no files have failed yet.
These include 99% of all Europe H.264 broadcasts, and some Dish Network (echostar) H.264 broadcasts from abc/nbc/cbs/fox.
bob0r is offline
Old 26th June 2007, 02:13   #414  |  Link
Thank you, I will keep that in mind if I run into any problems.
Guest is offline
Old 26th June 2007, 03:45   #415  |  Link
quantum
Alpha 6 works for me. I have VS 2005 full suite installed. However I'm getting strange coloring problems. The weird colors are displayed in the index viewer and in VirtualDub via AVS file. PowerDVD plays the clip normally.
I will send a link to a sample clip via PM.
Great work by the way. This will be appreciated by many.
quantum is offline
Old 26th June 2007, 13:58   #416  |  Link
klinika
Could you see if the issue is present with alpha 5?
http://neuron2.net/dgavcdec/dgavcdec100a5.zip
klinika is offline
Old 26th June 2007, 14:03   #417  |  Link
It's a libavcodec problem. It won't play right in VLC either.
Guest is offline
Old 26th June 2007, 14:20   #418  |  Link
crapz0rs
neuron2: sent you a pm with an url to a h264 sample from a hddvd.
dgavcdec says it's 29.97 fps (all hddvd are 23.976), and the colours are real strange.
They are normal if cyberlink's decoder is used.
Also sent it to the ffmpeg-dev mailing list.
crapz0rs is offline
Old 27th June 2007, 23:01   #419  |  Link
adrianmak
VLC can play the extracted .h264 file.
I read all posts of this thread and tried other libxxx.dll posted by other members with no success.
DGAVCindex still cash when opening a h264 file. I installed VS 2005 sp1 runtime.
Old 28th June 2007, 02:41   #420  |  Link
Please post a link to the file or a fragment thereof.
Guest is offline
